path: root/tools/perf/Makefile
2011-09-23perf tools: Add support for disabling -Werror via WERROR=0Darren Hart
GCC often introduces new warnings with lots of false positives - breaking -Werror builds. WERROR=0 allows one to build perf without much fuss - while still encouraging people to send patches to avoid the fuss of having to type WERROR=0. Bisecting back to commits that produce a (mostly harmless) warning on some compilers is more difficult. With WERROR=0 one could bisect without worrying about harmless warnings. Cc: Ingo Molnar <mingo@elte.hu> Link: http://lkml.kernel.org/r/eac06c7cc4920e5d4830417d466161fb26c7359c.1315514559.git.dvhart@linux.intel.com Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-09Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
2011-08-08perf tools: Add support to install perf python extensionJiri Olsa
Adding install-python_ext target to install python extension related files. Installation directory is governed by python distutils package and follows the DESTDIR variable settings. Also moving python extension build output into '$(O)python_ext_build' directory and making it configurable via PYTHON_EXTBUILD variable. Keeping the '$(O)python/perf.so' file, so it could be used for testing as of until now. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110722113307.GA1931@jolsa.brq.redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-08perf tools: Make clean leaves some filesKusanagi Kouichi
Use LIB_OBJS and BUILTIN_OBJS for .o files. LIB_FILE is already prefixed with OUTPUT. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110807083932.9C0E514C03B@msa103.auone-net.jp Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-07-23Merge branches 'x86-urgent-for-linus', 'core-debug-for-linus', ↵Linus Torvalds
'irq-core-for-linus' and 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Make rwsem.S depend on CONFIG_RWSEM_XCHGADD_ALGORITHM * 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debug: Make CONFIG_EXPERT select CONFIG_DEBUG_KERNEL to unhide debug options * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Remove unused CHECK_IRQ_PER_CPU() * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools, x86: Fix 32-bit compile on 64-bit system
2011-07-21perf tools, x86: Fix 32-bit compile on 64-bit systemDavid Ahern
Builds for 32-bit perf binaries on a 64-bit host currently fail with this error: [...] bench/../../../arch/x86/lib/memcpy_64.S: Assembler messages: bench/../../../arch/x86/lib/memcpy_64.S:29: Error: bad register name `%rdi' bench/../../../arch/x86/lib/memcpy_64.S:34: Error: invalid instruction suffix for `movs' bench/../../../arch/x86/lib/memcpy_64.S:50: Error: bad register name `%rdi' bench/../../../arch/x86/lib/memcpy_64.S:61: Error: bad register name `%rdi' ... The problem is the detection of the host arch without considering passed in flags. This change fixes 32-bit builds via: make EXTRA_CFLAGS=-m32 and 64-bit builds still reference the memcpy_64.S. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/1310420304-21452-1-git-send-email-dsahern@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-15perf-probe: Move dwarf library routines to dwarf-aux.{c, h}Masami Hiramatsu
Move dwarf library related routines to dwarf-aux.{c,h}. This includes several minor changes. - Add simple documents for each API. - Rename die_find_real_subprogram() to die_find_realfunc() - Rename line_walk_handler_t to line_walk_callback_t. - Minor cleanups. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072727.6528.57647.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-16tools/perf: Fix static build of perf toolMathias Krause
To build a statically linked version of the perf tool all needed libraries must be added in the correct order to get the symbols resolved. Currently this is broken when, e.g. python or newt support is enabled -- libpython needs libpthread which is an unconditional link dependency of the perf tool; libslang needs libm, another unconditional dependency. To solve the problem in the long run without the need to keep track of transitive library dependencies, simply make the linker look at the EXTLIBS multiple times until it has all symbols resolved. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/1308171818-20370-1-git-send-email-minipli@googlemail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-26perf tools: Fix build on older systemsArnaldo Carvalho de Melo
Where /usr/include/linux/const.h is not present, e.g. RHEL5. Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/n/tip-ypcw2mu0w7dl1rrc6ncz3pee@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-05-10Merge commit 'v2.6.39-rc7' into perf/coreIngo Molnar
Merge reason: pull in the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-07perf tools: Makefile: Use gcc to determine ARCHLin Ming
The original Makefile uses "uname -m" to determine ARCH. This causes problem on x86 when compile perf tool on 32 bit userspace with a 64 bit kernel. bench/../../../arch/x86/lib/memcpy_64.S: Assembler messages: bench/../../../arch/x86/lib/memcpy_64.S:28: Error: bad register name `%rdi' This is because "uname -m" returns x86_64 and memcpy_64.S is included in 32 bit build. Reported-by: Riccardo Magliocchetti <riccardo.magliocchetti@gmail.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Link: http://lkml.kernel.org/r/1304743274.3132.17.camel@localhost Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-19perf tools: git mv tools/perf/{features-tests.mak,config/}Michael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Link: http://lkml.kernel.org/n/tip-a6zhefjayuounko1tk5sjji2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-19perf tools: Makefile: PYTHON{,_CONFIG} to bandage Python 3 incompatibilityMichael Witten
Currently, Python 3 is not supported by perf's code; this can cause the build to fail for systems that have Python 3 installed as the default python: python{,-config} The Correct Solution is to write compatibility code so that Python 3 works out-of-the-box. However, users often have an ancillary Python 2 installed: python2{,-config} Therefore, a quick fix is to allow the user to specify those ancillary paths as the python binaries that Makefile should use, thereby avoiding Python 3 altogether; as an added benefit, the Python binaries may be installed in non-standard locations without the need for updating any PATH variable. This commit adds the ability to set PYTHON and/or PYTHON_CONFIG either as environment variables or as make variables on the command line; the paths may be relative, and usually only PYTHON is necessary in order for PYTHON_CONFIG to be defined implicitly. Some rudimentary error checking is performed when the user explicitly specifies a value for any of these variables. In addition, this commit introduces significantly robust makefile infrastructure for working with paths and communicating with the shell; it's currently only used for handling Python, but I hope it will prove useful in refactoring the makefiles. Thanks to: Raghavendra D Prabhu <rprabhu@wnohang.net> for motivating this patch. Acked-by: Raghavendra D Prabhu <rprabhu@wnohang.net> Link: http://lkml.kernel.org/r/e987828e-87ec-4973-95e7-47f10f5d9bab-mfwitten@gmail.com Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-19perf tools: Makefile: Clean up `python/perf.so' ruleMichael Witten
There is no need for a subshell or an explicit `export'; as per the POSIX Shell Command Language specification: http://pubs.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_09_01 http://pubs.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_10_02 It is only necessary to include the environment variable assignment just before the command to be run. Also, it is better to use single-quotes, because GNU make might expand `$(BASIC_CFLAGS)' into something that the shell could interpret within double-quotes. Acked-by: Raghavendra D Prabhu <rprabhu@wnohang.net> Link: http://lkml.kernel.org/n/tip-58n38o02ocuzrm9qh096hsf5@git.kernel.org Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf tools: Fix NO_NEWT=1 python build errorRobert Richter
Fix the following build error: GEN python/perf.so In file included from util/evsel.h:10, from util/python.c:6: util/hist.h:106:18: error: newt.h: No such file or directory error: command 'x86_64-pc-linux-gnu-gcc' failed with exit status 1 make: *** [python/perf.so] Error 1 by passing BASIC_CFLAGS to setup.py. BASIC_CFLAGS variable contains the -DNO_NEWT_SUPPORT switch which prevents building python c extension with newt. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <20110329180236.GA19366@erda.amd.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-15perf evlist: New command to list the names of events present in a perf.data fileArnaldo Carvalho de Melo
[root@emilia ~]# perf record -a -e sched:* -e timer:timer* sleep 5 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.172 MB perf.data (~7530 samples) ] [root@emilia ~]# perf evlist sched:sched_kthread_stop sched:sched_kthread_stop_ret sched:sched_wakeup sched:sched_wakeup_new sched:sched_switch sched:sched_migrate_task sched:sched_process_free sched:sched_process_exit sched:sched_wait_task sched:sched_process_wait sched:sched_process_fork sched:sched_stat_wait sched:sched_stat_sleep sched:sched_stat_iowait sched:sched_stat_runtime sched:sched_pi_setprio timer:timer_init timer:timer_start timer:timer_expire_entry timer:timer_expire_exit timer:timer_cancel [root@emilia ~]# Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-18perf tools: Makefile: Remove various and sundry cruftMichael Witten
This commit squashes several commits that remove: unnecessary uname calls `sh -c' BUILT_INS and QUIET_BUILT_IN They have no effect, and the `fixup-builtins' and `check-builtins.sh' scripts don't even exist. RUNTIME_PREFIX It's currently never anything but unset, and it's apparently only meaningful when Microsoft Windows is the operating system (according to the source for git). TEST_PROGRAMS EXTRA_PROGRAMS unused SHELL_PATH_SQ portions unused test for V=2 useless exports Only when `V' is undefined (that is, only when the value of `V' is empty) is `export V' performed, which just has the effect of placing the empty-valued variable `V' in the environment. The only other script to make use of `V' is `Documentation/Makefile', which only checks whether `V' is undefined (that is, whether the value of `V' is empty); hence, the `export V' has no effect whatsoever. Similarly, `export QUIET_GEN' is useless because it will only have a non-empty value when `V' has an empty-value, and when `V' has an empty-value, `QUIET_GEN' is always explicitly set in every script in which it is used. `DESTDIR' is only ever defined by the user via the environment or the command line, both of which are automatically exported to sub-make processes. Furthermore, no non-make sub-scripts make use of `DESTDIR' as an environment variable. No other scripts use `perfexec_instdir'. unused QUIET_SUBDIR{0,1} TAR and RPMBUILD PTHREAD_LIBS Maintainer's dist rules and commands distclean target Test suite coverage testing PRINT_DIR and NO_SUBDIR `configure' target NO_CURL @@PERF_VERSION@@ substitution Without the sed command, all of the rule's commands can be reduced to a single line that copies a file and sets the permissions properly in the process. `make test' echo line template_instdir PERF-BUILD-OPTIONS double-colon rules The use of double-colon rules seems misguided or vestigial git. Essentially hard-coded $(SCRIPTS) expansion Signed-off-by: Michael Witten <mfwitten@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-18perf tools: Makefile: Remove tool-specific cruftMichael Witten
This commit squashes several commits that remove: NO_C99_FORMAT CURLDIR and EXPATDIR NO_DEFLATE_BOUND CC_LD_DYNPATH and NO_R_TO_GCC_LINKER NO_PERL_MAKEMAKER INTERNAL_QSORT NO_EXTERNAL_GREP NO_PERL SCRIPT_PERL PERL_PATH_SQ Signed-off-by: Michael Witten <mfwitten@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-18perf tools: Makefile: Remove platform-specific cruftMichael Witten
While it makes sense that this tool could be used on other platforms at least to parse data, there doesn't appear to be any real support for such usage. This commit squashes several commits that remove: SNPRINTF_RETURNS_BOGUS FREAD_READS_DIRECTORIES NO_D_{INO,TYPE}_IN_DIRENT NO_STRCASESTR NO_MEMMEM NO_STRTOUMAX and NO_STRTOULL NO_SETENV NO_UNSETENV NO_MKDTEMP NEEDS_LIBICONV NEEDS_SOCKET NO_MMAP NO_PTHREADS NO_PREAD NO_TRUSTABLE_FILEMODE NO_IPV6 and NO_SOCKADDR_STORAGE NO_ICONV and OLD_ICONV NO_NSEC, USE_NSEC, and USE_ST_TIMESPEC NO_ST_BLOCKS_IN_STRUCT_STAT NO_FINK and NO_DARWIN_PORTS NO_SYS_SELECT_H NO_HSTRERROR DIR_HAS_BSD_GROUP_SEMANTICS and FORCE_DIR_SET_GID NEEDS_NSL, NO_UINTMAX_T, NO_INET_{N,P}TON COMPAT_{CFLAGS,OBJS} Executable extension `X' Signed-off-by: Michael Witten <mfwitten@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-18perf tools: Makefile: Remove vestigial git-specific cruftMichael Witten
This commit squashes several commits that remove: NO_SYMLINK_HEAD NO_SVN_TESTS NO_FAST_WORKING_DIRECTORY USE_STDEV SHA1/SSL cruft makefile rules Signed-off-by: Michael Witten <mfwitten@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-16perf tools: Update Makefile with some helpJesse Brandeburg
The perf makefile is nicely complete except for a) an uninstall option b) a 'make help' description This patch implements b) it also comments out other non-working makefile targets Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-16perf ui: Serialize screen updatesArnaldo Carvalho de Melo
The ui operations so far were used by just one thread, but 'perf top --tui' now has two threads updating the screen, so we need to use a mutex to avoid garbling the screen. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-16perf tool: Add cgroup supportStephane Eranian
This patch adds the ability to filter monitoring based on container groups (cgroups) for both perf stat and perf record. It is possible to monitor multiple cgroup in parallel. There is one cgroup per event. The cgroups to monitor are passed via a new -G option followed by a comma separated list of cgroup names. The cgroup filesystem has to be mounted. Given a cgroup name, the perf tool finds the corresponding directory in the cgroup filesystem and opens it. It then passes that file descriptor to the kernel. Example: $ perf stat -B -a -e cycles:u,cycles:u,cycles:u -G test1,,test2 -- sleep 1 Performance counter stats for 'sleep 1': 2,368,667,414 cycles test1 2,369,661,459 cycles <not counted> cycles test2 1.001856890 seconds time elapsed Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4d590290.825bdf0a.7d0a.4890@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-07perf tools: Makefile: Use $(QUIET_GEN) for perf.soMichael Witten
So that we get this: CC /home/acme/git/build/perf/bench/mem-memcpy-x86-64-asm.o GEN perf-archive * GEN /home/acme/git/build/perf/python/perf.so CC /home/acme/git/build/perf/builtin-annotate.o Instead of silently building the python binding. LKML-Reference: <1296890359-22659-1-git-send-email-mfwitten@gmail.com> Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-05perf annotate: Move annotate functions to util/Arnaldo Carvalho de Melo
They will be used by perf top, so that we have just one set of routines to do annotation. Rename "struct sym_priv" to "struct annotation", etc, to clarify this code a bit. Rename "struct sym_ext" to "struct source_line", to give it a meaningful name, that clarifies that it is a the result of an addr2line call, that is sorted by percentage one particular source code line appeared in the annotation. And since we're moving things around also rename 'sym_hist->ip' to 'sym_hist->addr' as we want to do data structure annotation at some point. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-01perf tools: Don't try to build python bindings if Python.h not availableArnaldo Carvalho de Melo
Just leverage the test done for python support in 'python script', emitting a warning about losing those features if python-dev[el] is not installed. Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-01perf tools: Fix up 'make clean' targetArnaldo Carvalho de Melo
It wasn't using $(OUTPUT) to rm *.o and there were some funny looking automake files that never get created but were being deleted anyway. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-01perf tools: Remove verbose build messages for the python bindingArnaldo Carvalho de Melo
Also now it builds it in a well known location: [acme@felicio linux]$ rm -rf ../build/perf/ [acme@felicio linux]$ mkdir ../build/perf [acme@felicio linux]$ make -j2 O=~acme/git/build/perf -C tools/perf/ <SNIP> [acme@felicio linux]$ ls -la ../build/perf/python/ total 152 -rwxrwxr-x 1 acme acme 147957 Feb 1 14:56 perf.so drwxrwxr-x 3 acme acme 17 Feb 1 14:56 temp [acme@felicio linux]$ [root@felicio ~]# strip ~acme/git/build/perf/python/perf.so [root@felicio ~]# ls -la ~acme/git/build/perf/python/perf.so -rwxrwxr-x 1 acme acme 46264 Feb 1 14:58 /home/acme/git/build/perf/python/perf.so [root@felicio ~]# export PYTHONPATH=~acme/git/build/perf/python/ [root@felicio ~]# ~acme/git/linux/tools/perf/python/twatch.py cpu: 0, pid: 7751, tid: 7751 { type: exit, pid: 7751, ppid: 7751, tid: 7751, ptid: 7751, time: 54562393512356} cpu: 0, pid: 13700, tid: 13700 { type: fork, pid: 7756, ppid: 13700, tid: 7756, ptid: 13700, time: 54562393746739} cpu: 1, pid: 7756, tid: 7756 { type: fork, pid: 7757, ppid: 7756, tid: 7757, ptid: 7756, time: 54562394246152} cpu: 1, pid: 7757, tid: 7757 { type: comm, pid: 7757, tid: 7757, comm: awk } cpu: 1, pid: 7757, tid: 7757 { type: exit, pid: 7757, ppid: 7757, tid: 7757, ptid: 7757, time: 54562395456813} Reported-by: Ingo Molnar <mingo@elte.hu> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-31perf top: Introduce slang based TUIArnaldo Carvalho de Melo
Disabled by default as there are features found in the stdio based one that aren't implemented, like live annotation, filtering knobs data entry. Annotation hopefully will get somehow merged with the 'perf annotate' code. To use it: perf top --tui Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-31perf top: Move display agnostic routines to util/top.[ch]Arnaldo Carvalho de Melo
Paving the way for a slang browser a la 'perf report --tui'. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-30perf tools: Initial python bindingArnaldo Carvalho de Melo
First clarifying that this kind of binding is not a replacement or an equivalent to the 'perf script' way of using python with perf. The 'perf script' way is to process events and look at a given script for some python function that matches the events to pass each event for processing. This is a python module, i.e. everything is driven from the python script, that merely uses "import perf" or "from perf import". perf script is focused on tracepoints, this binding is focused on profiling as an initial target. More work is needed to make available tracepoint specific variables as event variables accessible via this binding. There is one example of such usage model, in tools/perf/python/twatch.py, a tool to watch "cycles" events together with task (fork, exit) and comm perf events. For now, due to me not being able to grok how python distutils cope with building C extensions outside the sources dir the install target just builds it, I'm using it as: [root@emilia linux]# export PYTHONPATH=~acme/git/build/perf/lib.linux-x86_64-2.6/ [root@emilia linux]# tools/perf/python/twatch.py cpu: 4, pid: 30126, tid: 30126 { type: mmap, pid: 30126, tid: 30126, start: 0x4, length: 0x82e9ca03, offset: 0, filename: } cpu: 6, pid: 47, tid: 47 { type: mmap, pid: 47, tid: 47, start: 0x6, length: 0xbef87c36, offset: 0, filename: } cpu: 1, pid: 0, tid: 0 { type: mmap, pid: 0, tid: 0, start: 0x1, length: 0x775d1904, offset: 0, filename: } cpu: 7, pid: 0, tid: 0 { type: mmap, pid: 0, tid: 0, start: 0x7, length: 0xc750aeb6, offset: 0, filename: } cpu: 5, pid: 2255, tid: 2255 { type: mmap, pid: 2255, tid: 2255, start: 0x5, length: 0x76669635, offset: 0, filename: } cpu: 0, pid: 0, tid: 0 { type: mmap, pid: 0, tid: 0, start: 0, length: 0x6422ef6b, offset: 0, filename: } cpu: 2, pid: 2255, tid: 2255 { type: mmap, pid: 2255, tid: 2255, start: 0x2, length: 0xe078757a, offset: 0, filename: } cpu: 1, pid: 5769, tid: 5769 { type: fork, pid: 30127, ppid: 5769, tid: 30127, ptid: 5769, time: 103893991270534} cpu: 6, pid: 30127, tid: 30127 { type: comm, pid: 30127, tid: 30127, comm: ls } cpu: 6, pid: 30127, tid: 30127 { type: exit, pid: 30127, ppid: 30127, tid: 30127, ptid: 30127, time: 103893993273024} The first 8 mmap events in this 8 way machine are a mistery that is still being investigated. More of the tools/perf/util/ APIs will be exposed via this python binding as the need arises. For now the focus is on creating events and processing them, symbol resolution is an obvious next step, with tracepoint variables as a close second step. Cc: Clark Williams <williams@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-28perf tools: Add strfilter for general purpose string filterMasami Hiramatsu
Add strfilter for general purpose string filter. Every filter rules are descrived by glob matching pattern and '!' prefix which means Logical NOT. A strfilter consists of those filter rules connected with '&' and '|'. A set of rules can be folded by using '(' and ')'. It also accepts spaces around rules and those operators. Format: <rule> ::= <glob-exp> | "!" <rule> | <rule> <op> <rule> | "(" <rule> ")" <op> ::= "&" | "|" e.g.: "(add* | del*) & *timer" filter rules pass strings which start with add or del and end with timer. This will be used by perf probe --filter. Changes in V2: - Fix to check result of strdup() and strfilter__alloc(). - Encapsulate and simplify interfaces as like regex(3). Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Franck Bui-Huu <fbuihuu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20110120141530.25915.12673.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-24perf threads: Move thread_map to separate fileArnaldo Carvalho de Melo
To untangle it from struct thread handling, that is tied to symbols, etc. Right now in the python bindings I'm working on I need just a subset of the util/ files, untangling it allows me to do that. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf evsel: Introduce perf_evlistArnaldo Carvalho de Melo
Killing two more perf wide global variables: nr_counters and evsel_list as a list_head. There are more operations that will need more fields in perf_evlist, like the pollfd for polling all the fds in a list of evsel instances. Use option->value to pass the evsel_list to parse_{events,filters}. LKML-Reference: <new-submission> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf tools: Fix build by checking if extra warnings are supportedArnaldo Carvalho de Melo
The -Wstack-protector and -Wvolatile-register-var warnings, for instance, are not supported by gcc 3.4.6. So fix by doing the same check we already do for -fstack-protector-all. With this and the other patches in this series, perf builds unmodified on, for instance, RHEL4. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-06perf tools: Build with frame pointerFrederic Weisbecker
It seems that some gcc versions build by default with frame pointers and some others omit them. Just build the tools with frame pointers as the callchains can be an important part of the perf workflow. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1294325513-14276-3-git-send-email-fweisbec@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf tools: Introduce event selectorsArnaldo Carvalho de Melo
Out of ad-hoc code and global arrays with hard coded sizes. This is the first step on having a library that will be first used on regression tests in the 'perf test' tool. [acme@felicio linux]$ size /tmp/perf.before text data bss dec hex filename 1273776 97384 5104416 6475576 62cf38 /tmp/perf.before [acme@felicio linux]$ size /tmp/perf.new text data bss dec hex filename 1275422 97416 1392416 2765254 2a31c6 /tmp/perf.new Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-07perf makefile: Allow strong and weak functions in LIB_OBJSIan Munsie
When we build perf we place all of the .o files from the library files (util, arch/x/util, etc) into libperf.a which is then linked into perf. The problem is that the linker will by default only consider .o files within the .a archive if they are necessary to satisfy an unresolved symbol. As weak functions are not unresolved, it will not consider a .o file from the archive containing the strong versions of weak functions unless it requires it for another reason. This patch adds the --whole-archive flags to the linker when passing in the libperf.a file to ensure that it will consider every .o file in the archive, not just what it believes that it needs. The end result is that weak functions can now be overridden by strong variants of them in the libperf.a file. Cc: "tom.leiming" <tom.leiming@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290991642-sup-5890@au1.ibm.com> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-01Merge branch 'perf/rename' into perf/coreIngo Molnar
Merge reason: This is an older commit under testing that was not pushed yet - merge it. Also fix up the merge in command-list.txt. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Tom Zanussi <tzanussi@gmail.com>
2010-11-26perf bench: Add feature that measures the performance of the ↵Hitoshi Mitake
arch/x86/lib/memcpy_64.S memcpy routines via 'perf bench mem' This patch ports arch/x86/lib/memcpy_64.S to perf bench mem memcpy for benchmarking memcpy() in userland with tricky and dirty way. util/include/asm/cpufeature.h, util/include/asm/dwarf2.h, and util/include/linux/linkage.h are mostly dummy files with small wrappers, so that we are able to include memcpy_64.S unmodified. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: h.mitake@gmail.com Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: Ma Ling <ling.ma@intel.com> Cc: Zhao Yakui <yakui.zhao@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <1290668693-27068-2-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-19perf tools: Remove hardcoded include paths for elfutilsRobert Morell
This change removes the use of hardcoded absolute "/usr/include/elfutils" paths from the perf build. The problem with hardcoded paths is that it prevents them from being overridden by $prefix or by -I in CFLAGS (e.g., for cross-compiling purposes). Instead, just include the "elfutils/" subdirectory as a relative path when files are needed from that directory. Tested by building perf: - Cross-compiled for ARM on x86_64 - Built natively on x86_64 - Built on x86_64 with /usr/include/elfutils moved to another location and manually included in CFLAGS Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1289945793-31441-1-git-send-email-rmorell@nvidia.com> Signed-off-by: Robert Morell <rmorell@nvidia.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-16perf: Rename 'perf trace' to 'perf script'Ingo Molnar
Free the perf trace name space and rename the trace to 'script' which is a better match for the scripting engine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-05Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: tools/perf/util/ui/browsers/hists.c Merge reason: fix the conflict and merge in changes for dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-04perf tools: Fix build breakageKusanagi Kouichi
The patch ecafda6 introduced a problem where all object files would be always rebuilt, fix it by using: http://www.gnu.org/software/make/manual/html_node/Prerequisite-Types.html Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Bernd Petrovitsch <bernd@sysprog.at> Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf tools: Fix linking errors with --as-needed flagTom Zanussi
External shared libraries should never be appended to the LDFLAGS as this messes the linking order. As EXTLIBS collects those libraries, it seems that perl and python libraries should also be appended to EXTLIBS. Also fix the broken linking order. This is a refresh of a patch by Ozan Çağlayan and improved by both Tom Zanussi and Kirill A. Shutemov. Cc: Ozan Çağlayan <ozan@pardus.org.tr> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <1282627430.28324.8.camel@tropicana> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: pick up perf fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-21perf tools: add test for strlcpy()Kirill A. Shutemov
Some Linux distributions like ALT Linux provides patched glibc with contains strlcpy(). It's confilcts with strlcpy() from perf. Let's add check for strlcpy(). Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1282351101-8879-1-git-send-email-kirill@shutemov.name> Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-18perf tools: Fix build error on read only source.Kusanagi Kouichi
Parts of the build process were generating files outside the specified O= directory, causing the build to fail on systems where the sources are in a read only file system. Fix it by using $(OUTPUT) on these locations. Also check that $(OUTPUT) actually exists, just like the top level kernel Makefile does. Otherwise the failure message emitted is completely misleading. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20100817140841.0859362C03A@msa106.auone-net.jp> Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-17perf tools: Fix build on POSIX shellsBernd Petrovitsch
POSIX sh does not specify the brace expansion, so fix it by replacing the global $(shell ...) lines quite at the top creating the output directories with real rules. Cc: Ingo Molnar <mingo@elte.hu> Cc: Kusanagi Kouichi <slash@ac.auone-net.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1282046280.5822.4.camel@thorin> Signed-off-by: Bernd Petrovitsch <bernd@sysprog.at> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf ui: Complete the breakdown of util/newt.cArnaldo Carvalho de Melo
