[ Upstream commit 63e41226afc3f7a044b70325566fa86ac3142538 ]
When a VCPU blocks (WFI) and has programmed the vtimer, we program a
soft timer to expire in the future to wake up the vcpu thread when
appropriate. Because such as wake up involves a vcpu kick, and the
timer expire function can get called from interrupt context, and the
kick may sleep, we have to schedule the kick in the work function.
The work function currently has a warning that gets raised if it turns
out that the timer shouldn't fire when it's run, which was added because
the idea was that in that case the work should never have been cancelled.
However, it turns out that this whole thing is racy and we can get
spurious warnings. The problem is that we clear the armed flag in the
work function, which may run in parallel with the
kvm_timer_unschedule->timer_disarm() call. This results in a possible
situation where the timer_disarm() call does not call
cancel_work_sync(), which effectively synchronizes the completion of the
work function with running the VCPU. As a result, the VCPU thread
proceeds before the work function completees, causing changes to the
timer state such that kvm_timer_should_fire(vcpu) returns false in the
work function.
All we do in the work function is to kick the VCPU, and an occasional
rare extra kick never harmed anyone. Since the race above is extremely
rare, we don't bother checking if the race happens but simply remove the
check and the clearing of the armed flag from the work function.
Reported-by: Matthias Brugger <mbrugger@suse.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit ddf42d068f8802de122bb7efdfcb3179336053f1 upstream.
When an interrupt is injected with the HW bit set (indicating that
deactivation should be propagated to the physical distributor),
special care must be taken so that we never mark the corresponding
LR with the Active+Pending state (as the pending state is kept in
the physycal distributor).
Cc: stable@vger.kernel.org
Fixes: 140b086dd197 ("KVM: arm/arm64: vgic-new: Add GICv2 world switch backend")
Reviewed-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Christoffer Dall <cdall@linaro.org>
commit 3d6e77ad1489650afa20da92bb589c8778baa8da upstream.
Fixes: 59529f69f504 ("KVM: arm/arm64: vgic-new: Add GICv3 world switch backend")
commit 370a0ec1819990f8e2a93df7cc9c0146980ed45f upstream.
Currently, if a vcpu thread tries to change the active state of an
interrupt which is already on the same vcpu's AP list, it will loop
forever. Since the VGIC mmio handler is called after a vcpu has
already synced back the LR state to the struct vgic_irq, we can just
let it proceed safely.
Signed-off-by: Jintack Lim <jintack@cs.columbia.edu>
commit 0bdbf3b071986ba80731203683cf623d5c0cacb1 upstream.
The IRQFD framework calls the architecture dependent function
twice if the corresponding GSI type is edge triggered. For ARM,
the function kvm_set_msi() is getting called twice whenever the
IRQFD receives the event signal. The rest of the code path is
trying to inject the MSI without any validation checks. No need
to call the function vgic_its_inject_msi() second time to avoid
an unnecessary overhead in IRQ queue logic. It also avoids the
possibility of VM seeing the MSI twice.
Simple fix, return -1 if the argument 'level' value is zero.
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Signed-off-by: Shanker Donthineni <shankerd@codeaurora.org>
commit 1193e6aeecb36c74c48c7cd0f641acbbed9ddeef upstream.
Dmitry Vyukov reported that the syzkaller fuzzer triggered a
deadlock in the vgic setup code when an error was detected, as
the cleanup code tries to take a lock that is already held by
the setup code.
The fix is to avoid retaking the lock when cleaning up, by
telling the cleanup function that we already hold it.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
When we inject a level triggerered interrupt (and unless it
is backed by the physical distributor - timer style), we request
a maintenance interrupt. Part of the processing for that interrupt
is to feed to the rest of KVM (and to the eventfd subsystem) the
information that the interrupt has been EOIed.
But that notification only makes sense for SPIs, and not PPIs
(such as the PMU interrupt). Skip over the notification if
the interrupt is not an SPI.
Cc: stable@vger.kernel.org # 4.7+
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
KVM calls kvm_pmu_set_counter_event_type() when PMCCFILTR is configured.
But this function can't deals with PMCCFILTR correctly because the evtCount
bits of PMCCFILTR, which is reserved 0, conflits with the SW_INCR event
type of other PMXEVTYPER<n> registers. To fix it, when eventsel == 0, this
function shouldn't return immediately; instead it needs to check further
if select_idx is ARMV8_PMU_CYCLE_IDX.
Another issue is that KVM shouldn't copy the eventsel bits of PMCCFILTER
blindly to attr.config. Instead it ought to convert the request to the
"cpu cycle" event type (i.e. 0x11).
To support this patch and to prevent duplicated definitions, a limited
set of ARMv8 perf event types were relocated from perf_event.c to
asm/perf_event.h.
Cc: stable@vger.kernel.org # 4.6+
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Wei Huang <wei@redhat.com>
In cases like IPI, we could be queueing an interrupt for a VCPU
that is already running and is not about to exit, because the
VCPU has entered the VM with the interrupt pending and would
not trap on EOI'ing that interrupt. This could result to delays
in interrupt deliveries or even loss of interrupts.
To guarantee prompt interrupt injection, here we have to try to
kick the VCPU.
Signed-off-by: Shih-Wei Li <shihwei@cs.columbia.edu>
In our VGIC implementation we limit the number of SPIs to a number
that the userland application told us. Accordingly we limit the
allocation of memory for virtual IRQs to that number.
However in our MMIO dispatcher we didn't check if we ever access an
IRQ beyond that limit, leading to out-of-bound accesses.
Add a test against the number of allocated SPIs in check_region().
Adjust the VGIC_ADDR_TO_INT macro to avoid an actual division, which
is not implemented on ARM(32).
[maz: cleaned-up original patch]
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
If the vgic hasn't been created and initialized, we shouldn't attempt to
look at its data structures or flush/sync anything to the GIC hardware.
This fixes an issue reported by Alexander Graf when using a userspace
irqchip.
Fixes: 0919e84c0fc1 ("KVM: arm/arm64: vgic-new: Add IRQ sync/flush framework")
Reported-by: Alexander Graf <agraf@suse.de>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
If userspace creates a PMU for the VCPU, but doesn't create an in-kernel
irqchip, then we end up in a nasty path where we try to take an
uninitialized spinlock, which can lead to all sorts of breakages.
Luckily, QEMU always creates the VGIC before the PMU, so we can
establish this as ABI and check for the VGIC in the PMU init stage.
This can be relaxed at a later time if we want to support PMU with a
userspace irqchip.
Cc: Shannon Zhao <shannon.zhao@linaro.org>
This patch allows to build and use vgic-v3 in 32-bit mode.
Unfortunately, it can not be split in several steps without extra
stubs to keep patches independent and bisectable. For instance,
virt/kvm/arm/vgic/vgic-v3.c uses function from vgic-v3-sr.c, handling
access to GICv3 cpu interface from the guest requires vgic_v3.vgic_sre
to be already defined.
It is how support has been done:
* handle SGI requests from the guest
* report configured SRE on access to GICv3 cpu interface from the guest
* required vgic-v3 macros are provided via uapi.h
* static keys are used to select GIC backend
* to make vgic-v3 build KVM_ARM_VGIC_V3 guard is removed along with
the static inlines
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
We have couple of 64-bit registers defined in GICv3 architecture, so
unsigned long accesses to these registers will only access a single
32-bit part of that regitser. On the other hand these registers can't
be accessed as 64-bit with a single instruction like ldrd/strd or
ldmia/stmia if we run a 32-bit host because KVM does not support
access to MMIO space done by these instructions.
It means that a 32-bit guest accesses these registers in 32-bit
chunks, so the only thing we need to do is to ensure that
extract_bytes() always takes 64-bit data.
Well, this patch is looking ahead of time, but we'll get following
compiler warnings as soon as we introduce vgic-v3 to 32-bit world
CC arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.o
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c: In function 'vgic_mmio_read_v3r_typer':
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:184:35: warning: left shift count >= width of type [-Wshift-count-overflow]
value = (mpidr & GENMASK(23, 0)) << 32;
In file included from ./include/linux/kernel.h:10:0,
from ./include/asm-generic/bug.h:13,
from ./arch/arm/include/asm/bug.h:59,
from ./include/linux/bug.h:4,
from ./include/linux/io.h:23,
from ./arch/arm/include/asm/arch_gicv3.h:23,
from ./include/linux/irqchip/arm-gic-v3.h:411,
from arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:14:
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c: In function 'vgic_v3_dispatch_sgi':
./include/linux/bitops.h:6:24: warning: left shift count >= width of type [-Wshift-count-overflow]
#define BIT(nr) (1UL << (nr))
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:614:20: note: in expansion of macro 'BIT'
broadcast = reg & BIT(ICC_SGI1R_IRQ_ROUTING_MODE_BIT);
Let's fix them now.
By now ITS code guarded with KVM_ARM_VGIC_V3 config option which was
introduced to hide everything specific to vgic-v3 from 32-bit world.
We are going to support vgic-v3 in 32-bit world and KVM_ARM_VGIC_V3
will gone, but we don't have support for ITS there yet and we need to
continue keeping ITS away.
Introduce the new config option to prevent ITS code being build in
32-bit mode when support for vgic-v3 is done.
So we can reuse the code under arch/arm
Currently GIC backend is selected via alternative framework and this
is fine. We are going to introduce vgic-v3 to 32-bit world and there
we don't have patching framework in hand, so we can either check
support for GICv3 every time we need to choose which backend to use or
try to optimise it by using static keys. The later looks quite
promising because we can share logic involved in selecting GIC backend
between architectures if both uses static keys.
This patch moves arm64 from alternative to static keys framework for
selecting GIC backend. For that we embed static key into vgic_global
and enable the key during vgic initialisation based on what has
already been exposed by the host GIC driver.
Remove two unnecessary labels now that kvm_timer_hyp_init is not
creating its own workqueue anymore.
If, when proxying a GICV access at EL2, we detect that the guest is
doing something silly, report an EL1 SError instead ofgnoring the
access.
So far, we've been disabling KVM on systems where the GICV region couldn't
be safely given to a guest. Now that we're able to handle this access
safely by emulating it in HYP, we can enable this feature when we detect
an unsafe configuration.
Now that we have the necessary infrastructure to handle MMIO accesses
in HYP, perform the GICV access on behalf of the guest. This requires
checking that the access is strictly 32bit, properly aligned, and
falls within the expected range.
When all condition are satisfied, we perform the access and tell
the rest of the HYP code that the instruction has been correctly
emulated.
In order to efficiently perform the GICV access on behalf of the
guest, we need to be able to avoid going back all the way to
the host kernel.
For this, we introduce a new hook in the world switch code,
conveniently placed just after populating the fault info.
At that point, we only have saved/restored the GP registers,
and we can quickly perform all the required checks (data abort,
translation fault, valid faulting syndrome, not an external
abort, not a PTW).
Coming back from the emulation code, we need to skip the emulated
instruction. This involves an additional bit of save/restore in
order to be able to access the guest's PC (and possibly CPSR if
this is a 32bit guest).
At this stage, no emulation code is provided.
As we plan to do some emulation at HYP, let's make kvm_skip_instr32
as part of the hyp_text section. This doesn't preclude the kernel
from using it.
Add the bit of glue and const-ification that is required to use
the code inherited from the arm64 port, and move over to it.
It would make some sense to share the conditional execution code
between 32 and 64bit. In order to achieve this, let's move that
code to virt/kvm/arm/aarch32.c. While we're at it, drop a
superfluous BUG_ON() that wasn't that useful.
Following patches will migrate the 32bit port to that code base.
As kvm_set_routing_entry() was changing prototype between 4.7 and 4.8,
an ugly hack was put in place in order to survive both building in
-next and the merge window.
Now that everything has been merged, let's dump the compatibility
hack for good.
Just a rename so we can implement a v3-specific function later.
We take the chance to get rid of the V2/V3 ops comments as well.
No functional change.
As we are about to deal with multiple data types and situations where
the vgic should not be initialized when doing userspace accesses on the
register attributes, factor out the functionality of
vgic_attr_regs_access into smaller bits which can be reused by a new
function later.
The workqueue "irqfd_cleanup_wq" queues a single work item
&irqfd->shutdown and hence doesn't require ordering. It is a host-wide
workqueue for issuing deferred shutdown requests aggregated from all
vm* instances. It is not being used on a memory reclaim path.
Hence, it has been converted to use system_wq.
The work item has been flushed in kvm_irqfd_release().
The workqueue "wqueue" queues a single work item &timer->expired
and hence doesn't require ordering. Also, it is not being used on
a memory reclaim path. Hence, it has been converted to use system_wq.
System workqueues have been able to handle high level of concurrency
for a long time now and hence it's not required to have a singlethreaded
workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue
created with create_singlethread_workqueue(), system_wq allows multiple
work items to overlap executions even on the same CPU; however, a
per-cpu workqueue doesn't have any CPU locality or global ordering
guarantee unless the target CPU is explicitly specified and thus the
increase of local concurrency shouldn't make any difference.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
KVM/ARM Fixes for v4.8-rc3
This tag contains the following fixes on top of v4.8-rc1:
- ITS init issues
- ITS error handling issues
- ITS IRQ leakage fix
- Plug a couple of ITS race conditions
- An erratum workaround for timers
- Some removal of misleading use of errors and comments
- A fix for GICv3 on 32-bit guests
Similarily to f005bd7e3b84 ("clocksource/arm_arch_timer: Force
per-CPU interrupt to be level-triggered"), make sure we can
survive an interrupt that has been misconfigured as edge-triggered
by forcing it to be level-triggered (active low is assumed, but
the GIC doesn't really care whether this is high or low).
Hopefully, the amount of shouting in the kernel log will convince
the user to do something about their firmware.
When a guest wants to map a device-ID/event-ID combination that is
already mapped, we may end up in a situation where an LPI is never
"put", thus never being freed.
Since the GICv3 spec says that mapping an already mapped LPI is
UNPREDICTABLE, lets just bail out early in this situation to avoid
any potential leaks.
When userspace provides the doorbell address for an MSI to be
injected into the guest, we find a KVM device which feels responsible.
Lets check that this device is really an emulated ITS before we make
real use of the container_of-ed pointer.
[ Moved NULL-pointer check to caller of static function
- Christoffer ]
Currently we register an ITS device upon userland issuing the CTLR_INIT
ioctl to mark initialization of the ITS as done.
This deviates from the initialization sequence of the existing GIC
devices and does not play well with the way QEMU handles things.
To be more in line with what we are used to, register the ITS(es) just
before the first VCPU is about to run, so in the map_resources() call.
This involves iterating through the list of KVM devices and map each
ITS that we find.
Tested-by: Eric Auger <eric.auger@redhat.com>
There are two problems with the current implementation of the MMIO
handlers for the propbaser and pendbaser:
First, the write to the value itself is not guaranteed to be an atomic
64-bit write so two concurrent writes to the structure field could be
intermixed.
Second, because we do a read-modify-update operation without any
synchronization, if we have two 32-bit accesses to separate parts of the
register, we can loose one of them.
By using the atomic cmpxchg64 we should cover both issues above.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
KVM devices were manipulating list data structures without any form of
synchronization, and some implementations of the create operations also
suffered from a lack of synchronization.
Now when we've split the xics create operation into create and init, we
can hold the kvm->lock mutex while calling the create operation and when
manipulating the devices list.
The error path in the generic code gets slightly ugly because we have to
take the mutex again and delete the device from the list, but holding
the mutex during anon_inode_getfd or releasing/locking the mutex in the
common non-error path seemed wrong.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Right now the following sequence of events can happen:
1. Thread X calls vgic_put_irq
2. Thread Y calls vgic_add_lpi
3. Thread Y gets lpi_list_lock
4. Thread X drops the ref count to 0 and blocks on lpi_list_lock
5. Thread Y finds the irq via the lpi_list_lock, raises the ref
count to 1, and release the lpi_list_lock.
6. Thread X proceeds and frees the irq.
Avoid this by holding the spinlock around the kref_put.
During low memory conditions, we could be dereferencing a NULL pointer
when vgic_add_lpi fails to allocate memory.
Consider for example this call sequence:
vgic_its_cmd_handle_mapi
itte->irq = vgic_add_lpi(kvm, lpi_nr);
update_lpi_config(kvm, itte->irq, NULL);
ret = kvm_read_guest(kvm, propbase + irq->intid
kaboom?
Instead, return an error pointer from vgic_add_lpi and check the return
value from its single caller.
According to the KVM API documentation a successful MSI injection
should return a value > 0 on success.
Return possible errors in vgic_its_trigger_msi() and report a
successful injection back to userland, while also reporting the
case where the MSI could not be delivered due to the guest not
having the LPI mapped, for instance.
KVM/ARM Changes for v4.8 - Take 2
Includes GSI routing support to go along with the new VGIC and a small fix that
has been cooking in -next for a while.
Pull KVM updates from Paolo Bonzini:
- ARM: GICv3 ITS emulation and various fixes. Removal of the
old VGIC implementation.
- s390: support for trapping software breakpoints, nested
virtualization (vSIE), the STHYI opcode, initial extensions
for CPU model support.
- MIPS: support for MIPS64 hosts (32-bit guests only) and lots
of cleanups, preliminary to this and the upcoming support for
hardware virtualization extensions.
- x86: support for execute-only mappings in nested EPT; reduced
vmexit latency for TSC deadline timer (by about 30%) on Intel
hosts; support for more than 255 vCPUs.
- PPC: bugfixes.
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (302 commits)
KVM: PPC: Introduce KVM_CAP_PPC_HTM
MIPS: Select HAVE_KVM for MIPS64_R{2,6}
MIPS: KVM: Reset CP0_PageMask during host TLB flush
MIPS: KVM: Fix ptr->int cast via KVM_GUEST_KSEGX()
MIPS: KVM: Sign extend MFC0/RDHWR results
MIPS: KVM: Fix 64-bit big endian dynamic translation
MIPS: KVM: Fail if ebase doesn't fit in CP0_EBase
MIPS: KVM: Use 64-bit CP0_EBase when appropriate
MIPS: KVM: Set CP0_Status.KX on MIPS64
MIPS: KVM: Make entry code MIPS64 friendly
MIPS: KVM: Use kmap instead of CKSEG0ADDR()
MIPS: KVM: Use virt_to_phys() to get commpage PFN
MIPS: Fix definition of KSEGX() for 64-bit
KVM: VMX: Add VMCS to CPU's loaded VMCSs before VMPTRLD
kvm: x86: nVMX: maintain internal copy of current VMCS
KVM: PPC: Book3S HV: Save/restore TM state in H_CEDE
KVM: PPC: Book3S HV: Pull out TM state save/restore into separate procedures
KVM: arm64: vgic-its: Simplify MAPI error handling
KVM: arm64: vgic-its: Make vgic_its_cmd_handle_mapi similar to other handlers
KVM: arm64: vgic-its: Turn device_id validation into generic ID validation
kvm_set_routing_entry is changing in -next, and causes things to
explode. Add a temporary workaround that should be dropped when
we hit 4.8-rc1
Up to now, only irqchip routing entries could be set. This patch
adds the capability to insert MSI routing entries.
For ARM64, let's also increase KVM_MAX_IRQ_ROUTES to 4096: this
include SPI irqchip routes plus MSI routes. In the future this
might be extended.
Signed-off-by: Eric Auger <eric.auger@redhat.com>
This patch adds compilation and link against irqchip.
Main motivation behind using irqchip code is to enable MSI
routing code. In the future irqchip routing may also be useful
when targeting multiple irqchips.
Routing standard callbacks now are implemented in vgic-irqfd:
- kvm_set_routing_entry
- kvm_set_irq
- kvm_set_msi
They only are supported with new_vgic code.
Both HAVE_KVM_IRQCHIP and HAVE_KVM_IRQ_ROUTING are defined.
KVM_CAP_IRQ_ROUTING is advertised and KVM_SET_GSI_ROUTING is allowed.
So from now on IRQCHIP routing is enabled and a routing table entry
must exist for irqfd injection to succeed for a given SPI. This patch
builds a default flat irqchip routing table (gsi=irqchip.pin) covering
all the VGIC SPI indexes. This routing table is overwritten by the
first first user-space call to KVM_SET_GSI_ROUTING ioctl.
MSI routing setup is not yet allowed.
If we care to move all the checks that do not involve any memory
allocation, we can simplify the MAPI error handling. Let's do that,
it cannot hurt.
vgic_its_cmd_handle_mapi has an extra "subcmd" argument, which is
already contained in the command buffer that all command handlers
obtain from the command queue. Let's drop it, as it is not that
useful.
There is no need to have separate functions to validate devices
and collections, as the architecture doesn't really distinguish the
two, and they are supposed to be managed the same way.
Let's turn the DevID checker into a generic one.
Going from the ITS structure to the corresponding KVM structure
would be quite handy at times. The kvm_device pointer that is
passed at create time is quite convenient for this, so let's
keep a copy of it in the vgic_its structure.
This will be put to a good use in subsequent patches.
Instead of spreading random allocations all over the place,
consolidate allocation/init/freeing of collections in a pair
of constructor/destructor.
