path: root/conf/tdx_version.conf
2019-06-22tdx_version.conf: removeMax Krummenacher
The default setting is now done in the distro. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-04tdx_version: increment thud version to 3.0b1Marcel Ziswiler
2019-03-04tdx_version: increment rocko version to 2.8b6Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-10-09tdx_version: increment rocko version to 2.8b5Marcel Ziswiler
2018-09-27tdx_version: increment rocko version to 2.8b4Marcel Ziswiler
2018-06-18tdx_version: increment rocko version to 2.8b3Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-22tdx_version: add hint to also update Toradex mirror URLStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22tdx_version: increment rocko version to 2.8b2Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tdx_version: add TDX_BUILDNBStefan Agner
TDX_BUILDNB is an optional build number to identify a specific build. This is useful for CI builds. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tdx_version: adapt variable names to versioning reworkMax Krummenacher
The terms external and internal version has been changed to package and item version. Use variable names to reflect that. TDX_VER_EXT -> TDX_VER_PACKAGE TDX_VER_EXT_MIN -> TDX_VER_PACKAGE_MIN TDX_VER_INT -> TDX_VER_ITEM While at it fix spelling in TDX_VER_MINOR (only used within the file). Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tdx_version: increment rocko version to 2.8b1Max Krummenacher
2017-11-27tdx_version: increment morty version to 2.7b5Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-04tdx_version.conf: bump version to beta 4Max Krummenacher
2017-06-30tdx_version.conf: update to 2.7.3 resp. 2.7b3 for Q2 2017 releaseMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-07tdx_version.conf: add variables to construct the bsp versionMax Krummenacher
0123456789012345678901234567890123456789012345678901234567890123456789 These variables are used to mark the BSP version in U-Boot, the Linux kernel and the final image. Note that some can be overridden from the shell environment, e.g.: export BB_ENV_EXTRAWHITE="$BB_ENV_EXTRAWHITE TDX_VERNIGHTLY" export TDX_VERNIGHTLY="-nightly" Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
