path: root/tools/iio
2015-03-28tools: iio: generic_buffer: Fix generic scale extractionIrina Tirdea
When using generic_buffer to read data, the scale is not properly detected for scale shared by type. This is caused by a problem with the generation of generic name out of the full name. E.g.: for current->name in_accel_z, the extracted generic name is "in" (when it should be "in_accel"). This is used in generic_buffer to generate scale and offset paths (in_accel_scale). Consider the in_ or out_ prefix when extracting the generic name from the full name. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Reviewed-by: Daniel Baluta <daniel.baluta@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-03-24Merge tag 'iio-for-4.1a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First set of new drivers, cleanups and functionality for IIO in the 4.1 cycle. New drivers * CM3323 color sensor. * MS5611 pressure and temperature sensor. New functionality * mup6050 - create mux clients for devices described via ACPI. The reasoning and approach taken in this patch are complex. Basically there is no otherway of finding out what is there than by some esoteric look ups in the ACPI data. * cm3232 - PM support * itg3200 - suspend/resume support * mcp320x - add more ADCs to the kconfig to reflect what the driver supports (this patch and the bindings got left behind when the support was added a while back). Docs / utils * ti-adc128s052 - DT bindings. * mcp3422 - DT bindings. * mcp320x - DT bindings * ABI docs for event threshold scale attributes, in_magn_offset, proximity scan_element and thresh falling/rising values for accelerometers. All elements long in use that have slipped by being explicitly documented. * Tidy up the tools previously in drivers/staging/iio/Documentation and move them out to /tools/iio. Yet another move that should have happened long ago. This time Roberta Dobrescu did the leg work. Thanks! Core Cleanups * Export userspace IIO headers. We should have done the appropriate header splitting a long time ago. Thanks to Daniel for sorting this out. * Refactor the registring of attributes for buffers to move all non-custom ones to a vector allowing easier additions to the current set in the future. Driver Cleanups * gpiod related cleanups. Make use of the additional parameter to specify initial direciton to avoid extra code. * bmc150 - Various refactorings to reduce code repitition and prepare for hardware buffer support. Some of these cleanups are good even without the new functionality. * kmx61 - direct use of index to an array avoiding a structure element which was always the index to an element in an array of that structure. * vf610 - avoid incorrect type for return from wait_for_completion_timeout. * gp2ap020a00f - use put_unaligned_le32 for slight code simplification. * ade7754 - improve error handling including suppressing some build warnings. * ade7759 - improve error handling including suppressing some build warnings. * hmc5843 - Long line and indentation fixes. Also some constifying of various constant data. * ade7854 - 80+ character line splitting. * ad2s1210 - fix wrong printf format string. * mxs-lradc - fix wrong printf format string. * ade7954-i2c - code alignment fixes and other trivial but worthwhile bits. * periodic rtc trigger - make the frequency type an unsigned int as it is always treated as such. * jsa1212 - constify struct regmap_config as it is constant. * ad7793 - typo in the MODULE_DESCRIPTION * mma9551 - check gpiod_to_irq errors. Note that this doesn't actually cause any trouble but is worth tidying up as obviously incorrect. * mlx90614 - refactor the register symbols to make it clear which reads are to RAM not PROM.
2015-03-09tools: iio: lsiio: Remove unused variablesRoberta Dobrescu
This patch removes unused variables from lsiio.c in order to get rid of the warnings regarding them. Signed-off-by: Roberta Dobrescu <roberta.dobrescu@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-03-09tools: iio: Define _GNU_SOURCE in MakefileRoberta Dobrescu
Definition of _GNU_SOURCE is needed to get rid of some warnings, such as: warning: implicit declaration of function `asprintf'. generic_buffer.c and iio_event_monitor.c define _GNU_SOURCE, but it is also needed in lsiio.c and iio_utils.c. For this reason, this patch adds the definition in Makefile and removes it from where it already exists. Signed-off-by: Roberta Dobrescu <roberta.dobrescu@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-03-09iio: Move iio userspace applications out of stagingRoberta Dobrescu
This patch moves iio userspace applications out of staging, to tools/iio/ and adds a Makefile in order to compile them easily. It also adds tools/iio/ to MAINTAINERS file. Signed-off-by: Roberta Dobrescu <roberta.dobrescu@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
