On cmdlines with "root=" not at first position the current sed script
fails to only provide the root partitions PARTUUID. Fix that.
Fixes c8651fe ("udev: mount.sh: create a symlink to the partition with
the bootfiles")
Additionally add a word boundary \b before root and simplify sed script.
This prevents nfsroot, extroot matching.
Related-to: ELB-3337
Add to the mount.sh script code which creates a symlink to partition
with the bootfiles if that can be guessed from the rootfs partition.
Scan the /proc/cmdline for the rootfs partition. If this is the second
partition of a block device and a first partition exists it creates
the symlink /dev/boot-part.
/etc/fstab consumes the symlink to mount that at /boot.
oe-core moved the mountpoint used to /run/media/<drive>.
In our setup we don't see issues with /media being read only
when udev starts mounting.
In our environment with graphical desktop udisks will later take over
the automount job and udisks currently still uses /media,
so keep this consistent between mounting at boottime and mounting at runtime.
Refer to openembedded-core commits:
acfe3014d41de5e87cdbc58d0396349c6b9c3ffd
62ae16c40252f39ba28e072218d67f47b26b3535
