path: root/tools
2014-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: Documentation/devicetree/bindings/net/micrel-ks8851.txt net/core/netpoll.c The net/core/netpoll.c conflict is a bug fix in 'net' happening to code which is completely removed in 'net-next'. In micrel-ks8851.txt we simply have overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-18Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull two 'perf bench' fixes from Arnaldo: * Make 'perf bench mem' (i.e. no args) mean 'run all tests' so that we can run all tests, not stopping at the numa ones. (Arnaldo Carvalho de Melo) * Fix NULL pointer dereference after last test in in "perf bench all" (Patrick Palka) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-16Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc smaller fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Fix leak in uncore_type_init failure paths perf machine: Use map as success in ip__resolve_ams perf symbols: Fix crash in elf_section_by_name perf trace: Decode architecture-specific signal numbers
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14perf bench: Fix NULL pointer dereference in "perf bench all"Patrick Palka
The for_each_bench() macro must check that the "benchmarks" field of a collection is not NULL before dereferencing it because the "all" collection in particular has a NULL "benchmarks" field (signifying that it has no benchmarks to iterate over). This fixes this NULL pointer dereference when running "perf bench all": [root@ssdandy ~]# perf bench all <SNIP> # Running mem/memset benchmark... # Copying 1MB Bytes ... 2.453675 GB/Sec 12.056327 GB/Sec (with prefault) Segmentation fault (core dumped) [root@ssdandy ~]# Signed-off-by: Patrick Palka <patrick@parcs.ath.cx> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1394664051-6037-1-git-send-email-patrick@parcs.ath.cx Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench numa: Make no args mean 'run all tests'Arnaldo Carvalho de Melo
If we call just: perf bench numa mem it will present the same output as: perf bench numa mem -h i.e. ask for instructions about what to run. While that is kinda ok, using 'run all tests' as the default, i.e. making 'no parms' be equivalent to: perf bench numa mem -a Will allow: perf bench numa all to actually do what is asked: i.e. run all the 'bench' tests, instead of responding to that by asking what to do. That, in turn, allows: perf bench all to actually complete, for the same reasons. And after that, the tests that come after that, and that at some point hit a NULL deref, will run, allowing me to reproduce a recently reported problem. That when you have the needed numa libraries, which wasn't the case for the reporter, making me a bit confused after trying to reproduce his report. So make no parms mean -a. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Patrick Palka <patrick@parcs.ath.cx> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-x7h0ghx4pef4n0brywg21krk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "I know this is a bit more than you want to see, and I've told the wireless folks under no uncertain terms that they must severely scale back the extent of the fixes they are submitting this late in the game. Anyways: 1) vmxnet3's netpoll doesn't perform the equivalent of an ISR, which is the correct implementation, like it should. Instead it does something like a NAPI poll operation. This leads to crashes. From Neil Horman and Arnd Bergmann. 2) Segmentation of SKBs requires proper socket orphaning of the fragments, otherwise we might access stale state released by the release callbacks. This is a 5 patch fix, but the initial patches are giving variables and such significantly clearer names such that the actual fix itself at the end looks trivial. From Michael S. Tsirkin. 3) TCP control block release can deadlock if invoked from a timer on an already "owned" socket. Fix from Eric Dumazet. 4) In the bridge multicast code, we must validate that the destination address of general queries is the link local all-nodes multicast address. From Linus Lüssing. 5) The x86 BPF JIT support for negative offsets puts the parameter for the helper function call in the wrong register. Fix from Alexei Starovoitov. 6) The descriptor type used for RTL_GIGA_MAC_VER_17 chips in the r8169 driver is incorrect. Fix from Hayes Wang. 7) The xen-netback driver tests skb_shinfo(skb)->gso_type bits to see if a packet is a GSO frame, but that's not the correct test. It should use skb_is_gso(skb) instead. Fix from Wei Liu. 8) Negative msg->msg_namelen values should generate an error, from Matthew Leach. 9) at86rf230 can deadlock because it takes the same lock from it's ISR and it's hard_start_xmit method, without disabling interrupts in the latter. Fix from Alexander Aring. 10) The FEC driver's restart doesn't perform operations in the correct order, so promiscuous settings can get lost. Fix from Stefan Wahren. 11) Fix SKB leak in SCTP cookie handling, from Daniel Borkmann. 12) Reference count and memory leak fixes in TIPC from Ying Xue and Erik Hugne. 13) Forced eviction in inet_frag_evictor() must strictly make sure all frags are deleted, otherwise module unload (f.e. 6lowpan) can crash. Fix from Florian Westphal. 14) Remove assumptions in AF_UNIX's use of csum_partial() (which it uses as a hash function), which breaks on PowerPC. From Anton Blanchard. The main gist of the issue is that csum_partial() is defined only as a value that, once folded (f.e. via csum_fold()) produces a correct 16-bit checksum. It is legitimate, therefore, for csum_partial() to produce two different 32-bit values over the same data if their respective alignments are different. 15) Fix endiannes bug in MAC address handling of ibmveth driver, also from Anton Blanchard. 16) Error checks for ipv6 exthdrs offload registration are reversed, from Anton Nayshtut. 17) Externally triggered ipv6 addrconf routes should count against the garbage collection threshold. Fix from Sabrina Dubroca. 18) The PCI shutdown handler added to the bnx2 driver can wedge the chip if it was not brought up earlier already, which in particular causes the firmware to shut down the PHY. Fix from Michael Chan. 19) Adjust the sanity WARN_ON_ONCE() in qdisc_list_add() because as currently coded it can and does trigger in legitimate situations. From Eric Dumazet. 20) BNA driver fails to build on ARM because of a too large udelay() call, fix from Ben Hutchings. 21) Fair-Queue qdisc holds locks during GFP_KERNEL allocations, fix from Eric Dumazet. 22) The vlan passthrough ops added in the previous release causes a regression in source MAC address setting of outgoing headers in some circumstances. Fix from Peter Boström" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (70 commits) ipv6: Avoid unnecessary temporary addresses being generated eth: fec: Fix lost promiscuous mode after reconnecting cable bonding: set correct vlan id for alb xmit path at86rf230: fix lockdep splats net/mlx4_en: Deregister multicast vxlan steering rules when going down vmxnet3: fix building without CONFIG_PCI_MSI MAINTAINERS: add networking selftests to NETWORKING net: socket: error on a negative msg_namelen MAINTAINERS: Add tools/net to NETWORKING [GENERAL] packet: doc: Spelling s/than/that/ net/mlx4_core: Load the IB driver when the device supports IBoE net/mlx4_en: Handle vxlan steering rules for mac address changes net/mlx4_core: Fix wrong dump of the vxlan offloads device capability xen-netback: use skb_is_gso in xenvif_start_xmit r8169: fix the incorrect tx descriptor version tools/net/Makefile: Define PACKAGE to fix build problems x86: bpf_jit: support negative offsets bridge: multicast: enable snooping on general queries only bridge: multicast: add sanity check for general query destination tcp: tcp_release_cb() should release socket ownership ...
2014-03-12tools/net/Makefile: Define PACKAGE to fix build problemsMarkos Chandras
Fixes the following build problem with binutils-2.24 gcc -Wall -O2 -c -o bpf_jit_disasm.o bpf_jit_disasm.c In file included from bpf_jit_disasm.c:25:0: /usr/include/bfd.h:35:2: error: #error config.h must be included before this header #error config.h must be included before this header This is similar to commit 3ce711a6abc27abce1554e1d671a8762b7187690 "perf tools: bfd.h/libbfd detection fails with recent binutils" See: https://sourceware.org/bugzilla/show_bug.cgi?id=14243 CC: David S. Miller <davem@davemloft.net> CC: Daniel Borkmann <dborkman@redhat.com> CC: netdev@vger.kernel.org Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-11Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: * Fix build of 'trace' in some systems due to using some architecture-specific signal numbers (Ben Hutchings) * Stop resolving when finding a map in in ip__resolve_ams, this way at least the DSO will be resolved when a symbol isn't (Don Zickus) * Fix crash in elf_section_by_name when not checking if some section string index is valid (Jiri Olsa) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-10tools/testing/selftests/ipc/msgque.c: handle msgget failure return correctlyColin Ian King
A failed msgget causes the test to return an uninitialised value in ret. Assign ret to -errno on error exit. Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-10perf machine: Use map as success in ip__resolve_amsDon Zickus
When trying to map a bunch of instruction addresses to their respective threads, I kept getting a lot of bogus entries [I forget the exact reason as I patched my code months ago]. Looking through ip__resolve_ams, I noticed the check for if (al.sym) and realized, most times I have an al.map definition but sometimes an al.sym is undefined. In the cases where al.sym is undefined, the loop keeps going even though a valid al.map exists. Modify this check to use the more reliable al.map. This fixed my bogus entries. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1393386227-149412-2-git-send-email-dzickus@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-10perf symbols: Fix crash in elf_section_by_nameJiri Olsa
Fixing crash in elf_section_by_name function caused by missing section name in elf binary. Reported-by: Albert Strasheim <albert@cloudflare.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Albert Strasheim <albert@cloudflare.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393767127-599-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-10perf trace: Decode architecture-specific signal numbersBen Hutchings
SIGSTKFLT is not defined on alpha, mips or sparc. SIGEMT and SIGSWI are defined on some architectures and should be decoded here if so. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 8bad5b0abfdb ('perf trace: Beautify signal number arg in several syscalls') Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1391648441.3003.101.camel@deadeye.wl.decadent.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-03Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull liblockdep fixes from Ingo Molnar: "A handful of build fixes for liblockdep" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tools/liblockdep: Use realpath for srctree and objtree tools/liblockdep: Add a stub for new rcu_is_watching tools/liblockdep: Mark runtests.sh as executable tools/liblockdep: Add include directory to allow tests to compile tools/liblockdep: Fix include of asm/hash.h tools/liblockdep: Fix initialization code path
2014-02-28perf tools: Fix strict alias issue for find_first_bitJiri Olsa
When compiling perf tool code with gcc 4.4.7 I'm getting following error: CC util/session.o cc1: warnings being treated as errors util/session.c: In function ‘perf_session_deliver_event’: tools/perf/util/include/linux/bitops.h:109: error: dereferencing pointer ‘p’ does break strict-aliasing rules tools/perf/util/include/linux/bitops.h:101: error: dereferencing pointer ‘p’ does break strict-aliasing rules util/session.c:697: note: initialized from here tools/perf/util/include/linux/bitops.h:101: note: initialized from here make[1]: *** [util/session.o] Error 1 make: *** [util/session.o] Error 2 The aliased types here are u64 and unsigned long pointers, which is safe for the find_first_bit processing. This error shows up for me only for gcc 4.4 on 32bit x86, even for -Wstrict-aliasing=3, while newer gcc are quiet and scream here for -Wstrict-aliasing={2,1}. Looks like newer gcc changed the rules for strict alias warnings. The gcc documentation offers workaround for valid aliasing by using __may_alias__ attribute: http://gcc.gnu.org/onlinedocs/gcc-4.4.0/gcc/Type-Attributes.html Using this workaround for the find_first_bit function. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393434867-20271-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-27perf tools: fix BFD detection on opensuseAndi Kleen
opensuse libbfd requires -lz -liberty to build. Add those to the BFD feature detection. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: David Ahern <dsahern@gmail.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1389469379-13340-2-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-27Merge branch 'liblockdep-fixes' of https://github.com/sashalevin/liblockdep ↵Ingo Molnar
into core/urgent Pull tools/lib/lockdep/ fixes from Sasha Levin. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: * Fix annotation on stdio/GTK+ interfaces (Namhyung Kim) * Fix file descriptor leaking while searching DSOs for suitable symtab (Namhyung Kim). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-26tools/liblockdep: Use realpath for srctree and objtreeWang Nan
If BUILD_SRC or CURDIR contains tailing '/', the file names passed to gcc will contain '//'. It will be contained .o's in debuginfo, then confuse debugedit: https://bugzilla.redhat.com/show_bug.cgi?id=304121 This patch uses realpath command to makesure potential tailing '/'s are removed. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Geng Hui <hui.geng@huawei.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Add a stub for new rcu_is_watchingSasha Levin
Stub out rcu_is_watching(), prevents build error with the updated tree. Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Mark runtests.sh as executableSasha Levin
runtests.sh is used to run the sanity tests for liblockdep and should be set +x. Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Add include directory to allow tests to compileIra W. Snyder
All of the programs in the tests directory require the liblockdep/mutex.h header in order to compile. Add the include directory to the compiler options so that the tests can be built with the provided Makefile. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Fix include of asm/hash.hIra W. Snyder
Commit 71ae8aac ("lib: introduce arch optimized hash library") added an include to <linux/hash.h> for setting up an architecture specific fast hash. This patch mirrors the fix used for perf, titled "tools: perf: util: fix include for non x86 architectures". Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Fix initialization code pathIra W. Snyder
This makes initialization actually happen. Without it, initialization is always skipped due to an incorrect conditional statement. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-24tools: bpf_dbg: various misc code cleanupsDaniel Borkmann
Lets clean up bpf_dbg a bit and improve its code slightly in various areas: i) Get rid of some macros as there's no good reason for keeping them, ii) remove one unused variable and reduce scope of various variables found by cppcheck, iii) Close non-default file descriptors when exiting the shell. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-24perf symbols: Destroy unused symsrcsNamhyung Kim
Stephane reported that perf report and annotate failed to process data using lots of (> 500) shared libraries. It was because of the limit on number of open files (ulimit -n). Currently when perf loads a DSO, it'll look for normal and dynamic symbol tables. And if it fails to find out both tables, it'll iterate all of possible symtab types. But many of them are useless since they have no additional information and the problem is that it's not closing those files even though they're not used. Fix it. Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1392859976-32760-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-24perf annotate: Check availability of annotate when processing samplesNamhyung Kim
The TUI of perf report and top support annotation, but stdio and GTK don't. So it should be checked before calling hist_entry__inc_addr_ samples() to avoid wasting resources that will never be used. perf annotate need it regardless of UI and sort keys, so the check of whether to allocate resources should be on the tools that have annotate as an option in the TUI, 'report' and 'top', not on the function called by all of them. It caused perf annotate on ppc64 to produce zero output, since the buckets were not being allocated. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Anton Blanchard <anton@samba.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1392859976-32760-1-git-send-email-namhyung@kernel.org [ Renamed (report,top)__needs_annotate() to ui__has_annotation() ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-22Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixlets from all around the place" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/uncore: Fix IVT/SNB-EP uncore CBOX NID filter table perf/x86: Correctly use FEATURE_PDCM perf, nmi: Fix unknown NMI warning perf trace: Fix ioctl 'request' beautifier build problems on !(i386 || x86_64) arches perf trace: Add fallback definition of EFD_SEMAPHORE perf list: Fix checking for supported events on older kernels perf tools: Handle PERF_RECORD_HEADER_EVENT_TYPE properly perf probe: Do not add offset twice to uprobe address perf/x86: Fix Userspace RDPMC switch perf/x86/intel/p6: Add userspace RDPMC quirk for PPro
2014-02-13perf trace: Fix ioctl 'request' beautifier build problems on !(i386 || ↵Arnaldo Carvalho de Melo
x86_64) arches Supporting decoding the ioctl 'request' parameter needs more work to properly support more architectures, the current approach doesn't work on at least powerpc and sparc, as reported by Ben Hutchings in http://lkml.kernel.org/r/1391593985.3003.48.camel@deadeye.wl.decadent.org.uk . Work around that by making it to be ifdefed for the architectures known to work with the current, limited approach, i386 and x86_64 till better code is written. Reported-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Ben Hutchings <ben@decadent.org.uk> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: <stable@vger.kernel.org> # 3.13 Fixes: 78645cf3ed32 ("perf trace: Initial beautifier for ioctl's 'cmd' arg") Link: http://lkml.kernel.org/n/tip-ss04k11insqlu329xh5g02q0@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf trace: Add fallback definition of EFD_SEMAPHOREBen Hutchings
glibc 2.17 is missing this on sparc, despite the fact that it's not architecture-specific. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 49af9e93adfa ('perf trace: Beautify eventfd2 'flags' arg') Cc: <stable@vger.kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1391648435.3003.100.camel@deadeye.wl.decadent.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf list: Fix checking for supported events on older kernelsVince Weaver
"perf list" listing of hardware events doesn't work on older ARM devices. The change enabling event detection: commit b41f1cec91c37eeea6fdb15effbfa24ea0a5536b Author: Namhyung Kim <namhyung.kim@lge.com> Date: Tue Aug 27 11:41:53 2013 +0900 perf list: Skip unsupported events uses the following code in tools/perf/util/parse-events.c: struct perf_event_attr attr = { .type = type, .config = config, .disabled = 1, .exclude_kernel = 1, }; On ARM machines pre-dating the Cortex-A15 this doesn't work, as these machines don't support .exclude_kernel. So starting with 3.12 "perf list" does not report any hardware events at all on older machines (seen on Rasp-Pi, Pandaboard, Beagleboard, etc). This version of the patch makes changes suggested by Namhyung Kim to check for EACCESS and retry (instead of just dropping the exclude_kernel) so we can properly handle machines where /proc/sys/kernel/perf_event_paranoid is set to 2. Reported-by: Chad Paradis <chad.paradis@umit.maine.edu> Signed-off-by: Vince Weaver <vincent.weaver@maine.edu> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Chad Paradis <chad.paradis@umit.maine.edu> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1312301536150.28814@vincent-weaver-1.um.maine.edu Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf tools: Handle PERF_RECORD_HEADER_EVENT_TYPE properlyJiri Olsa
We removed event types from data file in following commits: 6065210 perf tools: Remove event types framework completely 44b3c57 perf tools: Remove event types from perf data file We no longer need this information, because we can get it directly from tracepoints. But we still need to handle PERF_RECORD_HEADER_EVENT_TYPE event for the sake of old perf data files created in pipe mode like: $ perf.3.4 record -o - foo >perf.data $ perf.312 report -i - < perf.data Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1391524668-12546-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf probe: Do not add offset twice to uprobe addressMasami Hiramatsu
Fix perf-probe not to add offset value twice to uprobe probe address when post processing. The tevs[i].point.address struct member is the address of symbol+offset, but current perf-probe adjusts the point.address by adding the offset. As a result, the probe address becomes symbol+offset+offset. This may cause unexpected code corruption. Urgent fix is needed. Without this fix: --- # ./perf probe -x ./perf dso__load_vmlinux+4 # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d2b8) # nm ./perf.orig | grep dso__load_vmlinux\$ 000000000046d0a0 T dso__load_vmlinux --- You can see the given offset is 3 but the actual probed address is dso__load_vmlinux+8. With this fix: --- # ./perf probe -x ./perf dso__load_vmlinux+4 # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d2b4) --- Now the problem is fixed. Note: This bug is introduced by commit fb7345bbf7fad9bf72ef63a19c707970b9685812 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140205051858.6519.27314.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-09Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Tooling fixes, mostly related to the KASLR fallout, but also other fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf buildid-cache: Check relocation when checking for existing kcore perf tools: Adjust kallsyms for relocated kernel perf tests: No need to set up ref_reloc_sym perf symbols: Prevent the use of kcore if the kernel has moved perf record: Get ref_reloc_sym from kernel map perf machine: Set up ref_reloc_sym in machine__create_kernel_maps() perf machine: Add machine__get_kallsyms_filename() perf tools: Add kallsyms__get_function_start() perf symbols: Fix symbol annotation for relocated kernel perf tools: Fix include for non x86 architectures perf tools: Fix AAAAARGH64 memory barriers perf tools: Demangle kernel and kernel module symbols too perf/doc: Remove mention of non-existent set_perf_event_pending() from design.txt
2014-02-02Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull turbostat updates from Len Brown. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: introduce -s to dump counters tools/power turbostat: remove unused command line option turbostat: Add option to report joules consumed per sample turbostat: run on HSX turbostat: Add a .gitignore to ignore the compiled turbostat binary turbostat: Clean up error handling; disambiguate error messages; use err and errx turbostat: Factor out common function to open file and exit on failure turbostat: Add a helper to parse a single int out of a file turbostat: Check return value of fscanf turbostat: Use GCC's CPUID functions to support PIC turbostat: Don't attempt to printf an off_t with %zx turbostat: Don't put unprocessed uapi headers in the include path
2014-02-01tools/power turbostat: introduce -s to dump countersAndy Shevchenko
The new option allows just run turbostat and get dump of counter values. It's useful when we have something more than one program to test. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2014-02-01tools/power turbostat: remove unused command line optionAndy Shevchenko
The -s is not used, let's remove it, and update quick help accordingly. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2014-01-31perf buildid-cache: Check relocation when checking for existing kcoreAdrian Hunter
perf buildid-cache does not make another copy of kcore if the buildid and modules match an existing copy. That does not take into account the possibility that the kernel has been relocated. Extend the check to check if the reference relocation symbol matches too, otherwise do make a copy. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-10-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tools: Adjust kallsyms for relocated kernelAdrian Hunter
If the kernel is relocated at boot time, kallsyms will not match data recorded previously. That does not matter for modules because they are corrected anyway. It also does not matter if vmlinux is being used for symbols. But if perf tools has only kallsyms then the symbols will not match. Fix by applying the delta gained by comparing the old and current addresses of the relocation reference symbol. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-9-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tests: No need to set up ref_reloc_symAdrian Hunter
Now that ref_reloc_sym is set up by machine__create_kernel_maps(), the "vmlinux symtab matches kallsyms" test does have to do it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-8-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf symbols: Prevent the use of kcore if the kernel has movedAdrian Hunter
Use of kcore is predicated upon it matching the recorded data. If the kernel has been relocated at boot time (i.e. since the data was recorded) then do not use kcore. Note that it is possible to make a copy of kcore at the time the data is recorded using 'perf buildid-cache'. Then the perf tools will use the copy because it does match the data. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-7-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf record: Get ref_reloc_sym from kernel mapAdrian Hunter
Now that ref_reloc_sym is set up when the kernel map is created, 'perf record' does not need to pass the symbol names to perf_event__synthesize_kernel_mmap() which can read the values needed from ref_reloc_sym directly. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-6-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf machine: Set up ref_reloc_sym in machine__create_kernel_maps()Adrian Hunter
The ref_reloc_sym is always needed for the kernel map in order to check for relocation. Consequently set it up when the kernel map is created. Otherwise it was only being set up by 'perf record'. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-5-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf machine: Add machine__get_kallsyms_filename()Adrian Hunter
Separate out the logic used to make the kallsyms full path name for a machine. It will be reused in a subsequent patch. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-4-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tools: Add kallsyms__get_function_start()Adrian Hunter
Separate out the logic used to find the start address of the reference symbol used to track kernel relocation. kallsyms__get_function_start() is used in subsequent patches. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf symbols: Fix symbol annotation for relocated kernelAdrian Hunter
Kernel maps map memory addresses to file offsets. For symbol annotation, objdump needs the object VMA addresses. For an unrelocated kernel, that is the same as the memory address. The addresses passed to objdump for symbol annotation did not take into account kernel relocation. This patch fixes that. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tools: Fix include for non x86 architecturesFrancesco Fusco
Commit 71ae8aac ("lib: introduce arch optimized hash library") added an include to <linux/hash.h> for setting up an architecture specific fast hash. Since perf includes directly the non-uapi kernel header, it cannot find <asm/hash.h> on non-x86 and thus prevents perf to be compiled on every architecture other than x86. The problem is the inclusion of <asm/hash.h> in hash.h that results in the following error originating from util/evlist.c: fatal error: asm/hash.h: No such file or directory This commit simply adds an empty <asm/hash.h> stub/file to fix the compile issue on non-x86 architectures. As perf does not use any of these new functions, it fixes the compilation and therefore seems to be the most appropriate solution to go with. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Link: http://lkml.kernel.org/r/2cf8143aad65a6aa6fe30325ef8a65847141afa2.1390829373.git.ffusco@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-29perf tools: Fix AAAAARGH64 memory barriersPeter Zijlstra
Someone got the load and store barriers mixed up for AAAAARGH64. Turn them the right side up. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Fixes: a94d342b9cb0 ("tools/perf: Add required memory barriers") Cc: Ingo Molnar <mingo@kernel.org> Cc: Will Deacon <will.deacon@arm.com> Link: http://lkml.kernel.org/r/20140124154002.GF31570@twins.programming.kicks-ass.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-27perf tools: Demangle kernel and kernel module symbols tooAvi Kivity
Some kernels contain C++ code, and thus their symbols need to be demangled. This allows 'perf kvm top' to generate readable output. Signed-off-by: Avi Kivity <avi@cloudius-systems.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/26f71bf5bf7ee1408e3f1a803556d5df18223ef1.1390420726.git.avi@cloudius-systems.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
