[ Upstream commit 63e41226afc3f7a044b70325566fa86ac3142538 ]
When a VCPU blocks (WFI) and has programmed the vtimer, we program a
soft timer to expire in the future to wake up the vcpu thread when
appropriate. Because such as wake up involves a vcpu kick, and the
timer expire function can get called from interrupt context, and the
kick may sleep, we have to schedule the kick in the work function.
The work function currently has a warning that gets raised if it turns
out that the timer shouldn't fire when it's run, which was added because
the idea was that in that case the work should never have been cancelled.
However, it turns out that this whole thing is racy and we can get
spurious warnings. The problem is that we clear the armed flag in the
work function, which may run in parallel with the
kvm_timer_unschedule->timer_disarm() call. This results in a possible
situation where the timer_disarm() call does not call
cancel_work_sync(), which effectively synchronizes the completion of the
work function with running the VCPU. As a result, the VCPU thread
proceeds before the work function completees, causing changes to the
timer state such that kvm_timer_should_fire(vcpu) returns false in the
work function.
All we do in the work function is to kick the VCPU, and an occasional
rare extra kick never harmed anyone. Since the race above is extremely
rare, we don't bother checking if the race happens but simply remove the
check and the clearing of the armed flag from the work function.
Reported-by: Matthias Brugger <mbrugger@suse.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 5d6dee80a1e94cc284d03e06d930e60e8d3ecf7d upstream.
At the point where the kvm-vfio pseudo device wants to release its
vfio group reference, we can't always acquire a new reference to make
that happen. The group can be in a state where we wouldn't allow a
new reference to be added. This new helper function allows a caller
to match a file to a group to facilitate this. Given a file and
group, report if they match. Thus the caller needs to already have a
group reference to match to the file. This allows the deletion of a
group without acquiring a new reference.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Tested-by: Eric Auger <eric.auger@redhat.com>
commit ddf42d068f8802de122bb7efdfcb3179336053f1 upstream.
When an interrupt is injected with the HW bit set (indicating that
deactivation should be propagated to the physical distributor),
special care must be taken so that we never mark the corresponding
LR with the Active+Pending state (as the pending state is kept in
the physycal distributor).
Cc: stable@vger.kernel.org
Fixes: 140b086dd197 ("KVM: arm/arm64: vgic-new: Add GICv2 world switch backend")
Reviewed-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Christoffer Dall <cdall@linaro.org>
commit 3d6e77ad1489650afa20da92bb589c8778baa8da upstream.
Fixes: 59529f69f504 ("KVM: arm/arm64: vgic-new: Add GICv3 world switch backend")
commit 90db10434b163e46da413d34db8d0e77404cc645 upstream.
No caller currently checks the return value of
kvm_io_bus_unregister_dev(). This is evil, as all callers silently go on
freeing their device. A stale reference will remain in the io_bus,
getting at least used again, when the iobus gets teared down on
kvm_destroy_vm() - leading to use after free errors.
There is nothing the callers could do, except retrying over and over
again.
So let's simply remove the bus altogether, print an error and make
sure no one can access this broken bus again (returning -ENOMEM on any
attempt to access it).
Fixes: e93f8a0f821e ("KVM: convert io_bus to SRCU")
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: David Hildenbrand <david@redhat.com>
commit df630b8c1e851b5e265dc2ca9c87222e342c093b upstream.
When releasing the bus, let's clear the bus pointers to mark it out. If
any further device unregister happens on this bus, we know that we're
done if we found the bus being released already.
Signed-off-by: Peter Xu <peterx@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 370a0ec1819990f8e2a93df7cc9c0146980ed45f upstream.
Currently, if a vcpu thread tries to change the active state of an
interrupt which is already on the same vcpu's AP list, it will loop
forever. Since the VGIC mmio handler is called after a vcpu has
already synced back the LR state to the struct vgic_irq, we can just
let it proceed safely.
Signed-off-by: Jintack Lim <jintack@cs.columbia.edu>
commit 0bdbf3b071986ba80731203683cf623d5c0cacb1 upstream.
The IRQFD framework calls the architecture dependent function
twice if the corresponding GSI type is edge triggered. For ARM,
the function kvm_set_msi() is getting called twice whenever the
IRQFD receives the event signal. The rest of the code path is
trying to inject the MSI without any validation checks. No need
to call the function vgic_its_inject_msi() second time to avoid
an unnecessary overhead in IRQ queue logic. It also avoids the
possibility of VM seeing the MSI twice.
Simple fix, return -1 if the argument 'level' value is zero.
Signed-off-by: Shanker Donthineni <shankerd@codeaurora.org>
commit 1193e6aeecb36c74c48c7cd0f641acbbed9ddeef upstream.
Dmitry Vyukov reported that the syzkaller fuzzer triggered a
deadlock in the vgic setup code when an error was detected, as
the cleanup code tries to take a lock that is already held by
the setup code.
The fix is to avoid retaking the lock when cleaning up, by
telling the cleanup function that we already hold it.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
We should move the ops->destroy(dev) after the list_del(&dev->vm_node)
so that we don't use "dev" after freeing it.
Fixes: a28ebea2adc4 ("KVM: Protect device ops->create and list_add with kvm->lock")
Reviewed-by: David Hildenbrand <david@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
KVM/ARM updates for v4.9-rc7
- Do not call kvm_notify_acked for PPIs
When we inject a level triggerered interrupt (and unless it
is backed by the physical distributor - timer style), we request
a maintenance interrupt. Part of the processing for that interrupt
is to feed to the rest of KVM (and to the eventfd subsystem) the
information that the interrupt has been EOIed.
But that notification only makes sense for SPIs, and not PPIs
(such as the PMU interrupt). Skip over the notification if
the interrupt is not an SPI.
Cc: stable@vger.kernel.org # 4.7+
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
This was reported by syzkaller:
[ INFO: possible recursive locking detected ]
4.9.0-rc4+ #49 Not tainted
kworker/2:1/5658 is trying to acquire lock:
([ 1644.769018] (&work->work)
[< inline >] list_empty include/linux/compiler.h:243
[<ffffffff8128dd60>] flush_work+0x0/0x660 kernel/workqueue.c:1511
but task is already holding lock:
[<ffffffff812916ab>] process_one_work+0x94b/0x1900 kernel/workqueue.c:2093
stack backtrace:
CPU: 2 PID: 5658 Comm: kworker/2:1 Not tainted 4.9.0-rc4+ #49
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: events async_pf_execute
ffff8800676ff630 ffffffff81c2e46b ffffffff8485b930 ffff88006b1fc480
0000000000000000 ffffffff8485b930 ffff8800676ff7e0 ffffffff81339b27
ffff8800676ff7e8 0000000000000046 ffff88006b1fcce8 ffff88006b1fccf0
Call Trace:
[<ffffffff8128ddf3>] flush_work+0x93/0x660 kernel/workqueue.c:2846
[<ffffffff812954ea>] __cancel_work_timer+0x17a/0x410 kernel/workqueue.c:2916
[<ffffffff81295797>] cancel_work_sync+0x17/0x20 kernel/workqueue.c:2951
[<ffffffff81073037>] kvm_clear_async_pf_completion_queue+0xd7/0x400 virt/kvm/async_pf.c:126
[< inline >] kvm_free_vcpus arch/x86/kvm/x86.c:7841
[<ffffffff810b728d>] kvm_arch_destroy_vm+0x23d/0x620 arch/x86/kvm/x86.c:7946
[< inline >] kvm_destroy_vm virt/kvm/kvm_main.c:731
[<ffffffff8105914e>] kvm_put_kvm+0x40e/0x790 virt/kvm/kvm_main.c:752
[<ffffffff81072b3d>] async_pf_execute+0x23d/0x4f0 virt/kvm/async_pf.c:111
[<ffffffff8129175c>] process_one_work+0x9fc/0x1900 kernel/workqueue.c:2096
[<ffffffff8129274f>] worker_thread+0xef/0x1480 kernel/workqueue.c:2230
[<ffffffff812a5a94>] kthread+0x244/0x2d0 kernel/kthread.c:209
[<ffffffff831f102a>] ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:433
The reason is that kvm_put_kvm is causing the destruction of the VM, but
the page fault is still on the ->queue list. The ->queue list is owned
by the VCPU, not by the work items, so we cannot just add list_del to
the work item.
Instead, use work->vcpu to note async page faults that have been resolved
and will be processed through the done list. There is no need to flush
those.
Cc: Dmitry Vyukov <dvyukov@google.com>
KVM/ARM updates for v4.9-rc6
- Fix handling of the 32bit cycle counter
- Fix cycle counter filtering
KVM calls kvm_pmu_set_counter_event_type() when PMCCFILTR is configured.
But this function can't deals with PMCCFILTR correctly because the evtCount
bits of PMCCFILTR, which is reserved 0, conflits with the SW_INCR event
type of other PMXEVTYPER<n> registers. To fix it, when eventsel == 0, this
function shouldn't return immediately; instead it needs to check further
if select_idx is ARMV8_PMU_CYCLE_IDX.
Another issue is that KVM shouldn't copy the eventsel bits of PMCCFILTER
blindly to attr.config. Instead it ought to convert the request to the
"cpu cycle" event type (i.e. 0x11).
To support this patch and to prevent duplicated definitions, a limited
set of ARMv8 perf event types were relocated from perf_event.c to
asm/perf_event.h.
Cc: stable@vger.kernel.org # 4.6+
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Wei Huang <wei@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
KVM/ARM updates for v4.9-rc4
- Kick the vcpu when a pending interrupt becomes pending again
- Prevent access to invalid interrupt registers
- Invalid TLBs when two vcpus from the same VM share a CPU
Pull KVM updates from Paolo Bonzini:
"One NULL pointer dereference, and two fixes for regressions introduced
during the merge window.
The rest are fixes for MIPS, s390 and nested VMX"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm: x86: Check memopp before dereference (CVE-2016-8630)
kvm: nVMX: VMCLEAR an active shadow VMCS after last use
KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCK
KVM: x86: fix wbinvd_dirty_mask use-after-free
kvm/x86: Show WRMSR data is in hex
kvm: nVMX: Fix kernel panics induced by illegal INVEPT/INVVPID types
KVM: document lock orders
KVM: fix OOPS on flush_work
KVM: s390: Fix STHYI buffer alignment for diag224
KVM: MIPS: Precalculate MMIO load resume PC
KVM: MIPS: Make ERET handle ERL before EXL
KVM: MIPS: Fix lazy user ASID regenerate for SMP
In cases like IPI, we could be queueing an interrupt for a VCPU
that is already running and is not about to exit, because the
VCPU has entered the VM with the interrupt pending and would
not trap on EOI'ing that interrupt. This could result to delays
in interrupt deliveries or even loss of interrupts.
To guarantee prompt interrupt injection, here we have to try to
kick the VCPU.
Signed-off-by: Shih-Wei Li <shihwei@cs.columbia.edu>
In our VGIC implementation we limit the number of SPIs to a number
that the userland application told us. Accordingly we limit the
allocation of memory for virtual IRQs to that number.
However in our MMIO dispatcher we didn't check if we ever access an
IRQ beyond that limit, leading to out-of-bound accesses.
Add a test against the number of allocated SPIs in check_region().
Adjust the VGIC_ADDR_TO_INT macro to avoid an actual division, which
is not implemented on ARM(32).
[maz: cleaned-up original patch]
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The conversion done by commit 3706feacd007 ("KVM: Remove deprecated
create_singlethread_workqueue") is broken. It flushes a single work
item &irqfd->shutdown instead of all of them, and even worse if there
is no irqfd on the list then you get a NULL pointer dereference.
Revert the virt/kvm/eventfd.c part of that patch; to avoid the
deprecated function, just allocate our own workqueue---it does
not even have to be unbound---with alloc_workqueue.
Fixes: 3706feacd007
This patch unexports the low-level __get_user_pages() function.
Recent refactoring of the get_user_pages* functions allow flags to be
passed through get_user_pages() which eliminates the need for access to
this function from its one user, kvm.
We can see that the two calls to get_user_pages() which replace
__get_user_pages() in kvm_main.c are equivalent by examining their call
stacks:
get_user_page_nowait():
get_user_pages(start, 1, flags, page, NULL)
__get_user_pages_locked(current, current->mm, start, 1, page, NULL, NULL,
false, flags | FOLL_TOUCH)
__get_user_pages(current, current->mm, start, 1,
flags | FOLL_TOUCH | FOLL_GET, page, NULL, NULL)
check_user_page_hwpoison():
get_user_pages(addr, 1, flags, NULL, NULL)
__get_user_pages_locked(current, current->mm, addr, 1, NULL, NULL, NULL,
__get_user_pages(current, current->mm, addr, 1, flags | FOLL_TOUCH, NULL,
NULL, NULL)
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
This removes the redundant 'write' and 'force' parameters from
__get_user_pages_unlocked() to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
hence bugs) within the mm subsystem.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into next
KVM/ARM Changes for v4.9
- Various cleanups and removal of redundant code
- Two important fixes for not using an in-kernel irqchip
- A bit of optimizations
- Handle SError exceptions and present them to guests if appropriate
- Proxying of GICV access at EL2 if guest mappings are unsafe
- GICv3 on AArch32 on ARMv8
- Preparations for GICv3 save/restore, including ABI docs
If the vgic hasn't been created and initialized, we shouldn't attempt to
look at its data structures or flush/sync anything to the GIC hardware.
This fixes an issue reported by Alexander Graf when using a userspace
irqchip.
Fixes: 0919e84c0fc1 ("KVM: arm/arm64: vgic-new: Add IRQ sync/flush framework")
Reported-by: Alexander Graf <agraf@suse.de>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
If userspace creates a PMU for the VCPU, but doesn't create an in-kernel
irqchip, then we end up in a nasty path where we try to take an
uninitialized spinlock, which can lead to all sorts of breakages.
Luckily, QEMU always creates the VGIC before the PMU, so we can
establish this as ABI and check for the VGIC in the PMU init stage.
This can be relaxed at a later time if we want to support PMU with a
userspace irqchip.
Cc: Shannon Zhao <shannon.zhao@linaro.org>
This patch allows to build and use vgic-v3 in 32-bit mode.
Unfortunately, it can not be split in several steps without extra
stubs to keep patches independent and bisectable. For instance,
virt/kvm/arm/vgic/vgic-v3.c uses function from vgic-v3-sr.c, handling
access to GICv3 cpu interface from the guest requires vgic_v3.vgic_sre
to be already defined.
It is how support has been done:
* handle SGI requests from the guest
* report configured SRE on access to GICv3 cpu interface from the guest
* required vgic-v3 macros are provided via uapi.h
* static keys are used to select GIC backend
* to make vgic-v3 build KVM_ARM_VGIC_V3 guard is removed along with
the static inlines
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
We have couple of 64-bit registers defined in GICv3 architecture, so
unsigned long accesses to these registers will only access a single
32-bit part of that regitser. On the other hand these registers can't
be accessed as 64-bit with a single instruction like ldrd/strd or
ldmia/stmia if we run a 32-bit host because KVM does not support
access to MMIO space done by these instructions.
It means that a 32-bit guest accesses these registers in 32-bit
chunks, so the only thing we need to do is to ensure that
extract_bytes() always takes 64-bit data.
Well, this patch is looking ahead of time, but we'll get following
compiler warnings as soon as we introduce vgic-v3 to 32-bit world
CC arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.o
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c: In function 'vgic_mmio_read_v3r_typer':
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:184:35: warning: left shift count >= width of type [-Wshift-count-overflow]
value = (mpidr & GENMASK(23, 0)) << 32;
In file included from ./include/linux/kernel.h:10:0,
from ./include/asm-generic/bug.h:13,
from ./arch/arm/include/asm/bug.h:59,
from ./include/linux/bug.h:4,
from ./include/linux/io.h:23,
from ./arch/arm/include/asm/arch_gicv3.h:23,
from ./include/linux/irqchip/arm-gic-v3.h:411,
from arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:14:
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c: In function 'vgic_v3_dispatch_sgi':
./include/linux/bitops.h:6:24: warning: left shift count >= width of type [-Wshift-count-overflow]
#define BIT(nr) (1UL << (nr))
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:614:20: note: in expansion of macro 'BIT'
broadcast = reg & BIT(ICC_SGI1R_IRQ_ROUTING_MODE_BIT);
Let's fix them now.
By now ITS code guarded with KVM_ARM_VGIC_V3 config option which was
introduced to hide everything specific to vgic-v3 from 32-bit world.
We are going to support vgic-v3 in 32-bit world and KVM_ARM_VGIC_V3
will gone, but we don't have support for ITS there yet and we need to
continue keeping ITS away.
Introduce the new config option to prevent ITS code being build in
32-bit mode when support for vgic-v3 is done.
So we can reuse the code under arch/arm
Currently GIC backend is selected via alternative framework and this
is fine. We are going to introduce vgic-v3 to 32-bit world and there
we don't have patching framework in hand, so we can either check
support for GICv3 every time we need to choose which backend to use or
try to optimise it by using static keys. The later looks quite
promising because we can share logic involved in selecting GIC backend
between architectures if both uses static keys.
This patch moves arm64 from alternative to static keys framework for
selecting GIC backend. For that we embed static key into vgic_global
and enable the key during vgic initialisation based on what has
already been exposed by the host GIC driver.
This commit adds the ability for archs to export
per-vcpu information via a new per-vcpu dir in
the VM's debugfs directory.
If kvm_arch_has_vcpu_debugfs() returns true, then KVM
will create a vcpu dir for each vCPU in the VM's
debugfs directory. Then kvm_arch_create_vcpu_debugfs()
is responsible for populating each vcpu directory
with arch specific entries.
The per-vcpu path in debugfs will look like:
/sys/kernel/debug/kvm/29162-10/vcpu0
/sys/kernel/debug/kvm/29162-10/vcpu1
This is all arch specific for now because the only
user of this interface (x86) wants to export x86-specific
per-vcpu information to user-space.
Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com>
This make it possible to call kvm_destroy_vm_debugfs() from
kvm_create_vm_debugfs() in error conditions.
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc into HEAD
Paul Mackerras writes:
The highlights are:
* Reduced latency for interrupts from PCI pass-through devices, from
Suresh Warrier and me.
* Halt-polling implementation from Suraj Jitindar Singh.
* 64-bit VCPU statistics, also from Suraj.
* Various other minor fixes and improvements.
Remove two unnecessary labels now that kvm_timer_hyp_init is not
creating its own workqueue anymore.
If, when proxying a GICV access at EL2, we detect that the guest is
doing something silly, report an EL1 SError instead ofgnoring the
access.
So far, we've been disabling KVM on systems where the GICV region couldn't
be safely given to a guest. Now that we're able to handle this access
safely by emulating it in HYP, we can enable this feature when we detect
an unsafe configuration.
Now that we have the necessary infrastructure to handle MMIO accesses
in HYP, perform the GICV access on behalf of the guest. This requires
checking that the access is strictly 32bit, properly aligned, and
falls within the expected range.
When all condition are satisfied, we perform the access and tell
the rest of the HYP code that the instruction has been correctly
emulated.
In order to efficiently perform the GICV access on behalf of the
guest, we need to be able to avoid going back all the way to
the host kernel.
For this, we introduce a new hook in the world switch code,
conveniently placed just after populating the fault info.
At that point, we only have saved/restored the GP registers,
and we can quickly perform all the required checks (data abort,
translation fault, valid faulting syndrome, not an external
abort, not a PTW).
Coming back from the emulation code, we need to skip the emulated
instruction. This involves an additional bit of save/restore in
order to be able to access the guest's PC (and possibly CPSR if
this is a 32bit guest).
At this stage, no emulation code is provided.
As we plan to do some emulation at HYP, let's make kvm_skip_instr32
as part of the hyp_text section. This doesn't preclude the kernel
from using it.
Add the bit of glue and const-ification that is required to use
the code inherited from the arm64 port, and move over to it.
It would make some sense to share the conditional execution code
between 32 and 64bit. In order to achieve this, let's move that
code to virt/kvm/arm/aarch32.c. While we're at it, drop a
superfluous BUG_ON() that wasn't that useful.
Following patches will migrate the 32bit port to that code base.
As kvm_set_routing_entry() was changing prototype between 4.7 and 4.8,
an ugly hack was put in place in order to survive both building in
-next and the merge window.
Now that everything has been merged, let's dump the compatibility
hack for good.
Just a rename so we can implement a v3-specific function later.
We take the chance to get rid of the V2/V3 ops comments as well.
No functional change.
As we are about to deal with multiple data types and situations where
the vgic should not be initialized when doing userspace accesses on the
register attributes, factor out the functionality of
vgic_attr_regs_access into smaller bits which can be reused by a new
function later.
vms and vcpus have statistics associated with them which can be viewed
within the debugfs. Currently it is assumed within the vcpu_stat_get() and
vm_stat_get() functions that all of these statistics are represented as
u32s, however the next patch adds some u64 vcpu statistics.
Change all vcpu statistics to u64 and modify vcpu_stat_get() accordingly.
Since vcpu statistics are per vcpu, they will only be updated by a single
vcpu at a time so this shouldn't present a problem on 32-bit machines
which can't atomically increment 64-bit numbers. However vm statistics
could potentially be updated by multiple vcpus from that vm at a time.
To avoid the overhead of atomics make all vm statistics ulong such that
they are 64-bit on 64-bit systems where they can be atomically incremented
and are 32-bit on 32-bit systems which may not be able to atomically
increment 64-bit numbers. Modify vm_stat_get() to expect ulongs.
Signed-off-by: Suraj Jitindar Singh <sjitindarsingh@gmail.com>
Reviewed-by: David Matlack <dmatlack@google.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
The workqueue "irqfd_cleanup_wq" queues a single work item
&irqfd->shutdown and hence doesn't require ordering. It is a host-wide
workqueue for issuing deferred shutdown requests aggregated from all
vm* instances. It is not being used on a memory reclaim path.
Hence, it has been converted to use system_wq.
The work item has been flushed in kvm_irqfd_release().
The workqueue "wqueue" queues a single work item &timer->expired
and hence doesn't require ordering. Also, it is not being used on
a memory reclaim path. Hence, it has been converted to use system_wq.
System workqueues have been able to handle high level of concurrency
for a long time now and hence it's not required to have a singlethreaded
workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue
created with create_singlethread_workqueue(), system_wq allows multiple
work items to overlap executions even on the same CPU; however, a
per-cpu workqueue doesn't have any CPU locality or global ordering
guarantee unless the target CPU is explicitly specified and thus the
increase of local concurrency shouldn't make any difference.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
KVM/ARM Fixes for v4.8-rc3
This tag contains the following fixes on top of v4.8-rc1:
- ITS init issues
- ITS error handling issues
- ITS IRQ leakage fix
- Plug a couple of ITS race conditions
- An erratum workaround for timers
- Some removal of misleading use of errors and comments
- A fix for GICv3 on 32-bit guests
Similarily to f005bd7e3b84 ("clocksource/arm_arch_timer: Force
per-CPU interrupt to be level-triggered"), make sure we can
survive an interrupt that has been misconfigured as edge-triggered
by forcing it to be level-triggered (active low is assumed, but
the GIC doesn't really care whether this is high or low).
Hopefully, the amount of shouting in the kernel log will convince
the user to do something about their firmware.
When a guest wants to map a device-ID/event-ID combination that is
already mapped, we may end up in a situation where an LPI is never
"put", thus never being freed.
Since the GICv3 spec says that mapping an already mapped LPI is
UNPREDICTABLE, lets just bail out early in this situation to avoid
any potential leaks.
