ENV{DEVTYPE} has been found to not be present on apalis-imx6 sometimes.
Since we see also some troubles on our lava setup this property is being
removed from this rule as anyway disk and partition is already catched with the
"p" in the KERNEL rule
This commit does three things:
- Use "-part<number>" instead of "-p" as it is with /dev/emmc symlinks
- Use ENV{DEVTYPE} as it is used with /dev/emmc symlinks to for sure
be able to distinguish partitions vs. disks
- Use %n in stead of $attr{partition} as it is already used for emmc
symlink rules
ain naming should only be used for colibri boards. Apalis should
use "apalis-adc*" symlinks.
Change KERNELS=="5b010000.usdhc" to KERNELS=="5b010000.mmc", this fixes
a issue that /dev/emmc* device nodes not created after we upgraded to
linux-toradex 5.4 kernel.
Related-to: TOR-1484
Signed-off-by: Ming Liu <ming.liu@toradex.com>
In 5.4 kernel the naming changed from lpspi to spi. Address this in
all i.MX8 udev rules
Create symlinks for each supported by Apalis iMX8 ADC channels,
standardizing names as apalis-adcX, according to the Apalis signal names
table.
Related-to: ELB-2839
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit a98861ebc9d2a26f458a57f674b53cb81405da64)
According to the internal document "Hardware interfaces
standardization", the UART interfaces should be accessed
via device nodes named with the module family and matching
the signal name used in the module datasheet.
Modify udev rules for UART devices accordingly.
Related-to: ELB-2787
(cherry picked from commit 2e2be094e62bb61c9e58a115b5d89d5b960eed50)
This adds udev rules for symlinking eMMC devices consitently.
Related-to: ELB-2380, ELB-2696
(cherry picked from commit ac32e59f1f961070189e1a038644f87ce9e7c152)
This commit adds rules to udev so apalis/colibri or verdin spi
devices are symlinked consistently.
Related-to: ELB-2380, ELB-2598
(cherry picked from commit bd072a5fc62dd7f29a94d682de2346257344ea35)
These rules make sure that a symlink is created for all i2c and tty
devices. This symlinks are named like on the Toradex carrier boards.
This makes it easy to identify which device in software is matching
the hardware pins.
Additional non-standard devices that are not named clearly on the
carrier board are left out to prevent confusion.
(cherry picked from commit 47ef64803548f73a0eda753c5d3d3f7f315af606)
