perf_stat__update_shadow_stats
Move the shadow stats scale computation to the
perf_stat__update_shadow_stats() function, so it's centralized and we
don't forget to do it. It also saves few lines of code.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Changbin Du <changbin.du@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jin Yao <yao.jin@linux.intel.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-htg7mmyxv6pcrf57qyo6msid@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Add struct perf_data_file to represent a single file within a perf_data
struct.
Link: http://lkml.kernel.org/n/tip-c3f9p4xzykr845ktqcek6p4t@git.kernel.org
[ Fixup recent changes in 'perf script --per-event-dump' ]
Rename struct perf_data_file to perf_data, because we will add the
possibility to have multiple files under perf.data, so the 'perf_data'
name fits better.
Link: http://lkml.kernel.org/n/tip-39wn4d77phel3dgkzo3lyan0@git.kernel.org
When we started using it for stats and did it not just in
builtin-stat.c, but also for builtin-script.c, then it stopped being a
tool private area, so introduce a new pointer for these stats and leave
->priv to its original purpose.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: yuzhoujian <yuzhoujian@didichuxing.com>
Fixes: cfc8874a4859 ("perf script: Process cpu/threads maps")
Link: http://lkml.kernel.org/n/tip-jtpzx3rjqo78snmmsdzwb2eb@git.kernel.org
It's not possible to run a package event and a per cpu event in the same
group. This is used by some of the power metrics. They work correctly
when not using a group.
Normally weak groups should handle that, but in this case EBADF is
returned instead of the normal EINVAL.
$ strace -e perf_event_open ./perf stat -v -e '{cstate_pkg/c2-residency/,msr/tsc/}:W' -a sleep 1
Using CPUID GenuineIntel-6-3E
perf_event_open({type=0x17 /* PERF_TYPE_??? */, size=PERF_ATTR_SIZE_VER5, config=0, ...}, -1, 0, -1, PERF_FLAG_FD_CLOEXEC) = -1 EINVAL (Invalid argument)
perf_event_open({type=0x17 /* PERF_TYPE_??? */, size=PERF_ATTR_SIZE_VER5, config=0, ...}, -1, 0, -1, 0) = -1 EINVAL (Invalid argument)
perf_event_open({type=0x17 /* PERF_TYPE_??? */, size=PERF_ATTR_SIZE_VER5, config=0, ...}, -1, 0, -1, 0) = 3
perf_event_open({type=0x7 /* PERF_TYPE_??? */, size=PERF_ATTR_SIZE_VER5, config=0, ...}, -1, 0, 3, 0) = 4
perf_event_open({type=0x7 /* PERF_TYPE_??? */, size=PERF_ATTR_SIZE_VER5, config=0, ...}, -1, 1, 0, 0) = -1 EBADF (Bad file descriptor)
and perf errors out.
Make weak groups trigger a fall back for EBADF too. Then this case works correctly:
$ perf stat -v -e '{cstate_pkg/c2-residency/,msr/tsc/}:W' -a sleep 1
Weak group for cstate_pkg/c2-residency//2 failed
cstate_pkg/c2-residency/: 476709882 1000598460 1000598460
msr/tsc/: 39625837911 12007369110 12007369110
Performance counter stats for 'system wide':
476,709,882 cstate_pkg/c2-residency/
39,625,837,911 msr/tsc/
1.000697588 seconds time elapsed
This fixes perf stat -M Power ...
$ perf stat -M Power --metric-only -a sleep 1
Turbo_Utilization C3_Core_Residency C6_Core_Residency C7_Core_Residency C2_Pkg_Residency C3_Pkg_Residency C6_Pkg_Residency C7_Pkg_Residency
1.0 0.7 30.0 0.0 0.9 0.1 0.4 0.0
1.001240740 seconds time elapsed
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/20170905211324.32427-1-andi@firstfloor.org
Some metrics (like GFLOPs) need walltime_nsecs_stats for each interval.
Compute it for each interval instead of only at the end.
Pointed out by Jiri.
Link: http://lkml.kernel.org/r/20170831194036.30146-12-andi@firstfloor.org
Some perf stat metrics use an internal "duration_time" metric. It is not
correctly printed however. So hide it during output to avoid confusing
users with 0 counts.
Link: http://lkml.kernel.org/r/20170831194036.30146-11-andi@firstfloor.org
Add generic support for standalone metrics specified in JSON files to
perf stat. A metric is a formula that uses multiple events to compute a
higher level result (e.g. IPC).
Previously metrics were always tied to an event and automatically
enabled with that event. But now change it that we can have standalone
metrics. They are in the same JSON data structure as events, but don't
have an event name.
We also allow to organize the metrics in metric groups, which allows a
short cut to select several related metrics at once.
Add a new -M / --metrics option to perf stat that adds the metrics or
metric groups specified.
Add the core code to manage and parse the metric groups. They are
collected from the JSON data structures into a separate rblist. When
computing shadow values look for metrics in that list. Then they are
computed using the existing saved values infrastructure in stat-shadow.c
The actual JSON metrics are in a separate pull request.
% perf stat -M Summary --metric-only -a sleep 1
Instructions CLKS CPU_Utilization GFLOPs SMT_2T_Utilization Kernel_Utilization
317614222.0 1392930775.0 0.0 0.0 0.2 0.1
1.001497549 seconds time elapsed
% perf stat -M GFLOPs flops
Performance counter stats for 'flops':
3,999,541,471 fp_comp_ops_exe.sse_scalar_single # 1.2 GFLOPs (66.65%)
14 fp_comp_ops_exe.sse_scalar_double (66.65%)
0 fp_comp_ops_exe.sse_packed_double (66.67%)
0 fp_comp_ops_exe.sse_packed_single (66.70%)
0 simd_fp_256.packed_double (66.70%)
0 simd_fp_256.packed_single (66.67%)
0 duration_time
3.238372845 seconds time elapsed
v2: Add missing header file
v3: Move find_map to pmu.c
Link: http://lkml.kernel.org/r/20170831194036.30146-7-andi@firstfloor.org
Setting up groups can be complicated due to the complicated scheduling
restrictions of different PMUs.
User tools usually don't understand all these restrictions.
Still in many cases it is useful to set up groups and they work most of
the time. However if the group is set up wrong some members will not
report any value because they never get scheduled.
Add a concept of a 'weak group': try to set up a group, but if it's not
schedulable fallback to not using a group. That gives us the best of
both worlds: groups if they work, but still a usable fallback if they
don't.
In theory it would be possible to have more complex fallback strategies
(e.g. try to split the group in half), but the simple fallback of not
using a group seems to work for now.
So far the weak group is only implemented for perf stat, not for record.
Here's an unschedulable group (on IvyBridge with SMT on)
% perf stat -e '{branches,branch-misses,l1d.replacement,l2_lines_in.all,l2_rqsts.all_code_rd}' -a sleep 1
73,806,067 branches
4,848,144 branch-misses # 6.57% of all branches
14,754,458 l1d.replacement
24,905,558 l2_lines_in.all
<not supported> l2_rqsts.all_code_rd <------- will never report anything
With the weak group:
% perf stat -e '{branches,branch-misses,l1d.replacement,l2_lines_in.all,l2_rqsts.all_code_rd}:W' -a sleep 1
125,366,055 branches (80.02%)
9,208,402 branch-misses # 7.35% of all branches (80.01%)
24,560,249 l1d.replacement (80.00%)
43,174,971 l2_lines_in.all (80.05%)
31,891,457 l2_rqsts.all_code_rd (79.92%)
The extra event scheduled with some extra multiplexing
v2: Move fallback code to separate function.
Add comment on for_each_group_member
Adjust to new perf_evsel__close interface
v3: Fix debug print out.
Committer testing:
Before:
# perf stat -e '{branches,branch-misses,l1d.replacement,l2_lines_in.all,l2_rqsts.all_code_rd}' -a sleep 1
<not counted> branches
<not counted> branch-misses
<not counted> l1d.replacement
<not counted> l2_lines_in.all
1.002147212 seconds time elapsed
# perf stat -e '{branches,l1d.replacement,l2_lines_in.all,l2_rqsts.all_code_rd}' -a sleep 1
83,207,892 branches
11,065,444 l1d.replacement
28,484,024 l2_lines_in.all
12,186,179 l2_rqsts.all_code_rd
1.001739493 seconds time elapsed
After:
# perf stat -e '{branches,branch-misses,l1d.replacement,l2_lines_in.all,l2_rqsts.all_code_rd}':W -a sleep 1
543,323,909 branches (80.01%)
27,100,512 branch-misses # 4.99% of all branches (80.02%)
50,402,905 l1d.replacement (80.03%)
67,385,892 l2_lines_in.all (80.01%)
21,352,885 l2_rqsts.all_code_rd (79.94%)
1.001086658 seconds time elapsed
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20170831194036.30146-2-andi@firstfloor.org
[ Add a "'perf stat' only, for now" comment in the man page, suggested by Jiri ]
When packaging the perf userland application into an AppImage, the
wait() call in perf stat returned too early. It turned out that some
other child process exited, but not the one perf stat launched:
$ sudo strace -e fork,execve,clone,wait4 -f ./perf-x86_64.AppImage stat sleep 1
execve("./perf-git.3a73b7f9-x86_64.AppImage", ["./perf-git.3a73b7f9-x86_64.AppIm"..., "stat", "sleep", "1"], 0x7ffec1bbf050 /* 18 vars */) = 0
clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f6a6e7efe50) = 3912
strace: Process 3912 attached
[pid 3912] clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f6a6e7efe50) = 3914
strace: Process 3914 attached
[pid 3912] +++ exited with 0 +++
[pid 3911] --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=3912, si_uid=0, si_status=0, si_utime=0, si_stime=0} ---
[pid 3914] clone(strace: Process 3915 attached
child_stack=0x7f6a6d9fefb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f6a6d9ff9d0, tls=0x7f6a6d9ff700, child_tidptr=0x7f6a6d9ff9d0) = 3915
[pid 3911] execve("/tmp/.mount_perf-g6VYMpl/AppRun", ["./perf-git.3a73b7f9-x86_64.AppIm"..., "stat", "sleep", "1"], 0x14aab70 /* 21 vars */) = 0
[pid 3911] clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f4ae113c4d0) = 3916
strace: Process 3916 attached
[pid 3911] wait4(-1, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 3912
[pid 3916] execve("/usr/libexec/perf-core/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/tmp/./sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/home/milian/.bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/usr/lib/icecream/libexec/icecc/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/ssd2/milian/projects/compiled/other/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/home/milian/.bin/kf5/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/ssd2/milian/projects/compiled/kf5/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/home/milian/projects/compiled/other/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/home/milian/projects/compiled/kf5/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/usr/local/sbin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/usr/local/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */) = -1 ENOENT (No such file or directory)
[pid 3916] execve("/usr/bin/sleep", ["sleep", "1"], 0x27d3650 /* 22 vars */
Performance counter stats for 'sleep 1':
<not counted> task-clock
<not counted> context-switches
<not counted> cpu-migrations
<not counted> page-faults
<not counted> cycles
<not counted> instructions
0.000047194 seconds time elapsed
[pid 3916] --- SIGTERM {si_signo=SIGTERM, si_code=SI_USER, si_pid=3911, si_uid=0} ---
[pid 3916] +++ killed by SIGTERM +++
[pid 3911] --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_KILLED, si_pid=3916, si_uid=0, si_status=SIGTERM, si_utime=0, si_stime=0} ---
[pid 3915] --- SIGPIPE {si_signo=SIGPIPE, si_code=SI_USER, si_pid=3914, si_uid=0} ---
[pid 3911] +++ exited with 0 +++
[pid 3915] --- SIGHUP {si_signo=SIGHUP, si_code=SI_USER, si_pid=3914, si_uid=0} ---
[pid 3915] +++ exited with 0 +++
This patch uses waitpid instead to ensure the call waits for the
debuggee application launched by 'perf stat'. This fixes 'perf stat'
when launched from an AppImage:
$ ./perf-x86_64.AppImage stat sleep 1
0.357235 task-clock (msec) # 0.000 CPUs utilized
1 context-switches # 0.003 M/sec
0 cpu-migrations # 0.000 K/sec
50 page-faults # 0.140 M/sec
1269602 cycles # 3.554 GHz
654278 instructions # 0.52 insn per cycle
129963 branches # 363.803 M/sec
7082 branch-misses # 5.45% of all branches
1.000633420 seconds time elapsed
Signed-off-by: Milian Wolff <milian.wolff@kdab.com>
Link: http://lkml.kernel.org/r/20170912152523.4497-1-milian.wolff@kdab.com
Peter reported that when he explicitely asked for multiple events with
the same name on the command line it got coalesced into just one line,
i.e.:
# perf stat -e cycles -e cycles -e cycles usleep 1
Performance counter stats for 'usleep 1':
3,269,652 cycles
0.000884123 seconds time elapsed
And while there is the --no-merges option to disable that auto-merging,
this is a blunt change in behaviour for such explicit request, so change
the code so that this auto merging is done only when handling the multi
PMU aliases with the same name that introduced this coalescing,
restoring the previous behaviour for the explicit case:
1,472,837 cycles
1,472,837 cycles
1,472,837 cycles
0.001764870 seconds time elapsed
Reported-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Andi Kleen <ak@linux.intel.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Fixes: 430daf2dc7af ("perf stat: Collapse identically named events")
Link: http://lkml.kernel.org/r/20170831184122.GK4831@kernel.org
Make perf stat use group read if there are groups defined. The group
read will get the values for all member of groups within a single
syscall instead of calling read syscall for every event.
We can see considerable less amount of kernel cycles spent on single
group read, than reading each event separately, like for following perf
stat command:
# perf stat -e {cycles,instructions} -I 10 -a sleep 1
Monitored with "perf stat -r 5 -e '{cycles:u,cycles:k}'"
Before:
24,325,676 cycles:u
297,040,775 cycles:k
1.038554134 seconds time elapsed
After:
25,034,418 cycles:u
158,256,395 cycles:k
1.036864497 seconds time elapsed
The perf_evsel__open fallback changes contributed by Andi Kleen.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Link: http://lkml.kernel.org/r/20170726120206.9099-4-jolsa@kernel.org
To consolidate the error reporting facility.
Link: http://lkml.kernel.org/n/tip-b41iot1094katoffdf19w9zk@git.kernel.org
Implementing a new --smi-cost mode in perf stat to measure SMI cost.
During the measurement, the /sys/device/cpu/freeze_on_smi will be set.
The measurement can be done with one counter (unhalted core cycles), and
two free running MSR counters (IA32_APERF and SMI_COUNT).
In practice, the percentages of SMI core cycles should be more useful
than absolute value. So the output will be the percentage of SMI core
cycles and SMI#. metric_only will be set by default.
SMI cycles% = (aperf - unhalted core cycles) / aperf
Here is an example output.
Performance counter stats for 'sudo echo ':
SMI cycles% SMI#
0.1% 1
0.010858678 seconds time elapsed
Users who wants to get the actual value can apply additional
--no-metric-only.
Signed-off-by: Kan Liang <Kan.liang@intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Robert Elliott <elliott@hpe.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1495825538-5230-3-git-send-email-kan.liang@intel.com
Only print the NMI watchdog hint when that watchdog it actually enabled.
This avoids printing these unnecessarily.
Link: http://lkml.kernel.org/n/tip-lnw7edxnqsphkmeew857wz1i@git.kernel.org
Not needed in this header, added to the places that need poll(), wait()
and a few other prototypes.
Link: http://lkml.kernel.org/n/tip-i39c7b6xmo1vwd9wxp6fmkl0@git.kernel.org
Not needed in this header, added to the places that need FILE,
putchar(), access() and a few other prototypes.
Link: http://lkml.kernel.org/n/tip-xxtdsl6nsna82j7puwbdjqhs@git.kernel.org
And remove it from util.h, disentangling it a bit more.
Link: http://lkml.kernel.org/n/tip-2zg9s5nx90yde64j3g4z2uhk@git.kernel.org
Removing it from util.h, part of an effort to disentangle the includes
hell, that makes changes to util.h or something included by it to cause
a complete rebuild of the tools.
Link: http://lkml.kernel.org/n/tip-ztrjy52q1rqcchuy3rubfgt2@git.kernel.org
Moving them from util.h, where they don't belong. Since libc already
have string.h, name it slightly differently, as string2.h.
Link: http://lkml.kernel.org/n/tip-eh3vz5sqxsrdd8lodoro4jrw@git.kernel.org
More stuff that came from git, out of the hodge-podge that is util.h
Link: http://lkml.kernel.org/n/tip-e3lana4gctz3ub4hn4y29hkw@git.kernel.org
Needed to use the PRI[xu](32,64) formatting macros.
Link: http://lkml.kernel.org/n/tip-wkbho8kaw24q67dd11q0j39f@git.kernel.org
(This is a patch has been sitting in the Intel CQM/CMT driver series for
a while, despite not depend on it. Sending it now independently since
the series is being discarded.)
When an event is in error state, read() returns 0 instead of sizeof()
buffer. In certain modes, such as interval printing, ignoring the 0
return value may cause bogus count deltas to be computed and thus
invalid results printed.
This patch fixes this problem by modifying read_counters() to mark the
event as not scaled (scaled = -1) to force the printout routine to show
<NOT COUNTED>.
Signed-off-by: Stephane Eranian <eranian@google.com>
Reviewed-by: David Carrillo-Cisneros <davidcc@google.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20170412182301.44406-1-davidcc@google.com
To strip csv output, use ltrim() instead of just while loop and
isspace() at print_metric_{only}_csv().
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Link: http://lkml.kernel.org/r/1491575061-704-3-git-send-email-treeze.taeung@gmail.com
We got it from the git sources but never used it for anything, with the
place where this would be somehow used remaining:
static int run_builtin(struct cmd_struct *p, int argc, const char **argv)
prefix = NULL;
if (p->option & RUN_SETUP)
prefix = NULL; /* setup_perf_directory(); */
Ditch it.
Link: http://lkml.kernel.org/n/tip-uw5swz05vol0qpr32c5lpvus@git.kernel.org
Add generic infrastructure to perf stat to output ratios for
"MetricExpr" entries in the event lists. Many events are more useful as
ratios than in raw form, typically some count in relation to total
ticks.
Transfer the MetricExpr information from the alias to the evsel.
We mark the events that need to be collected for MetricExpr, and also
link the events using them with a pointer. The code is careful to always
prefer the right event in the same group to minimize multiplexing
errors. At the moment only a single relation is supported.
Then add a rblist to the stat shadow code that remembers stats based on
the cpu and context.
Then finally update and retrieve and print these values similarly to the
existing hardcoded perf metrics. We use the simple expression parser
added earlier to evaluate the expression.
Normally we just output the result without further commentary, but for
--metric-only this would lead to empty columns. So for this case use the
original event as description.
There is no attempt to automatically add the MetricExpr event, if it is
missing, however we suggest it to the user, because the user tool
doesn't have enough information to reliably construct a group that is
guaranteed to schedule. So we leave that to the user.
% perf stat -a -I 1000 -e '{unc_p_clockticks,unc_p_freq_max_os_cycles}'
1.000147889 800,085,181 unc_p_clockticks
1.000147889 93,126,241 unc_p_freq_max_os_cycles # 11.6
2.000448381 800,218,217 unc_p_clockticks
2.000448381 142,516,095 unc_p_freq_max_os_cycles # 17.8
3.000639852 800,243,057 unc_p_clockticks
3.000639852 162,292,689 unc_p_freq_max_os_cycles # 20.3
% perf stat -a -I 1000 -e '{unc_p_clockticks,unc_p_freq_max_os_cycles}' --metric-only
# time freq_max_os_cycles %
1.000127077 0.9
2.000301436 0.7
3.000456379 0.0
v2: Change from DivideBy to MetricExpr
v3: Use expr__ prefix. Support more than one other event.
v4: Update description
v5: Only print warning message once for multiple PMUs.
Link: http://lkml.kernel.org/r/20170320201711.14142-11-andi@firstfloor.org
When any result that is being merged is bad, mark them all bad to give
consistent output in interval mode.
No before/after, because the issue was only found in theoretical review
and it is hard to reproduce
Link: http://lkml.kernel.org/r/20170320201711.14142-4-andi@firstfloor.org
The uncore PMU has a lot of duplicated PMUs for different subsystems.
When expanding an uncore alias we usually end up with a large
number of identically named aliases, which makes perf stat
output difficult to read.
Automatically sum them up in perf stat, unless --no-merge is specified.
This can be default because only the uncores generally have duplicated
aliases. Other PMUs have unique names.
Before:
% perf stat --no-merge -a -e unc_c_llc_lookup.any sleep 1
694,976 Bytes unc_c_llc_lookup.any
706,304 Bytes unc_c_llc_lookup.any
956,608 Bytes unc_c_llc_lookup.any
782,720 Bytes unc_c_llc_lookup.any
605,696 Bytes unc_c_llc_lookup.any
442,816 Bytes unc_c_llc_lookup.any
659,328 Bytes unc_c_llc_lookup.any
509,312 Bytes unc_c_llc_lookup.any
263,936 Bytes unc_c_llc_lookup.any
592,448 Bytes unc_c_llc_lookup.any
672,448 Bytes unc_c_llc_lookup.any
608,640 Bytes unc_c_llc_lookup.any
641,024 Bytes unc_c_llc_lookup.any
856,896 Bytes unc_c_llc_lookup.any
808,832 Bytes unc_c_llc_lookup.any
684,864 Bytes unc_c_llc_lookup.any
710,464 Bytes unc_c_llc_lookup.any
538,304 Bytes unc_c_llc_lookup.any
1.002577660 seconds time elapsed
After:
% perf stat -a -e unc_c_llc_lookup.any sleep 1
2,685,120 Bytes unc_c_llc_lookup.any
1.002648032 seconds time elapsed
v2: Split collect_aliases. Rename alias flag.
v3: Make sure unsupported/not counted is always printed.
v4: Factor out callback change into separate patch.
v5: Move check for bad results here
Move merged check into collect_data
Link: http://lkml.kernel.org/r/20170320201711.14142-3-andi@firstfloor.org
To be used in next patch to support automatic summing of alias events.
v2: Move check for bad results to next patch
v3: Remove trivial addition.
v4: Use perf_evsel__cpus instead of evsel->cpus
Link: http://lkml.kernel.org/r/20170320201711.14142-2-andi@firstfloor.org
Make system wide (-a) the default option if no target was specified and
one of following conditions is met:
- there's no workload specified (current behaviour)
- there is workload specified but all requested
events are system wide ones
Mixed events core/uncore with workload:
$ perf stat -e 'uncore_cbox_0/clockticks/,cycles' sleep 1
<not supported> uncore_cbox_0/clockticks/
980,489 cycles
1.000897406 seconds time elapsed
Uncore event with workload:
$ perf stat -e 'uncore_cbox_0/clockticks/' sleep 1
281,473,897,192,670 uncore_cbox_0/clockticks/
1.000833784 seconds time elapsed
Committer note:
When testing I realized the default case for !root, i.e. no events
passed via -e, was broke by v2 of this patch, reported and after a
patch provided by Jiri it is back working:
[acme@jouet linux]$ perf stat usleep 1
0.401335 task-clock:u (msec) # 0.297 CPUs utilized
0 context-switches:u # 0.000 K/sec
0 cpu-migrations:u # 0.000 K/sec
48 page-faults:u # 0.120 M/sec
458,146 cycles:u # 1.142 GHz
245,113 instructions:u # 0.54 insn per cycle
47,991 branches:u # 119.578 M/sec
4,022 branch-misses:u # 8.38% of all branches
0.001350029 seconds time elapsed
[acme@jouet linux]$
Suggested-and-Tested-by: Borislav Petkov <bp@alien8.de>
Link: http://lkml.kernel.org/r/20170227094818.GA12764@krava
When using perf stat on an AMD F15h system with the default hw events
attributes, some of the events don't get counted:
0.749208 task-clock (msec) # 0.001 CPUs utilized
1 context-switches # 0.001 M/sec
54 page-faults # 0.072 M/sec
1,122,815 cycles # 1.499 GHz
286,740 stalled-cycles-frontend # 25.54% frontend cycles idle
<not counted> stalled-cycles-backend (0.00%)
<not counted> instructions (0.00%)
<not counted> branches (0.00%)
<not counted> branch-misses (0.00%)
1.001550070 seconds time elapsed
The reason is that we have the HW watchdog consuming one PMU counter and
when perf tries to schedule 6 events on 6 counters and some of those
counters are constrained to only a specific subset of PMCs by the
hardware, the event scheduling fails.
So issue a hint to disable the HW watchdog around a perf stat session.
Committer note:
Testing it...
# perf stat -d usleep 1
1.180203 task-clock (msec) # 0.490 CPUs utilized
1 context-switches # 0.847 K/sec
54 page-faults # 0.046 M/sec
184,754 cycles # 0.157 GHz
714,553 instructions # 3.87 insn per cycle
154,661 branches # 131.046 M/sec
7,247 branch-misses # 4.69% of all branches
219,984 L1-dcache-loads # 186.395 M/sec
17,600 L1-dcache-load-misses # 8.00% of all L1-dcache hits (90.16%)
<not counted> LLC-loads (0.00%)
<not counted> LLC-load-misses (0.00%)
0.002406823 seconds time elapsed
Some events weren't counted. Try disabling the NMI watchdog:
echo 0 > /proc/sys/kernel/nmi_watchdog
perf stat ...
echo 1 > /proc/sys/kernel/nmi_watchdog
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Robert Richter <rric@kernel.org>
Cc: Vince Weaver <vince@deater.net>
Link: http://lkml.kernel.org/r/20170211183218.ijnvb5f7ciyuunx4@pd.tnic
It now can have negative value to suppress the message entirely. So it
needs to check it being positive.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: kernel-team@lge.com
Link: http://lkml.kernel.org/r/20170217081742.17417-3-namhyung@kernel.org
[ Adjust fuzz on tools/perf/util/pmu.c, add > 0 checks in many other places ]
Boris asked for default -a option in case we monitor only uncore events.
While implementing that I thought it might be actually useful to make it
overall default.
Running 'perf stat' will now collect system wide data.
Committer note:
Testing it:
# perf stat
^C
3571.559178 cpu-clock (msec) # 4.000 CPUs utilized
3,346 context-switches # 0.937 K/sec
277 cpu-migrations # 0.078 K/sec
57,271 page-faults # 0.016 M/sec
4,535,633,835 cycles # 1.270 GHz
6,389,736,516 instructions # 1.41 insn per cycle
1,541,293,875 branches # 431.547 M/sec
14,526,396 branch-misses # 0.94% of all branches
0.892950118 seconds time elapsed
Requested-and-Acked-by: Borislav Petkov <bp@alien8.de>
Link: http://lkml.kernel.org/r/20170217170034.GB15389@krava
cpu_topology_map
There are 2 problems wrt. cpu_topology_map on systems with sparse CPUs:
1. offline/absent CPUs will have their socket_id and core_id set to -1
which triggers:
"socket_id number is too big.You may need to upgrade the perf tool."
2. size of cpu_topology_map (perf_env.cpu[]) is allocated based on
_SC_NPROCESSORS_CONF, but can be indexed with CPU ids going above.
Users of perf_env.cpu[] are using CPU id as index. This can lead
to read beyond what was allocated:
==19991== Invalid read of size 4
==19991== at 0x490CEB: check_cpu_topology (topology.c:69)
==19991== by 0x490CEB: test_session_topology (topology.c:106)
For example:
_SC_NPROCESSORS_CONF == 16
available: 2 nodes (0-1)
node 0 cpus: 0 6 8 10 16 22 24 26
node 0 size: 12004 MB
node 0 free: 9470 MB
node 1 cpus: 1 7 9 11 23 25 27
node 1 size: 12093 MB
node 1 free: 9406 MB
node distances:
node 0 1
0: 10 20
1: 20 10
This patch changes HEADER_NRCPUS.nr_cpus_available from _SC_NPROCESSORS_CONF
to max_present_cpu and updates any user of cpu_topology_map to iterate
with nr_cpus_avail.
As a consequence HEADER_CPU_TOPOLOGY core_id and socket_id lists get longer,
but maintain compatibility with pre-patch state - index to cpu_topology_map is
CPU id.
perf test 36 -v
36: Session topology :
--- start ---
test child forked, pid 22211
templ file: /tmp/perf-test-gmdX5i
CPU 0, core 0, socket 0
CPU 1, core 0, socket 1
CPU 6, core 10, socket 0
CPU 7, core 10, socket 1
CPU 8, core 1, socket 0
CPU 9, core 1, socket 1
CPU 10, core 9, socket 0
CPU 11, core 9, socket 1
CPU 16, core 0, socket 0
CPU 22, core 10, socket 0
CPU 23, core 10, socket 1
CPU 24, core 1, socket 0
CPU 25, core 1, socket 1
CPU 26, core 9, socket 0
CPU 27, core 9, socket 1
test child finished with 0
---- end ----
Session topology: Ok
Signed-off-by: Jan Stancek <jstancek@redhat.com>
Link: http://lkml.kernel.org/r/d7c05c6445fca74a8442c2c73cfffd349c52c44f.1487146877.git.jstancek@redhat.com
When a tool can't open counters due to the kernel.perf_event_paranoit
sysctl setting, we inform how to tweak it to allow the operation to
succeed, in addition to that, suggest setting /etc/sysctl.conf to
make the setting permanent.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/n/tip-4gwe99k4a6p12d4u8bbyttj2@git.kernel.org
I.e. those parameters/functions _are_ used, so ditch that misleading attribute.
Link: http://lkml.kernel.org/n/tip-13cqtjh0yojg5gzvpq1zzpl0@git.kernel.org
Now that the required mechanic is there to deal with PMU specific
configuration, add the functionality to the tools where events can be
selected.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Link: http://lkml.kernel.org/r/1474041004-13956-7-git-send-email-mathieu.poirier@linaro.org
[ Fix the build on XSI-compliant systems, using str_error_r() to make sure we return a string, not an integer ]
To match how this is done in the kernel.
Link: http://lkml.kernel.org/n/tip-gym6yshewpdegt153u8v2q5r@git.kernel.org
And remove it from tools/perf/{perf,util}.h, making code that needs
these macros to include linux/time64.h instead, to match how this is
used in the kernel sources.
Link: http://lkml.kernel.org/n/tip-e69fc1pvkgt57yvxqt6eunyg@git.kernel.org
When we don't have a tracee (i.e. we're attaching to a task or CPU),
counters can still be running after our workload finishes, and can still
be running as we read their values. As we read events one-by-one, there
can be arbitrary skew between values of events, even within a group.
This means that ratios within an event group are not reliable.
This skew can be seen if measuring a group of identical events, e.g:
# perf stat -a -C0 -e '{cycles,cycles}' sleep 1
To avoid this, we must stop groups from counting before we read the
values of any constituent events. This patch adds and makes use of a new
disable_counters() helper, which disables group leaders (and thus each
group as a whole). This mirrors the use of enable_counters() for
starting event groups in the absence of a tracee.
Closing a group leader splits the group, and without a disabled group
leader the newly split events will begin counting. Thus to ensure counts
are reliable we must defer closing group leaders until all counts have
been read. To do so this patch removes the event closing logic from the
read_counters() helper, explicitly closes the events using
perf_evlist__close(), which also aids legibility.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Link: http://lkml.kernel.org/r/1470747869-3567-1-git-send-email-mark.rutland@arm.com
In create_perf_stat_counter, when a target CPU has not been provided, we
call __perf_evsel__open with empty_cpu_map, and open a single FD per
thread. However, in read_counter we assume that we opened events for the
product of threads and CPUs described in the evsel's cpu_map.
Thus, if an evsel has a cpu_map with more than one entry, we will
attempt to access FDs that we didn't open. This could result in a number
of problems (e.g. blocking while reading from STDIN if the fd memory
happened to be initialised to zero).
This is problematic for systems were a logical CPU PMU covers some
arbitrary subset of CPUs. The cpu_map of any evsel for that PMU will be
initialised based on the cpumask exposed through sysfs, even if the user
requests per-thread events.
Cc: He Kuang <hekuang@huawei.com>
Link: http://lkml.kernel.org/r/1468577293-19667-2-git-send-email-mark.rutland@arm.com
The tools so far have been using the strerror_r() GNU variant, that
returns a string, be it the buffer passed or something else.
But that, besides being tricky in cases where we expect that the
function using strerror_r() returns the error formatted in a provided
buffer (we have to check if it returned something else and copy that
instead), breaks the build on systems not using glibc, like Alpine
Linux, where musl libc is used.
So, introduce yet another wrapper, str_error_r(), that has the GNU
interface, but uses the portable XSI variant of strerror_r(), so that
users rest asured that the provided buffer is used and it is what is
returned.
Link: http://lkml.kernel.org/n/tip-d4t42fnf48ytlk8rjxs822tf@git.kernel.org
To match the semantics for list.h in the kernel, that are used to
implement those macros.
Cc: Milian Wolff <milian.wolff@kdab.com>
Cc: Taeung Song <treeze.taeung@gmail.com>
Link: http://lkml.kernel.org/n/tip-qbcjlgj0ffxquxscahbpddi3@git.kernel.org
When in CSV mode --metric-only outputs an header, unlike the other
modes. Previously it did not properly print headers for the aggregation
columns, so the headers were actually shifted against the real values.
Fix this here by outputting the correct headers for CSV.
v2: Indent array.
Link: http://lkml.kernel.org/r/1464119559-17203-4-git-send-email-andi@firstfloor.org
When --metric-only is enabled there were no headers for the topology in
interval mode. Also when headers were printed they were on a separate
line.
Before:
$ perf stat --metric-only -A -I 1000 -a
1.001038376 frontend cycles idle insn per cycle stalled cycles per insn branch-misses of all branches
1.001038376 CPU0 123.54% 0.23 5.29 7.61%
1.001038376 CPU1 137.78% 0.24 5.13 10.07%
1.001038376 CPU2 64.48% 0.22 5.50 6.84%
After:
1.001111114 CPU0 82.46% 0.32 2.60 7.64%
1.001111114 CPU1 126.63% 0.02 42.83 0.15%
1.001111114 CPU2 193.54% 0.32 2.59 6.92%
v2: Move all headers on a single line
Reported-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1464119559-17203-3-git-send-email-andi@firstfloor.org
Add basic plumbing for TopDown in perf stat
TopDown is intended to replace the frontend cycles idle/ backend cycles
idle metrics in standard perf stat output. These metrics are not
reliable in many workloads, due to out of order effects.
This implements a new --topdown mode in perf stat (similar to
--transaction) that measures the pipe line bottlenecks using
standardized formulas. The measurement can be all done with 5 counters
(one fixed counter)
The result are four metrics:
FrontendBound, BackendBound, BadSpeculation, Retiring
that describe the CPU pipeline behavior on a high level.
The full top down methology has many hierarchical metrics. This
implementation only supports level 1 which can be collected without
multiplexing. A full implementation of top down on top of perf is
available in pmu-tools toplev. (http://github.com/andikleen/pmu-tools)
The current version works on Intel Core CPUs starting with Sandy Bridge,
and Atom CPUs starting with Silvermont. In principle the generic
metrics should be also implementable on other out of order CPUs.
TopDown level 1 uses a set of abstracted metrics which are generic to
out of order CPU cores (although some CPUs may not implement all of
them):
topdown-total-slots Available slots in the pipeline
topdown-slots-issued Slots issued into the pipeline
topdown-slots-retired Slots successfully retired
topdown-fetch-bubbles Pipeline gaps in the frontend
topdown-recovery-bubbles Pipeline gaps during recovery
from misspeculation
These metrics then allow to compute four useful metrics:
FrontendBound, BackendBound, Retiring, BadSpeculation.
Add a new --topdown options to enable events. When --topdown is
specified set up events for all topdown events supported by the kernel.
Add topdown-* as a special case to the event parser, as is needed for
all events containing -.
The actual code to compute the metrics is in follow-on patches.
v2: Use standard sysctl read function.
v3: Move x86 specific code to arch/
v4: Enable --metric-only implicitly for topdown.
v5: Add --single-thread option to not force per core mode
v6: Fix output order of topdown metrics
v7: Allow combining with -d
v8: Remove --single-thread again
v9: Rename functions, adding arch_ and topdown_.
v10: Expand man page and describe TopDown better
Paste intro into commit description.
Print error when malloc fails.
Link: http://lkml.kernel.org/r/1464119559-17203-1-git-send-email-andi@firstfloor.org
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/core
Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo:
User visible changes:
- Honour the kernel.perf_event_max_stack knob more precisely by not counting
PERF_CONTEXT_{KERNEL,USER} when deciding when to stop adding entries to
the perf_sample->ip_callchain[] array (Arnaldo Carvalho de Melo)
- Fix identation of 'stalled-backend-cycles' in 'perf stat' (Namhyung Kim)
- Update runtime using 'cpu-clock' event in 'perf stat' (Namhyung Kim)
- Use 'cpu-clock' for cpu targets in 'perf stat' (Namhyung Kim)
- Avoid fractional digits for integer scales in 'perf stat' (Andi Kleen)
- Store vdso buildid unconditionally, as it appears in callchains and
we're not checking those when creating the build-id table, so we
end up not being able to resolve VDSO symbols when doing analysis
on a different machine than the one where recording was done, possibly
of a different arch even (arm -> x86_64) (He Kuang)
Infrastructure changes:
- Generalize max_stack sysctl handler, will be used for configuring
multiple kernel knobs related to callchains (Arnaldo Carvalho de Melo)
Cleanups:
- Introduce DSO__NAME_KALLSYMS and DSO__NAME_KCORE, to stop using
open coded strings (Masami Hiramatsu)
Currently 'perf stat' always counts task-clock event by default. But
it's somewhat confusing for system-wide targets (especially with 'sleep
N' as the 'sleep' task just sleeps and doesn't use cputime). Changing
to cpu-clock event instead for that case makes more sense IMHO.
Before:
# perf stat -a sleep 0.1
403.038603 task-clock (msec) # 4.001 CPUs utilized
150 context-switches # 0.372 K/sec
7 cpu-migrations # 0.017 K/sec
71 page-faults # 0.176 K/sec
23,705,169 cycles # 0.059 GHz
15,888,166 instructions # 0.67 insn per cycle
3,326,078 branches # 8.253 M/sec
87,643 branch-misses # 2.64% of all branches
0.100737009 seconds time elapsed
After:
404.271182 cpu-clock (msec) # 4.000 CPUs utilized
143 context-switches # 0.354 K/sec
13 cpu-migrations # 0.032 K/sec
73 page-faults # 0.181 K/sec
22,119,220 cycles # 0.055 GHz
13,622,065 instructions # 0.62 insn per cycle
2,918,769 branches # 7.220 M/sec
85,033 branch-misses # 2.91% of all branches
0.101073089 seconds time elapsed
Link: http://lkml.kernel.org/r/1463119263-5569-3-git-send-email-namhyung@kernel.org
When the scaling factor is a full integer don't display fractional
digits. This avoids unnecessary .00 output for topdown metrics with
scale factors.
v2: Remove redundant check.
Link: http://lkml.kernel.org/r/1462489447-31832-7-git-send-email-andi@firstfloor.org
[ Rename 'round' to 'stat_round' as 'round' is defined in math.h,
included by this patch, and this breaks the build on ubuntu 12.04 ]
Pull perf updates from Ingo Molnar:
"Bigger kernel side changes:
- Add backwards writing capability to the perf ring-buffer code,
which is preparation for future advanced features like robust
'overwrite support' and snapshot mode. (Wang Nan)
- Add pause and resume ioctls for the perf ringbuffer (Wang Nan)
- x86 Intel cstate code cleanups and reorgnization (Thomas Gleixner)
- x86 Intel uncore and CPU PMU driver updates (Kan Liang, Peter
Zijlstra)
- x86 AUX (Intel PT) related enhancements and updates (Alexander
Shishkin)
- x86 MSR PMU driver enhancements and updates (Huang Rui)
- ... and lots of other changes spread out over 40+ commits.
Biggest tooling side changes:
- 'perf trace' features and enhancements. (Arnaldo Carvalho de Melo)
- BPF tooling updates (Wang Nan)
- 'perf sched' updates (Jiri Olsa)
- 'perf probe' updates (Masami Hiramatsu)
- ... plus 200+ other enhancements, fixes and cleanups to tools/
The merge commits, the shortlog and the changelogs contain a lot more
details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (249 commits)
perf/core: Disable the event on a truncated AUX record
perf/x86/intel/pt: Generate PMI in the STOP region as well
perf buildid-cache: Use lsdir() for looking up buildid caches
perf symbols: Use lsdir() for the search in kcore cache directory
perf tools: Use SBUILD_ID_SIZE where applicable
perf tools: Fix lsdir to set errno correctly
perf trace: Move seccomp args beautifiers to tools/perf/trace/beauty/
perf trace: Move flock op beautifier to tools/perf/trace/beauty/
perf build: Add build-test for debug-frame on arm/arm64
perf build: Add build-test for libunwind cross-platforms support
perf script: Fix export of callchains with recursion in db-export
perf script: Fix callchain addresses in db-export
perf script: Fix symbol insertion behavior in db-export
perf symbols: Add dso__insert_symbol function
perf scripting python: Use Py_FatalError instead of die()
perf tools: Remove xrealloc and ALLOC_GROW
perf help: Do not use ALLOC_GROW in add_cmd_list
perf pmu: Make pmu_formats_string to check return value of strbuf
perf header: Make topology checkers to check return value of strbuf
perf tools: Make alias handler to check return value of strbuf
