ENV{DEVTYPE} has been found to not be present on apalis-imx6 sometimes.
Since we see also some troubles on our lava setup this property is being
removed from this rule as anyway disk and partition is already catched with the
"p" in the KERNEL rule
TEZI uses the same machine colibri-imx7 for both eMMC and NAND
variants of the module. For correct work with Colibri iMX7 eMMC TEZI
requires symlinks emmc* generated by toradex udev rules - it allows
TEZI to unblock boot-partitions for writing operations on start.
The udev "emmc*" rules are triggered by the block instances of the
device usdhc@30b60000. The usdhc@30b60000 device disabled by default
in the device tree for Colibri-iMX7 NAND SoM, so that the "emmc*"
doesn't affect the NAND module.
Adding "emmc*" rules to the 99-toradex.rules for colibri-imx7 machine
fixes several TEZI issues for Colibri iMX7 eMMC, i.e. this one:
Processing blockdev: "mmcblk0boot0"
Running Command: "/usr/sbin/blkdiscard" ("/dev/mmcblk0boot0")
Progress: "Toradex Embedded Linux Reference Minimal Image (UPSTREAM): Erasing partition"
Output: "blkdiscard: /dev/mmcblk0boot0: BLKDISCARD ioctl failed: Operation not permitted\n"
Finished with exit code: 1
Related-to: TEI-851
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This commit does three things:
- Use "-part<number>" instead of "-p" as it is with /dev/emmc symlinks
- Use ENV{DEVTYPE} as it is used with /dev/emmc symlinks to for sure
be able to distinguish partitions vs. disks
- Use %n in stead of $attr{partition} as it is already used for emmc
symlink rules
Create symlinks for each supported by Colibri iMX7/iMX7-eMMC
ADC channels, standardizing names as colibri-ainX, according
to the Colibri signal names table.
Related-to: ELB-2839
(cherry picked from commit f627f20a298d441b5d94ba4ab80a1121065f1f75)
According to the internal document "Hardware interfaces
standardization", the UART interfaces should be accessed
via device nodes named with the module family and matching
the signal name used in the module datasheet.
Modify udev rules for UART devices accordingly.
Related-to: ELB-2787
(cherry picked from commit 2e2be094e62bb61c9e58a115b5d89d5b960eed50)
There are 2 different names for spi use by downstream and upstream
kernel. Fix the udev rules to match both variants.
Related-to: ELB-2784
(cherry picked from commit bbdee96d17e5a69e832197dedc587e45737892be)
This commit adds rules to udev so apalis/colibri or verdin spi
devices are symlinked consistently.
Related-to: ELB-2380, ELB-2598
(cherry picked from commit bd072a5fc62dd7f29a94d682de2346257344ea35)
These rules make sure that a symlink is created for all i2c and tty
devices. This symlinks are named like on the Toradex carrier boards.
This makes it easy to identify which device in software is matching
the hardware pins.
Additional non-standard devices that are not named clearly on the
carrier board are left out to prevent confusion.
(cherry picked from commit 47ef64803548f73a0eda753c5d3d3f7f315af606)
