Upon hot-plugging device (resp. un-plugging host) dwc3_gadget_init()
does nicely get executed. However, for an actual gadget to get started,
it also requires the libusbgx dance as well. Instead of only doing this
upon boot aka after multi-user.target (which is fine only if the device
is already there at boot), execute it after usb-gadget.target. This
ensures dwc3_gadget_start() gets executed also during hot-plugging.
Github no longer allows a plain git protocol.
https://github.blog/2021-09-01-improving-git-protocol-security-github/#no-more-unauthenticated-git
To involve in the following fixes:
1ee53e4 Copy ether_addr structs to avoid union pointer alignment issues
4852080 Delete embedded copies of libtool m4 files
ccba65f Tell git which paths to ignore are directories
3a0f66a Tell git to ignore autotools cruft in the src functions subdirectory
37fcf90 Tell git to ignore generated usbg_version.h header
1e7161d Tell git to ignore the generated cmake config file
b9a5b9c Tell git to ignore the right generated pkg-config .pc file
e972b9e Document that the configfs Linux kernel module needs to be loaded
97b6477 Support printer function
ad378b4 Fix --without-libconfig segment fault on gadget-hid attr setting
67605a0 libusbgx: examples: gadget-vid-pid-remove: fix exit code on success
e0cdec8 Merge pull request #54 from mgrzeschik/gadget-vid-pid-remove
547a759 Merge pull request #55 from mgrzeschik/uvc
52aa5ed libusbgx: Add UVC support
852087a libusbgx: examples: gadget-vid-pid-remove: add dynamic vid pid support
af2292c Fix typo in comment
664b7e6 Added support for CMake projects macros
b5ad66e Fix #39 Compilation fails on gcc v8
283879d libusbgx: fix --without-libconfig build against glibc-2.28
45c14ef libusbgx: fix build with glibc-2.28 since <sys/sysmacros.h> is no more included by <sys/types.h>
6ffbb21 libusbgx: Fix doc build with new doxygen version
dccb4f1 libusbgx: Fix out of tree compilation
especially the fix for:
https://github.com/linux-usb-gadgets/libusbgx/issues/57
Related-to: TEI-924
Signed-off-by: Ming Liu <ming.liu@toradex.com>
It's ${PN}-examples rather than ${PN} should be set in
SYSTEMD_PACKAGES.
Also do some cleaning up:
- Drop deprecated NATIVE_SYSTEMD_SUPPORT.
- Drop ${systemd_unitdir}/system/usbg.service from FILES.
(cherry picked from commit 3966043524aa76454c96903af5e9f73f4cf750e3)
Add the product name at compile time so that we do not need to provide
slightly different copies of the file.
While at it set package arch to machine arch. The packages created are
machine specific due to the g1.schema file.
(cherry picked from commit 3fa96f28bb30643cac3b8a49d3abd7c976acb704)
The update is mostly bugfixing, notably:
This fixes a build error with glibc 2.28.
additionally:
Add support for UAC2 function
Using "10#" to treat the product ID as a decimal value does not
work with the BusyBox shell. Use eval productid + 0 which works
well with bash and BusyBox to convert to a decimal value.
Since the OS Descriptor feature has been reviewed and upstreamed
the USB Gadget library configuration format changed slightly.
Update the configuration files to make sure they work with the
current upstream library version.
The OS descriptor changes have been merged upstream, hence we can
use upstream libusbgx again.
In the Toradex Easy Installer we do not use the example programs
or configuration. Create a separate package for the library and
the example programs and configurations.
So far a generic USB vendor and product ID has been used in the
Toradex specific schema files. However, the startup service wrote a
Toradex specific USB product ID. This lead to the awkward combination
of a generic USB vendor ID and Toradex specific product ID.
Use the Toradex vendor ID by default and do not specify the product ID
since it will get filled in by the usbg service.
This allows to use the same schema for Colibri iMX7 with raw
NAND and eMMC flash.
The Toradex product ID from the config block is decimal coded
ASCII with leading zeros. In C and bash, leading zeros means octal
number... This leads to wrong calculation of the USB product ID
and to errors if the product ID contains the number 8 or 9 (since
those are not valid under the octal numeric system).
Fix both issues by explicitly force decimal system for the Toradex
product ID.
Prevents a warning when not building for one of the machines which have a g1.schema
| WARNING: ...libusbgx/libusbgx_git.bb: Unable to get checksum for libusbgx SRC_URI entry g1.schema: file could not be found
Update libusbgx to a version with OS Descriptor support for better
interoperability with Windows operating systems. Add configuration
using RNDIS with Toradex vendor id. Read serial number and product
id from the device tree to configure the USB gadget device.
libusbgx (libusbg-neXt) is a fork of libusbg which is more actively
maintained.
