We can get it from syme->map->dso->kernel (that should be renamed to
origin, but leave this for another patch).
Cc: Stephane Eranian <eranian@google.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <new-submission>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
We can get that counter index from perf_top->sym_evsel->idx instead.
Passing multiple events might force out information about pid/tid/cpu.
Attached patch leaves 30 characters for this info at the expense of the
events' names.
Cc: Han Pingtian <phan@redhat.com>
LKML-Reference: <1299528821-17521-3-git-send-email-jolsa@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
The snprintf function returns number of printed characters even if it
cross the size parameter. So passing enough events via '-e' parameter
will cause segmentation fault.
It's reproduced by following command:
perf top -e `perf list | grep Tracepoint | awk -F'[' '\
{gsub(/[[:space:]]+/,"",$1);array[FNR]=$1}END{outputs=array[1];\
for (i=2;i<=FNR;i++){ outputs=outputs "," array[i];};print outputs}'`
Attached patch is adding SNPRINTF macro that provides the overflow check
and returns actuall number of printed characters.
Reported-by: Han Pingtian <phan@redhat.com>
LKML-Reference: <1299528821-17521-2-git-send-email-jolsa@redhat.com>
From the sym_entry struct, struct symbol already has this field.
Disabled by default as there are features found in the stdio based one
that aren't implemented, like live annotation, filtering knobs data
entry.
Annotation hopefully will get somehow merged with the 'perf annotate'
code.
To use it:
perf top --tui
Paving the way for a slang browser a la 'perf report --tui'.
