This also fixes a compile error against openbox 3.5.2 and later.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
change all recipe which fail out of tree builds to autotools-brokensep
This fixes errors when a second machine is built with the same work
folder:
| autopoint: File config.rpath has been locally modified.
| autopoint: File po/Makefile.in.in has been locally modified.
| autopoint: *** Some files have been locally modified. Not overwriting them because --force has not been specified. For your convenience, you find the local modifications in the file '/tmp/gtf3UV2x/autopoint.diff'.
| autopoint: *** Stop.
| ERROR: autopoint failed
