2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2013-10-10 | libvpx: configure enable-runtime-cpu-detect | Max Krummenacher | |
- make use of NEON if available, decide at runtime | |||
2013-09-22 | v4l2-utils: removed patch, fixed upstream now | Max Krummenacher | |
2013-09-22 | libvpx: update to 1.1.0 | Max Krummenacher | |
2013-09-22 | libvpx: add qemuarm as a armv6 machine | Max Krummenacher | |
2013-02-06 | v4l-utils: fix for NULL not found erros | Max Krummenacher | |
2013-01-29 | libvpx: use armv6, as our setup does not allow for neon | Max Krummenacher | |
2012-11-19 | libvpx: | Max Krummenacher | |
- don't use neon on t30, as at the moment we don't build anything for neon and the compiler fails. | |||
2012-10-18 | libvpx, T20 does not have neon, but the libvpx assumes armv7a CPU's to have it | Max Krummenacher | |
