path: root/tools/perf/builtin-kvm.c
2014-04-20perf kvm: Fix 'Min time' counting in report commandAlexander Yarygin
Every event in the perf-kvm has a 'stats' structure, which contains max/min/average/etc times of handling this event. The problem is that the 'perf-kvm stat report' command always shows that 'min time' is 0us for every event. Example: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 0us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 0us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 0us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 0us 44us 16.49us ( +- 38.20% ) [..] This happens because the 'stats' structure is not initialized and stats->min equals to 0. Lets initialize the structure for every event after its allocation using init_stats() function. This initializes stats->min to -1 and makes 'Min time' statistics counting work: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 6us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 7us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 1us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 1us 44us 16.49us ( +- 38.20% ) [..] Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1397053319-2130-3-git-send-email-borntraeger@de.ibm.com [ Fixing the perf examples changelog output ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-03-14perf kvm: introduce --list-cmds for use by scriptsRamkumar Ramachandra
Introduce $ perf kvm --list-cmds to dump a raw list of commands for use by the completion script. In order to do this, introduce parse_options_subcommand() for handling subcommands as a special case in the parse-options machinery. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1393896396-10427-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-13perf evlist: Introduce evlist__for_each() & friendsArnaldo Carvalho de Melo
For the common evsel list traversal, so that it becomes more compact. Use the opportunity to start ditching the 'perf_' from 'perf_evlist__', as discussed, as the whole conversion touches a lot of places, lets do it piecemeal when we have the chance due to other work, like in this case. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-qnkx7dzm2h6m6uptkfk03ni6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-13perf evlist: Move destruction of maps to evlist destructorArnaldo Carvalho de Melo
Instead of requiring tools to do an extra destructor call just before calling perf_evlist__delete. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-0jd2ptzyikxb5wp7inzz2ah2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-26perf tools: No need to test against NULL before calling free()Arnaldo Carvalho de Melo
Its perfectly fine to call free(NULL), so no need to clutter the source code with all those superfluous testing. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-uux5wpvevlerd42gqer13e7n@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-19perf tools: Rename 'perf_record_opts' to 'record_optsArnaldo Carvalho de Melo
Reduce typing, functions use class__method convention, so unlikely to clash with other libraries. This actually was discussed in the "Link:" referenced message below. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20131112113427.GA4053@ghostprotocols.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-16tools/: Convert to new topic librariesBorislav Petkov
Move debugfs.* to api/fs/. We have a common tools/lib/api/ place where the Makefile lives and then we place the headers in subdirs. For example, all the fs-related stuff goes to tools/lib/api/fs/ from which we get libapikfs.a (acme got almost the naming he wanted :-)) and we link it into the tools which need it - in this case perf and tools/vm/page-types. acme: "Looking at the implementation, I think some tools can even link directly to the .o files, avoiding the .a file altogether. But that is just an optimization/finer granularity tools/lib/ cherrypicking that toolers can make use of." Fixup documentation cleaning target while at it. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <rric@kernel.org> Cc: Stanislav Fomichev <stfomichev@yandex-team.ru> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386605664-24041-2-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-09perf kvm: Move code to generate filename for perf-kvm to function.Dongsheng Yang
The code in builtin-kvm.c to generate filename for perf-kvm is useful to other command such as builtin-diff. This patch move the related code form builtin-kvm.c to util/util.c and wrap them in a function named get_filename_for_perf_kvm. Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Link: http://lkml.kernel.org/r/5e09a5c47e8a495e888cbdc65a6fafb2c950f529.1386368672.git.yangds.fnst@cn.fujitsu.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-09perf kvm: Fix bug in 'stat report'Dongsheng Yang
When we use perf kvm record-report, there is a bug in report subcommand. Example: # perf kvm stat record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.678 MB perf.data.guest (~29641 samples) ] # perf kvm stat report failed to open perf.data: No such file or directory (try 'perf record' first) Initializing perf session failed This bug was introduced by f5fc14124. + struct perf_data_file file = { + .path = input_name, + .mode = PERF_DATA_MODE_READ, + }; kvm->tool = eops; - kvm->session = perf_session__new(kvm->file_name, O_RDONLY, 0, false, - &kvm->tool); + kvm->session = perf_session__new(&file, false, &kvm->tool); It changed the path from kvm->file_name to input_name, this patch change the path back to 'kvm->file_name', then it works well. Verification: # perf kvm stat record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.807 MB perf.data.guest (~35264 samples) ] # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time EPT_VIOLATION 200 32.79% 1.25% 0us 12064us 62.35us ( +- 96.74% ) EPT_MISCONFIG 134 21.97% 0.21% 0us 35us 15.25us ( +- 4.14% ) EXCEPTION_NMI 96 15.74% 0.02% 0us 11us 1.95us ( +- 9.81% ) APIC_ACCESS 79 12.95% 0.02% 0us 13us 2.94us ( +- 11.20% ) HLT 65 10.66% 98.47% 0us 16706us 15084.86us ( +- 1.89% ) IO_INSTRUCTION 27 4.43% 0.02% 0us 29us 6.42us ( +- 15.53% ) EXTERNAL_INTERRUPT 5 0.82% 0.01% 0us 77us 23.65us ( +- 57.90% ) TPR_BELOW_THRESHOLD 4 0.66% 0.00% 0us 1us 1.22us ( +- 4.36% ) Total Samples:610, Total events handled time:995745.54us. Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1386632823-17539-1-git-send-email-yangds.fnst@cn.fujitsu.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-09perf kvm: Introduce option -v for perf kvm command.Dongsheng Yang
As there is no -v option for perf kvm, the all debug message for perf kvm will nerver be printed out to user. Example: # perf kvm --guestmount /tmp/guestmount/ record -a Not enough memory for reading perf file header It is confusing message for newbies such as me. With this patch applied, we can use -v option to get the detail. Example: # perf kvm --guestmount /tmp/guestmount/ record -a -v Can't access file /tmp/guestmount//15069/proc/kallsyms Not enough memory for reading perf file header Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1386609311-23889-1-git-send-email-yangds.fnst@cn.fujitsu.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf target: Shorten perf_target__ to target__Arnaldo Carvalho de Melo
Getting unwieldly long, for this app domain should be descriptive enough and the use of __ to separate the class from the method names should help with avoiding clashes with other code bases. Reported-by: David Ahern <dsahern@gmail.com> Suggested-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20131112113427.GA4053@ghostprotocols.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-11perf machine: Simplify synthesize_threads methodArnaldo Carvalho de Melo
Several tools (top, kvm) don't need to be called back to process each of the syntheiszed records, instead relying on the machine__process_event function to change the per machine data structures that represent threads and mmaps, so provide a way to ask for this common idiom. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-pusqibp8n3c4ynegd1frn4zd@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-11perf machine: Introduce synthesize_threads method out of open coded equivalentArnaldo Carvalho de Melo
Further simplifications to be done on following patch, as most tools don't use the callback, using instead just the canned machine__process_event one. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-r1m0vuuj3cat4bampno9yc8d@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-11perf record: Synthesize non-exec MMAP records when --data usedArnaldo Carvalho de Melo
When perf_event_attr.mmap_data is set the kernel will generate PERF_RECORD_MMAP events when non-exec (data, SysV mem) mmaps are created, so we need to synthesize from /proc/pid/maps for existing threads, as we do for exec mmaps. Right now just 'perf record' does it, but any other tool that uses perf_event__synthesize_thread(s|map) can request it. Reported-by: Don Zickus <dzickus@redhat.com> Tested-by: Don Zickus <dzickus@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Bill Gray <bgray@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joe Mario <jmario@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Richard Fowles <rfowles@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ihwzraikx23ian9txinogvv2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-05perf kvm: Disable live command if timerfd is not supportedDavid Ahern
If the OS does not have timerfd support (e.g., older OS'es like RHEL5) disable perf kvm stat live. Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1383064996-20933-2-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-29Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: tools/perf/builtin-record.c tools/perf/builtin-top.c tools/perf/util/hist.h
2013-10-28perf tools: Fixup mmap event consumptionZhouyi Zhou
The tail position of the event buffer should only be modified after actually use that event. If not the event buffer could be invalid before use, and segment fault occurs when invoking perf top -G. Signed-off-by: Zhouyi Zhou <yizhouzhou@ict.ac.cn> Cc: David Ahern <dsahern@gmail.com> Cc: Zhouyi Zhou <yizhouzhou@ict.ac.cn> Link: http://lkml.kernel.org/r/1382600613-32177-1-git-send-email-zhouzhouyi@gmail.com [ Simplified the logic using exit gotos and renamed write_tail method to mmap_consume ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-21perf tools: Add data object to handle perf data fileJiri Olsa
This patch is adding 'struct perf_data_file' object as a placeholder for all attributes regarding perf.data file handling. Changing perf_session__new to take it as an argument. The rest of the functionality will be added later to keep this change simple enough, because all the places using perf_session are changed now. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1381847254-28809-2-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-09perf tools: Check mmap pages value earlyJiri Olsa
Move the check of the mmap_pages value to the options parsing time, so we could rely on this value on other parts of code. Related changes come in the next patches. Also changes perf_evlist::mmap_len to proper size_t type. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1378031796-17892-2-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-09perf kvm: Fix sample_type manipulationAdrian Hunter
Manipulating the sample_type of an evsel requires the use of: perf_evsel__set_sample_bit() and perf_evsel__reset_sample_bit() Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: David Ahern <dsahern@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1378496412-2424-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-29perf tools: change machine__findnew_thread() to set thread pidAdrian Hunter
Add a new parameter for 'pid' to machine__findnew_thread(). Change callers to pass 'pid' when it is known. Note that callers sometimes want to find the main thread which has the memory maps. The main thread has tid == pid so the usage in that case is: machine__findnew_thread(machine, pid, pid) whereas the usage to find the specific thread is: machine__findnew_thread(machine, pid, tid) Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1377591794-30553-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-16perf kvm: Remove force option to cmd_recordDavid Ahern
4a4d371a missed builtin-kvm in the cleanup to remove the force option to cmd_record. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1376512573-85012-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-12perf kvm: Option to print events that exceed a durationDavid Ahern
This is useful to spot high latency blips. It is normal for HLT reasons to have long exit times, so strip those from the duration check. v2: changed threshold to duration per acme's request Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1375926999-75129-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-07perf kvm stat report: Add option to analyze specific VMDavid Ahern
Add an option to analyze a specific VM within a data file. This allows the collection of kvm events for all VMs and then analyze data for each VM (or set of VMs) individually. Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1375753297-69645-6-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-07perf kvm: Add min and max stats to displayDavid Ahern
Add max and min times for exit events. v2: address Xiao's comment to use get_event function for pulling max and min from stats struct similar to mean and count Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1375753297-69645-4-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-07perf kvm: Add live modeDavid Ahern
perf kvm stat currently requires back to back record and report commands to see stats. e.g,. perf kvm stat record -p $pid -- sleep 1 perf kvm stat report This is inconvenvient for on box monitoring of a VM. This patch introduces a 'live' mode that in effect combines the record plus report into one command. e.g., to monitor a single VM: perf kvm stat live -p $pid or all VMs: perf kvm stat live Same stats options for the record+report path work with the live mode. Display rate defaults to 1 second and can be changed using the -d option. v4: - address comments from Xiao -- verify_vcpu check should not look at processors on line for the host, prune configurable options. - set attr->{mmap,comm,task} to 0 - don't need task events so trim events we have to deal with - better control of time for queue event flushing to reduce frequency of "Timestamp below last timeslice flush" failures. v3: updated to use existing tracepoint parsing code v2: removed ABSTIME arg from timerfd_settime as mentioned by Namhyung only call perf_kvm__handle_stdin when poll returns activity. Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1375753297-69645-3-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-08-07perf kvm: Split out tracepoints from record argsDavid Ahern
Needed by kvm live command. Make record_args a local while we are messing with the args. Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1375473947-64285-5-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-05-28perf kvm: Handle realloc failuresDavid Ahern
Save previous pointer and free on failure. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1369527896-3650-7-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15perf tools: Introduce tools/lib/lk libraryBorislav Petkov
This introduces the tools/lib/lk library, that will gradually have the routines that now are used in tools/perf/ and other tools and that can be shared. Start by carving out debugfs routines for general use. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1361374353-30385-5-git-send-email-bp@alien8.de [ committer note: Add tools/lib/lk/ to perf's MANIFEST so that its tarballs continue to build ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-24perf kvm: Initialize file_name var to fix segfaultArnaldo Carvalho de Melo
The 3786063 commit: perf kvm: Rename perf_kvm to perf_kvm_stat Moved the file_name from inside a local struct var that initialized some of its members, thus zero initializing the not explicitely initialized variables, one of which was 'file_name', to a standalone local variable, but forgot to initialize it explicitely to NULL, so it then got some undefined value, causing a segfault in strdup when it wasn't, by luck, zero. Fix it by explicitely initializing it to NULL. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-qo2jevp1bdcnh8khzdazs17s@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-12-08Merge branch 'linus' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/builtin-test.c tools/perf/perf.h tools/perf/tests/parse-events.c tools/perf/util/evsel.h Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-11-23perf kvm: Fix building perf kvm on non x86 archesXiao Guangrong
Now, 'perf kvm stat' is only supported on x86, let its code depend on (__x86_64__ || __i386__) to fix building it on other architectures. Reviewed-by: David Howells <dhowells@redhat.com> Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Cc: David Ahern <dsahern@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: x86@kernel.org Link: http://lkml.kernel.org/r/50A9EB89.70901@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-23perf kvm: Rename perf_kvm to perf_kvm_statXiao Guangrong
Then let it only be used in 'perf kvm stat'. Preparatory patch to stop trying to build parts of this tool that for now are only supported on x86. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Cc: David Ahern <dsahern@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: x86@kernel.org Link: http://lkml.kernel.org/r/50A488DD.6090106@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-19perf: Make perf build for x86 with UAPI disintegration appliedDavid Howells
Make perf build for x86 once the UAPI disintegration patches for that arch have been applied by adding the appropriate -I flags - in the right order - and then converting some #includes that use ../.. notation to find main kernel headerfiles to use <asm/foo.h> and <linux/foo.h> instead. Note that -Iarch/foo/include/uapi is present _before_ -Iarch/foo/include. This makes sure we get the userspace version of the pt_regs struct. Ideally, we wouldn't have the latter -I flag at all, but unfortunately we want asm/svm.h and asm/vmx.h in builtin-kvm.c and these aren't part of the UAPI - at least not for x86. I wonder if the bits outside of the __KERNEL__ guards *should* be transferred there. I note also that perf seems to do its dependency handling manually by listing all the header files it might want to use in LIB_H in the Makefile. Can this be changed to use -MD? Note that to do make this work, we need to export and UAPI disintegrate linux/hw_breakpoint.h, which I think should've been exported previously so that perf can access the bits. We have to do this in the same patch to maintain bisectability. Signed-off-by: David Howells <dhowells@redhat.com>
2012-10-08perf kvm: Add braces around multi-line statementsDavid Ahern
Multi-line statements should have braces. Improves readability. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1349716656-48165-9-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-08perf kvm: Total count is a u64, print as soDavid Ahern
remove cast and use proper type in format. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1349716656-48165-11-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-08perf kvm: Remove typecast in init_kvm_event_recordDavid Ahern
Not needed after changing i to unsigned int. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1349716656-48165-7-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-08perf kvm: Only process events for vcpus of interestDavid Ahern
Minimizing processing overhead for each sample - which becomes important for the upcoming live mode when it has to deal with 100+k events per second. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1349716656-48165-12-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-03perf kvm: Move global variables into a perf_kvm structDavid Ahern
Cleans up the builtin-kvm code in preparation for the live mode. No functional changes; only code movement. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1349237393-86006-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-24perf kvm: Use perf_session_env for reading cpuidNamhyung Kim
We have processed and saved cpuid information to perf_session_env so reuse it for get_cpu_isa(). Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1348474503-15070-6-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-24perf kvm: Use perf_evsel__intvalArnaldo Carvalho de Melo
Using plain raw_field_value(evsel->tp_format) will look at the common fields as well, and since this tool doesn't need those, speed it up a bit by looking at just the event specific fields. Also in general use just evsel and sample, just like was done in 'perf sched'. v2: Fixed up test against evsel->name, that contains the subsys name too, by David Ahern. Cc: David Ahern <dsahern@gmail.com> Cc: Dong Hao <haodong@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-v9x3q9rv4caxtox7wtjpchq5@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-21perf kvm: Events analysis toolXiao Guangrong
Add 'perf kvm stat' support to analyze kvm vmexit/mmio/ioport smartly Usage: - kvm stat run a command and gather performance counter statistics, it is the alias of perf stat - trace kvm events: perf kvm stat record, or, if other tracepoints are interesting as well, we can append the events like this: perf kvm stat record -e timer:* -a If many guests are running, we can track the specified guest by using -p or --pid, -a is used to track events generated by all guests. - show the result: perf kvm stat report The output example is following: 13005 13059 total 2 guests are running on the host Then, track the guest whose pid is 13059: ^C[ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.253 MB perf.data.guest (~11065 samples) ] See the vmexit events: Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Avg time APIC_ACCESS 460 70.55% 0.01% 22.44us ( +- 1.75% ) HLT 93 14.26% 99.98% 832077.26us ( +- 10.42% ) EXTERNAL_INTERRUPT 64 9.82% 0.00% 35.35us ( +- 14.21% ) PENDING_INTERRUPT 24 3.68% 0.00% 9.29us ( +- 31.39% ) CR_ACCESS 7 1.07% 0.00% 8.12us ( +- 5.76% ) IO_INSTRUCTION 3 0.46% 0.00% 18.00us ( +- 11.79% ) EXCEPTION_NMI 1 0.15% 0.00% 5.83us ( +- -nan% ) Total Samples:652, Total events handled time:77396109.80us. See the mmio events: Analyze events for all VCPUs: MMIO Access Samples Samples% Time% Avg time 0xfee00380:W 387 84.31% 79.28% 8.29us ( +- 3.32% ) 0xfee00300:W 24 5.23% 9.96% 16.79us ( +- 1.97% ) 0xfee00300:R 24 5.23% 7.83% 13.20us ( +- 3.00% ) 0xfee00310:W 24 5.23% 2.93% 4.94us ( +- 3.84% ) Total Samples:459, Total events handled time:4044.59us. See the ioport event: Analyze events for all VCPUs: IO Port Access Samples Samples% Time% Avg time 0xc050:POUT 3 100.00% 100.00% 13.75us ( +- 10.83% ) Total Samples:3, Total events handled time:41.26us. And, --vcpu is used to track the specified vcpu and --key is used to sort the result: Analyze events for VCPU 0: VM-EXIT Samples Samples% Time% Avg time HLT 27 13.85% 99.97% 405790.24us ( +- 12.70% ) EXTERNAL_INTERRUPT 13 6.67% 0.00% 27.94us ( +- 22.26% ) APIC_ACCESS 146 74.87% 0.03% 21.69us ( +- 2.91% ) IO_INSTRUCTION 2 1.03% 0.00% 17.77us ( +- 20.56% ) CR_ACCESS 2 1.03% 0.00% 8.55us ( +- 6.47% ) PENDING_INTERRUPT 5 2.56% 0.00% 6.27us ( +- 3.94% ) Total Samples:195, Total events handled time:10959950.90us. Signed-off-by: Dong Hao <haodong@linux.vnet.ibm.com> Signed-off-by: Runzhen Wang <runzhen@linux.vnet.ibm.com> [ Dong Hao <haodong@linux.vnet.ibm.com> Runzhen Wang <runzhen@linux.vnet.ibm.com>: - rebase it on current acme's tree - fix the compiling-error on i386 ] Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: kvm@vger.kernel.org Cc: Runzhen Wang <runzhen@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1347870675-31495-4-git-send-email-haodong@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06perf kvm: Do guest-only counting by defaultJoerg Roedel
Make use of exclude_guest and exlude_host in perf-kvm to do only guest-only counting by default. Cc: Gleb Natapov <gleb@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joro@8bytes.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> [ committer note: Moved perf_{guest,host} & event_attr_init to util.c ] [ so as not to drag more stuff to the python binding] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-03perf kvm: Fix copy & paste error in descriptionJoerg Roedel
The --host option certainly enables host-data collection. Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: kvm@vger.kernel.org Link: http://lkml.kernel.org/r/1317816084-18026-5-git-send-email-gleb@redhat.com Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Type check all the remaining OPT_ variantsArnaldo Carvalho de Melo
OPT_SET_INT was renamed to OPT_SET_UINT since the only use in these tools is to set something that has an enum type, that is builtin compatible with unsigned int. Several string constifications were done to make OPT_STRING require a const char * type. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Type check OPT_BOOLEAN and fix the offendersArnaldo Carvalho de Melo
2010-04-19perf: 'perf kvm' tool for monitoring guest performance from hostZhang, Yanmin
Here is the patch of userspace perf tool. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
