Merge reason: We'll be queueing dependent changes.
When profiling C++ workloads the symbol name length can be
really big, so cap it before it garbles the result.
This builds upon the autosizing already present where we choose
to use the short, basename of DSOs instead of its long, full
pathname.
Reported-by: Pavel Krauz <krauz@cngroup.cz>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1268676230-9261-1-git-send-email-acme@infradead.org>
Before this patch this message would very briefly appear on the
screen and then the screen would get updates only on the top,
for number of interrupts received, etc, but no annotation would
be performed:
[root@doppio linux-2.6-tip]# perf top -s n_tty_write > /tmp/bla
objdump: '[kernel.kallsyms]': No such file
Now this is what the user gets:
Can't annotate n_tty_write: No vmlinux file was found in the
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.33-rc5
[3] /lib/modules/2.6.33-rc5/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.33-rc5/vmlinux
This bug was introduced when we added automatic search for
vmlinux, before that time the user had to specify a vmlinux
file.
Reported-by: David S. Miller <davem@davemloft.net>
Reported-by: Ingo Molnar <mingo@elte.hu>
Cc: <stable@kernel.org>
LKML-Reference: <1268664418-28328-2-git-send-email-acme@infradead.org>
LKML-Reference: <1268349164-5822-1-git-send-email-acme@infradead.org>
Because symbol->end is not fixed up at symbol_filter time, only
after all symbols for a DSO are loaded, and that, for asm
symbols, may be bogus, causing segfaults when hits happen in
these symbols.
Reported-by: David Miller <davem@davemloft.net>
Reported-by: Anton Blanchard <anton@samba.org>
Acked-by: David Miller <davem@davemloft.net>
Cc: <stable@kernel.org> # for .33.x. Does not apply cleanly, needs backport.
LKML-Reference: <20100225155740.GB8553@ghostprotocols.net>
Be more clear about DSO long names and tell from which file
kernel symbols were obtained, all in --verbose mode:
[root@mica ~]# perf report -v > /dev/null
Looking at the vmlinux_path (5 entries long)
Using /lib/modules/2.6.33-rc8-tip-00777-g0918527-dirty/build/vmlinux for symbols
[root@mica ~]# mv /lib/modules/2.6.33-rc8-tip-00777-g0918527-dirty/build/vmlinux /tmp/dd
Using /proc/kallsyms for symbols
[root@mica ~]#
LKML-Reference: <1266866139-6361-1-git-send-email-acme@infradead.org>
In function dso__split_kallsyms(), curr_map saves the return value
of map__new2. So check it instead of var map after the call returns.
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1267066851.1726.9.camel@localhost>
In 2161db9 we stopped failing when not finding modules when
asked too, but then the kernel maps (just one, for vmlinux)
wasn't having its ->end field correctly set up, so symbols were
not being found for the vmlinux map because its range was 0-0.
LKML-Reference: <1266702793-29434-1-git-send-email-acme@infradead.org>
perf top and perf record refuses to initialize on non-modular kernels:
refuse to initialize:
$ perf top -v
map_groups__set_modules_path_dir: cannot open /lib/modules/2.6.33-rc6-tip-00586-g398dde3-dirty/
LKML-Reference: <1265223128-11786-1-git-send-email-acme@infradead.org>
Not to pollute too much 'perf annotate' debugging sessions.
LKML-Reference: <1265223128-11786-7-git-send-email-acme@infradead.org>
We want to stream events as fast as possible to perf.data, and
also in the future we want to have splice working, when no
interception will be possible.
Using build_id__mark_dso_hit_ops to create the list of DSOs that
back MMAPs we also optimize disk usage in the build-id cache by
only caching DSOs that had hits.
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
LKML-Reference: <1265223128-11786-6-git-send-email-acme@infradead.org>
We can check using strcmp, most DSOs don't start with '[' so the
test is cheap enough and we had to test it there anyway since
when reading perf.data files we weren't calling the routine that
created this global variable and thus weren't setting it as
"loaded", which was causing a bogus:
Failed to open [vdso], continuing without symbols
Message as the first line of 'perf report'.
LKML-Reference: <1265223128-11786-3-git-send-email-acme@infradead.org>
While debugging a problem reported by Pekka Enberg by printing
the IP and all the maps for a thread when we don't find a map
for an IP I noticed that dso__load_sym needs to fixup these
extra maps it creates to hold symbols in different ELF sections
than the main kernel one.
Now we're back showing things like:
[root@doppio linux-2.6-tip]# perf report | grep vsyscall
0.02% mutt [kernel.kallsyms].vsyscall_fn [.] vread_hpet
0.01% named [kernel.kallsyms].vsyscall_fn [.] vread_hpet
0.01% NetworkManager [kernel.kallsyms].vsyscall_fn [.] vread_hpet
0.01% gconfd-2 [kernel.kallsyms].vsyscall_0 [.] vgettimeofday
0.01% hald-addon-rfki [kernel.kallsyms].vsyscall_fn [.] vread_hpet
0.00% dbus-daemon [kernel.kallsyms].vsyscall_fn [.] vread_hpet
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
LKML-Reference: <1265223128-11786-2-git-send-email-acme@infradead.org>
I noticed while writing the first test in 'perf regtest' that to
just test the symbol handling routines one needs to create a
perf session, that is a layer centered on a perf.data file,
events, etc, so I untied these layers.
This reduces the complexity for the users as the number of
parameters to most of the symbols and session APIs now was
reduced while not adding more state to all the map instances by
only having data that is needed to split the kernel (kallsyms
and ELF symtab sections) maps and do vmlinux relocation on the
main kernel map.
To make it clear and allow for direct usage by, for instance,
regression test suites.
LKML-Reference: <1264633557-17597-3-git-send-email-acme@infradead.org>
So that we can call it directly from regression tests, and also
to reduce the size of dso__load_kernel_sym(), making it more
clear.
LKML-Reference: <1264633557-17597-2-git-send-email-acme@infradead.org>
Probably this wasn't noticed when testing this on my parisc
machine because I must have copied manually to its cache the
vmlinux file used in the x86_64 machine, now that I tried
looking on a x86-32 machine with a fresh cache, kernel symbols
weren't being resolved even with the right kallsyms copy on its
cache, duh.
LKML-Reference: <1264178102-4203-2-git-send-email-acme@infradead.org>
Only if we parsed /proc/kallsyms (or a copy found in the buildid
cache) we should set the dso long name to "[kernel.kallsyms]".
Reported-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1264178102-4203-1-git-send-email-acme@infradead.org>
For now it just has operations to examine a given file, find its
build-id and add or remove it to/from the cache.
Useful, for instance, when adding binaries sent together with a
perf.data file, so that we can add them to the cache and have
the tools find it when resolving symbols.
It'll also manage the size of the cache like 'ccache' does.
LKML-Reference: <1264008525-29025-1-git-send-email-acme@infradead.org>
Found while analysing a perf.data file collected on an ARM
machine where an explicitely specified vmlinux was being
disregarded.
Reported-by: Jamie Iles <jamie.iles@picochip.com>
LKML-Reference: <1263904574-30732-2-git-send-email-acme@infradead.org>
Using this option 'perf buildid-list' will process all samples,
marking the DSOs that had some hits to list just them.
This in turn will be used by a new porcelain, 'perf archive',
that will be just a shell script to create a tarball from the
'perf buildid-list --with-hits' output and the files cached by
'perf record' in ~/.debug.
LKML-Reference: <1263519930-22803-4-git-send-email-acme@infradead.org>
If not we end up duplicating the module DSOs because first we
insert them using the short name found in /proc/modules, then,
when processing synthesized MMAP events we add them again.
LKML-Reference: <1263519930-22803-1-git-send-email-acme@infradead.org>
So that when we don't have a vmlinux handy we can store the
kallsyms for later use by 'perf report'.
LKML-Reference: <1263501006-14185-3-git-send-email-acme@infradead.org>
Now a perf.data file collected on a x86_64 fedora 12 machine
gets properly parsed on a Debian testing PARISC64 machine with
32-bit userland:
acme@parisc:~/git/linux-2.6-tip$ perf report 2> /dev/null | head -15
# Samples: 293085637
# Overhead Command Shared Object Symbol
35.11% find [kernel.kallsyms] [k] 0xffffffff81002b5a
18.25% perf [kernel.kallsyms] [k] 0xffffffff8102235f
9.07% find find [.] 0x0000000000fb0e
5.80% swapper [kernel.kallsyms] [k] 0xffffffff8102235f
3.29% perf libc-2.10.2.so [.] __GI_strcmp
2.70% find libc-2.10.2.so [.] __GI_memmove
2.33% init [kernel.kallsyms] [k] 0xffffffff810091b9
2.03% find libc-2.10.2.so [.] _int_malloc
1.67% find libc-2.10.2.so [.] _IO_vfprintf_internal
1.65% sshd libcrypto.so.0.9.8k [.] 0x00000000105440
LKML-Reference: <1263501006-14185-2-git-send-email-acme@infradead.org>
We were always looking at the running machine /proc/modules,
even when processing a perf.data file, which only makes sense
when we're doing 'perf record' and 'perf report' on the same
machine, and in close sucession, or if we don't use modules at
all, right Peter? ;-)
Now, at 'perf record' time we read /proc/modules, find the long
path for modules, and put them as PERF_MMAP events, just like we
did to encode the reloc reference symbol for vmlinux. Talking
about that now it is encoded in .pgoff, so that we can use
.{start,len} to store the address boundaries for the kernel so
that when we reconstruct the kmaps tree we can do lookups right
away, without having to fixup the end of the kernel maps like we
did in the past (and now only in perf record).
One more step in the 'perf archive' direction when we'll finally
be able to collect data in one machine and analyse in another.
LKML-Reference: <1263396139-4798-1-git-send-email-acme@infradead.org>
So that we can restore them to the right DSO list (either
dsos__kernel or dsos__user).
We do that just like the kernel does for the other events,
encoding PERF_RECORD_MISC_{KERNEL,USER} in perf_event_header.
LKML-Reference: <1262901583-8074-2-git-send-email-acme@infradead.org>
DSOs don't have this problem because the kernel emits a
PERF_MMAP for each new executable mapping it performs on
monitored threads.
To fix the kernel case we simulate the same behaviour, by having
'perf record' to synthesize a PERF_MMAP for the kernel, encoded
like this:
[root@doppio ~]# perf record -a -f sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.344 MB perf.data (~15038 samples) ]
[root@doppio ~]# perf report -D | head -10
0xd0 [0x40]: event: 1
. ... raw event: size 64 bytes
. 0000: 01 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 ......@........
. 0010: 00 00 00 81 ff ff ff ff 00 00 00 00 00 00 00 00 ...............
. 0020: 00 00 00 00 00 00 00 00 5b 6b 65 72 6e 65 6c 2e ........ [kernel
. 0030: 6b 61 6c 6c 73 79 6d 73 2e 5f 74 65 78 74 5d 00 kallsyms._text]
. 0xd0
[0x40]: PERF_RECORD_MMAP 0/0: [0xffffffff81000000((nil)) @ (nil)]: [kernel.kallsyms._text]
I.e. we identify such event as having:
.pid = 0
.filename = [kernel.kallsyms.REFNAME]
.start = REFNAME addr in /proc/kallsyms at 'perf record' time
and use now a hardcoded value of '.text' for REFNAME.
Then, later, in 'perf report', if there are any kernel hits and
thus we need to resolve kernel symbols, we search for REFNAME
and if its address changed, relocation happened and we thus must
change the kernel mapping routines to one that uses .pgoff as
the relocation to apply.
This way we use the same mechanism used for the other DSOs and
don't have to do a two pass in all the kernel symbols.
Reported-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
LKML-Reference: <1262717431-1246-1-git-send-email-acme@infradead.org>
So that tools such as 'perf probe' don't have to lookup
'[kernel.kallsyms]' but instead access them directly after
perf_session__create_kernel_maps or
map_groups__create_kernel_maps.
Cc: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <1262629169-22797-4-git-send-email-acme@infradead.org>
Will be needed by the new HEADER_DSO_INFO feature that will be a
HEADER_BUILD_ID superset, replacing it.
LKML-Reference: <1262629169-22797-2-git-send-email-acme@infradead.org>
Will be used to find an specific symbol by name on 'perf record'
to support relocation reference symbols to support relocatable
kernels.
Still have to conver the perf trace tools to use it instead of
their current reimplementation.
LKML-Reference: <1262629169-22797-1-git-send-email-acme@infradead.org>
Now a cache will be created in a ~/.debug debuginfo like
hierarchy, so that at the end of a 'perf record' session all the
binaries (with build-ids) involved get collected and indexed by
their build-ids, so that perf report can find them.
This is interesting when developing software where you want to
do a 'perf diff' with the previous build and opens avenues for
lots more interesting tools, like a 'perf diff --graph' that
takes more than two binaries into account.
Tunables for collecting just the symtabs can be added if one
doesn't want to have the full binary, but having the full binary
allows things like 'perf rerecord' or other tools that can
re-run the tests by having access to the exact binary in some
perf.data file, so it may well be interesting to keep the full
binary there.
Space consumption is minimised by trying to use hard links, a
'perf cache' tool to manage the space used, a la ccache is
required to purge older entries.
With this in place it will be possible also to introduce new
commands, 'perf archive' and 'perf restore' (or some more
suitable and future proof names) to create a cpio/tar file with
the perf data and the files in the cache that _had_ perf hits of
interest.
There are more aspects to polish, like finding the right vmlinux
file to cache, etc, but this is enough for a first step.
LKML-Reference: <1261957026-15580-10-git-send-email-acme@infradead.org>
Pull it out of builtin-report - further changes will be made and it
will then be reusable in 'perf diff' as well.
LKML-Reference: <1260914682-29652-4-git-send-email-acme@infradead.org>
So that --dsos, --comm, --symbols can bem used in more tools,
like in perf diff:
$ perf record -f find / > /dev/null
$ perf diff --dsos /lib64/libc-2.10.1.so | head -5
1 +22392124 /lib64/libc-2.10.1.so _IO_vfprintf_internal
2 +6410655 /lib64/libc-2.10.1.so __GI_memmove
3 +1 +9192692 /lib64/libc-2.10.1.so _int_malloc
4 -1 -15158605 /lib64/libc-2.10.1.so _int_free
5 +45669 /lib64/libc-2.10.1.so _IO_new_file_xsputn
LKML-Reference: <1260914682-29652-3-git-send-email-acme@infradead.org>
Will be used in perf diff too.
LKML-Reference: <1260914682-29652-2-git-send-email-acme@infradead.org>
This simplifies a lot of functions, less stuff to be done by
tool writers.
LKML-Reference: <1260914682-29652-1-git-send-email-acme@infradead.org>
There is still some more work to do to disentangle map creation
from DSO loading, but this happens only for the kernel, and for
the early adopters of perf diff, where this disentanglement
matters most, we'll be testing different kernels, so no problem
here.
Further clarification: right now we create the kernel maps for
the various modules and discontiguous kernel text maps when
loading the DSO, we should do it as a two step process, first
creating the maps, for multiple mappings with the same DSO
store, then doing the dso load just once, for the first hit on
one of the maps sharing this DSO backing store.
LKML-Reference: <1260741029-4430-6-git-send-email-acme@infradead.org>
It is always wired to dso__find_symbol.
LKML-Reference: <1260564999-13371-1-git-send-email-acme@infradead.org>
Configurable via symbol_conf.sort_by_name, so that the cost of an
extra rb_node on all 'struct symbol' instances is not paid by tools
that only want to decode addresses.
How to use it:
symbol_conf.sort_by_name = true;
symbol_init(&symbol_conf);
struct map *map = map_groups__find_by_name(kmaps, MAP__VARIABLE, "[kernel.kallsyms]");
if (map == NULL) {
pr_err("couldn't find map!\n");
kernel_maps__fprintf(stdout);
} else {
struct symbol *sym = map__find_symbol_by_name(map, sym_filter, NULL);
if (sym == NULL)
pr_err("couldn't find symbol %s!\n", sym_filter);
else
pr_info("symbol %s: %#Lx-%#Lx \n", sym_filter, sym->start, sym->end);
Looking over the vmlinux/kallsyms is common enough that I'll add a
variable to the upcoming struct perf_session to avoid the need to
use map_groups__find_by_name to get the main vmlinux/kallsyms map.
The above example looks on the 'variable' symtab, but it is just
like that for the functions one.
Also the sort operation is done when we first use
map__find_symbol_by_name, in a lazy way.
LKML-Reference: <1260564622-12392-1-git-send-email-acme@infradead.org>
Example:
u64 addr = strtoull(sym_filter, NULL, 16);
struct map *map = map_groups__find(kmaps, MAP__VARIABLE, addr);
if (map == NULL)
else {
struct symbol *sym = map__find_symbol(map, addr, NULL);
if (sym == NULL)
pr_err("couldn't find addr!\n");
else
pr_info("addr %#Lx is in %s global var\n", addr, sym->name);
exit(0);
Added just after symbol__init() call in 'perf top', then:
if (map == NULL)
else {
if (sym == NULL)
else
exit(0);
[root@doppio linux-2.6-tip]# grep ' [dD] ' /proc/kallsyms | grep ' sched'
ffffffff817827d8 d sched_nr_latency
ffffffff81782ce0 d sched_domains_mutex
ffffffff8178c070 d schedstr.22423
ffffffff817909a0 d sched_register_mutex
ffffffff81823490 d sched_feat_names
ffffffff81823558 d scheduler_running
ffffffff818235b8 d sched_clock_running
ffffffff818235bc D sched_clock_stable
ffffffff81824f00 d sched_switch_trace
[root@doppio linux-2.6-tip]# perf top -s 0xffffffff817827d9
addr 0xffffffff817827d9 is in sched_nr_latency global var
[root@doppio linux-2.6-tip]# perf top -s ffffffff81782ce0
addr 0xffffffff81782ce0 is in sched_domains_mutex global var
[root@doppio linux-2.6-tip]# perf top -s ffffffff81782ce0 --vmlinux OFF
The file OFF cannot be used, trying to use /proc/kallsyms...addr 0xffffffff81782ce0 is in sched_domains_mutex global var
[root@doppio linux-2.6-tip]# perf top -s ffffffff818235bc --vmlinux OFF
The file OFF cannot be used, trying to use /proc/kallsyms...addr 0xffffffff818235bc is in sched_clock_stable global var
So it works with both /proc/kallsyms and with ELF symtabs, either
the one on the vmlinux explicitely passed via --vmlinux or in one
in the vmlinux_path that matches the buildid for the running kernel
or the one found in the buildid header section in a perf.data file.
LKML-Reference: <1260550239-5372-4-git-send-email-acme@infradead.org>
For selecting the right types of symbols in ELF symtabs.
LKML-Reference: <1260550239-5372-3-git-send-email-acme@infradead.org>
For selecting the right types of symbols in /proc/kallsyms, will be
followed by elf_symbol_type__is_a, for the same purpose on ELF
symtabs.
LKML-Reference: <1260550239-5372-2-git-send-email-acme@infradead.org>
Using a struct thread instance just to hold the kernel space maps
(vmlinux + modules) is overkill and confuses people trying to
understand the perf symbols abstractions.
The kernel maps are really present in all threads, i.e. the kernel
is a library, not a separate thread.
So introduce the 'map_groups' abstraction and use it for the kernel
maps, now in the kmaps global variable.
It, in turn, will move, together with the threads list to the
perf_file abstraction, so that we can support multiple perf_file
instances, needed by perf diff.
Brainstormed-with: Eduardo Habkost <ehabkost@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
LKML-Reference: <1260550239-5372-1-git-send-email-acme@infradead.org>
LKML-Reference: <1260396578-19116-1-git-send-email-acme@infradead.org>
Now we have a very high level routine for simple tools to
process IP sample events:
int event__preprocess_sample(const event_t *self,
struct addr_location *al,
symbol_filter_t filter)
It receives the event itself and will insert new threads in the
global threads list and resolve the map and symbol, filling all
this info into the new addr_location struct, so that tools like
annotate and report can further process the event by creating
hist_entries in their specific way (with or without callgraphs,
etc).
It in turn uses the new next layer function:
void thread__find_addr_location(struct thread *self, u8 cpumode,
enum map_type type, u64 addr,
This one will, given a thread (userspace or the kernel kthread
one), will find the given type (MAP__FUNCTION now, MAP__VARIABLE
too in the near future) at the given cpumode, taking vdsos into
account (userspace hit, but kernel symbol) and will fill all
these details in the addr_location given.
Tools that need a more compact API for plain function
resolution, like 'kmem', can use this other one:
struct symbol *thread__find_function(struct thread *self, u64 addr,
So, to resolve a kernel symbol, that is all the 'kmem' tool
needs, its just a matter of calling:
sym = thread__find_function(kthread, addr, NULL);
The 'filter' parameter is needed because we do lazy
parsing/loading of ELF symtabs or /proc/kallsyms.
With this we remove more code duplication all around, which is
always good, huh? :-)
Cc: John Kacur <jkacur@redhat.com>
LKML-Reference: <1259346563-12568-12-git-send-email-acme@infradead.org>
LKML-Reference: <1259346563-12568-10-git-send-email-acme@infradead.org>
Making the routines that were so far specific to the kernel maps
useful for all threads.
This is done by making the kernel maps be contained in a kernel
"thread".
This gets the kernel specific routines closer to the userspace
counterparts, which will help in reducing the boilerplate for
resolving a symbol, as will be demonstrated in the next patches.
LKML-Reference: <1259346563-12568-9-git-send-email-acme@infradead.org>
So that we can support multiple symbol table types.
LKML-Reference: <1259346563-12568-8-git-send-email-acme@infradead.org>
So that the kallsyms loading routines are the direct counterpart
of the vmlinux loading ones, i.e. dso__load_kallsyms is the
counterpart of dso__load_vmlinux.
In the process make them also use the symbols rb tree indexed by
map->type, paving the way for supporting other types of symtabs,
such as the next one to be supported: variables.
This also allowed removal of yet another global variable:
kernel_map__functions.
LKML-Reference: <1259346563-12568-7-git-send-email-acme@infradead.org>
By using an array of rb_roots in struct dso we can, from a
struct map instance to get the right symbol rb_tree more easily.
This way we can have just one symbol lookup method for struct
map instances, map__find_symbol, instead of one per symtab type
(functions, variables).
LKML-Reference: <1259346563-12568-6-git-send-email-acme@infradead.org>
That way we will be able to check if the right symtab is loaded
in the underlying DSO.
LKML-Reference: <1259346563-12568-5-git-send-email-acme@infradead.org>
