Toradex NXP layer could be used by other external projects, so we
should make sure Toradex specific changes dont impact them.
Use 'tdx' overrides to ensure Toradex specific changes only valid for
Toradex distros.
Related-to: ELB-3046
Signed-off-by: Ming Liu <ming.liu@toradex.com>
The current default value of 64M may be too much for some of Toradex's
modules, so let's decrease it to 16M.
Related-to: TOR-1780
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Revert in favor of fstab + udev automount.
This reverts commit 2554f4eec62d2cd68dec3d043654874f3b221e63.
Compare with commit 38705bd ("fstab: configure the emmc's first
partition to mount at /boot") in meta-toradex-demos.
Related-to: ELB-3250
Mount Separate FAT Boot Partition to /boot.
Testing:
Mounting Boot partition...
[ OK ] Mounted Boot partition.
root@colibri-imx6:/boot# ls -lah
drwxrwx--- 3 root disk 1.0K Jan 1 1970 .
drwxr-xr-x 18 root root 4.0K Mar 9 2018 ..
-rwxrwx--- 1 root disk 4.7K Nov 29 19:21 boot.scr
-rwxrwx--- 1 root disk 69.0K Nov 29 19:21 imx6dl-colibri-aster.dtb
-rwxrwx--- 1 root disk 71.2K Nov 29 19:21 imx6dl-colibri-cam-eval-v3.dtb
-rwxrwx--- 1 root disk 69.6K Nov 29 19:21 imx6dl-colibri-eval-v3.dtb
-rwxrwx--- 1 root disk 70.2K Nov 29 19:21 imx6dl-colibri-iris-v2.dtb
-rwxrwx--- 1 root disk 69.0K Nov 29 19:21 imx6dl-colibri-iris.dtb
drwxrwx--- 2 root disk 1.5K Nov 29 19:21 overlays
-rwxrwx--- 1 root disk 14 Nov 29 19:21 overlays.txt
-rwxrwx--- 1 root disk 6.2M Nov 29 19:21 zImage
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
the configuration file keeps beeing changed with each version requiring
a refresh of the patch frequently.
Replace the patch with a sed script which should be more stable.
Disable configuration of wired interfaces by systemd-networkd.
Also provide an option which will force to keep ip configuration in case
of critical connection (rootfs mounted via nfs etc.).
Relates-to: ELB-2610
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 02b8668e7f49d163f48e879c51a0d2be34196ab3)
Since oe-core commit 3150253898ba ("systemd-conf: simplify
creation of machine-specific configuration") systemd-conf no
longer unpacks the systemd sources. Hence the patch which patches
units/systemd-udevd.service.in does no longer apply.
Apply the patch in the systemd recipe instead.
The systemd-udevd.service file is only deployed in a package
built from the systemd recipe anyway, hence this also makes sure
that the patched file gets actually deployed.
This essentially reverts commit 118f6b1b17b6 ("systemd: follow
recipe split which added systemd-conf").
Upstream has changes in the context lines.
The patch is not obsolete AFAIKT.
i.e. the configuration file should NOT make mounts by udevd private or
other processes will not be able to see the mount.
This reverts commit 3640a12c85df4ac180e38f19038072df6b1d6d55.
That patch has been merged to systemd-conf.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Or else the changes for systemd-conf recipe will be missed.
The systemd configuration has been split from the systemd recipe.
Thus we need to move our changes to the systemd configuration.
While at it drop the kmod packageconfig. This was only needed with angstrom.
This starts a service which inserts kernel modules on boot.
Updates in meta-angstrom removed this default packageconfig.
Keywords in udevd.service.in were changed upstream.
OE-core dropped to do this for whatever reasons.
Compare with openembedded core, commit 6c1765a05c1321f08f3d1fb521dfe6b07bc8e92
* Drop mount propagation patch, it only happens with libseccomp, OE doesnt
enable it
This reverts commit a8ee603737444c74db61d0a705b08e9a1dea5158.
The patch is forward ported to systemd 234.
The BSP should automount for all users.
The Demo Software Layers cares for RNDIS.
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10.
Remove the backport, is part of fido.
Angstom Dizzy now uses systemd V218 so there is no need to build
a component seperately anymore.
This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
This changes the minimum required Linux version from 3.7 back to 3.0.
[YOCTO #7409]
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
backported from openembedded-core,
commit 31163abc7bedd477c1aad10e6d1f47dbee194513
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c.
recipes-core/systemd/systemd_%.bbappend
Since Connman is better suited for more advanced Wireless solutions,
we keep Connman for the main network configuration manager. However,
for the simple RNDIS debug/test configuration, Connman is not well
suited since Connman tries to maintain one connection only at any
given time.
This change enables networkd and adds a simple standard configuration
for USB/RNDIS network devices.
When the link goes down, the DHCP service has been disabled, while
there is no corresponding functionality which enables the service
when the link goes up again. This fix is taken from systemd 217.
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Patch pending in meta-angstrom
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
