path: root/tools/testing
2012-11-09revert "epoll: support for disabling items, and a self-test app"Andrew Morton
Revert commit 03a7beb55b9f ("epoll: support for disabling items, and a self-test app") pending resolution of the issues identified by Michael Kerrisk, copied below. We'll revisit this for 3.8. : I've taken a look at this patch as it currently stands in 3.7-rc1, and : done a bit of testing. (By the way, the test program : tools/testing/selftests/epoll/test_epoll.c does not compile...) : : There are one or two places where the behavior seems a little strange, : so I have a question or two at the end of this mail. But other than : that, I want to check my understanding so that the interface can be : correctly documented. : : Just to go though my understanding, the problem is the following : scenario in a multithreaded application: : : 1. Multiple threads are performing epoll_wait() operations, : and maintaining a user-space cache that contains information : corresponding to each file descriptor being monitored by : epoll_wait(). : : 2. At some point, a thread wants to delete (EPOLL_CTL_DEL) : a file descriptor from the epoll interest list, and : delete the corresponding record from the user-space cache. : : 3. The problem with (2) is that some other thread may have : previously done an epoll_wait() that retrieved information : about the fd in question, and may be in the middle of using : information in the cache that relates to that fd. Thus, : there is a potential race. : : 4. The race can't solved purely in user space, because doing : so would require applying a mutex across the epoll_wait() : call, which would of course blow thread concurrency. : : Right? : : Your solution is the EPOLL_CTL_DISABLE operation. I want to : confirm my understanding about how to use this flag, since : the description that has accompanied the patches so far : has been a bit sparse : : 0. In the scenario you're concerned about, deleting a file : descriptor means (safely) doing the following: : (a) Deleting the file descriptor from the epoll interest list : using EPOLL_CTL_DEL : (b) Deleting the corresponding record in the user-space cache : : 1. It's only meaningful to use this EPOLL_CTL_DISABLE in : conjunction with EPOLLONESHOT. : : 2. Using EPOLL_CTL_DISABLE without using EPOLLONESHOT in : conjunction is a logical error. : : 3. The correct way to code multithreaded applications using : EPOLL_CTL_DISABLE and EPOLLONESHOT is as follows: : : a. All EPOLL_CTL_ADD and EPOLL_CTL_MOD operations should : should EPOLLONESHOT. : : b. When a thread wants to delete a file descriptor, it : should do the following: : : [1] Call epoll_ctl(EPOLL_CTL_DISABLE) : [2] If the return status from epoll_ctl(EPOLL_CTL_DISABLE) : was zero, then the file descriptor can be safely : deleted by the thread that made this call. : [3] If the epoll_ctl(EPOLL_CTL_DISABLE) fails with EBUSY, : then the descriptor is in use. In this case, the calling : thread should set a flag in the user-space cache to : indicate that the thread that is using the descriptor : should perform the deletion operation. : : Is all of the above correct? : : The implementation depends on checking on whether : (events & ~EP_PRIVATE_BITS) == 0 : This replies on the fact that EPOLL_CTL_AD and EPOLL_CTL_MOD always : set EPOLLHUP and EPOLLERR in the 'events' mask, and EPOLLONESHOT : causes those flags (as well as all others in ~EP_PRIVATE_BITS) to be : cleared. : : A corollary to the previous paragraph is that using EPOLL_CTL_DISABLE : is only useful in conjunction with EPOLLONESHOT. However, as things : stand, one can use EPOLL_CTL_DISABLE on a file descriptor that does : not have EPOLLONESHOT set in 'events' This results in the following : (slightly surprising) behavior: : : (a) The first call to epoll_ctl(EPOLL_CTL_DISABLE) returns 0 : (the indicator that the file descriptor can be safely deleted). : (b) The next call to epoll_ctl(EPOLL_CTL_DISABLE) fails with EBUSY. : : This doesn't seem particularly useful, and in fact is probably an : indication that the user made a logic error: they should only be using : epoll_ctl(EPOLL_CTL_DISABLE) on a file descriptor for which : EPOLLONESHOT was set in 'events'. If that is correct, then would it : not make sense to return an error to user space for this case? Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: "Paton J. Lewis" <palewis@adobe.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-28Merge tag 'ktest-v3.7-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest confusion fix from Steven Rostedt: "With the v3.7-rc2 kernel, the network cards on my target boxes were not being brought up. I found that the modules for the network was not being installed. This was due to the config CONFIG_MODULES_USE_ELF_RELA that came before CONFIG_MODULES, and confused ktest in thinking that CONFIG_MODULES=y was not found. Ktest needs to test all configs and not just stop if something starts with CONFIG_MODULES." * tag 'ktest-v3.7-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Fix ktest confusion with CONFIG_MODULES_USE_ELF_RELA
2012-10-26ktest: Fix ktest confusion with CONFIG_MODULES_USE_ELF_RELASteven Rostedt
In order to decide if ktest should bother installing modules on the target box, it checks if the config file has CONFIG_MODULES=y. But it also checks if the '=y' part exists. It only will install modules if the config exists and is set with '=y'. But as the regex that was used tests: /^CONFIG_MODULES(=y)?/ this will also match: CONFIG_MODULES_USE_ELF_RELA as the '=y' part was optional and it did not test the rest of the line. When this happens, ktest will stop checking the rest of the configs but it will also think that no modules are needed to be installed. What it should do is only jump out of the loop if it actually found a CONFIG_MODULES that is set to true. Otherwise, ktest wont install the necessary modules needed for proper booting of the test target. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-10-25tools/testing/selftests/epoll/test_epoll.c: fix buildDaniel Hazelton
Latest Linus head run of "make selftests" in the tools directory failed with references to undefined variables. Reference was to 'write_thread_data' which is the name of a struct that is being used, not the variable itself. Change reference so it points to the variable. Signed-off-by: Daniel Hazelton <dshadowwolf@gmail.com> Cc: "Paton J. Lewis" <palewis@adobe.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-12Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig changes from Michal Marek: "kconfig in v3.7 is going to - initialize ncurses only once in menuconfig - be able to jump to a search result in menuconfig - change the misnomer oldnoconfig to a more meaningful name olddefconfig, keeping the old name as alias" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: replace 'oldnoconfig' with 'olddefconfig', and keep the old name as an alias menuconfig: Assign jump keys per-page instead of globally menuconfig: Do not open code textbox scroll up/down menuconfig: Add jump keys to search results menuconfig: Extend dialog_textbox so that it can return to a scrolled position menuconfig: Extend dialog_textbox so that it can exit on arbitrary keypresses menuconfig: Remove superfluous conditionnal kconfig: document oldnoconfig to what it really does in conf.c kconfig/mconf.c: revision of curses initialization.
2012-10-06epoll: support for disabling items, and a self-test appPaton J. Lewis
Enhanced epoll_ctl to support EPOLL_CTL_DISABLE, which disables an epoll item. If epoll_ctl doesn't return -EBUSY in this case, it is then safe to delete the epoll item in a multi-threaded environment. Also added a new test_epoll self- test app to both demonstrate the need for this feature and test it. Signed-off-by: Paton J. Lewis <palewis@adobe.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jason Baron <jbaron@redhat.com> Cc: Paul Holland <pholland@adobe.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01Merge tag 'ktest-v3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest fix from Steven Rostedt: "ktest has one fix needed for this merge window - fix parsing of ELSE IF in reading config file" * tag 'ktest-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Fix ELSE IF statements
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-27kconfig: replace 'oldnoconfig' with 'olddefconfig', and keep the old name as ↵Adam Lee
an alias As 67d34a6a391369269a2e5dba8a5f42cc4cd50231 said, 'oldnoconfig' doesn't set new symbols to 'n', but instead sets it to their default values. So, this patch replaces 'oldnoconfig' with 'olddefconfig', stop making people confused, and keep the old name 'oldnoconfig' as an alias, because people already are dependent on its behavior with the counter-intuitive name. Signed-off-by: Adam Lee <adam8157@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-26ktest: Fix ELSE IF statementsSteven Rostedt
The ELSE IF statements do not work as expected if another ELSE statement follows. This is because the $if_set is not set. If the ELSE IF condition is true, the following ELSE should be ignored. But because the $if_set is not set, the following ELSE will also be executed. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-09-01tools/testing: fix comment / output typosMasanari Iida
Correct spelling typo in tools/testing Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-31fault-injection: fix failcmd.sh warningAkinobu Mita
"fault-injection: add tool to run command with failslab or fail_page_alloc" added tools/testing/fault-injection/failcmd.sh to make it easier to inject slab/page allocation failures by fault injection. failcmd.sh prints the following warning when running with arguments for command. # ./failcmd.sh echo aaa failcmd.sh: line 209: [: echo: binary operator expected aaa This warning is caused by an improper check whether at least one parameter is left after parsing command options. Fix it by testing the length of $1 instead of $@ Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30fault-injection: add tool to run command with failslab or fail_page_allocAkinobu Mita
This adds tools/testing/fault-injection/failcmd.sh to run a command while injecting slab/page allocation failures via fault injection. Example: Run a command "make -C tools/testing/selftests/ run_tests" with injecting slab allocation failure. # ./tools/testing/fault-injection/failcmd.sh \ -- make -C tools/testing/selftests/ run_tests Same as above except to specify 100 times failures at most instead of one time at most by default. # ./tools/testing/fault-injection/failcmd.sh --times=100 \ -- make -C tools/testing/selftests/ run_tests Same as above except to inject page allocation failure instead of slab allocation failure. # env FAILCMD_TYPE=fail_page_alloc \ ./tools/testing/fault-injection/failcmd.sh --times=100 \ -- make -C tools/testing/selftests/ run_tests Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30fault-injection: add selftests for cpu and memory hotplugAkinobu Mita
This adds two selftests * tools/testing/selftests/cpu-hotplug/on-off-test.sh is testing script for CPU hotplug 1. Online all hot-pluggable CPUs 2. Offline all hot-pluggable CPUs 3. Online all hot-pluggable CPUs again 4. Exit if cpu-notifier-error-inject.ko is not available 5. Offline all hot-pluggable CPUs in preparation for testing 6. Test CPU hot-add error handling by injecting notifier errors 7. Online all hot-pluggable CPUs in preparation for testing 8. Test CPU hot-remove error handling by injecting notifier errors * tools/testing/selftests/memory-hotplug/on-off-test.sh is doing the similar thing for memory hotplug. 1. Online all hot-pluggable memory 2. Offline 10% of hot-pluggable memory 3. Online all hot-pluggable memory again 4. Exit if memory-notifier-error-inject.ko is not available 5. Offline 10% of hot-pluggable memory in preparation for testing 6. Test memory hot-add error handling by injecting notifier errors 7. Online all hot-pluggable memory in preparation for testing 8. Test memory hot-remove error handling by injecting notifier errors Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30ktest: Allow perl regex expressions in conditional statementsSteven Rostedt
Add '=~' and '!~' to the list of allowed conditionals for DEFAULT and TEST_START section if statements. ie. TEST_START IF TEST =~ .*test$ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-30ktest: Ignore errors it tests if IGNORE_ERRORS is setSteven Rostedt
The option IGNORE_ERRORS is used to allow a test to succeed even if a warning appears from the kernel. Sometimes kernels will produce warnings that are not associated with a test, and the user wants to test something else. The IGNORE_ERRORS works for boot up, but was not preventing test runs to succeed if the kernel produced a warning. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-20ktest: Reset saved min (force) configs for each testSteven Rostedt
The min configs are saved in a perl hash called force_configs, and this hash is used to add configs to the .config file. But it was not being reset between tests and a min config from a previous test would affect the min config of the next test causing undesirable results. Reset the force_config hash at the start of each test. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Add check for bug or panic during rebootSteven Rostedt
Usually the target is booted into a dependable kernel when a test starts. The test will install the test kernel and reboot the box. But there may be a time that the kernel is running an unreliable kernel and the reboot may crash. Have ktest detect crashes on a reboot and force a power-cycle instead. This can usually happen if a test kernel was installed to run manual tests, but the user forgot to reboot to the known good kernel. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Add MAX_MONITOR_WAIT optionSteven Rostedt
If the console is constantly outputting content, this can cause ktest to get stuck waiting on the monitor to settle down. The option MAX_MONITOR_WAIT is the maximum time (in seconds) for ktest to wait for the console to flush. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Fix config bisect with how make oldnoconfig worksSteven Rostedt
With a name like 'oldnoconfig' one may think that the config generated would disable all configs that were not defined (selecting "no" for all options). But this is not the case. It selects the default. If a config has a 'default y', then it is added if not specified. This broke the config bisect, because options not specified by a config will just use the default, where it expected to turn off. This caused an option to be enabled that disabled an option that would break the build. The end result was that we never found the bad config at the end of the test. Instead of using 'make oldnoconfig', ktest now builds the options it expects enabled and disabled. When it turns off an option, it will no longer remove it, but actually set it to: # CONFIG_FOO is not set. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Add CONFIG_BISECT_CHECK optionSteven Rostedt
The config-bisect can take a bad config and bisect it down to find out what config actually breaks the config. But as all tests will apply a minconfig (defined by a user) to apply before booting, it is possible that the minconfig could actually make the bad config work (minconfigs can disable configs). The end result is that the config bisect test will not find a config that breaks. This can be rather frustrating to the user. The CONFIG_BISECT_CHECK option, when set to 1, will make sure that the bad config (with the minconfig applied) still fails before trying to bisect. And yes, I did get burned by this. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Add PRE_INSTALL optionSteven Rostedt
Add the PRE_INSTALL option that will allow a user to specify a shell command to be executed before the install operation executes. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Add PRE/POST_KTEST and TEST optionsSteven Rostedt
In order to let the user add commands before and after ktest runs, the PRE_KTEST and POST_KTEST options are defined. They hold shell commands that will execute befor ktest runs its first test, as well as when it completed its last test. The PRE_TEST and POST_TEST will be run befor and after (respectively) for a given test. They can either be global (done for all tests) or defined by a single test. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ktest: Remove commented exitSteven Rostedt
A debug 'exit' was left in ktest.pl. Remove it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-31syscalls, x86: add __NR_kcmp syscallCyrill Gorcunov
While doing the checkpoint-restore in the user space one need to determine whether various kernel objects (like mm_struct-s of file_struct-s) are shared between tasks and restore this state. The 2nd step can be solved by using appropriate CLONE_ flags and the unshare syscall, while there's currently no ways for solving the 1st one. One of the ways for checking whether two tasks share e.g. mm_struct is to provide some mm_struct ID of a task to its proc file, but showing such info considered to be not that good for security reasons. Thus after some debates we end up in conclusion that using that named 'comparison' syscall might be the best candidate. So here is it -- __NR_kcmp. It takes up to 5 arguments - the pids of the two tasks (which characteristics should be compared), the comparison type and (in case of comparison of files) two file descriptors. Lookups for pids are done in the caller's PID namespace only. At moment only x86 is supported and tested. [akpm@linux-foundation.org: fix up selftests, warnings] [akpm@linux-foundation.org: include errno.h] [akpm@linux-foundation.org: tweak comment text] Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Glauber Costa <glommer@parallels.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tejun Heo <tj@kernel.org> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Valdis.Kletnieks@vt.edu Cc: Michal Marek <mmarek@suse.cz> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31tools/selftests: add mq_perf_testsDoug Ledford
Add the mq_perf_tests tool I used when creating my mq performance patch. Also add a local .gitignore to keep the binaries from showing up in git status output. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Doug Ledford <dledford@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31selftests: add mq_open_testsDoug Ledford
Add a directory to house POSIX message queue subsystem specific tests. Add first test which checks the operation of mq_open() under various corner conditions. Signed-off-by: Doug Ledford <dledford@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Joe Korty <joe.korty@ccur.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-23ktest: Change singular "paranthesis" to plural "parentheses"Jesper Juhl
Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-22ktest: Add README to explain what is in the examples directorySteven Rostedt
Add a README that explains what the different example configs in the ktest example directory are about. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-22ktest: Add the snowball.conf example configSteven Rostedt
I used the snowball.conf in a live demo that demonstrated how to use ktest.pl with a snowball ARM board. I've been asked to included that config in the ktest repository. Here it is. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-22ktest: Add an example config that does cross compiling of several archsSteven Rostedt
Add the config that I use to test several archs. I downloaded several cross compilers from: http://kernel.org/pub/tools/crosstool/files/bin/x86_64/ and this config is an example to crosscompile several archs to make sure that your changes do not break archs that you are not working on. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-22ktest: Add kvm.conf example configSteven Rostedt
Add an example config that explains how to use ktest with a virtual guest as the target. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-22ktest: Add useful example configsSteven Rostedt
I've been asked several times to provide more useful example configs for ktest.pl, as the sample.conf is too complex (because it explains all configs). This adds configs broken up by use case, and these configs are based on actual configs that I use on a daily basis. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-22ktest: Add USE_OUTPUT_MIN_CONFIG to avoid prompt on make_min_configSteven Rostedt
If the file that OUTPUT_MIN_CONFIG exists then ktest.pl will prompt the user and ask them if the OUTPUT_MIN_CONFIG should be used as the starting point for make_min_config instead of MIN_CONFIG. This is usually the case, and to allow the user to do so, which is helpful if the user is creating different min configs based on tests, and they know one is a superset of another test, they can set USE_OUTPUT_MIN_CONFIG to one, which will prevent kest.pl from prompting to use the OUTPUT_MIN_CONFIG and it will just use it. If USE_OUTPUT_MIN_CONIFG is set to zero, then ktest.pl will continue to use MIN_CONFIG instead. The default is that USE_OUTPUT_MIN_CONFIG is undefined. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-21ktest: Add MIN_CONFIG_TYPE to allow making a minum .config that has networkSteven Rostedt
Add a MIN_CONFIG_TYPE that can be set to 'test' or 'boot'. The default is 'boot' which is what make_min_config has done previously: makes a config file that is the minimum needed to boot the target. But when MIN_CONFIG_TYPE is set to 'test', not only must the target boot, but it must also successfully run the TEST. This allows the creation of a config file that is the minimum to boot and also perform ssh to the target, or anything else a developer wants. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-18ktest: Fix kernelrevision with POST_BUILDSteven Rostedt
The PRE_BUILD and POST_BUILD options of ktest are added to allow the user to add temporary patch to the system and remove it on builds. This is sometimes use to take a change from another git branch and add it to a series without the fix so that this series can be tested, when an unrelated bug exists in the series. The problem comes when a tagged commit is being used. For example, if v3.2 is being tested, and we add a patch to it, the kernelrelease for that commit will be 3.2.0+, but without the patch the version will be 3.2.0. This can cause problems when the kernelrelease is determined for creating the /lib/modules directory. The kernel booting has the '+' but the module directory will not, and the modules will be missing for that boot, and may not allow the kernel to succeed. The fix is to put the creation of the kernelrelease in the POST_BUILD logic, before it applies the POST_BUILD operation. The POST_BUILD is where the patch may be removed, removing the '+' from the kernelrelease. The calculation of the kernelrelease will also stay in its current location but will be ignored if it was already calculated previously. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-01ktest: Fix reboot on success stopping all rebootsSteven Rostedt
The change to let individual tests decide to reboot the machine on success of the entire test also prevented errors from rebooting when an error was detected. The "no_reboot" variable was only cleared if the test had reboot_on_success set. But the no_reboot variable also prevents the test rebooting when an error was detected even when REBOOT_ON_ERROR was set. Add a new "reboot_success" variable that is used to determine if the test should reboot on success and not touch the no_reboot variable. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-01ktest.pl: Fix combined usage of BISECT_REVERSE and BISECT_SKIPRuss Dill
When BISECT_REVERSE and BISECT_SKIP are used together with boot or test testing, build failures are treated as boot or test failures and 'git bisect bad' is executed instead of 'git bisect skip'. This is because the $ret value of -1 is treated as a build failure, but the $reverse_bisect logic does not properly handle this. Simple fix, only invert it if it is positive. Link: http://lkml.kernel.org/r/1335235380-8509-1-git-send-email-Russ.Dill@ti.com Signed-off-by: Russ Dill <Russ.Dill@ti.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-28mm: move hugepage test examples to tools/testing/selftests/vmDave Young
hugepage-mmap.c, hugepage-shm.c and map_hugetlb.c in Documentation/vm are simple pass/fail tests, It's better to promote them to tools/testing/selftests. Thanks suggestion of Andrew Morton about this. They all need firstly setting up proper nr_hugepages and hugepage-mmap need to mount hugetlbfs. So I add a shell script run_vmtests to do such work which will call the three test programs and check the return value of them. Changes to original code including below: a. add run_vmtests script b. return error when read_bytes mismatch with writed bytes. c. coding style fixes: do not use assignment in if condition [akpm@linux-foundation.org: build the targets before trying to execute them] [akpm@linux-foundation.org: Documentation/vm/ no longer has a Makefile. Fixes "make clean"] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28selftests/Makefile: make `run_tests' depend on `all'Andrew Morton
So a "make run_tests" will build the tests before trying to run them. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28selftests: launch individual selftests from the main MakefileFrederic Weisbecker
Remove the run_tests script and launch the selftests by calling "make run_tests" from the selftests top directory instead. This delegates to the Makefile in each selftest directory, where it is decided how to launch the local test. This removes the need to add each selftest directory to the now removed "run_tests" top script. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Dave Young <dyoung@redhat.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge tag 'ktest-v3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest changes from Steven Rostedt. * tag 'ktest-v3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Allow a test to override REBOOT_ON_SUCCESS ktest: Fix SWITCH_TO_GOOD to also reboot the machine ktest: Add SCP_TO_TARGET_INSTALL option ktest: Add warning when bugs are ignored ktest: Add INSTALL_MOD_STRIP=1 when installing modules
2012-03-21ktest: Allow a test to override REBOOT_ON_SUCCESSSteven Rostedt
The option REBOOT_ON_SUCCESS is global, and will have the machine reboot the the box if all tests are successful. But a test may not want the machine to reboot, and perhaps have the kernel it loaded be used to install the next kernel. Or the last test may set up a kernel that the user may want to look at. In this case, the user could have the global option REBOOT_ON_SUCCESS be true, but if a test is defined to run at the end, that test can override the global option and keep the kernel it installed for the user to log in with. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-21ktest: Fix SWITCH_TO_GOOD to also reboot the machineSteven Rostedt
When the option SWITCH_TO_GOOD is set, it will be called when the system needs to reboot to the good server. But currently, this keeps the reboot from happening. The SWITCH_TO_GOOD is just a way to get to a new kernel, it may not mean to not reboot. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-21ktest: Add SCP_TO_TARGET_INSTALL optionSteven Rostedt
Currently the option used to scp both the modules to the target as well as the kernel image are the same (SCP_TO_TARGET). But some embedded boards may require them to be different. The modules may need to be put directly on the board, but the kernel image may need to go to a tftpserver. Add the option SCP_TO_TARGET_INSTALL that will allow the user to change the config so that they may have the modules and image got to different machines. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-21ktest: Add warning when bugs are ignoredSteven Rostedt
When IGNORE_ERRORS is set, ktest will not fail a test if a backtrace is detected. But this can be an issue if the user added it in the config but forgot to remove it. They may be left wondering why their test did not fail, or even worse, why their bisect gave the wrong commit. Add a warning in the output if IGNORE_WARNINGS is set, and ktest detects a kernel error. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-21ktest: Add INSTALL_MOD_STRIP=1 when installing modulesSteven Rostedt
To keep the modules from bloating the target's filesystem strip them during the install. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-02-27Merge tag 'ktest-fix-make-min-failed-build-for-real' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest While demoing ktest at ELC in 2012, it was embarrassing that the make_min_config test failed to work because the snowball board I was testing it against had a config that would not build. But the make_min_config only tested the testing part and ignored build failures. The end result was a config file that would not boot. This time, for real. * tag 'ktest-fix-make-min-failed-build-for-real' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Fix make_min_config test when build fails
