path: root/conf
2020-03-21layer.conf: add dunfell, drop thud, warrior in compat layerMax Krummenacher
2019-10-13layer.conf: Add zeus to compatible release seriesMing Liu
Also drop 'sumo' from compatible release series since we have not tested that for a long time, so it's probably not supported any more. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-06-22conf/layer.conf: decrease layer priority to 23Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 88fbe7232ef49a4564de97c0e676a66577986f43)
2019-06-22colibri-pxa.conf: drop machineMax Krummenacher
This machine hasn't been used nor updated in years. The SoM's are discontinued by now. Drop it. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-22tdx_version.conf: removeMax Krummenacher
The default setting is now done in the distro. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-06layer.conf: Add warrior to compatible release serieswarrior-nextMing Liu
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
2019-03-04layer.conf: Add thud to LAYERSERIES_COMPATMax Krummenacher
2019-03-04layer: add LAYERSERIES_COMPATMax Krummenacher
2019-03-04tdx_version: increment thud version to 3.0b1Marcel Ziswiler
2019-03-04tdx_version: increment rocko version to 2.8b6Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-10-09tdx_version: increment rocko version to 2.8b5Marcel Ziswiler
2018-09-27tdx_version: increment rocko version to 2.8b4Marcel Ziswiler
2018-06-18tdx_version: increment rocko version to 2.8b3Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-22tdx_version: add hint to also update Toradex mirror URLStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22tdx_version: increment rocko version to 2.8b2Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tdx_version: add TDX_BUILDNBStefan Agner
TDX_BUILDNB is an optional build number to identify a specific build. This is useful for CI builds. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tdx_version: adapt variable names to versioning reworkMax Krummenacher
The terms external and internal version has been changed to package and item version. Use variable names to reflect that. TDX_VER_EXT -> TDX_VER_PACKAGE TDX_VER_EXT_MIN -> TDX_VER_PACKAGE_MIN TDX_VER_INT -> TDX_VER_ITEM While at it fix spelling in TDX_VER_MINOR (only used within the file). Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22layer.conf: warn only if dangling bbappends are foundMax Krummenacher
With the drop of meta-linaro-toolchain bbappend files without a matching bb file lead to a fatal ERROR. Keep this a warning in our setup. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tdx_version: increment rocko version to 2.8b1Max Krummenacher
2017-11-27tdx_version: increment morty version to 2.7b5Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-04tdx_version.conf: bump version to beta 4Max Krummenacher
2017-10-03image_type_tezi: use standard variables as much as possibleStefan Agner
Use OpenEmbedded standard variables such as PV and DATE as much as possible. This allows to reuse the Tezi image class for non- Toradex images with their own versioning scheme. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30tdx_version.conf: update to 2.7.3 resp. 2.7b3 for Q2 2017 releaseMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-09layer.conf: include correct filename tdx_version.confStefan Agner
2017-06-09layer.conf: export the tdx version variablesMax Krummenacher
2017-04-07tdx_version.conf: add variables to construct the bsp versionMax Krummenacher
0123456789012345678901234567890123456789012345678901234567890123456789 These variables are used to mark the BSP version in U-Boot, the Linux kernel and the final image. Note that some can be overridden from the shell environment, e.g.: export BB_ENV_EXTRAWHITE="$BB_ENV_EXTRAWHITE TDX_VERNIGHTLY" export TDX_VERNIGHTLY="-nightly" Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07layer.conf: add layer dependenciesMax Krummenacher
While at it clean-up and unify with other Toradex layers. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29add layer.confMax Krummenacher
2016-09-29machine conf: remove setting of MACHINE_GUI_CLASSMax Krummenacher
This is only used for choosing a custom logo size. Not needed in our use case. meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-10-28machine Apalis iMX6: deploy Ixora device treesMax Krummenacher
2015-10-28machines iMX6: drop pinning of X-Server versionMax Krummenacher
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-05-18machines: don't pin systemd version anymoreMax Krummenacher
Use systemd V2.18 from meta-angstrom. Issues with firmware loading and the 3.1.10 kernel for the tegra machines are fixed with a backport from oe-core.
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12Apalis/Colibri iMX6 build kernel uImageMax Krummenacher
The default changed to zImage so explicit set uImage for now. While at it cleanup the recipe, remove pci from Colibri machine features.
2015-01-20apalis/colibri-imx6: Fix serial console ttyBhuvanChandra.DV
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B). Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2014-12-11apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1Max Krummenacher
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules
2014-10-30machine: imx6: fix thumb2 arch settingMax Krummenacher
2014-10-30colibri-imx6: add machine definition and burnflashMax Krummenacher
2014-10-30machines: use thumb2 with meta-angstromMax Krummenacher
Angstrom started using thumb2 on machines with armv7-a architectures. This commit removes our override to stay on arm instruction set, so if building our machines with the angstrom distribution you now get thumb2 builds.
2014-10-06systemd: don't pull in systemd 216Max Krummenacher
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
2014-08-04apalis-imx6.conf: specify the devicetree nameMax Krummenacher
2014-08-04machine.conf: xserver: make sure to use machine specificMax Krummenacher
If the package manager finds a version newer than the prefered-version that one gets installed. As we need a specific one for the tegras and for imx6 we change the 'epoch' to something very high.
2014-08-04machine.conf: unify MACHINE_FEATURESMax Krummenacher
unify the features between machines kernel26 is deprecated and unused apm does not make sense on ARM While at it remove some commented stuff
2014-06-12apalis-imx6: remove unneeded variableMax Krummenacher
2014-06-11virtual/kernel: set preferred unconditionalyMax Krummenacher
Be consistent with the other machine recipes Help the autobuilder setup
2014-04-04Revert "cortex-a5.inc: backport from openembedded-core dora branch"Max Krummenacher
File now provided by openembedded-core This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
2014-04-01machines: add colibri-vf, apalis-imx6Max Krummenacher
2014-04-01colibri-vf: use meta-fsl* layer for BSP filesMax Krummenacher
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
