This patch is to return error code of perf_new_session function on
failure instead of NULL.
Test Results:
Before Fix:
$ perf c2c report -input
failed to open nput: No such file or directory
$ echo $?
0
After Fix:
$ echo $?
254
Committer notes:
Fix 'perf tests topology' case, where we use that TEST_ASSERT_VAL(...,
session), i.e. we need to pass zero in case of failure, which was the
case before when NULL was returned by perf_session__new() for failure,
but now we need to negate the result of IS_ERR(session) to respect that
TEST_ASSERT_VAL) expectation of zero meaning failure.
Reported-by: Nageswara R Sastry <rnsastry@linux.vnet.ibm.com>
Signed-off-by: Mamatha Inamdar <mamatha4@linux.vnet.ibm.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Tested-by: Nageswara R Sastry <rnsastry@linux.vnet.ibm.com>
Acked-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Reviewed-by: Jiri Olsa <jolsa@redhat.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Alexey Budankov <alexey.budankov@linux.intel.com>
Cc: Jeremie Galarneau <jeremie.galarneau@efficios.com>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Shawn Landden <shawn@git.icu>
Cc: Song Liu <songliubraving@fb.com>
Cc: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Link: http://lore.kernel.org/lkml/20190822071223.17892.45782.stgit@localhost.localdomain
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Move the perf_event_attr struct fron 'struct evsel' to 'struct perf_evsel'.
Committer notes:
Fixed up these:
tools/perf/arch/arm/util/auxtrace.c
tools/perf/arch/arm/util/cs-etm.c
tools/perf/arch/arm64/util/arm-spe.c
tools/perf/arch/s390/util/auxtrace.c
tools/perf/util/cs-etm.c
Also
cc1: warnings being treated as errors
tests/sample-parsing.c: In function 'do_test':
tests/sample-parsing.c:162: error: missing initializer
tests/sample-parsing.c:162: error: (near initialization for 'evsel.core.cpus')
struct evsel evsel = {
.needs_swap = false,
- .core.attr = {
- .sample_type = sample_type,
- .read_format = read_format,
+ .core = {
+ . attr = {
+ .sample_type = sample_type,
+ .read_format = read_format,
[perfbuilder@a70e4eeb5549 /]$ gcc --version |& head -1
gcc (GCC) 4.4.7
Also we don't need to include perf_event.h in
tools/perf/lib/include/perf/evsel.h, forward declaring 'struct
perf_event_attr' is enough. And this even fixes the build in some
systems where things are used somewhere down the include path from
perf_event.h without defining __always_inline.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Michael Petlan <mpetlan@redhat.com>
Link: http://lkml.kernel.org/r/20190721112506.12306-43-jolsa@kernel.org
Rename perf_evlist__delete() to evlist__delete(), so we don't have a
name clash when we add perf_evlist__delete() in libperf.
Link: http://lkml.kernel.org/r/20190721112506.12306-10-jolsa@kernel.org
Rename struct perf_evlist to struct evlist, so we don't have a name
clash when we add struct perf_evlist in libperf.
Committer notes:
Added fixes to build on arm64, from Jiri and from me
(tools/perf/util/cs-etm.c)
Link: http://lkml.kernel.org/r/20190721112506.12306-6-jolsa@kernel.org
Rename struct perf_evsel to struct evsel, so we don't have a name clash
when we add struct perf_evsel in libperf.
Committer notes:
Added fixes for arm64, provided by Jiri.
Link: http://lkml.kernel.org/r/20190721112506.12306-5-jolsa@kernel.org
In places where the equivalent was already being done, i.e.:
free(a);
a = NULL;
And in placs where struct members are being freed so that if we have
some erroneous reference to its struct, then accesses to freed members
will result in segfaults, which we can detect faster than use after free
to areas that may still have something seemingly valid.
Cc: Jiri Olsa <jolsa@kernel.org>
Link: https://lkml.kernel.org/n/tip-jatyoofo5boc1bsvoig6bb6i@git.kernel.org
Eroding a bit more the tools/perf/util/util.h hodpodge header.
Link: https://lkml.kernel.org/n/tip-natazosyn9rwjka25tvcnyi0@git.kernel.org
We got the sane_ctype.h headers from git and kept using it so far, but
since that code originally came from the kernel sources to the git
sources, perhaps its better to just use the one in the kernel, so that
we can leverage tools/perf/check_headers.sh to be notified when our copy
gets out of sync, i.e. when fixes or goodies are added to the code we've
copied.
This will help with things like tools/lib/string.c where we want to have
more things in common with the kernel, such as strim(), skip_spaces(),
etc so as to go on removing the things that we have in tools/perf/util/
and instead using the code in the kernel, indirectly and removing things
like EXPORT_SYMBOL(), etc, getting notified when fixes and improvements
are made to the original code.
Hopefully this also should help with reducing the difference of code
hosted in tools/ to the one in the kernel proper.
Link: https://lkml.kernel.org/n/tip-7k9868l713wqtgo01xxygn12@git.kernel.org
Based on 1 normalized pattern(s):
released under the gpl v2 and only v2 not any later version
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 12 file(s).
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190529141332.526460839@linutronix.de
This strncat() is safe because the buffer was allocated with zalloc(),
however gcc doesn't know that. Since the string always has 4 non-null
bytes, just use memcpy() here.
CC /home/shawn/linux/tools/perf/util/data-convert-bt.o
In file included from /usr/include/string.h:494,
from /home/shawn/linux/tools/lib/traceevent/event-parse.h:27,
from util/data-convert-bt.c:22:
In function ‘strncat’,
inlined from ‘string_set_value’ at util/data-convert-bt.c:274:4:
/usr/include/powerpc64le-linux-gnu/bits/string_fortified.h:136:10: error: ‘__builtin_strncat’ output may be truncated copying 4 bytes from a string of length 4 [-Werror=stringop-truncation]
136 | return __builtin___strncat_chk (__dest, __src, __len, __bos (__dest));
Signed-off-by: Shawn Landden <shawn@git.icu>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Wang Nan <wangnan0@huawei.com>
LPU-Reference: 20190518183238.10954-1-shawn@git.icu
Link: https://lkml.kernel.org/n/tip-289f1jice17ta7tr3tstm9jm@git.kernel.org
to "tep"
The member "pevent" of the struct tep_event is renamed to "tep". This
makes the struct consistent with the chosen naming convention:
tep (trace event parser), instead of the old pevent.
Signed-off-by: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Link: http://lore.kernel.org/linux-trace-devel/20190401132111.13727-3-tstoyanov@vmware.com
Link: http://lkml.kernel.org/r/20190401164344.627724996@goodmis.org
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Add a 'path' member to 'struct perf_data'. It will keep the configured
path for the data (const char *). The path in struct perf_data_file is
now dynamically allocated (duped) from it.
This scheme is useful/used in following patches where struct
perf_data::path holds the 'configure' directory path and struct
perf_data_file::path holds the allocated path for specific files.
Also it actually makes the code little simpler.
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20190221094145.9151-3-jolsa@kernel.org
[ Fixup data-convert-bt.c missing conversion ]
tep_format_flags
In order to make libtraceevent into a proper library, variables, data
structures and functions require a unique prefix to prevent name space
conflicts. That prefix will be "tep_". This renames enum format_flags
to enum tep_format_flags and adds prefix TEP_ to all of its members.
Signed-off-by: Tzvetomir Stoyanov (VMware) <tz.stoyanov@gmail.com>
Cc: Tzvetomir Stoyanov (VMware) <tz.stoyanov@gmail.com>
Cc: linux-trace-devel@vger.kernel.org
Link: http://lkml.kernel.org/r/20180919185722.803127871@goodmis.org
tep_format{_field}
conflicts. That prefix will be "tep_". This renames struct format to
struct tep_format and struct format_field to struct tep_format_field
Link: http://lkml.kernel.org/r/20180919185722.661319373@goodmis.org
Building the perf CTF converter fails with gcc 4.8.4 on Ubuntu 14.04
with the following error:
error: missing initializer for field ‘fd’ of ‘struct perf_data_file’
[-Werror=missing-field-initializers]
Per 4b838b0db4e9 ("perf tools: Add compression id into 'struct
kmod_path'") and the ensuing discussion on the mailing list, it appears
that this affects other distributions and gcc versions.
Signed-off-by: Jeremie Galarneau <jeremie.galarneau@efficios.com>
Link: http://lkml.kernel.org/r/20180829201648.19588-1-jeremie.galarneau@efficios.com
conflicts. That prefix will be "tep_" and not "pevent_". This changes
APIs: pevent_read_number, pevent_read_number_field
Cc: Yordan Karadzhov (VMware) <y.karadz@gmail.com>
Link: http://lkml.kernel.org/r/20180808180700.804271434@goodmis.org
Add struct perf_data_file to represent a single file within a perf_data
struct.
Cc: Changbin Du <changbin.du@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jin Yao <yao.jin@linux.intel.com>
Link: http://lkml.kernel.org/n/tip-c3f9p4xzykr845ktqcek6p4t@git.kernel.org
[ Fixup recent changes in 'perf script --per-event-dump' ]
Rename struct perf_data_file to perf_data, because we will add the
possibility to have multiple files under perf.data, so the 'perf_data'
name fits better.
Link: http://lkml.kernel.org/n/tip-39wn4d77phel3dgkzo3lyan0@git.kernel.org
This adds the mmap and mmap2 events to the CTF trace obtained from perf
data.
These events will allow CTF trace visualization tools like Trace Compass
to automatically resolve the symbols of the callchain to the
corresponding function or origin library.
To include those events, one needs to convert with the --all option.
Here follows an output of babeltrace:
$ sudo perf data convert --all --to-ctf myctftrace
$ babeltrace ./myctftrace
[19:00:00.000000000] (+0.000000000) perf_mmap2: { cpu_id = 0 },
{ pid = 638, tid = 638, start = 0x7F54AE39E000, filename =
"/usr/lib/ld-2.25.so" }
[19:00:00.000000000] (+0.000000000) perf_mmap2: { cpu_id = 0 }, { pid =
638, tid = 638, start = 0x7F54AE565000, filename =
"/usr/lib/libudev.so.1.6.6" }
638, tid = 638, start = 0x7FFC093EA000, filename = "[vdso]" }
Signed-off-by: Geneviève Bastien <gbastien@versatic.net>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Francis Deslauriers <francis.deslauriers@efficios.com>
Cc: Julien Desfossez <jdesfossez@efficios.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Link: http://lkml.kernel.org/r/20170727181205.24843-2-gbastien@versatic.net
The field perf_callchain, if available, is added to the sampling events
during the CTF conversion. It is an array of u64 values. The
perf_callchain_size field contains the size of the array.
It will allow the analysis of sampling data in trace visualization tools
like Trace Compass. Possible analyses with those data: dynamic
flamegraphs, correlation with other tracing data like a userspace trace.
Here follows a babeltrace CTF output of a trace with callchain:
[17:38:45.672760285] (+?.?????????) cycles:ppp: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF81063EE4, perf_tid = 25841, perf_pid = 25774, perf_period = 1, perf_callchain_size = 7, perf_callchain = [ [0] = 0xFFFFFFFFFFFFFF80, [1] = 0xFFFFFFFF81063EE4, [2] = 0xFFFFFFFF8100C770, [3] = 0xFFFFFFFF81006EC6, [4] = 0xFFFFFFFF8118245E, [5] = 0xFFFFFFFF810A9224, [6] = 0xFFFFFFFF8164A4C6 ] }
[17:38:45.672777672] (+0.000017387) cycles:ppp: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF81063EE4, perf_tid = 25841, perf_pid = 25774, perf_period = 1, perf_callchain_size = 8, perf_callchain = [ [0] = 0xFFFFFFFFFFFFFF80, [1] = 0xFFFFFFFF81063EE4, [2] = 0xFFFFFFFF8100C770, [3] = 0xFFFFFFFF81006EC6, [4] = 0xFFFFFFFF8118245E, [5] = 0xFFFFFFFF810A9224, [6] = 0xFFFFFFFF8164A4C6, [7] = 0xFFFFFFFF8164ABAD ] }
[17:38:45.672786700] (+0.000009028) cycles:ppp: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF81063EE4, perf_tid = 25841, perf_pid = 25774, perf_period = 70, perf_callchain_size = 3, perf_callchain = [ [0] = 0xFFFFFFFFFFFFFF80, [1] = 0xFFFFFFFF81063EE4, [2] = 0xFFFFFFFF8100C770 ] }
Link: http://lkml.kernel.org/r/20170727181205.24843-1-gbastien@versatic.net
[ Removed PERF_SAMPLE_CALLCHAIN from the TODO list, jolsa ]
Just warn the user and ignore those values.
Link: http://lkml.kernel.org/n/tip-tbf60nj3ierm6hrkhpothymx@git.kernel.org
Removing it from util.h, part of an effort to disentangle the includes
hell, that makes changes to util.h or something included by it to cause
a complete rebuild of the tools.
Link: http://lkml.kernel.org/n/tip-ztrjy52q1rqcchuy3rubfgt2@git.kernel.org
More stuff that came from git, out of the hodge-podge that is util.h
Link: http://lkml.kernel.org/n/tip-e3lana4gctz3ub4hn4y29hkw@git.kernel.org
Needed to use the PRI[xu](32,64) formatting macros.
Link: http://lkml.kernel.org/n/tip-wkbho8kaw24q67dd11q0j39f@git.kernel.org
To pave the way for further cleanups where linux/kernel.h may stop being
included in some header.
Link: http://lkml.kernel.org/n/tip-qqxan6tfsl6qx3l0v3nwgjvk@git.kernel.org
Introduce a new option to record PERF_RECORD_NAMESPACES events emitted
by the kernel when fork, clone, setns or unshare are invoked. And update
perf-record documentation with the new option to record namespace
events.
Committer notes:
Combined it with a later patch to allow printing it via 'perf report -D'
and be able to test the feature introduced in this patch. Had to move
here also perf_ns__name(), that was introduced in another later patch.
Also used PRIu64 and PRIx64 to fix the build in some enfironments wrt:
util/event.c:1129:39: error: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type 'long long unsigned int' [-Werror=format=]
ret += fprintf(fp, "%u/%s: %lu/0x%lx%s", idx
Testing it:
# perf record --namespaces -a
^C[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 1.083 MB perf.data (423 samples) ]
# perf report -D
<SNIP>
3 2028902078892 0x115140 [0xa0]: PERF_RECORD_NAMESPACES 14783/14783 - nr_namespaces: 7
[0/net: 3/0xf0000081, 1/uts: 3/0xeffffffe, 2/ipc: 3/0xefffffff, 3/pid: 3/0xeffffffc,
4/user: 3/0xeffffffd, 5/mnt: 3/0xf0000000, 6/cgroup: 3/0xeffffffb]
0x1151e0 [0x30]: event: 9
. ... raw event: size 48 bytes
. 0000: 09 00 00 00 02 00 30 00 c4 71 82 68 0c 7f 00 00 ......0..q.h....
. 0010: a9 39 00 00 a9 39 00 00 94 28 fe 63 d8 01 00 00 .9...9...(.c....
. 0020: 03 00 00 00 00 00 00 00 ce c4 02 00 00 00 00 00 ................
<SNIP>
NAMESPACES events: 1
<SNIP>
Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com>
Cc: Alexei Starovoitov <ast@fb.com>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Aravinda Prasad <aravinda@linux.vnet.ibm.com>
Cc: Brendan Gregg <brendan.d.gregg@gmail.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Sargun Dhillon <sargun@sargun.me>
Link: http://lkml.kernel.org/r/148891930386.25309.18412039920746995488.stgit@hbathini.in.ibm.com
Previously these were being ignored, sometimes silently.
Stop doing that, emitting debug messages and handling the errors.
Testing it:
$ cat ~/.perfconfig
cat: /home/acme/.perfconfig: No such file or directory
$ perf stat -e cycles usleep 1
Performance counter stats for 'usleep 1':
938,996 cycles:u
0.003813731 seconds time elapsed
$ perf top --stdio
Error:
You may not have permission to collect system-wide stats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid,
<SNIP>
[ perf record: Captured and wrote 0.019 MB perf.data (7 samples) ]
[acme@jouet linux]$ perf report --stdio
# To display the perf.data header info, please use --header/--header-only options.
# Overhead Command Shared Object Symbol
71.77% usleep libc-2.24.so [.] _dl_addr
27.07% usleep ld-2.24.so [.] _dl_next_ld_env_entry
1.13% usleep [kernel.kallsyms] [k] page_fault
$ touch ~/.perfconfig
$ ls -la ~/.perfconfig
-rw-rw-r--. 1 acme acme 0 Jan 27 12:14 /home/acme/.perfconfig
$ perf stat -e instructions usleep 1
244,610 instructions:u
0.000805383 seconds time elapsed
[root@jouet ~]# chown acme.acme ~/.perfconfig
[root@jouet ~]# perf stat -e cycles usleep 1
Warning: File /root/.perfconfig not owned by current user or root, ignoring it.
937,615 cycles
0.000836931 seconds time elapsed
Link: http://lkml.kernel.org/n/tip-j2rq96so6xdqlr8p8rd6a3jx@git.kernel.org
On ARM32 building it report following error when we build with
libbabeltrace:
util/data-convert-bt.c: In function 'add_bpf_output_values':
util/data-convert-bt.c:440:3: error: format '%lu' expects argument of type 'long unsigned int', but argument 5 has type 'unsigned int' [-Werror=format]
cc1: all warnings being treated as errors
Fix it by changing %lu to %zu.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Zefan Li <lizefan@huawei.com>
Cc: pi3orama@163.com
Fixes: 6122d57e9f7c ("perf data: Support converting data from bpf_perf_event_output()")
Link: http://lkml.kernel.org/r/1475035126-146587-1-git-send-email-wangnan0@huawei.com
If 'all' is selected, convert fork and exit events to output CTF stream.
Link: http://lkml.kernel.org/r/1466767332-114472-8-git-send-email-wangnan0@huawei.com
If 'all' is selected, convert comm event to output CTF stream.
setup_non_sample_events() is called if non_sample is selected. It
creates a comm_class for comm event.
Use macros to generate and process_comm_event and add_comm_event. These
macros can be reused for other non-sample events.
Link: http://lkml.kernel.org/r/1466767332-114472-6-git-send-email-wangnan0@huawei.com
Following commits are going to allow 'perf data convert' to collect not
only samples, but also non-sample events like comm and fork. In this
patch we count non-sample events using c.non_sample_count, and prepare
to print number of both type of events like:
# ~/perf data convert --all --to-ctf ./out.ctf
[ perf data convert: Converted 'perf.data' into CTF data './out.ctf' ]
[ perf data convert: Converted and wrote 0.846 MB (6508 samples, 686 non-samples) ]
Link: http://lkml.kernel.org/r/1466767332-114472-5-git-send-email-wangnan0@huawei.com
Following commits will add new option to 'perf data convert'. All options
should be grouped into a structure and passed to low level converter
(currently there's only one converter).
Introduce data-convert.h and define 'struct perf_data_convert_opts' in
it. Pass 'force' through opts.
Link: http://lkml.kernel.org/r/1466767332-114472-3-git-send-email-wangnan0@huawei.com
There are many value_set_##x helper for integer, but only for integer.
This patch adds value_set_string() helper to help following commits
create string fields.
Link: http://lkml.kernel.org/r/1466767332-114472-2-git-send-email-wangnan0@huawei.com
Otherwise some compiler might scream:
$ make LIBBABELTRACE_DIR=/opt/libbabeltrace/ LIBBABELTRACE=1
BUILD: Doing 'make -j4' parallel build
CC util/data-convert-bt.o
util/data-convert-bt.c: In function ‘convert__config’:
util/data-convert-bt.c:1299:19: error: implicit declaration of function ‘perf_config_u64’ [-Werror=implicit-function-declaration]
c->queue_size = perf_config_u64(var, value);
Cc: He Kuang <hekuang@huawei.com>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: Taeung Song <treeze.taeung@gmail.com>
Fixes: 41840d211c51 ("perf config: Move config declarations from util/cache.h to util/config.h")
Link: http://lkml.kernel.org/r/1466772025-17471-1-git-send-email-jolsa@kernel.org
To match the semantics for list.h in the kernel, that are used to
implement those macros.
Cc: Milian Wolff <milian.wolff@kdab.com>
Link: http://lkml.kernel.org/n/tip-qbcjlgj0ffxquxscahbpddi3@git.kernel.org
We observed some crazy apps on Android set their comm to unprintable
string. For example:
# cat /proc/10607/task/*/comm
tencent.qqmusic
Binder_2
日志输出线 <-- Chinese word 'log output thread'
WifiManager
'perf data convert' fails to convert perf.data with such string to CTF format.
For example:
# cat << EOF > ./badguy.c
#include <sys/prctl.h>
int main(int argc, char *argv[])
prctl(PR_SET_NAME, "\xe6\x97\xa5\xe5\xbf\x97\xe8\xbe\x93\xe5\x87\xba\xe7\xba\xbf");
while(1)
sleep(1);
return 0;
EOF
# gcc ./badguy.c
# perf record -e sched:* ./a.out
# perf data convert --to-ctf ./bad.ctf
CTF stream 4 flush failed
[ perf data convert: Converted 'perf.data' into CTF data './bad.ctf' ]
[ perf data convert: Converted and wrote 0.008 MB (78 samples) ]
# babeltrace ./bad.ctf/
[error] Packet size (18446744073709551615 bits) is larger than remaining file size (262144 bits).
[error] Stream index creation error.
[error] Open file stream error.
[warning] [Context] Cannot open_trace of format ctf at path ./bad.ctf.
[warning] [Context] cannot open trace "./bad.ctf" from ./bad.ctf/ for reading.
[error] Cannot open any trace for reading.
[error] opening trace "./bad.ctf/" for reading.
[error] none of the specified trace paths could be opened.
This patch converts unprintable characters to hexadecimal word.
After applying this patch the above test works correctly:
# ~/perf data convert --to-ctf ./good.ctf
[ perf data convert: Converted 'perf.data' into CTF data './good.ctf' ]
# babeltrace ./good.ctf
[23:14:35.491665268] (+0.000001100) sched:sched_wakeup: { cpu_id = 4 }, { perf_ip = 0xFFFFFFFF810AEF33, perf_tid = 0, perf_pid = 0, perf_id = 5123, perf_period = 1, common_type = 270, common_flags = 45, common_preempt_count = 4, common_pid = 0, comm = "\xe6\x97\xa5\xe5\xbf\x97\xe8\xbe\x93\xe5\x87\xba\xe7\xba\xbf", pid = 1057, prio = 120, success = 1, target_cpu = 4 }
[23:14:35.491666230] (+0.000000962) sched:sched_wakeup: { cpu_id = 4 }, { perf_ip = 0xFFFFFFFF810AEF33, perf_tid = 0, perf_pid = 0, perf_id = 5122, perf_period = 1, common_type = 270, common_flags = 45, common_preempt_count = 4, common_pid = 0, comm = "\xe6\x97\xa5\xe5\xbf\x97\xe8\xbe\x93\xe5\x87\xba\xe7\xba\xbf", pid = 1057, prio = 120, success = 1, target_cpu = 4 }
Committer note:
To build perf with libabeltrace, use:
$ mkdir -p /tmp/build/perf
$ make LIBBABELTRACE=1 LIBBABELTRACE_DIR=/usr/local O=/tmp/build/perf -C tools/perf install-bin
Or equivalent (no O=, fixup LIBBABELTRACE_DIR, etc).
Link: http://lkml.kernel.org/r/1464348951-179595-1-git-send-email-wangnan0@huawei.com
All over the tree.
cc: Jiri Olsa <jolsa@kernel.org>
Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/n/tip-8nzhnokxyp8y4v7gf0j00oyb@git.kernel.org
After babeltrace commit 5cec03e402aa ("ir: copy variants and sequences
when setting a field path"), 'perf data convert' gets incorrect result
if there's bpf output data. For example:
# perf data convert --to-ctf ./out.ctf
# babeltrace ./out.ctf
[10:44:31.186045346] (+?.?????????) evt: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF810E7DD1, perf_tid = 23819, perf_pid = 23819, perf_id = 518, raw_len = 3, raw_data = [ [0] = 0xC028E32F, [1] = 0x815D0100, [2] = 0x1000000 ] }
[10:44:31.286101003] (+0.100055657) evt: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF8105B609, perf_tid = 23819, perf_pid = 23819, perf_id = 518, raw_len = 3, raw_data = [ [0] = 0x35D9F1EB, [1] = 0x15D81, [2] = 0x2 ] }
The expected result of the first sample should be:
raw_data = [ [0] = 0x2FE328C0, [1] = 0x15D81, [2] = 0x1 ] }
however, 'perf data convert' output big endian value to resuling CTF
file.
The reason is a internal change (or a bug?) of babeltrace.
Before this patch, at the first add_bpf_output_values(), byte order of
all integer type is uncertain (is 0, neither 1234 (le) nor 4321 (be)).
It would be fixed by:
perf_evlist__deliver_sample
-> process_sample_event
-> ctf_stream
->bt_ctf_trace_add_stream_class
->bt_ctf_field_type_structure_set_byte_order
->bt_ctf_field_type_integer_set_byte_order
during creating the stream.
However, the babeltrace commit mentioned above duplicates types in
sequence to prevent potential conflict in following call stack and link
the newly allocated type into the 'raw_data' sequence:
-> ctf_stream
-> bt_ctf_trace_add_stream_class
-> bt_ctf_stream_class_resolve_types
-> bt_ctf_field_type_sequence_copy
->bt_ctf_field_type_integer_copy
This happens before byte order setting, so only the newly allocated
type is initialized, the byte order of original type perf choose to
create the first raw_data is still uncertain.
Byte order in CTF output is not related to byte order in perf.data.
Setting it to anything other than BT_CTF_BYTE_ORDER_NATIVE solves this
problem (only BT_CTF_BYTE_ORDER_NATIVE needs to be fixed). To reduce
behavior changing, set byte order according to compiling options.
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Jérémie Galarneau <jeremie.galarneau@efficios.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/1456479154-136027-10-git-send-email-wangnan0@huawei.com
bpf_perf_event_output() outputs data through sample->raw_data. This
patch adds support to convert those data into CTF. A python script then
can be used to process output data from BPF programs.
Test result:
# cat ./test_bpf_output_2.c
/************************ BEGIN **************************/
#include <uapi/linux/bpf.h>
struct bpf_map_def {
unsigned int type;
unsigned int key_size;
unsigned int value_size;
unsigned int max_entries;
#define SEC(NAME) __attribute__((section(NAME), used))
static u64 (*ktime_get_ns)(void) =
(void *)BPF_FUNC_ktime_get_ns;
static int (*trace_printk)(const char *fmt, int fmt_size, ...) =
(void *)BPF_FUNC_trace_printk;
static int (*get_smp_processor_id)(void) =
(void *)BPF_FUNC_get_smp_processor_id;
static int (*perf_event_output)(void *, struct bpf_map_def *, int, void *, unsigned long) =
(void *)BPF_FUNC_perf_event_output;
struct bpf_map_def SEC("maps") channel = {
.type = BPF_MAP_TYPE_PERF_EVENT_ARRAY,
.key_size = sizeof(int),
.value_size = sizeof(u32),
.max_entries = __NR_CPUS__,
static inline int __attribute__((always_inline))
func(void *ctx, int type)
struct {
u64 ktime;
int type;
} __attribute__((packed)) output_data;
char error_data[] = "Error: failed to output\n";
int err;
output_data.type = type;
output_data.ktime = ktime_get_ns();
err = perf_event_output(ctx, &channel, get_smp_processor_id(),
&output_data, sizeof(output_data));
if (err)
trace_printk(error_data, sizeof(error_data));
return 0;
SEC("func_begin=sys_nanosleep")
int func_begin(void *ctx) {return func(ctx, 1);}
SEC("func_end=sys_nanosleep%return")
int func_end(void *ctx) { return func(ctx, 2);}
char _license[] SEC("license") = "GPL";
int _version SEC("version") = LINUX_VERSION_CODE;
/************************* END ***************************/
# ./perf record -e bpf-output/no-inherit,name=evt/ \
-e ./test_bpf_output_2.c/map:channel.event=evt/ \
usleep 100000
[ perf record: Captured and wrote 0.012 MB perf.data (2 samples) ]
# ./perf script
usleep 14942 92503.198504: evt: ffffffff810e0ba1 sys_nanosleep (/lib/modules/4.3.0....
usleep 14942 92503.298562: evt: ffffffff810585e9 kretprobe_trampoline_holder (/lib....
# ./perf data convert --to-ctf ./out.ctf
[ perf data convert: Converted and wrote 0.000 MB (2 samples) ]
[01:41:43.198504134] (+?.?????????) evt: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF810E0BA1, perf_tid = 14942, perf_pid = 14942, perf_id = 1044, raw_len = 3, raw_data = [ [0] = 0x32C0C07B, [1] = 0x5421, [2] = 0x1 ] }
[01:41:43.298562257] (+0.100058123) evt: { cpu_id = 0 }, { perf_ip = 0xFFFFFFFF810585E9, perf_tid = 14942, perf_pid = 14942, perf_id = 1044, raw_len = 3, raw_data = [ [0] = 0x38B77FAA, [1] = 0x5421, [2] = 0x2 ] }
# cat ./test_bpf_output_2.py
from babeltrace import TraceCollection
tc = TraceCollection()
tc.add_trace('./out.ctf', 'ctf')
d = {1:[], 2:[]}
for event in tc.events:
if not event.name.startswith('evt'):
continue
raw_data = event['raw_data']
(time, type) = ((raw_data[0] + (raw_data[1] << 32)), raw_data[2])
d[type].append(time)
print(list(map(lambda i: d[2][i] - d[1][i], range(len(d[1])))));
# python3 ./test_bpf_output_2.py
[100056879]
Committer note:
Make sure you have python3-devel installed, not python-devel, which may
be for python2, which will lead to some "PyInstance_Type" errors. Also
make sure that you use the right libbabeltrace, because it is shipped
in Fedora, for instance, but an older version.
To build libbabeltrace's python binding one also needs to use:
./configure --enable-python-bindings
And then set PYTHONPATH=/usr/local/lib64/python3.4/site-packages/.
Link: http://lkml.kernel.org/r/1456479154-136027-9-git-send-email-wangnan0@huawei.com
Before this patch each subcommand calls perf_config() by themself,
reading the default configuration together with subcommand specific
options. If a subcommand doesn't have it own options, it needs to call
'perf_config(perf_default_config, NULL)' to ensure .perfconfig is
loaded.
This patch brings perf_config(perf_default_config, NULL) to the very
start of main(), so subcommands don't need to do it.
After this patch, 'llvm.clang-path' works for 'perf trace'.
Suggested-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/1456479154-136027-4-git-send-email-wangnan0@huawei.com
A new patch in libbabeltrace [1] reveals a object leak problem in
'perf data' CTF support: perf code never releases the event_class
which is allocated in add_event() and stored in evsel's private field.
If libbabeltrace has the above patch applied, leaking event_class
prevents the writer from being destroyed and flushing metadata. For
example:
$ perf record ls
perf.data
[ perf record: Captured and wrote 0.012 MB perf.data (12 samples) ]
$ perf data convert --to-ctf ./out.ctf
[ perf data convert: Converted and wrote 0.000 MB (12 samples) ]
$ cat ./out.ctf/metadata
$ ls -l ./out.ctf/metadata
-rw-r----- 1 w00229757 mm 0 Jan 27 10:49 ./out.ctf/metadata
The correct result should be:
/* CTF 1.8 */
trace {
[SNIP]
-rw-r----- 1 w00229757 mm 2446 Jan 27 10:52 ./out.ctf/metadata
The full story is:
Patch [1] of babeltrace redesigns its reference counting scheme. In that
patch:
* writer <- trace (bt_ctf_writer_create)
* trace <- stream_class (bt_ctf_trace_add_stream_class)
* stream_class <- event_class (bt_ctf_stream_class_add_event_class)
('<-' means 'is a parent of')
Holding of event_class causes reference count of corresponding 'writer'
to increase through parent chain. Perf expects that 'writer' is released
(so metadata is flushed) through bt_ctf_writer_put() in
ctf_writer__cleanup(). However, since it never releases event_class, the
reference of 'writer' won't be dropped, so bt_ctf_writer_put() won't
lead to the release of writer.
Before this CTF patch, !(writer <- trace). Even with event_class leaking,
the writer ends up being released.
[1] https://github.com/efficios/babeltrace/commit/e6a8e8e4744633807083a077ff9f101eb97d9801
Cc: Cody P Schafer <dev@codyps.com>
Cc: Kirill Smelkov <kirr@nexedi.com>
Link: http://lkml.kernel.org/r/1454680939-24963-6-git-send-email-wangnan0@huawei.com
Add hexadecimal u32 to base data type, which is useful for raw output
because raw data is u32 aligned.
Link: http://lkml.kernel.org/r/1449541544-67621-12-git-send-email-wangnan0@huawei.com
When converting int values, perf first extractes it to a ulonglong, then
feeds it to babeltrace as a signed value.
For negative 32 bit values (for example, return values of failed
syscalls), the extracted data should be something like 0xfffffffe (-2).
It becomes a large int64 value.
Babeltrace denies to insert it with bt_ctf_field_signed_integer_set_value()
because it is larger than 0x7fffffff, the largest positive value a
32 bit int can be.
This patch introduces adjust_signedness(), which fills high bits of
ulonglong with 1 if the value is negative.
Cc: Jeremie Galarneau <jgalar@efficios.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Tom Zanussi <tzanussi@gmail.com>
Link: http://lkml.kernel.org/r/1429372220-6406-8-git-send-email-jolsa@kernel.org
[ s/signess/signedness/g ]
Some parameters of syscall tracepoints named as 'nr', 'event', etc.
When dealing with them, perf convert to ctf meets some problem:
1. If a parameter with name 'nr', it will duplicate syscall's
common field 'nr'. One such syscall is io_submit().
2. If a parameter with name 'event', it is denied to be inserted
because 'event' is a CTF spec keyword[1]. One such syscall is
epoll_ctl.
This patch appends '_dupl_X' suffix to avoid problem 1, prepend a '_'
prefix to avoid problem 2.
[1] http://diamon.org/docs/ctf/v1.8.2/#specC.1.2
Link: http://lkml.kernel.org/r/1429372220-6406-7-git-send-email-jolsa@kernel.org
[ changed to use format_file::alias ]
Adding support to limit the size of ordered_events queue, so we could
control allocation size of perf data files without proper finished round
events.
Reviewed-by: David Ahern <dsahern@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1429372220-6406-5-git-send-email-jolsa@kernel.org
For big data files the size of data allocated for stream instance could
get really high. It's needed to flush the data out of the stream once in
a while.
Unfortunately there's no size indication in the stream object, so we
govern the flush based on the number of stored events. Current flush
limit is set ot 100000 events.
Link: http://lkml.kernel.org/r/1429372220-6406-4-git-send-email-jolsa@kernel.org
Currently we store the data into single data strea/file. The cpu if data
is stored within the event sample. The lttng puts the CPU number that
belongs to the event into the packet context instead into the event.
This patch makes sure that the trace produce by perf does look the same
way. We now use one stream per-CPU. Having it all in one stream
increased the total size of the resulting file. The test went from
416KiB (with perf_cpu event member) to 24MiB due to the required (and
pointless) flush. With the per-cpu streams the total size went up to
588KiB.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: http://lkml.kernel.org/r/1429372220-6406-3-git-send-email-jolsa@kernel.org
Show message when errors occurred during conversion setup and conversion
process.
Before this patch:
$ ./perf data convert --to-ctf=ctf
$ echo $?
255
After this patch:
Error during conversion setup.
Signed-off-by: He Kuang <hekuang@huawei.com>
Link: http://lkml.kernel.org/n/tip-xvhr1vf7zav9kkeo9w1hv4uk@git.kernel.org
Link: http://lkml.kernel.org/r/1429372220-6406-2-git-send-email-jolsa@kernel.org
Enable perf data convert to use perf.data when it is not owned by
current user or root.
Example:
# perf record ls
# chown Yunlong.Song:Yunlong.Song perf.data
# ls -al perf.data
-rw------- 1 Yunlong.Song Yunlong.Song 28260 Apr 2 17:35 perf.data
# id
uid=0(root) gid=0(root) groups=0(root),64(pkcs11)
Before this patch:
# perf data convert --to-ctf=./ctf-data/
File perf.data not owned by current user or root (use -f to override)
# perf data convert --to-ctf=./ctf-data/ -f
Error: unknown switch `f'
usage: perf data convert [<options>]
-v, --verbose be more verbose
-i, --input <file> input file name
--to-ctf ... Convert to CTF format
After this patch:
# ls ctf-data/
metadata perf_stream_0
As shown above, the -f option really works now.
Signed-off-by: Yunlong Song <yunlong.song@huawei.com>
Link: http://lkml.kernel.org/r/1427982439-27388-11-git-send-email-yunlong.song@huawei.com
Adding support to convert tracepoint event fields into CTF
event fields.
We parse each tracepoint event for CTF conversion and add
tracepoint fields as regular CTF event fields, so they
appear in babeltrace output like:
$ babeltrace ./ctf-data/
[09:02:00.950703057] (+?.?????????) sched:sched_stat_runtime: { }, { perf_ip = ... SNIP ... common_type = 298, common_flags = 1, \
common_preempt_count = 0, common_pid = 31813, comm = "perf", pid = 31813, runtime = 458800, vruntime = 52059858071 }
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1424470628-5969-6-git-send-email-jolsa@kernel.org
