Support booti automatic decompression with the following memory layout:
- loadaddr=0x48200000 allows for 128MB area for uncompressing (ie FIT
images, kernel_comp_addr_r, kernel_comp_size)
- fdt_addr_r = loadaddr + 128MB - allows for 128MB kernel
- scriptaddr = fdt_addr_r + 512KB - allows for 512KB fdt
- ramdisk_addr_r = scriptaddr + 512KB - allows for 512KB script
systemd only prints to the last console= statement that it finds in the
kernel arguments. Make sure that it prints to UART instead of display on
tty1.
Related-to: ELB-4435
The separator of fitImage's config section has been changed from '@' to
'-', let's adapt to that, or else fitImage could not boot.
Related-to: TOR-1700
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Without this commit it could happen, that U-Boot falls into strange
behavior when overlays.txt is missing. This commit fixes this behavior
with only executing "env import" if the previous load command returned
success.
Related-to: ELB-4246
In the nfs-dhcp case we should not pass any NFS related settings from
U-Boot as the Linux kernel will do its very own DHCP request where it
will get all those settings and knows very well how to apply those.
In the nfs-static case we should add a slash in front of the rootpath as
otherwise an additional /tftpboot/ will be pre-fixed which likely is not
what one wants.
https://man7.org/linux/man-pages/man7/bootparam.7.html
'nfsroot=...'
This sets the NFS root name to the given string. If this
string does not begin with '/' or ',' or a digit, then it
is prefixed by '/tftpboot/'. This root name is used in
case of a net boot.
We cant use a single KERNEL_BOOTCMD for both fit/non-fit kernel images,
that makes a invalid bootcmd being used in boot.scr either for fit
or for non-fit image.
Let's change to explicitly use 'bootm' for booting fitimage.
When the kernel image type is fitimage, load it to ${ramdisk_addr_r}
and boot it from there.
A new variable fitconf_fdt_overlays is introduced to collect overlays
boot configs from overlays.txt file, and it would be passed to boot
command.
This flag allows one to skip loading and applying overlay dtbo files,
e.g. in case, these files prevent the system from booting.
Related-to: ELB-3405
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
It is useful to see which devicetree file u-boot loads to boot kernel
with. Print this information.
Use the predefined prefix to overlay files to be loaded.
This significantly reduces the size of the overlays.txt file and
makes this file more readable and understandable by customers.
The kernel is able to use predefined IP address of NFS server.
Add special values of root_devtype "nfs-dhcp" and "nfs-static"
and proceed them accordingly to make the script able to boot the system
from a network without dhcp-server.
To boot the system from the particular server, just set the "serverip"
to the proper IP address of an TFTP/NFS server and set "devtype" to
"tftp".
To use the particular NFS server for mouting the root-fs only, set the
"serverip" to the proper IP address of an NFS server and set
"root_devtype" to "nfs-static".
The design of the script allows to use different sources for booting
a kernel, dtb and overlays, and using as a rootfs.
Using devtype to determine the media of rootfs breaks this ability.
Use root_devtype setting to fix this issue. Note the script is still
able to use the same devtype for both boot/rootfs media because both
boot_devtype and root_devtype set from devtype by default.
Print final bootargs value before jumping to the kernel.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Add error message if booting fails from particular boot source.
1. Move invocation of $setup when $load_cmd is properly set. This
helps to load hdp firmware from all supported boot sources, not
only from internal emmc
2. Set proper dhcpargs if we boot via DHCP
The script uses global variable in tftp and dhcp mode. Add a description
of these variables.
Use root_* incoming variable names where it should be.
The reason we inherit nopackages was that there was no files being
packaged at that moment, but this makes it impossible for a bbappend
to add packages, let's drop it.
Now torizoncore decides to add a ostree-uboot-env package in this
recipe.
Related-to: TOR-1335
This commit was intended as a last-minute fix for apalis-imx8 which
cannot boot because tezi writes the environment faulty.
This commit however also caused to set kernel_image to Image.gz
which is also used on TK1 and there this does not work at all.
This reverts commit 6d6828218c4c4ecea2c44c114a711fe19359b408.
Workaround a Toradex Easy Installer issue causing kernel_image to be
wrongly set to an ancient default.
The second license should be MIT instead of X11. Fix it.
Add an ability to independently set device type, num and partition
for boot and root partitions.
Makes script able to boot kernel via tftp/dhcp.
Provide KERNEL_IMAGE value for boot.scr. Use Image.gz for imx8
machines.
Relates-to: ELB-1372
1. Provide information about kernel image format instead of using
that information from U-Boot env.
2. Unpack kernel image before calling boot cmd, in case
Image.gz is used.
This has been applied to the openembedded-core layer's master and
dunfell branch.
The initial env has been implemented in OE, we dont need maintain this.
Related-to: ELB-2553
- We dont want to store to device when fw_setenv is called and there is
no value change, to avoid flash wear-out.
- We are using symbolic links in /etc/fw_env.config, libubootenv should
handle that.
- u-boot-default-env is being referred by libubootenv, add it to
RRECOMMENDS_${PN}-bin tor target build.
Related-to: ELB-2552
In some situation "for" loop don't alterate the non-empty iteration
variable [1]. Clean up the iteration var at the end of each loop.
[1]
Apalis iMX6 # load ${devtype} ${devnum}:${distro_bootpart} ${loadaddr} ${overlays_file}; env import -t ${loadaddr} ${filesize}
107 bytes read in 11 ms (8.8 KiB/s)
Apalis iMX6 # print fdt_overlays
fdt_overlays="devicetree/apalis-imx6_parallel-rgb_overlay.dtbo devicetree/apalis-imx6_ov5640_overlay.dtbo"
Apalis iMX6 # for overlay_file in ${fdt_overlays}; do echo "file=${overlay_file}"; done
file=devicetree/apalis-imx6_parallel-rgb_overlay.dtbo
{Add clean up}
Apalis iMX6 # for overlay_file in ${fdt_overlays}; do echo "file=${overlay_file}"; setenv overlay_file; done
file=devicetree/apalis-imx6_ov5640_overlay.dtbo"
Related-to: ELB-2797
(cherry picked from commit 94f69ea2545354e2294baecc6c9d54cc89fde97a)
Add support for DT overlays, which are obtained from overlays.txt
stored in bootfs.
Relates-to: ELB-2722
(cherry picked from commit 7b24a04860805abad1a3f5c850ee07fefa6272ac)
Since we already have u-boot-toradex-initial-env.inc file, and no
other recipes are referring u-boot-toradex-env.inc, we could drop it
now.
(cherry picked from commit 79daa8e8a77758b43f758546579a13e8f0f68aa6)
A new virtual recipe u-boot-default-script has been introduced in
meta-freescale-3rdparty and it's being included by WKS_FILE_DEPENDS,
u-boot-distro-boot should PROVIDES it.
Also change to deploy boot.scr-${MACHINE} instead of boot.scr, to be
consistent with other u-boot-default-script recipes.
(cherry picked from commit 3c9ed2641a6317a4fd9db77ecd508d4008cbad74)
(cherry picked from commit 5527f02bfa7c26277688692a8f2c47a423d06cb5)
It should be moved to meta-toradex-torizon layer.
ubifs should be umounted after the uEnv.txt file loading finished.
In 2016.11 U-Boot the MTD partition name which is used in the UBI
distro boot script has been fixed to capital "UBI". In newer U-Boot
this can be configured. With the switch to U-Boot 2019.07 we made
use of that feature to align with the BSP and named the MTD partition
lower case "ubi".
This changes the same in the boot script to make sure Linux looks
for UBI volumes in the correct MTD partition.
Related-to: TOR-237, TOR-513
The bootcmd variable is the entry point for regular boot. If booting
fails for some reason and one saves the environment at this point,
the next boot will no longer use distro boot. Often booting works
since the boot script setup all variables correctly, so one does not
notice that the boot flow has been altered/hard-coded.
Do not reuse bootcmd to avoid accidentally alter the boot flow.
Add pci=nomsi to boot arguments for Apalis iMX8. We cannot safely use
defargs since this variabel contains downstream specific environment
variables which might not work well with upstream kernels as used by
TorizonCore.
Related-to: #52562
Use the distro boot script to load the HDMI firmware. This minimizes
the dependencies to the U-Boot environment and gives more control
to the distribution.
Related-to: #52562
This reverts commit 3ad48d3c8a8fa5a1364450ea101b839140656279.
Running the machine specific setup is not how distro boot should
be used. Also this breaks Colibri iMX7s (and probably Colibri
iMX6ULL) PSCI support. Revert this and fix the firmware loading
issue separately.
Related-to: #52562
setup function needs to be run if it's defined in uboot environment,
for instance, loadhdp is being called in it for apalis-imx8 board.
Some setup functions also take care of setting bootargs, which is safe
for torizon as well if we run setup function before bootcmd_args, since
the later will override the bootargs.
Provide proper PARTUUID value in bootargs.
- Inherit nopackages since it does not generate any non-empty packages.
- Drop do_compile, we can run mkimage directly in do_deploy task.
- Drop 'S = "${WORKDIR}"', we do not have to explicitly set it, the
default S would be good enough.
- Do not install DEPLOYDIR, that is not necessary, it's already done
in deploy.bbclass.
- Do not set noexec flag to do_install, do_populate_sysroot, they are
basically empty tasks, making do_populate_sysroot noexec also will
cause QA warning when u-boot-distro-boot is set to DEPENDS in other
recipes.
This creates a distro boot script boot.scr and deploys it into
the ${DEPLOYDIR}.
Moved here from meta-toradex-torizon u-boot-distro-boot-ostree.
Including u-boot-toradex-initial-env.inc will generate a uEnv.txt
for newer U-Boot versions using U-Boot's u-boot-initial-env
Makfile target. It essential does what u-boot-toradex-env.inc did
before.
Note: Since there is now support for an exported environment in
upstream U-Boot, we should upstream the OE logic to the official
U-Boot too.
Including u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
This is useful for Toradex Easy Installer to write the default
environment using the "u_boot_env" property.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
