As with indirect_to_ptr(), ptr_to_indirect() and
RADIX_TREE_INDIRECT_PTR, change radix_tree_is_indirect_ptr() to
radix_tree_is_internal_node().
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com>
Cc: Jan Kara <jack@suse.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Mirrors the earlier commit introducing node_to_entry().
Also change the type returned to be a struct radix_tree_node pointer.
That lets us simplify a couple of places in the radix tree shrink &
extend paths where we could convert an entry into a pointer, modify the
node, then convert the pointer back into an entry.
verify_node() can use node->shift instead of the height.
tree_verify_min_height() can be converted over to using node_maxindex()
and shift_maxindex() instead of radix_tree_maxindex().
- Print which indices are covered by every leaf entry
- Print sibling entries
- Print the node pointer instead of the slot entry
- Build by default in userspace, and make it accessible to the test-suite
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
I had previously decided that tagging a single multiorder entry would
count as tagging 2^order entries for the purposes of 'nr_to_tag'. I now
believe that decision to be a mistake, and it should count as a single
entry. That's more likely to be what callers expect.
When walking back up the tree from a newly-tagged entry, the current
code assumed we were starting from the lowest level of the tree; if we
have a multiorder entry with an order at least RADIX_TREE_MAP_SHIFT in
size then we need to shift the index by 'shift' before we start walking
back up the tree, or we will end up not setting tags on higher entries,
and then mistakenly thinking that entries below a certain point in the
tree are not tagged.
If the first index we examine is a sibling entry of a tagged multiorder
entry, we were not tagging it. We need to examine the canonical entry,
and the easiest way to do that is to use radix_tree_descend(). We then
have to skip over sibling slots when looking for the next entry in the
tree or we will end up walking back to the canonical entry.
Add several tests for radix_tree_range_tag_if_tagged().
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Add a unit test that provides coverage for the bug fixed in the commit
entitled "radix-tree: rewrite radix_tree_locate_item fix" from Hugh
Dickins. I've verified that this test fails before his patch due to
miscalculated 'index' values in __locate() in lib/radix-tree.c, and
passes with his fix.
Link: http://lkml.kernel.org/r/1462307263-20623-1-git-send-email-ross.zwisler@linux.intel.com
Use the new multi-order support functions to rewrite
radix_tree_locate_item(). Modify the locate tests to test multiorder
entries too.
[hughd@google.com: radix_tree_locate_item() is often returning the wrong index]
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1605012108490.1166@eggly.anvils
If the radix tree user attempted to insert a colliding entry with an
existing multiorder entry, then radix_tree_create() could encounter a
sibling entry when walking down the tree to look for a slot. Use
radix_tree_descend() to fix the problem, and add a test-case to make
sure the problem doesn't come back in future.
Add a generic test for multi-order tag verification, and call it using
several different configurations.
This test creates a multi-order radix tree using the given index and
order, and then sets, checks and clears tags using the indices covered
by the single multi-order radix tree entry.
With the various calls done by this test we verify root multi-order
entries without siblings, multi-order entries without siblings in a
radix tree node, as well as multi-order entries with siblings of various
sizes.
Add a unit test to verify that we can iterate over multi-order entries
properly via a radix_tree_for_each_slot() loop.
This was done with a single, somewhat complicated configuration that was
meant to test many of the various corner cases having to do with
multi-order entries:
- An iteration could begin at a sibling entry, and we need to return the
canonical entry.
- We could have entries of various orders in the same slots[] array.
- We could have multi-order entries at a nonzero height, followed by
indirect pointers to more radix tree nodes later in that same slots[]
array.
This enables the macros radix_tree_for_each_slot() and friends to be
used with multi-order entries.
The way that this works is that we treat all entries in a given slots[]
array as a single chunk. If the index given to radix_tree_next_chunk()
happens to point us to a sibling entry, we will back up iter->index so
that it points to the canonical entry, and that will be the place where
we start our iteration.
As we're processing a chunk in radix_tree_next_slot(), we process
canonical entries, skip over sibling entries, and restart the chunk
lookup if we find a non-sibling indirect pointer. This drops back to
the radix_tree_next_chunk() code, which will re-walk the tree and look
for another chunk.
This allows us to properly handle multi-order entries mixed with other
entries that are at various heights in the radix tree.
These BUG_ON tests are to ensure that all the tags are clear when
inserting a new entry. If we insert a multiorder entry, we'll end up
looking at the tags for a different node, and so the BUG_ON can end up
triggering spuriously.
Also, we now have three tags, not two, so check all three are clear, and
check all the root tags with a single call to BUG_ON since the bits are
stored contiguously.
Include a test-case to ensure this problem does not reoccur.
Setting the indirect bit on the user data entry used to be unambiguous
because the tree walking code knew not to expect internal nodes in the
last level of the tree. Multiorder entries can appear at any level of
the tree, and a leaf with the indirect bit set is indistinguishable from
a pointer to a node.
Introduce a special entry (RADIX_TREE_RETRY) which is neither a valid
user entry, nor a valid pointer to a node. The radix_tree_deref_retry()
function continues to work the same way, but tree walking code can
distinguish it from a pointer to a node.
Also fix the condition for setting slot->parent to NULL; it does not
matter what height the tree is, it only matters whether slot is an
indirect pointer. Move this code above the comment which is referring
to the assignment to root->rnode.
Also fix the condition for preventing the tree from shrinking to a
single entry if it's a multiorder entry.
Add a test-case to the test suite that checks that the tree goes back
down to its original height after an item is inserted & deleted from a
higher index in the tree.
Test suite infrastructure for working with multiorder entries.
The test itself is pretty basic: Add an entry, check that all expected
indices return that entry and that indices around that entry don't
return an entry. Then delete the entry and check no index returns that
entry. Tests a few edge conditions including the multiorder entry at
index 0 and at a higher index. Also tests deleting through an alias as
well as through the canonical index.
I've been receiving increasingly concerned notes from 0day about how
much my recent changes have been bloating the radix tree. Make it
happier by only including multiorder support if
CONFIG_TRANSPARENT_HUGEPAGES is set.
This is an independent Kconfig option, so other radix tree users can
also set it if they have a need.
When we make changes to radix-tree.h in the regular kernel source
(include/linux/radix-tree.h), we really want our test code to be
rebuilt.
We also include a few other headers from tools/include and probably want
to rebuild if these have been changed.
Update the makefile so that all of our objects will be rebuilt when any
of the headers we depend on are changed.
Currently the full suite of regression tests take upwards of 30 minutes
to run on my development machine. The vast majority of this time is
taken by the big_gang_check() and copy_tag_check() tests, which each run
their tests through thousands of iterations...does this have value?
Without big_gang_check() and copy_tag_check(), the test suite runs in
around 15 seconds on my box.
Honestly the first time I ever ran through the entire test suite was to
gather the timings for this email - it simply takes too long to be
useful on a normal basis.
Instead, hide the excessive iterations through big_gang_check() and
copy_tag_check() tests behind an '-l' flag (for "long run") in case they
are still useful, but allow the regression test suite to complete in a
reasonable amount of time. We still run each of these tests a few times
(3 at present) to try and keep the test coverage.
The defines in regression2.c are already in radix-tree.h and duplicating
them in the test case makes experimenting with other values for the
fan-out harder than necessary. Allow the user of the radix tree to
decide what the fan-out should be rather than fixing it to 8 for
non-kernel uses.
Fairly simple tests; add various items to the tree, then make sure we
can find them again. Also check that a pointer that we know isn't in
the tree is not found.
Add an empty linux/init.h, and definitions for a few parts of the kernel
API either in use now, or to be used in the near future. Start using the
common definitions in tools/include/linux, although more work needs to be
done here.
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Support for Power ISA 3.0 (Power9) Radix Tree MMU from Aneesh Kumar K.V
- Live patching support for ppc64le (also merged via livepatching.git)
Various cleanups & minor fixes from:
- Aaro Koskinen, Alexey Kardashevskiy, Andrew Donnellan, Aneesh Kumar K.V,
Chris Smart, Daniel Axtens, Frederic Barrat, Gavin Shan, Ian Munsie,
Lennart Sorensen, Madhavan Srinivasan, Mahesh Salgaonkar, Markus Elfring,
Michael Ellerman, Oliver O'Halloran, Paul Gortmaker, Paul Mackerras,
Rashmica Gupta, Russell Currey, Suraj Jitindar Singh, Thiago Jung
Bauermann, Valentin Rothberg, Vipin K Parashar.
General:
- Update LMB associativity index during DLPAR add/remove from Nathan
Fontenot
- Fix branching to OOL handlers in relocatable kernel from Hari Bathini
- Add support for userspace Power9 copy/paste from Chris Smart
- Always use STRICT_MM_TYPECHECKS from Michael Ellerman
- Add mask of possible MMU features from Michael Ellerman
PCI:
- Enable pass through of NVLink to guests from Alexey Kardashevskiy
- Cleanups in preparation for powernv PCI hotplug from Gavin Shan
- Don't report error in eeh_pe_reset_and_recover() from Gavin Shan
- Restore initial state in eeh_pe_reset_and_recover() from Gavin Shan
- Revert "powerpc/eeh: Fix crash in eeh_add_device_early() on Cell"
from Guilherme G Piccoli
- Remove the dependency on EEH struct in DDW mechanism from Guilherme
G Piccoli
selftests:
- Test cp_abort during context switch from Chris Smart
- Add several tests for transactional memory support from Rashmica
Gupta
perf:
- Add support for sampling interrupt register state from Anju T
- Add support for unwinding perf-stackdump from Chandan Kumar
cxl:
- Configure the PSL for two CAPI ports on POWER8NVL from Philippe
Bergheaud
- Allow initialization on timebase sync failures from Frederic Barrat
- Increase timeout for detection of AFU mmio hang from Frederic
Barrat
- Handle num_of_processes larger than can fit in the SPA from Ian
Munsie
- Ensure PSL interrupt is configured for contexts with no AFU IRQs
from Ian Munsie
- Add kernel API to allow a context to operate with relocate disabled
from Ian Munsie
- Check periodically the coherent platform function's state from
Christophe Lombard
Freescale:
- Updates from Scott: "Contains 86xx fixes, minor device tree fixes,
an erratum workaround, and a kconfig dependency fix."
* tag 'powerpc-4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (192 commits)
powerpc/86xx: Fix PCI interrupt map definition
powerpc/86xx: Move pci1 definition to the include file
powerpc/fsl: Fix build of the dtb embedded kernel images
powerpc/fsl: Fix rcpm compatible string
powerpc/fsl: Remove FSL_SOC dependency from FSL_LBC
powerpc/fsl-pci: Add a workaround for PCI 5 errata
powerpc/fsl: Fix SPI compatible on t208xrdb and t1040rdb
powerpc/powernv/npu: Add PE to PHB's list
powerpc/powernv: Fix insufficient memory allocation
powerpc/iommu: Remove the dependency on EEH struct in DDW mechanism
powerpc/eeh: Drop unnecessary label in eeh_pe_change_owner()
powerpc/eeh: Ignore handlers in eeh_pe_reset_and_recover()
powerpc/eeh: Restore initial state in eeh_pe_reset_and_recover()
powerpc/eeh: Don't report error in eeh_pe_reset_and_recover()
Revert "powerpc/powernv: Exclude root bus in pnv_pci_reset_secondary_bus()"
powerpc/powernv/npu: Enable NVLink pass through
powerpc/powernv/npu: Rework TCE Kill handling
powerpc/powernv/npu: Add set/unset window helpers
powerpc/powernv/ioda2: Export debug helper pe_level_printk()
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS for 4.7. Here's the summary of
the changes:
- ATH79: Support for DTB passuing using the UHI boot protocol
- ATH79: Remove support for builtin DTB.
- ATH79: Add zboot debug serial support.
- ATH79: Add initial support for Dragino MS14 (Dragine 2), Onion Omega
and DPT-Module.
- ATH79: Update devicetree clock support for AR9132 and AR9331.
- ATH79: Cleanup the DT code.
- ATH79: Support newer SOCs in ath79_ddr_ctrl_init.
- ATH79: Fix regression in PCI window initialization.
- BCM47xx: Move SPROM driver to drivers/firmware/
- BCM63xx: Enable partition parser in defconfig.
- BMIPS: BMIPS5000 has I cache filing from D cache
- BMIPS: BMIPS: Add cpu-feature-overrides.h
- BMIPS: Add Whirlwind support
- BMIPS: Adjust mips-hpt-frequency for BCM7435
- BMIPS: Remove maxcpus from BCM97435SVMB DTS
- BMIPS: Add missing 7038 L1 register cells to BCM7435
- BMIPS: Various tweaks to initialization code.
- BMIPS: Enable partition parser in defconfig.
- BMIPS: Cache tweaks.
- BMIPS: Add UART, I2C and SATA devices to DT.
- BMIPS: Add BCM6358 and BCM63268support
- BMIPS: Add device tree example for BCM6358.
- BMIPS: Improve Improve BCM6328 and BCM6368 device trees
- Lantiq: Add support for device tree file from boot loader
- Lantiq: Allow build with no built-in DT.
- Loongson 3: Reserve 32MB for RS780E integrated GPU.
- Loongson 3: Fix build error after ld-version.sh modification
- Loongson 3: Move chipset ACPI code from drivers to arch.
- Loongson 3: Speedup irq processing.
- Loongson 3: Add basic Loongson 3A support.
- Loongson 3: Set cache flush handlers to nop.
- Loongson 3: Invalidate special TLBs when needed.
- Loongson 3: Fast TLB refill handler.
- MT7620: Fallback strategy for invalid syscfg0.
- Netlogic: Fix CP0_EBASE redefinition warnings
- Octeon: Initialization fixes
- Octeon: Add DTS files for the D-Link DSR-1000N and EdgeRouter Lite
- Octeon: Enable add Octeon-drivers in cavium_octeon_defconfig
- Octeon: Correctly handle endian-swapped initramfs images.
- Octeon: Support CN73xx, CN75xx and CN78xx.
- Octeon: Remove dead code from cvmx-sysinfo.
- Octeon: Extend number of supported CPUs past 32.
- Octeon: Remove some code limiting NR_IRQS to 255.
- Octeon: Simplify octeon_irq_ciu_gpio_set_type.
- Octeon: Mark some functions __init in smp.c
- Octeon: Octeon: Add Octeon III CN7xxx interface detection
- PIC32: Add serial driver and bindings for it.
- PIC32: Add PIC32 deadman timer driver and bindings.
- PIC32: Add PIC32 clock timer driver and bindings.
- Pistachio: Determine SoC revision during boot
- Sibyte: Fix Kconfig dependencies of SIBYTE_BUS_WATCHER.
- Sibyte: Strip redundant comments from bcm1480_regs.h.
- Panic immediately if panic_on_oops is set.
- module: fix incorrect IS_ERR_VALUE macro usage.
- module: Make consistent use of pr_*
- Remove no longer needed work_on_cpu() call.
- Remove CONFIG_IPV6_PRIVACY from defconfigs.
- Fix registers of non-crashing CPUs in dumps.
- Handle MIPSisms in new vmcore_elf32_check_arch.
- Select CONFIG_HANDLE_DOMAIN_IRQ and make it work.
- Allow RIXI to be used on non-R2 or R6 cores.
- Reserve nosave data for hibernation
- Fix siginfo.h to use strict POSIX types.
- Don't unwind user mode with EVA.
- Fix watchpoint restoration
- Ptrace watchpoints for R6.
- Sync icache when it fills from dcache
- I6400 I-cache fills from dcache.
- Various MSA fixes.
- Cleanup MIPS_CPU_* definitions.
- Signal: Move generic copy_siginfo to signal.h
- Signal: Fix uapi include in exported asm/siginfo.h
- Timer fixes for sake of KVM.
- XPA TLB refill fixes.
- Treat perf counter feature
- Update John Crispin's email address
- Add PIC32 watchdog and bindings.
- Handle R10000 LL/SC bug in set_pte()
- cpufreq: Various fixes for Longson1.
- R6: Fix R2 emulation.
- mathemu: Cosmetic fix to ADDIUPC emulation, plenty of other small fixes
- ELF: ABI and FP fixes.
- Allow for relocatable kernel and use that to support KASLR.
- Fix CPC_BASE_ADDR mask
- Plenty fo smp-cps, CM, R6 and M6250 fixes.
- Make reset_control_ops const.
- Fix kernel command line handling of leading whitespace.
- Cleanups to cache handling.
- Add brcm, bcm6345-l1-intc device tree bindings.
- Use generic clkdev.h header
- Remove CLK_IS_ROOT usage.
- Misc small cleanups.
- CM: Fix compilation error when !MIPS_CM
- oprofile: Fix a preemption issue
- Detect DSP ASE v3 support:1"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (275 commits)
MIPS: pic32mzda: fix getting timer clock rate.
MIPS: ath79: fix regression in PCI window initialization
MIPS: ath79: make ath79_ddr_ctrl_init() compatible for newer SoCs
MIPS: Fix VZ probe gas errors with binutils <2.24
MIPS: perf: Fix I6400 event numbers
MIPS: DEC: Export `ioasic_ssr_lock' to modules
MIPS: MSA: Fix a link error on `_init_msa_upper' with older GCC
MIPS: CM: Fix compilation error when !MIPS_CM
MIPS: Fix genvdso error on rebuild
USB: ohci-jz4740: Remove obsolete driver
MIPS: JZ4740: Probe OHCI platform device via DT
MIPS: JZ4740: Qi LB60: Remove support for AVT2 variant
MIPS: pistachio: Determine SoC revision during boot
MIPS: BMIPS: Adjust mips-hpt-frequency for BCM7435
mips: mt7620: fallback to SDRAM when syscfg0 does not have a valid value for the memory type
MIPS: Prevent "restoration" of MSA context in non-MSA kernels
MIPS: cevt-r4k: Dynamically calculate min_delta_ns
MIPS: malta-time: Take seconds into account
MIPS: malta-time: Start GIC count before syncing to RTC
MIPS: Force CPUs to lose FP context during mode switches
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"This includes two new updates for the ftrace infrastructure.
- With the changing of the code for filtering events by pid, from a
list of pids to a bitmask, we can now easily implement following
forks. With a new tracing option "event-fork" which, when set,
will have tasks with pids in set_event_pid, when they fork, to have
their child pids added to set_event_pid and the child will be
traced as well.
Note, if "event-fork" is set and a task with its pid in
set_event_pid exits, its pid will be removed from set_event_pid
- The addition of Tom Zanussi's hist triggers. This includes a very
thorough documentatino on how to use the hist triggers with events.
This introduces a quick and easy way to get histogram data from
events and their fields.
Some other cleanups and updates were added as well. Like Masami
Hiramatsu added test cases for the event trigger and hist triggers.
Also I added a speed up of filtering by using a temp buffer when
filters are set"
* tag 'trace-v4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (45 commits)
tracing: Use temp buffer when filtering events
tracing: Remove TRACE_EVENT_FL_USE_CALL_FILTER logic
tracing: Remove unused function trace_current_buffer_lock_reserve()
tracing: Remove one use of trace_current_buffer_lock_reserve()
tracing: Have trace_buffer_unlock_commit() call the _regs version with NULL
tracing: Remove unused function trace_current_buffer_discard_commit()
tracing: Move trace_buffer_unlock_commit{_regs}() to local header
tracing: Fold filter_check_discard() into its only user
tracing: Make filter_check_discard() local
tracing: Move event_trigger_unlock_commit{_regs}() to local header
tracing: Don't use the address of the buffer array name in copy_from_user
tracing: Handle tracing_map_alloc_elts() error path correctly
tracing: Add check for NULL event field when creating hist field
tracing: checking for NULL instead of IS_ERR()
tracing: Do not inherit event-fork option for instances
tracing: Fix unsigned comparison to zero in hist trigger code
kselftests/ftrace: Add a test for log2 modifier of hist trigger
tracing: Add hist trigger 'log2' modifier
kselftests/ftrace: Add hist trigger testcases
kselftests/ftrace : Add event trigger testcases
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for kernel cycle v4.7:
Core infrastructural changes:
- Support for natively single-ended GPIO driver stages.
This means that if the hardware has registers to configure open
drain or open source configuration, we use that rather than (as we
did before) try to emulate it by switching the line to an input to
get high impedance.
This is also documented throughly in Documentation/gpio/driver.txt
for those of you who did not understand one word of what I just
wrote.
- Start to do away with the unnecessarily complex and unitelligible
ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB, another
evolutional artifact from the time when the GPIO subsystem was
unmaintained.
Archs can now just select GPIOLIB and be done with it, cleanups to
arches will trickle in for the next kernel. Some minor archs ACKed
the changes immediately so these are included in this pull request.
- Advancing the use of the data pointer inside the GPIO device for
storing driver data by switching the PowerPC, Super-H Unicore and
a few other subarches or subsystem drivers in ALSA SoC, Input,
serial, SSB, staging etc to use it.
- The initialization now reads the input/output state of the GPIO
lines, so that each GPIO descriptor knows - if this callback is
implemented - whether the line is input or output. This also
reflects nicely in userspace "lsgpio".
- It is now possible to name GPIO producer names, line names, from
the device tree. (Platform data has been supported for a while).
I bet we will get a similar mechanism for ACPI one of those days.
This makes is possible to get sensible producer names for e.g.
GPIO rails in "lsgpio" in userspace.
New drivers:
- New driver for the Loongson1.
- The XLP driver now supports Broadcom Vulcan ARM64.
- The IT87 driver now supports IT8620 and IT8628.
- The PCA953X driver now supports Galileo Gen2.
Driver improvements:
- MCP23S08 was switched to use the gpiolib irqchip helpers and now
also suppors level-triggered interrupts.
- 74x164 and RCAR now supports the .set_multiple() callback
- AMDPT was converted to use generic GPIO.
- TC3589x, TPS65218, SX150X, F7188X, MENZ127, VX855, WM831X, WM8994
support the new single ended callback for open drain and in some
cases open source.
- Implement the .get_direction() callback for a few more drivers like
PL061, Xgene.
Cleanups:
- Paul Gortmaker combed through the drivers and de-modularized those
who are not really modules.
- Move the GPIO poweroff DT bindings to the power subdir where they
belong.
- Rename gpio-generic.c to gpio-mmio.c, which is much more to the
point. That's what it is handling, nothing more, nothing less"
* tag 'gpio-v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (126 commits)
MIPS: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB
gpio: zevio: make it explicitly non-modular
gpio: timberdale: make it explicitly non-modular
gpio: stmpe: make it explicitly non-modular
gpio: sodaville: make it explicitly non-modular
pinctrl: sh-pfc: Let gpio_chip.to_irq() return zero on error
gpio: dwapb: Add ACPI device ID for DWAPB GPIO controller on X-Gene platforms
gpio: dt-bindings: add wd,mbl-gpio bindings
gpio: of: make it possible to name GPIO lines
gpio: make gpiod_to_irq() return negative for NO_IRQ
gpio: xgene: implement .get_direction()
gpio: xgene: Enable ACPI support for X-Gene GFC GPIO driver
gpio: tegra: Implement gpio_get_direction callback
gpio: set up initial state from .get_direction()
gpio: rename gpio-generic.c into gpio-mmio.c
gpio: generic: fix GPIO_GENERIC_PLATFORM is set to module case
gpio: dwapb: add gpio-signaled acpi event support
gpio: dwapb: convert device node to fwnode
gpio: dwapb: remove name from dwapb_port_property
gpio/qoriq: select IRQ_DOMAIN
Pull trivial tree updates from Jiri Kosina.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (21 commits)
gitignore: fix wording
mfd: ab8500-debugfs: fix "between" in printk
memstick: trivial fix of spelling mistake on management
cpupowerutils: bench: fix "average"
treewide: Fix typos in printk
IB/mlx4: printk fix
pinctrl: sirf/atlas7: fix printk spelling
serial: mctrl_gpio: Grammar s/lines GPIOs/line GPIOs/, /sets/set/
w1: comment spelling s/minmum/minimum/
Blackfin: comment spelling s/divsor/divisor/
metag: Fix misspellings in comments.
ia64: Fix misspellings in comments.
hexagon: Fix misspellings in comments.
tools/perf: Fix misspellings in comments.
cris: Fix misspellings in comments.
c6x: Fix misspellings in comments.
blackfin: Fix misspelling of 'register' in comment.
avr32: Fix misspelling of 'definitions' in comment.
Doc: treewide : Fix typos in DocBook/filesystem.xml
Pull ACPI updates from Rafael Wysocki:
"The new features here are ACPI 6.1 support (and some previously
missing bits of ACPI 6.0 support) in ACPICA and two new drivers, a
driver for the ACPI Generic Event Device (GED) feature introduced by
ACPI 6.1 and the INT3406 thermal driver for display thermal
management. Also the value returned by the _HRV (hardware revision)
ACPI object will be exported to user space via sysfs now.
In addition to that, ACPI on ARM64 will not depend on EXPERT any more.
The rest is mostly fixes and cleanups and some code reorganization.
Specifics:
- In-kernel ACPICA code update to the upstream release 20160422
adding support for ACPI 6.1 along with some previously missing bits
of ACPI 6.0 support, making a fair amount of fixes and cleanups and
reducing divergences between the upstream ACPICA and the in-kernel
code (Bob Moore, Lv Zheng, Al Stone, Aleksey Makarov, Will Miles)
- ACPI Generic Event Device (GED) support and a fix for it (Sinan
Kaya, Paul Gortmaker)
- INT3406 thermal driver for display thermal management and ACPI
backlight support code reorganization related to it (Aaron Lu, Arnd
Bergmann)
- Support for exporting the value returned by the _HRV (hardware
revision) ACPI object via sysfs (Betty Dall)
- Removal of the EXPERT dependency for ACPI on ARM64 (Mark Brown)
- Rework of the handling of ACPI _OSI mechanism allowing the
_OSI("Darwin") support to be overridden from the kernel command
line among other things (Lv Zheng, Chen Yu)
- Rework of the ACPI tables override mechanism to prepare it for the
introduction of overlays support going forward (Lv Zheng, Rafael
Wysocki)
- Fixes related to the ECDT support and module-level execution of AML
(Lv Zheng)
- ACPI PCI interrupts management update to make it work better on
ARM64 mostly (Sinan Kaya)
- ACPI SRAT handling update to make the code process all entires in
the table order regardless of the entry type (Lukasz Anaczkowski)
- EFI power off support for full-hardware ACPI platforms that don't
support ACPI S5 (Chen Yu)
- Fixes and cleanups related to the ACPI core's sysfs interface (Dan
Carpenter, Betty Dall)
- acpi_dev_present() API rework to reduce possible confusion related
to it (Lukas Wunner)
- Removal of CLK_IS_ROOT from two ACPI drivers (Stephen Boyd)"
* tag 'acpi-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (82 commits)
ACPI / video: mark acpi_video_get_levels() inline
Thermal / ACPI / video: add INT3406 thermal driver
ACPI / GED: make evged.c explicitly non-modular
ACPI / tables: Fix DSDT override mechanism
ACPI / sysfs: fix error code in get_status()
ACPICA: Update version to 20160422
ACPICA: Move all ASCII utilities to a common file
ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support for acpi_hw_write()
ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support in acpi_hw_read()
ACPICA: Executer: Introduce a set of macros to handle bit width mask generation
ACPICA: Hardware: Add optimized access bit width support
ACPICA: Utilities: Add ACPI_IS_ALIGNED() macro
ACPICA: Renamed some #defined flag constants for clarity
ACPICA: ACPI 6.0, tools/iasl: Add support for new resource descriptors
ACPICA: ACPI 6.0: Update _BIX support for new package element
ACPICA: ACPI 6.1: Support for new PCCT subtable
ACPICA: Refactor evaluate_object to reduce nesting
ACPICA: Divergence: remove unwanted spaces for typedef
ACPI,PCI,IRQ: remove SCI penalize function
ACPI,PCI,IRQ: remove redundant code in acpi_irq_penalty_init()
Pull power management updates from Rafael Wysocki:
"The majority of changes go into the cpufreq subsystem this time.
To me, quite obviously, the biggest ticket item is the new "schedutil"
governor. Interestingly enough, it's the first new cpufreq governor
since the beginning of the git era (except for some out-of-the-tree
ones).
There are two main differences between it and the existing governors.
First, it uses the information provided by the scheduler directly for
making its decisions, so it doesn't have to track anything by itself.
Second, it can invoke drivers (supporting that feature) to adjust CPU
performance right away without having to spawn work items to be
executed in process context or similar. Currently, the acpi-cpufreq
driver is the only one supporting that mode of operation, but then it
is used on a large number of systems.
The "schedutil" governor as included here is very simple and mostly
regarded as a foundation for future work on the integration of the
scheduler with CPU power management (in fact, there is work in
progress on top of it already). Nevertheless it works and the
preliminary results obtained with it are encouraging.
There also is some consolidation of CPU frequency management for ARM
platforms that can add their machine IDs the the new stub dt-platdev
driver now and that will take care of creating the requisite platform
device for cpufreq-dt, so it is not necessary to do that in platform
code any more. Several ARM platforms are switched over to using this
generic mechanism.
In addition to that, the intel_pstate driver is now going to respect
CPU frequency limits set by the platform firmware (or a BMC) and
provided via the ACPI _PPC object.
The devfreq subsystem is getting a new "passive" governor for SoCs
subsystems that will depend on somebody else to manage their voltage
rails and its support for Samsung Exynos SoCs is consolidated.
The rest is support for new hardware (Intel Broxton support in
intel_idle for one example), bug fixes, optimizations and cleanups in
a number of places.
Specifics:
- New cpufreq "schedutil" governor (making decisions based on CPU
utilization information provided by the scheduler and capable of
switching CPU frequencies right away if the underlying driver
supports that) and support for fast frequency switching in the
acpi-cpufreq driver (Rafael Wysocki)
- Consolidation of CPU frequency management on ARM platforms allowing
them to get rid of some platform-specific boilerplate code if they
are going to use the cpufreq-dt driver (Viresh Kumar, Finley Xiao,
Marc Gonzalez)
- Support for ACPI _PPC and CPU frequency limits in the intel_pstate
driver (Srinivas Pandruvada)
- Fixes and cleanups in the cpufreq core and generic governor code
(Rafael Wysocki, Sai Gurrappadi)
- intel_pstate driver optimizations and cleanups (Rafael Wysocki,
Philippe Longepe, Chen Yu, Joe Perches)
- cpufreq powernv driver fixes and cleanups (Akshay Adiga, Shilpasri
Bhat)
- cpufreq qoriq driver fixes and cleanups (Jia Hongtao)
- ACPI cpufreq driver cleanups (Viresh Kumar)
- Assorted cpufreq driver updates (Ashwin Chaugule, Geliang Tang,
Javier Martinez Canillas, Paul Gortmaker, Sudeep Holla)
- Assorted cpufreq fixes and cleanups (Joe Perches, Arnd Bergmann)
- Fixes and cleanups in the OPP (Operating Performance Points)
framework, mostly related to OPP sharing, and reorganization of
OF-dependent code in it (Viresh Kumar, Arnd Bergmann, Sudeep Holla)
- New "passive" governor for devfreq (for SoC subsystems that will
rely on someone else for the management of their power resources)
and consolidation of devfreq support for Exynos platforms, coding
style and typo fixes for devfreq (Chanwoo Choi, MyungJoo Ham)
- PM core fixes and cleanups, mostly to make it work better with the
generic power domains (genpd) framework, and updates for that
framework (Ulf Hansson, Thierry Reding, Colin Ian King)
- Intel Broxton support for the intel_idle driver (Len Brown)
- cpuidle core optimization and fix (Daniel Lezcano, Dave Gerlach)
- ARM cpuidle cleanups (Jisheng Zhang)
- Intel Kabylake support for the RAPL power capping driver (Jacob
Pan)
- AVS (Adaptive Voltage Switching) rockchip-io driver update (Heiko
Stuebner)
- Updates for the cpupower tool (Arjun Sreedharan, Colin Ian King,
Mattia Dongili, Thomas Renninger)"
* tag 'pm-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (112 commits)
intel_pstate: Clean up get_target_pstate_use_performance()
intel_pstate: Use sample.core_avg_perf in get_avg_pstate()
intel_pstate: Clarify average performance computation
intel_pstate: Avoid unnecessary synchronize_sched() during initialization
cpufreq: schedutil: Make default depend on CONFIG_SMP
cpufreq: powernv: del_timer_sync when global and local pstate are equal
cpufreq: powernv: Move smp_call_function_any() out of irq safe block
intel_pstate: Clean up intel_pstate_get()
cpufreq: schedutil: Make it depend on CONFIG_SMP
cpufreq: governor: Fix handling of special cases in dbs_update()
PM / OPP: Move CONFIG_OF dependent code in a separate file
cpufreq: intel_pstate: Ignore _PPC processing under HWP
cpufreq: arm_big_little: use generic OPP functions for {init, free}_opp_table
PM / OPP: add non-OF versions of dev_pm_opp_{cpumask_, }remove_table
cpufreq: tango: Use generic platdev driver
PM / OPP: pass cpumask by reference
cpufreq: Fix GOV_LIMITS handling for the userspace governor
cpupower: fix potential memory leak
PM / devfreq: style/typo fixes
PM / devfreq: exynos: Add the detailed correlation for Exynos5422 bus
Pull x86 boot updates from Ingo Molnar:
"The biggest changes in this cycle were:
- prepare for more KASLR related changes, by restructuring, cleaning
up and fixing the existing boot code. (Kees Cook, Baoquan He,
Yinghai Lu)
- simplifly/concentrate subarch handling code, eliminate
paravirt_enabled() usage. (Luis R Rodriguez)"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits)
x86/KASLR: Clarify purpose of each get_random_long()
x86/KASLR: Add virtual address choosing function
x86/KASLR: Return earliest overlap when avoiding regions
x86/KASLR: Add 'struct slot_area' to manage random_addr slots
x86/boot: Add missing file header comments
x86/KASLR: Initialize mapping_info every time
x86/boot: Comment what finalize_identity_maps() does
x86/KASLR: Build identity mappings on demand
x86/boot: Split out kernel_ident_mapping_init()
x86/boot: Clean up indenting for asm/boot.h
x86/KASLR: Improve comments around the mem_avoid[] logic
x86/boot: Simplify pointer casting in choose_random_location()
x86/KASLR: Consolidate mem_avoid[] entries
x86/boot: Clean up pointer casting
x86/boot: Warn on future overlapping memcpy() use
x86/boot: Extract error reporting functions
x86/boot: Correctly bounds-check relocations
x86/KASLR: Clean up unused code from old 'run_size' and rename it to 'kernel_total_size'
x86/boot: Fix "run_size" calculation
x86/boot: Calculate decompression size during boot not build
Pull x86 asm updates from Ingo Molnar:
"The main changes in this cycle were:
- MSR access API fixes and enhancements (Andy Lutomirski)
- early exception handling improvements (Andy Lutomirski)
- user-space FS/GS prctl usage fixes and improvements (Andy
Lutomirski)
- Remove the cpu_has_*() APIs and replace them with equivalents
(Borislav Petkov)
- task switch micro-optimization (Brian Gerst)
- 32-bit entry code simplification (Denys Vlasenko)
- enhance PAT handling in enumated CPUs (Toshi Kani)
... and lots of other cleanups/fixlets"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits)
x86/arch_prctl/64: Restore accidentally removed put_cpu() in ARCH_SET_GS
x86/entry/32: Remove asmlinkage_protect()
x86/entry/32: Remove GET_THREAD_INFO() from entry code
x86/entry, sched/x86: Don't save/restore EFLAGS on task switch
x86/asm/entry/32: Simplify pushes of zeroed pt_regs->REGs
selftests/x86/ldt_gdt: Test set_thread_area() deletion of an active segment
x86/tls: Synchronize segment registers in set_thread_area()
x86/asm/64: Rename thread_struct's fs and gs to fsbase and gsbase
x86/arch_prctl/64: Remove FSBASE/GSBASE < 4G optimization
x86/segments/64: When load_gs_index fails, clear the base
x86/segments/64: When loadsegment(fs, ...) fails, clear the base
x86/asm: Make asm/alternative.h safe from assembly
x86/asm: Stop depending on ptrace.h in alternative.h
x86/entry: Rename is_{ia32,x32}_task() to in_{ia32,x32}_syscall()
x86/asm: Make sure verify_cpu() has a good stack
x86/extable: Add a comment about early exception handlers
x86/msr: Set the return value to zero when native_rdmsr_safe() fails
x86/paravirt: Make "unsafe" MSR accesses unsafe even if PARAVIRT=y
x86/paravirt: Add paravirt_{read,write}_msr()
x86/msr: Carry on after a non-"safe" MSR access fails
Pull perf updates from Ingo Molnar:
"Bigger kernel side changes:
- Add backwards writing capability to the perf ring-buffer code,
which is preparation for future advanced features like robust
'overwrite support' and snapshot mode. (Wang Nan)
- Add pause and resume ioctls for the perf ringbuffer (Wang Nan)
- x86 Intel cstate code cleanups and reorgnization (Thomas Gleixner)
- x86 Intel uncore and CPU PMU driver updates (Kan Liang, Peter
Zijlstra)
- x86 AUX (Intel PT) related enhancements and updates (Alexander
Shishkin)
- x86 MSR PMU driver enhancements and updates (Huang Rui)
- ... and lots of other changes spread out over 40+ commits.
Biggest tooling side changes:
- 'perf trace' features and enhancements. (Arnaldo Carvalho de Melo)
- BPF tooling updates (Wang Nan)
- 'perf sched' updates (Jiri Olsa)
- 'perf probe' updates (Masami Hiramatsu)
- ... plus 200+ other enhancements, fixes and cleanups to tools/
The merge commits, the shortlog and the changelogs contain a lot more
details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (249 commits)
perf/core: Disable the event on a truncated AUX record
perf/x86/intel/pt: Generate PMI in the STOP region as well
perf buildid-cache: Use lsdir() for looking up buildid caches
perf symbols: Use lsdir() for the search in kcore cache directory
perf tools: Use SBUILD_ID_SIZE where applicable
perf tools: Fix lsdir to set errno correctly
perf trace: Move seccomp args beautifiers to tools/perf/trace/beauty/
perf trace: Move flock op beautifier to tools/perf/trace/beauty/
perf build: Add build-test for debug-frame on arm/arm64
perf build: Add build-test for libunwind cross-platforms support
perf script: Fix export of callchains with recursion in db-export
perf script: Fix callchain addresses in db-export
perf script: Fix symbol insertion behavior in db-export
perf symbols: Add dso__insert_symbol function
perf scripting python: Use Py_FatalError instead of die()
perf tools: Remove xrealloc and ALLOC_GROW
perf help: Do not use ALLOC_GROW in add_cmd_list
perf pmu: Make pmu_formats_string to check return value of strbuf
perf header: Make topology checkers to check return value of strbuf
perf tools: Make alias handler to check return value of strbuf
Pull core signal updates from Ingo Molnar:
"These updates from Stas Sergeev and Andy Lutomirski, improve the
sigaltstack interface by extending its ABI with the SS_AUTODISARM
feature, which makes it possible to use swapcontext() in a sighandler
that works on sigaltstack. Without this flag, the subsequent signal
will corrupt the state of the switched-away sighandler.
The inspiration is more robust dosemu signal handling"
* 'core-signals-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
signals/sigaltstack: Change SS_AUTODISARM to (1U << 31)
signals/sigaltstack: Report current flag bits in sigaltstack()
selftests/sigaltstack: Fix the sigaltstack test on old kernels
signals/sigaltstack: If SS_AUTODISARM, bypass on_sig_stack()
selftests/sigaltstack: Add new testcase for sigaltstack(SS_ONSTACK|SS_AUTODISARM)
signals/sigaltstack: Implement SS_AUTODISARM flag
signals/sigaltstack: Prepare to add new SS_xxx flags
signals/sigaltstack, x86/signals: Unify the x86 sigaltstack check with other architectures
Pull RCU updates from Ingo Molnar:
"The main changes are:
- Documentation updates, including fixes to the design-level
requirements documentation and a fixed version of the design-level
data-structure documentation. These fixes include removing
cartoons and getting rid of the html/htmlx duplication.
- Further improvements to the new-age expedited grace periods.
- Miscellaneous fixes.
- Torture-test changes, including a new rcuperf module for measuring
RCU grace-period performance and scalability, which is useful for
the expedited-grace-period changes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
rcutorture: Add boot-time adjustment of leaf fanout
rcutorture: Add irqs-disabled test for call_rcu()
rcutorture: Dump trace buffer upon shutdown
rcutorture: Don't rebuild identical kernel
rcutorture: Add OS-jitter capability
documentation: Add documentation for RCU's major data structures
rcutorture: Convert test duration to seconds early
torture: Kill qemu, not parent process
torture: Clarify refusal to run more than one torture test
rcutorture: Consider FROZEN hotplug notifier transitions
rcutorture: Remove redundant initialization to zero
rcuperf: Do not wake up shutdown wait queue if "shutdown" is false.
rcutorture: Add largish-system rcuperf scenario
rcutorture: Avoid RCU CPU stall warning and RT throttling
rcutorture: Add rcuperf holdoff boot parameter to reduce interference
rcutorture: Make scripts analyze rcuperf trace data, if present
rcutorture: Make rcuperf collect expedited event-trace data
rcutorture: Print measure of batching efficiency
rcutorture: Set rcuperf writer kthreads to real-time priority
rcutorture: Bind rcuperf reader/writer kthreads to CPUs
* acpi-pci:
ACPI,PCI,IRQ: reduce static IRQ array size to 16
ACPI,PCI,IRQ: reduce resource requirements
* acpi-misc:
ACPI / device_sysfs: Clean up checkpatch errors
ACPI / device_sysfs: Change _SUN and _STA show functions error return to EIO
ACPI / device_sysfs: Add sysfs support for _HRV hardware revision
arm64: defconfig: Enable ACPI
ACPI / ARM64: Remove EXPERT dependency for ACPI on ARM64
ACPI / ARM64: Don't enable ACPI by default on ARM64
acer-wmi: Use acpi_dev_found()
eeepc-wmi: Use acpi_dev_found()
ACPI / utils: Rename acpi_dev_present()
* acpi-tools:
tools/power/acpi: close file only if it is open
This adds self-test support on MIPS, based on RFC patch from Kees Cook.
Modifications from the RFC:
- support the O32 syscall which passes the real syscall number in a0.
- Use PTRACE_{GET,SET}REGS
- Because SYSCALL_NUM and SYSCALL_RET are the same register, it is not
possible to test modifying the syscall return value when skipping,
since both would need to set the same register. Therefore modify that
test case to just detect the skipped test.
Tested on MIPS32r2 / MIPS64r2 with O32, N32 and N64 userlands.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Cc: Will Drewry <wad@chromium.org>
Cc: IMG-MIPSLinuxKerneldevelopers@imgtec.com
Cc: linux-kselftest@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/12977/
After 0161028b7c8a ("perf/core: Change the default paranoia level to 2")
'perf stat' fails for users without CAP_SYS_ADMIN, so just use
'perf_evsel__fallback()' to have the same behaviour as 'perf record',
i.e. set perf_event_attr.exclude_kernel to 1.
Now:
[acme@jouet linux]$ perf stat usleep 1
Performance counter stats for 'usleep 1':
0.352536 task-clock:u (msec) # 0.423 CPUs utilized
0 context-switches:u # 0.000 K/sec
0 cpu-migrations:u # 0.000 K/sec
49 page-faults:u # 0.139 M/sec
309,407 cycles:u # 0.878 GHz
243,791 instructions:u # 0.79 insn per cycle
49,622 branches:u # 140.757 M/sec
3,884 branch-misses:u # 7.83% of all branches
0.000834174 seconds time elapsed
[acme@jouet linux]$
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-b20jmx4dxt5hpaa9t2rroi0o@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Now with the default for the kernel.perf_event_paranoid sysctl being 2 [1]
we need to fall back to :u, i.e. to set perf_event_attr.exclude_kernel
to 1.
Before:
[acme@jouet linux]$ perf record usleep 1
Error:
You may not have permission to collect stats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid,
which controls use of the performance events system by
unprivileged users (without CAP_SYS_ADMIN).
The current value is 2:
-1: Allow use of (almost) all events by all users
>= 0: Disallow raw tracepoint access by users without CAP_IOC_LOCK
>= 1: Disallow CPU event access by users without CAP_SYS_ADMIN
>= 2: Disallow kernel profiling by users without CAP_SYS_ADMIN
[acme@jouet linux]$
After:
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.016 MB perf.data (7 samples) ]
[acme@jouet linux]$ perf evlist
cycles:u
[acme@jouet linux]$ perf evlist -v
cycles:u: size: 112, { sample_period, sample_freq }: 4000, sample_type: IP|TID|TIME|PERIOD, disabled: 1, inherit: 1, exclude_kernel: 1, mmap: 1, comm: 1, freq: 1, enable_on_exec: 1, task: 1, sample_id_all: 1, exclude_guest: 1, mmap2: 1, comm_exec: 1
[acme@jouet linux]$
And if the user turns on verbose mode, an explanation will appear:
[acme@jouet linux]$ perf record -v usleep 1
Warning:
kernel.perf_event_paranoid=2, trying to fall back to excluding kernel samples
mmap size 528384B
Looking at the vmlinux_path (8 entries long)
Using /lib/modules/4.6.0-rc7+/build/vmlinux for symbols
[acme@jouet linux]$
[1] 0161028b7c8a ("perf/core: Change the default paranoia level to 2")
We were showing a hardcoded default value for the kernel.perf_event_paranoid
sysctl, now that it became more paranoid (1 -> 2 [1]), this would need to be
updated, instead show the current value:
[acme@jouet linux]$ perf record ls
Error:
[acme@jouet linux]$
Link: http://lkml.kernel.org/n/tip-0gc4rdpg8d025r5not8s8028@git.kernel.org
At the end of process_filter(), collapse_tree() was changed to update
the parg parameter, but the reassignment after the call wasn't removed.
What happens is that the "current_op" gets modified and freed and parg
is assigned to the new allocated argument. But after the call to
collapse_tree(), parg is assigned again to the just freed "current_op",
and this causes the tool to crash.
The current_op variable must also be assigned to NULL in case of error,
otherwise it will cause it to be free()ed twice.
Acked-by: Namhyung Kim <namhyung@kernel.org>
Cc: stable@vger.kernel.org # 3.14+
Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()")
Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home
If not, tell the user that:
config/Makefile:273: Old libdw.h, finding variables at given 'perf probe' point will not work, install elfutils-devel/libdw-dev >= 0.157
And return -ENOTSUPP in die_get_var_range(), failing features that
need it, like the one pointed out above.
This fixes the build on older systems, such as Ubuntu 12.04.5.
Cc: Vinson Lee <vlee@freedesktop.org>
Link: http://lkml.kernel.org/n/tip-9l7luqkq4gfnx7vrklkq4obs@git.kernel.org
To fix the build on Fedora Rawhide (gcc 6.0.0 20160311 (Red Hat 6.0.0-0.17):
CC /tmp/build/perf/arch/x86/util/dwarf-regs.o
arch/x86/util/dwarf-regs.c:66:36: error: 'x86_32_regoffset_table' defined but not used [-Werror=unused-const-variable=]
static const struct pt_regs_offset x86_32_regoffset_table[] = {
cc1: all warnings being treated as errors
Link: http://lkml.kernel.org/n/tip-fghuksc1u8ln82bof4lwcj0o@git.kernel.org
The readdir() function is thread safe as long as just one thread uses a
DIR, which is the case when parsing tracepoint event definitions, to
avoid breaking the build with glibc-2.23.90 (upcoming 2.24), use it
instead of readdir_r().
See: http://man7.org/linux/man-pages/man3/readdir.3.html
"However, in modern implementations (including the glibc implementation),
concurrent calls to readdir() that specify different directory streams
are thread-safe. In cases where multiple threads must read from the
same directory stream, using readdir() with external synchronization is
still preferable to the use of the deprecated readdir_r(3) function."
Noticed while building on a Fedora Rawhide docker container.
Link: http://lkml.kernel.org/n/tip-wddn49r6bz6wq4ee3dxbl7lo@git.kernel.org
DIR, which is the case in thread_map, so, to avoid breaking the build
with glibc-2.23.90 (upcoming 2.24), use it instead of readdir_r().
Link: http://lkml.kernel.org/n/tip-del8h2a0f40z75j4r42l96l0@git.kernel.org
DIR, which is the case in 'perf script', so, to avoid breaking the build
Link: http://lkml.kernel.org/n/tip-mt3xz7n2hl49ni2vx7kuq74g@git.kernel.org
DIR, which is the case when synthesizing events for pre-existing threads
by traversing /proc, so, to avoid breaking the build with glibc-2.23.90
CC /tmp/build/perf/util/event.o
util/event.c: In function '__event__synthesize_thread':
util/event.c:466:2: error: 'readdir_r' is deprecated [-Werror=deprecated-declarations]
while (!readdir_r(tasks, &dirent, &next) && next) {
In file included from /usr/include/features.h:368:0,
from /usr/include/stdint.h:25,
from /usr/lib/gcc/x86_64-redhat-linux/6.0.0/include/stdint.h:9,
from /git/linux/tools/include/linux/types.h:6,
from util/event.c:1:
/usr/include/dirent.h:189:12: note: declared here
Link: http://lkml.kernel.org/n/tip-i1vj7nyjp2p750rirxgrfd3c@git.kernel.org
Use new lsdir() for looking up buildid caches. This changes logic a bit
to ignore all dot files, since the build-id cache must not start with
dot.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Brendan Gregg <brendan.d.gregg@gmail.com>
Cc: Hemant Kumar <hemant@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20160511135217.23943.94596.stgit@devbox
Use lsdir() to search in kcore cache directory. This also avoids
checking hidden dot directory entries, because kcore cache directories
must always have the name from timestamps when taking the kcore
snapshots, and it never start with dot.
Link: http://lkml.kernel.org/r/20160511135208.23943.68071.stgit@devbox
Use the existing SBUILD_ID_SIZE macro instead of the equivalent
BUILD_ID_SIZE * 2 + 1 expression for allocating a buffer for build-id
strings.
Link: http://lkml.kernel.org/r/20160511135159.23943.57120.stgit@devbox
Fix lsdir() to set correct positive error number (ENOMEM). Since
"errno" must have a positive error number instead of negative number,
fix lsdir to set it correctly.
Fixes: e1ce726e1db2 ("perf tools: Add lsdir() helper to read a directory")
Link: http://lkml.kernel.org/r/20160511135127.23943.40644.stgit@devbox
To reduce the size of builtin-trace.c.
Link: http://lkml.kernel.org/n/tip-ovxifncj34ynrjjseg33lil3@git.kernel.org
Link: http://lkml.kernel.org/n/tip-c4c47w2a2jx13terl2p2hros@git.kernel.org
