This is the 5.15.77 stable release
Signed-off-by: Daiane Angolini <daiane.angolini@foundries.io>
This is the 5.15.76 stable release
This is the 5.15.75 stable release
arch/arm/boot/dts/imx6dl.dtsi
arch/arm/boot/dts/imx6q.dtsi
arch/arm/boot/dts/imx6sl.dtsi
arch/arm/boot/dts/imx6sll.dtsi
arch/arm/boot/dts/imx6sx.dtsi
arch/arm/boot/dts/imx7d-sdb.dts
drivers/char/hw_random/imx-rngc.c
drivers/dma/mxs-dma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/tty/serial/fsl_lpuart.c
drivers/usb/host/xhci.h
This is the 5.15.73 stable release
This is the 5.15.72 stable release
This is the 5.15.71 stable release
drivers/net/phy/aquantia_main.c
This is the 5.15.70 stable release
This is the 5.15.68 stable release
drivers/soc/imx/gpcv2.c
This is the 5.15.65 stable release
This is the 5.15.64 stable release
net/dsa/slave.c
This is the 5.15.63 stable release
drivers/gpu/drm/imx/dcss/dcss-kms.c
drivers/net/ethernet/freescale/dpaa2/dpaa2-eth.c
This is the 5.15.61 stable release
arch/arm/boot/dts/imx6ul.dtsi
drivers/media/platform/nxp/imx-jpeg/mxc-jpeg.c
drivers/media/platform/nxp/imx-jpeg/mxc-jpeg.h
[ Upstream commit e9229d5b6254a75291536f582652c599957344d2 ]
Commit 0cc177cfc95d565e ("perf vendor events arm64: Add Hisi hip08 L3
metrics") add L3 metrics of hip08, but some metrics (IF_BP_MISP_BR_RET,
IF_BP_MISP_BR_RET, IF_BP_MISP_BR_BL) have incorrect event number due to
the mistakes in document, which caused incorrect result. Fix the
incorrect metrics.
Before:
65,811,214,308 armv8_pmuv3_0/event=0x1014/ # 18.87 push_branch
# -40.19 other_branch
3,564,316,780 BR_MIS_PRED # 0.51 indirect_branch
# 21.81 pop_branch
After:
6,537,146,245 BR_MIS_PRED # 0.48 indirect_branch
# 0.47 pop_branch
# 0.00 push_branch
# 0.05 other_branch
Fixes: 0cc177cfc95d565e ("perf vendor events arm64: Add Hisi hip08 L3 metrics")
Reviewed-by: John Garry <john.garry@huawei.com>
Signed-off-by: Shang XiaoJing <shangxiaojing@huawei.com>
Acked-by: James Clark <james.clark@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: John Garry <john.garry@huawei.com>
Cc: Kajol Jain <kjain@linux.ibm.com>
Cc: Leo Yan <leo.yan@linaro.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Mike Leach <mike.leach@linaro.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Will Deacon <will@kernel.org>
Link: https://lore.kernel.org/r/20221021105035.10000-2-shangxiaojing@huawei.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit b92dd11725a7c57f55e148c7d3ce58a86f480575 ]
Testcase stat_all_metrics.sh fails in powerpc:
90: perf all metrics test : FAILED!
The testcase "stat_all_metrics.sh" verifies perf stat result for all the
metric events present in perf list. It runs perf metric events with
various commands and expects non-empty metric result.
Incase of powerpc:hv-24x7 events, some of the event count can be 0 based
on system configuration. And if that event used as denominator in divide
equation, it can cause divide by 0 error. The current nest_metric.json
file creating divide by 0 issue for some of the metric events, which
results in failure of the "stat_all_metrics.sh" test case.
Most of the metrics events have cycles or an event which expect to have
a larger value as denominator, so adding 1 to the denominator of the
metric expression as a fix.
Result in powerpc box after this patch changes:
90: perf all metrics test : Ok
Fixes: a3cbcadfdfc330c2 ("perf vendor events power10: Adds 24x7 nest metric events for power10 platform")
Signed-off-by: Kajol Jain <kjain@linux.ibm.com>
Reviewed-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
Cc: Athira Jajeev <atrajeev@linux.vnet.ibm.com>
Cc: Disha Goel <disgoel@linux.vnet.ibm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nageswara R Sastry <rnsastry@linux.ibm.com>
Link: https://lore.kernel.org/r/20221014140220.122251-1-kjain@linux.ibm.com
memslot_modification_stress_test
[ Upstream commit 05c2224d4b049406b0545a10be05280ff4b8ba0a ]
It's required by vm_userspace_mem_region_add() that memory size
should be aligned to host page size. However, one guest page is
provided by memslot_modification_stress_test. It triggers failure
in the scenario of 64KB-page-size-host and 4KB-page-size-guest,
as the following messages indicate.
# ./memslot_modification_stress_test
Testing guest mode: PA-bits:40, VA-bits:48, 4K pages
guest physical test memory: [0xffbfff0000, 0xffffff0000)
Finished creating vCPUs
Started all vCPUs
==== Test Assertion Failure ====
lib/kvm_util.c:824: vm_adjust_num_guest_pages(vm->mode, npages) == npages
pid=5712 tid=5712 errno=0 - Success
1 0x0000000000404eeb: vm_userspace_mem_region_add at kvm_util.c:822
2 0x0000000000401a5b: add_remove_memslot at memslot_modification_stress_test.c:82
3 (inlined by) run_test at memslot_modification_stress_test.c:110
4 0x0000000000402417: for_each_guest_mode at guest_modes.c:100
5 0x00000000004016a7: main at memslot_modification_stress_test.c:187
6 0x0000ffffb8cd4383: ?? ??:0
7 0x0000000000401827: _start at :?
Number of guest pages is not compatible with the host. Try npages=16
Fix the issue by providing 16 guest pages to the memory slot for this
particular combination of 64KB-page-size-host and 4KB-page-size-guest
on aarch64.
Fixes: ef4c9f4f65462 ("KVM: selftests: Fix 32-bit truncation of vm_get_max_gfn()")
Signed-off-by: Gavin Shan <gshan@redhat.com>
Signed-off-by: Marc Zyngier <maz@kernel.org>
Link: https://lore.kernel.org/r/20221013063020.201856-1-gshan@redhat.com
commit cba04f3136b658583adb191556f99d087589c1cc upstream.
For modules, names from kallsyms__parse() contain the module name which
meant that module symbols did not match exactly by name.
Fix by matching the name string up to the separating tab character.
Fixes: 1b36c03e356936d6 ("perf record: Add support for using symbols in address filters")
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Ian Rogers <irogers@google.com>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20221026072736.2982-1-adrian.hunter@intel.com
commit 72b2aa38191bcba28389b0e20bf6b4f15017ff2b upstream.
The iio_utils uses a digit calculation in order to know length of the
file name containing a buffer number. The digit calculation does not
work for number 0.
This leads to allocation of one character too small buffer for the
file-name when file name contains value '0'. (Eg. buffer0).
Fix digit calculation by returning one digit to be present for number
'0'.
Fixes: 096f9b862e60 ("tools:iio:iio_utils: implement digit calculation")
Signed-off-by: Matti Vaittinen <mazziesaccount@gmail.com>
Link: https://lore.kernel.org/r/Y0f+tKCz+ZAIoroQ@dc75zzyyyyyyyyyyyyycy-3.rev.dnainternet.fi
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit e552b7be12ed62357df84392efa525ecb01910fb ]
If the kernel exposes a new perf_event_attr field in a format attr, perf
will return an error stating the specified PMU can't be found. For
example, a format attr with 'config3:0-63' causes an error as config3 is
unknown to perf. This causes a compatibility issue between a newer
kernel with older perf tool.
Before this change with a kernel adding 'config3' I get:
$ perf record -e arm_spe// -- true
event syntax error: 'arm_spe//'
\___ Cannot find PMU `arm_spe'. Missing kernel support?
Run 'perf list' for a list of valid events
Usage: perf record [<options>] [<command>]
or: perf record [<options>] -- <command> [<options>]
-e, --event <event> event selector. use 'perf list' to list
available events
After this change, I get:
WARNING: 'arm_spe_0' format 'inv_event_filter' requires 'perf_event_attr::config3' which is not supported by this version of perf!
[ perf record: Woken up 2 times to write data ]
[ perf record: Captured and wrote 0.091 MB perf.data ]
To support unknown configN formats, rework the YACC implementation to
pass any config[0-9]+ format to perf_pmu__new_format() to handle with a
warning.
Reviewed-by: Namhyung Kim <namhyung@kernel.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Tested-by: Leo Yan <leo.yan@linaro.org>
Cc: James Clark <james.clark@arm.com>
Link: https://lore.kernel.org/r/20220914-arm-perf-tool-spe1-2-v2-v4-1-83c098e6212e@kernel.org
commit 5a3d47071f0ced0431ef82a5fb6bd077ed9493db upstream.
uClibc segfaulted because NULL was passed as the format to fprintf().
That happened because one of the format strings was missing and
intel_pt_print_info() didn't check that before calling fprintf().
Add the missing format string, and check format is not NULL before calling
fprintf().
Fixes: 11fa7cb86b56d361 ("perf tools: Pass Intel PT information for decoding MTC and CYC")
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: https://lore.kernel.org/r/20221012082259.22394-2-adrian.hunter@intel.com
[ Upstream commit 5c152c2f66f9368394b89ac90dc7483476ef7b88 ]
When arm64 signal context data overflows the base struct sigcontext it gets
placed in an extra buffer pointed to by a record of type EXTRA_CONTEXT in
the base struct sigcontext which is required to be the last record in the
base struct sigframe. The current validation code attempts to check this
by using GET_RESV_NEXT_HEAD() to step forward from the current record to
the next but that is a macro which assumes it is being provided with a
struct _aarch64_ctx and uses the size there to skip forward to the next
record. Instead validate_extra_context() passes it a struct extra_context
which has a separate size field. This compiles but results in us trying
to validate a termination record in completely the wrong place, at best
failing validation and at worst just segfaulting. Fix this by passing
the struct _aarch64_ctx we meant to into the macro.
Signed-off-by: Mark Brown <broonie@kernel.org>
Link: https://lore.kernel.org/r/20220829160703.874492-4-broonie@kernel.org
[ Upstream commit cea558855c39b7f1f02ff50dcf701ca6596bc964 ]
When bpftool is linked against libcap, the library runs a "constructor"
function to compute the number of capabilities of the running kernel
[0], at the beginning of the execution of the program. As part of this,
it performs multiple calls to prctl(). Some of these may fail, and set
errno to a non-zero value:
# strace -e prctl ./bpftool version
prctl(PR_CAPBSET_READ, CAP_MAC_OVERRIDE) = 1
prctl(PR_CAPBSET_READ, 0x30 /* CAP_??? */) = -1 EINVAL (Invalid argument)
prctl(PR_CAPBSET_READ, CAP_CHECKPOINT_RESTORE) = 1
prctl(PR_CAPBSET_READ, 0x2c /* CAP_??? */) = -1 EINVAL (Invalid argument)
prctl(PR_CAPBSET_READ, 0x2a /* CAP_??? */) = -1 EINVAL (Invalid argument)
prctl(PR_CAPBSET_READ, 0x29 /* CAP_??? */) = -1 EINVAL (Invalid argument)
** fprintf added at the top of main(): we have errno == 1
./bpftool v7.0.0
using libbpf v1.0
features: libbfd, libbpf_strict, skeletons
+++ exited with 0 +++
This has been addressed in libcap 2.63 [1], but until this version is
available everywhere, we can fix it on bpftool side.
Let's clean errno at the beginning of the main() function, to make sure
that these checks do not interfere with the batch mode, where we error
out if errno is set after a bpftool command.
[0] https://git.kernel.org/pub/scm/libs/libcap/libcap.git/tree/libcap/cap_alloc.c?h=libcap-2.65#n20
[1] https://git.kernel.org/pub/scm/libs/libcap/libcap.git/commit/?id=f25a1b7e69f7b33e6afb58b3e38f3450b7d2d9a0
Signed-off-by: Quentin Monnet <quentin@isovalent.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Link: https://lore.kernel.org/bpf/20220815162205.45043-1-quentin@isovalent.com
[ Upstream commit 2d869f0b458547386fbcd8cf3004b271b7347b7f ]
The following output can bee seen when the test is executed:
test_flush_context (tpm2_tests.SpaceTest) ... \
/usr/lib64/python3.6/unittest/case.py:605: ResourceWarning: \
unclosed file <_io.FileIO name='/dev/tpmrm0' mode='rb+' closefd=True>
An instance of Client does not implicitly close /dev/tpm* handle, once it
gets destroyed. Close the file handle in the class destructor
Client.__del__().
Fixes: 6ea3dfe1e0732 ("selftests: add TPM 2.0 tests")
Cc: Shuah Khan <shuah@kernel.org>
Cc: linux-kselftest@vger.kernel.org
Cc: Jarkko Sakkinen <jarkko@kernel.org>
Signed-off-by: Stefan Berger <stefanb@linux.ibm.com>
Reviewed-by: Jarkko Sakkinen <jarkko@kernel.org>
Signed-off-by: Jarkko Sakkinen <jarkko@kernel.org>
[ Upstream commit af515a5587b8f45f19e11657746e0c89411b0380 ]
The put lowers the reference count to 0 and frees ctx, reading it
afterwards is invalid. Move the put after the uses and determine the
last use by the reference count being 1.
Fixes: 39e940d4abfa ("selftests/xsk: Destroy BPF resources only when ctx refcount drops to 0")
Signed-off-by: Ian Rogers <irogers@google.com>
Acked-by: Magnus Karlsson <magnus.karlsson@intel.com>
Link: https://lore.kernel.org/bpf/20220901202645.1463552-1-irogers@google.com
[ Upstream commit 7184aef9c0f7a81db8fd18d183ee42481d89bf35 ]
When `data` points to a boolean value, casting it to `int *` is problematic
and could lead to a wrong value being passed to `jsonw_bool`. Change the
cast to `bool *` instead.
Fixes: b12d6ec09730 ("bpf: btf: add btf print functionality")
Signed-off-by: Lam Thai <lamthai@arista.com>
Signed-off-by: Andrii Nakryiko <andrii@kernel.org>
Reviewed-by: Quentin Monnet <quentin@isovalent.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
Link: https://lore.kernel.org/bpf/20220824225859.9038-1-lamthai@arista.com
[ Upstream commit 5141d3a06b2da1731ac82091298b766a1f95d3d8 ]
elf_update_symbol fails to preserve the special st_shndx values
between [SHN_LORESERVE, SHN_HIRESERVE], which results in it
converting SHN_ABS entries into SHN_UNDEF, for example. Explicitly
check for the special indexes and ensure these symbols are not
marked undefined.
Fixes: ead165fa1042 ("objtool: Fix symbol creation")
Signed-off-by: Sami Tolvanen <samitolvanen@google.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lore.kernel.org/r/20220908215504.3686827-17-samitolvanen@google.com
[ Upstream commit eabd4523395e4a8f2b049165642801f2ab8ff893 ]
Previously the broken modifier causes a usage message to printed but
nothing else.
After:
$ perf stat -e 'cycles:kk' -a sleep 2
event syntax error: 'cycles:kk'
\___ Bad modifier
Usage: perf stat [<options>] [<command>]
-e, --event <event> event selector. use 'perf list' to list available events
$ perf stat -e '{instructions,cycles}:kk' -a sleep 2
event syntax error: '..ns,cycles}:kk'
\___ Bad modifier
Acked-by: Andi Kleen <ak@linux.intel.com>
Cc: Alexander Antonov <alexander.antonov@linux.intel.com>
Cc: Andrew Kilroy <andrew.kilroy@arm.com>
Cc: Changbin Du <changbin.du@intel.com>
Cc: Denys Zagorui <dzagorui@cisco.com>
Cc: Fabian Hemmer <copy@copy.sh>
Cc: Felix Fietkau <nbd@nbd.name>
Cc: Heiko Carstens <hca@linux.ibm.com>
Cc: Jacob Keller <jacob.e.keller@intel.com>
Cc: Jiapeng Chong <jiapeng.chong@linux.alibaba.com>
Cc: Jin Yao <yao.jin@linux.intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Joakim Zhang <qiangqing.zhang@nxp.com>
Cc: Kan Liang <kan.liang@linux.intel.com>
Cc: Kees Kook <keescook@chromium.org>
Cc: Nicholas Fraser <nfraser@codeweavers.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Paul Clarke <pc@us.ibm.com>
Cc: Riccardo Mancini <rickyman7@gmail.com>
Cc: Sami Tolvanen <samitolvanen@google.com>
Cc: ShihCheng Tu <mrtoastcheng@gmail.com>
Cc: Song Liu <songliubraving@fb.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Sumanth Korikkar <sumanthk@linux.ibm.com>
Cc: Thomas Richter <tmricht@linux.ibm.com>
Cc: Wan Jiabing <wanjiabing@vivo.com>
Cc: Zhen Lei <thunder.leizhen@huawei.com>
Link: https://lore.kernel.org/r/20211015172132.1162559-21-irogers@google.com
Stable-dep-of: 71c86cda750b ("perf parse-events: Remove "not supported" hybrid cache events")
This is the 5.15.60 stable release
This is the 5.15.59 stable release
This is the 5.15.58 stable release
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
This is the 5.15.57 stable release
This is the 5.15.54 stable release
arch/arm64/boot/dts/freescale/imx8mp-evk.dts
MX8MP_IOMUXC_GPIO1_IO14__USB2_OTG_PWR renamed to
MX8MP_IOMUXC_GPIO1_IO14__USB2_PWR
[ Upstream commit bc7a319844891746135dc1f34ab9df78d636a3ac ]
The socket 2 bind the addr in use, bind should fail with EADDRINUSE. So
if bind success or errno != EADDRINUSE, testcase should be failed.
Fixes: 3ca8e4029969 ("soreuseport: BPF selection functional test")
Signed-off-by: Wang Yufen <wangyufen@huawei.com>
Link: https://lore.kernel.org/r/1663916557-10730-1-git-send-email-wangyufen@huawei.com
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
This is the 5.15.53 stable release
[ Upstream commit 83e4b196838d90799a8879e5054a3beecf9ed256 ]
RHEL/Fedora RPM build checks are stricter, and complain when executable
files don't have a shebang line, e.g.
*** WARNING: ./kselftests/net/forwarding/sch_red.sh is executable but has no shebang, removing executable bit
Fix it by adding shebang line.
Fixes: 6cf0291f9517 ("selftests: forwarding: Add a RED test for SW datapath")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Reviewed-by: Petr Machata <petrm@nvidia.com>
Link: https://lore.kernel.org/r/20220922024453.437757-1-liuhangbin@gmail.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 999e4eaa4b3691acf85d094836260ec4b66c74fd ]
It needs to enter the namespace before reading a file.
Fixes: 4183a8d70a288627 ("perf tools: Allow synthesizing the build id for kernel/modules/tasks in PERF_RECORD_MMAP2")
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lore.kernel.org/lkml/20220920222822.2171056-1-namhyung@kernel.org
[ Upstream commit 5b427df27b94aec1312cace48a746782a0925c53 ]
/proc/kallsyms and /proc/modules are compared before and after the copy
in order to ensure no changes during the copy.
However /proc/modules also might change due to reference counts changing
even though that does not make any difference.
Any modules loaded or unloaded should be visible in changes to kallsyms,
so it is not necessary to check /proc/modules also anyway.
Remove the comparison checking that /proc/modules is unchanged.
Fixes: fc1b691d7651d949 ("perf buildid-cache: Add ability to add kcore to the cache")
Reported-by: Daniel Dao <dqminh@cloudflare.com>
Tested-by: Daniel Dao <dqminh@cloudflare.com>
Link: https://lore.kernel.org/r/20220914122429.8770-1-adrian.hunter@intel.com
[ Upstream commit babd04386b1df8c364cdaa39ac0e54349502e1e5 ]
The missing header makes it hard for programs like elfutils to open
these files.
Fixes: 2d86612aacb7805f ("perf symbol: Correct address for bss symbols")
Reviewed-by: Leo Yan <leo.yan@linaro.org>
Signed-off-by: Lieven Hey <lieven.hey@kdab.com>
Link: https://lore.kernel.org/r/20220915092910.711036-1-lieven.hey@kdab.com
[ Upstream commit 0d77326c3369e255715ed2440a78894ccc98dd69 ]
It seems the recent libbpf got more strict about the section name.
I'm seeing a failure like this:
$ sudo ./perf stat -a --bpf-counters --for-each-cgroup ^. sleep 1
libbpf: prog 'on_cgrp_switch': missing BPF prog type, check ELF section name 'perf_events'
libbpf: prog 'on_cgrp_switch': failed to load: -22
libbpf: failed to load object 'bperf_cgroup_bpf'
libbpf: failed to load BPF skeleton 'bperf_cgroup_bpf': -22
Failed to load cgroup skeleton
The section name should be 'perf_event' (without the trailing 's').
Although it's related to the libbpf change, it'd be better fix the
section name in the first place.
Fixes: 944138f048f7d759 ("perf stat: Enable BPF counter with --for-each-cgroup")
Cc: bpf@vger.kernel.org
Link: https://lore.kernel.org/r/20220916184132.1161506-2-namhyung@kernel.org
commit 95363747a6f39e88a3052fcf6ce6237769495ce0 upstream.
tools/include/uapi/asm/errno.h currently attempts to include
non-existent arch-specific errno.h header for xtensa.
Remove this case so that <asm-generic/errno.h> is used instead,
and add the missing arch-specific header for parisc.
References: https://buildd.debian.org/status/fetch.php?pkg=linux&arch=ia64&ver=5.8.3-1%7Eexp1&stamp=1598340829&raw=1
Signed-off-by: Ben Hutchings <benh@debian.org>
Signed-off-by: Salvatore Bonaccorso <carnil@debian.org>
Cc: <stable@vger.kernel.org> # 5.10+
Signed-off-by: Helge Deller <deller@gmx.de>
'/', filename)
commit 9d5f0c36438eeae7566ca383b2b673179e3cc613 upstream.
Its more intention revealing, and if we're interested in the odd cases
where this may end up truncating we can do debug checks at one
centralized place.
Motivation, of all the container builds, fedora rawhide started
complaining of:
util/machine.c: In function ‘machine__create_modules’:
util/machine.c:1419:50: error: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size between 0 and 4095 [-Werror=format-truncation=]
1419 | snprintf(path, sizeof(path), "%s/%s", dir_name, dent->d_name);
In file included from /usr/include/stdio.h:894,
from util/branch.h:9,
from util/callchain.h:8,
from util/machine.c:7:
In function ‘snprintf’,
inlined from ‘maps__set_modules_path_dir’ at util/machine.c:1419:3,
inlined from ‘machine__set_modules_path’ at util/machine.c:1473:9,
inlined from ‘machine__create_modules’ at util/machine.c:1519:7:
/usr/include/bits/stdio2.h:71:10: note: ‘__builtin___snprintf_chk’ output between 2 and 4352 bytes into a destination of size 4096
There are other places where we should use path__join(), but lets get rid of
this one first.
Acked-by: Ian Rogers <irogers@google.com>
Link: Link: https://lore.kernel.org/r/YebZKjwgfdOz0lAs@kernel.org
Signed-off-by: Jisheng Zhang <jszhang@kernel.org>
[ Upstream commit 82b2425fad2dd47204b3da589b679220f8aacc0e ]
Commit b91e5492f9d7ca89 ("perf record: Add a dummy event on hybrid
systems to collect metadata records") adds a dummy event on hybrid
systems to fix the symbol "unknown" issue when the workload is created
in a P-core but runs on an E-core. The added dummy event will cause
"perf script -F iregs" to fail. Dummy events do not have "iregs"
attribute set, so when we do evsel__check_attr, the "iregs" attribute
check will fail, so the issue happened.
The following commit [1] has fixed a similar issue by skipping the attr
check for the dummy event because it does not have any samples anyway. It
works okay for the normal mode, but the issue still happened when running
the test in the pipe mode. In the pipe mode, it calls process_attr() which
still checks the attr for the dummy event. This commit fixed the issue by
skipping the attr check for the dummy event in the API evsel__check_attr,
Otherwise, we have to patch everywhere when evsel__check_attr() is called.
Before:
#./perf record -o - --intr-regs=di,r8,dx,cx -e br_inst_retired.near_call:p -c 1000 --per-thread true 2>/dev/null|./perf script -F iregs |head -5
Samples for 'dummy:HG' event do not have IREGS attribute set. Cannot print 'iregs' field.
0x120 [0x90]: failed to process type: 64
After:
# ./perf record -o - --intr-regs=di,r8,dx,cx -e br_inst_retired.near_call:p -c 1000 --per-thread true 2>/dev/null|./perf script -F iregs |head -5
ABI:2 CX:0x55b8efa87000 DX:0x55b8efa7e000 DI:0xffffba5e625efbb0 R8:0xffff90e51f8ae100
ABI:2 CX:0x7f1dae1e4000 DX:0xd0 DI:0xffff90e18c675ac0 R8:0x71
ABI:2 CX:0xcc0 DX:0x1 DI:0xffff90e199880240 R8:0x0
ABI:2 CX:0xffff90e180dd7500 DX:0xffff90e180dd7500 DI:0xffff90e180043500 R8:0x1
ABI:2 CX:0x50 DX:0xffff90e18c583bd0 DI:0xffff90e1998803c0 R8:0x58
[1]https://lore.kernel.org/lkml/20220831124041.219925-1-jolsa@kernel.org/
Fixes: b91e5492f9d7ca89 ("perf record: Add a dummy event on hybrid systems to collect metadata records")
Suggested-by: Namhyung Kim <namhyung@kernel.org>
Signed-off-by: Xing Zhengjun <zhengjun.xing@linux.intel.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@intel.com>
Link: https://lore.kernel.org/r/20220908070030.3455164-1-zhengjun.xing@linux.intel.com
[ Upstream commit b71b7bfeac38c7a21c423ddafb29aa6258949df8 ]
"ns1" is a too generic name, use a random suffix to avoid
errors when such a netns exists. Also allows to run multiple
instances of the script in parallel.
commit bf515f024e4c0ca46a1b08c4f31860c01781d8a5 upstream.
If a weak group is broken then the reset_group flag remains set for
the next run. Having reset_group set means the counter isn't created
and ultimately a segfault.
A simple reproduction of this is:
# perf stat -r2 -e '{cycles,cycles,cycles,cycles,cycles,cycles,cycles,cycles,cycles,cycles}:W
which will be added as a test in the next patch.
Fixes: 4804e0111662d7d8 ("perf stat: Use affinity for opening events")
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Tested-by: Xing Zhengjun <zhengjun.xing@linux.intel.com>
Link: https://lore.kernel.org/r/20220822213352.75721-1-irogers@google.com
commit bc9e7fe313d5e56d4d5f34bcc04d1165f94f86fb upstream.
The previous change to Python autodetection had a small mistake where
the auto value was used to determine the Python binary, rather than the
user supplied value. The Python binary is only used for one part of the
build process, rather than the final linking, so it was producing
correct builds in most scenarios, especially when the auto detected
value matched what the user wanted, or the system only had a valid set
of Pythons.
Change it so that the Python binary path is derived from either the
PYTHON_CONFIG value or PYTHON value, depending on what is specified by
the user. This was the original intention.
This error was spotted in a build failure an odd cross compilation
environment after commit 4c41cb46a732fe82 ("perf python: Prefer
python3") was merged.
Fixes: 630af16eee495f58 ("perf tools: Use Python devtools for version autodetection rather than runtime")
Signed-off-by: James Clark <james.clark@arm.com>
Link: https://lore.kernel.org/r/20220728093946.1337642-1-james.clark@arm.com
[ Upstream commit f5eab65ff2b76449286d18efc7fee3e0b72f7d9b ]
A new feature is added where kprobes (and other probes) do not need to
explicitly state the event name when creating a probe. The event name will
come from what is being attached.
That is:
# echo 'p:foo/ vfs_read' > kprobe_events
Will no longer error, but instead create an event:
# cat kprobe_events
p:foo/p_vfs_read_0 vfs_read
This should not be tested as an error case anymore. Remove it from the
selftest as now this feature "breaks" the selftest as it no longer fails
as expected.
Link: https://lore.kernel.org/all/1656296348-16111-1-git-send-email-quic_linyyuan@quicinc.com/
Link: https://lkml.kernel.org/r/20220712161707.6dc08a14@gandalf.local.home
Signed-off-by: Steven Rostedt (Google) <rostedt@goodmis.org>
commit 1da1d60774014137d776d0400fdf2f1779d8d4d5 upstream.
If cpu_core PMU event fails to parse, try also cpu_atom PMU event when
parsing cycles event.
Fixes: 43eb05d066795bdf ("perf tests: Support 'Track with sched_switch' test for hybrid")
Link: https://lore.kernel.org/r/20220809080702.6921-3-adrian.hunter@intel.com
commit 2e828582b81f5bc76a4fe8e7812df259ab208302 upstream.
parse_events() is often called with parse_events_error set to NULL.
Make parse_events_error__handle() not segfault in that case.
A subsequent patch changes to avoid passing NULL in the first place.
Link: https://lore.kernel.org/r/20220809080702.6921-2-adrian.hunter@intel.com
commit 4bf6dcaa93bcd083a13c278a91418fe10e6d23a0 upstream.
If a memory allocation fail, we should branch to the error handling path
in order to free some resources allocated a few lines above.
Fixes: 15354d54698648e2 ("perf probe: Generate event name with line number")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: kernel-janitors@vger.kernel.org
Link: https://lore.kernel.org/r/b71bcb01fa0c7b9778647235c3ab490f699ba278.1659797452.git.christophe.jaillet@wanadoo.fr
commit 5b245985a6de5ac18b5088c37068816d413fb8ed upstream.
Switch to new EVP API for detecting libcrypto, as Fedora 36 returns an
error when it encounters the deprecated function MD5_Init() and the others.
The error would be interpreted as missing libcrypto, while in reality it is
not.
Fixes: 6e8ccb4f624a73c5 ("tools/bpf: properly account for libbfd variations")
Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Andrii Nakryiko <andrii@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: John Fastabend <john.fastabend@gmail.com>
Cc: KP Singh <kpsingh@kernel.org>
Cc: llvm@lists.linux.dev
Cc: Martin KaFai Lau <martin.lau@linux.dev>
Cc: Nathan Chancellor <nathan@kernel.org>
Cc: Nick Terrell <terrelln@fb.com>
Cc: Quentin Monnet <quentin@isovalent.com>
Cc: Song Liu <song@kernel.org>
Cc: Stanislav Fomichev <sdf@google.com>
Link: https://lore.kernel.org/r/20220719170555.2576993-4-roberto.sassu@huawei.com
commit 4f5ceb8851f0081af54313abbf56de1615911faf upstream.
When the number of partial slabs in each cache is the same (e.g., the
value are 0), the results of the `slabinfo -X -N5` and `slabinfo -P -N5`
are different.
/ # slabinfo -X -N5
Slabs sorted by number of partial slabs
Name Objects Objsize Space Slabs/Part/Cpu O/S O %Fr %Ef Flg
inode_cache 15180 392 6217728 758/0/1 20 1 0 95 a
kernfs_node_cache 22494 88 2002944 488/0/1 46 0 0 98
shmem_inode_cache 663 464 319488 38/0/1 17 1 0 96
biovec-max 50 3072 163840 4/0/1 10 3 0 93 A
dentry 19050 136 2600960 633/0/2 30 0 0 99 a
/ # slabinfo -P -N5
bdev_cache 32 984 32.7K 1/0/1 16 2 0 96 Aa
ext4_inode_cache 42 752 32.7K 1/0/1 21 2 0 96 a
dentry 19050 136 2.6M 633/0/2 30 0 0 99 a
TCPv6 17 1840 32.7K 0/0/1 17 3 0 95 A
RAWv6 18 856 16.3K 0/0/1 18 2 0 94 A
This problem is caused by the sort_slabs(). So let's use alphabetic order
when two values are equal in the sort_slabs().
By the way, the content of the `slabinfo -h` is not aligned because the
`-P|--partial Sort by number of partial slabs`
uses tabs instead of spaces. So let's use spaces instead of tabs to fix
it.
Link: https://lkml.kernel.org/r/20220528063117.935158-1-songyuanzheng@huawei.com
Fixes: 1106b205a3fe ("tools/vm/slabinfo: add partial slab listing to -X")
Signed-off-by: Yuanzheng Song <songyuanzheng@huawei.com>
Cc: "Tobin C. Harding" <tobin@kernel.org>
