path: root/sound
2015-04-24Merge tag 'sound-fix-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here are a few fixes that have been pending since the previous pull request: a regression fix for HD-audio multiple SPDIF / HDMI devices, several ALC256 codec fixes, a couple of i915 HDMI audio fixes, and various small fixes. Nothing exciting, just boring, but things good to have" * tag 'sound-fix-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - fix headset mic detection problem for one more machine ALSA: hda/realtek - Fix Headphone Mic doesn't recording for ALC256 ALSA: hda - fix "num_steps = 0" error on ALC256 ALSA: usb-audio: Fix audio output on Roland SC-D70 sound module ALSA: hda - add AZX_DCAPS_I915_POWERWELL to Baytrail ALSA: hda - only sync BCLK to the display clock for Haswell & Broadwell ALSA: hda - Mute headphone pin on suspend on XPS13 9333 sound/oss: fix deadlock in sequencer_ioctl(SNDCTL_SEQ_OUTOFBAND) ALSA: asound.h - use SNDRV_CTL_ELEM_ID_NAME_MAXLEN ALSA: hda - potential (but unlikely) uninitialized variable ALSA: hda - Fix regression for slave SPDIF setups ALSA: intel8x0: Check pci_iomap() success for DEVICE_ALI ALSA: hda - simplify azx_has_pm_runtime
2015-04-24Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: - new drivers for: - Ingenic JZ4780 controller - APM X-Gene controller - Freescale RaidEngine device - Renesas USB Controller - remove device_alloc_chan_resources dummy handlers - sh driver cleanups for peri peri and related emmc and asoc patches as well - fixes and enhancements spread over the drivers * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits) dmaengine: dw: don't prompt for DW_DMAC_CORE dmaengine: shdmac: avoid unused variable warnings dmaengine: fix platform_no_drv_owner.cocci warnings dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe() dmaengine: at_xdmac: unlock spin lock before return dmaengine: xgene: devm_ioremap() returns NULL on error dmaengine: xgene: buffer overflow in xgene_dma_init_channels() dmaengine: usb-dmac: Fix dereferencing freed memory 'desc' dmaengine: sa11x0: report slave capabilities to upper layers dmaengine: vdma: Fix compilation warnings dmaengine: fsl_raid: statify fsl_re_chan_probe dmaengine: Driver support for FSL RaidEngine device. dmaengine: xgene_dma_init_ring_mngr() can be static Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes dmaengine: Add support for APM X-Gene SoC DMA engine driver dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver dmaengine: renesas,usb-dmac: Add device tree bindings documentation dmaengine: edma: fixed wrongly initialized data parameter to the edma callback dmaengine: ste_dma40: fix implicit conversion ...
2015-04-24ALSA: hda - fix headset mic detection problem for one more machineHui Wang
We have two machines with alc256 codec in the pin quirk table, so moving the common pins to ALC256_STANDARD_PINS. Cc: stable@vger.kernel.org BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1447909 Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-23ALSA: hda/realtek - Fix Headphone Mic doesn't recording for ALC256Kailang Yang
Switch default pcbeep path to Line in path. Signed-off-by: Kailang Yang <kailang@realtek.com> Tested-by: Hui Wang <hui.wang@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-21Merge tag 'char-misc-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver patchset for 4.1-rc1. Lots of different driver subsystem updates here, nothing major, full details are in the shortlog. All of this has been in linux-next for a while" * tag 'char-misc-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (133 commits) mei: trace: remove unused TRACE_SYSTEM_STRING DTS: ARM: OMAP3-N900: Add lis3lv02d support Documentation: DT: lis302: update wakeup binding lis3lv02d: DT: add wakeup unit 2 and wakeup threshold lis3lv02d: DT: use s32 to support negative values Drivers: hv: hv_balloon: correctly handle num_pages>INT_MAX case Drivers: hv: hv_balloon: correctly handle val.freeram<num_pages case mei: replace check for connection instead of transitioning mei: use mei_cl_is_connected consistently mei: fix mei_poll operation hv_vmbus: Add gradually increased delay for retries in vmbus_post_msg() Drivers: hv: hv_balloon: survive ballooning request with num_pages=0 Drivers: hv: hv_balloon: eliminate jumps in piecewiese linear floor function Drivers: hv: hv_balloon: do not online pages in offline blocks hv: remove the per-channel workqueue hv: don't schedule new works in vmbus_onoffer()/vmbus_onoffer_rescind() hv: run non-blocking message handlers in the dispatch tasklet coresight: moving to new "hwtracing" directory coresight-tmc: Adding a status interface to sysfs coresight: remove the unnecessary configuration coresight-default-sink ...
2015-04-21ALSA: hda - fix "num_steps = 0" error on ALC256David Henningsson
The ALC256 does not have a mixer nid at 0x0b, and there's no loopback path (the output pins are directly connected to the DACs). This commit fixes an "num_steps = 0 for NID=0xb (ctl = Beep Playback Volume)" error (and as a result, problems with amixer/alsamixer). If there's pcbeep functionality, it certainly isn't controlled by setting an amp on 0x0b, so disable beep functionality (at least for now). Cc: stable@vger.kernel.org BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1446517 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-21ALSA: usb-audio: Fix audio output on Roland SC-D70 sound moduleTakamichi Horikawa
Roland SC-D70 reports its device class as vendor specific class and the quirk QUIRK_AUDIO_FIXED_ENDPOINT was used for audio output. In the quirks table the sampling rate was hard-coded to 44100 Hz and therefore not worked when the sound module was in 48000 Hz mode. In this change the quirk is changed to QUIRK_AUDIO_STANDARD_INTERFACE but as the sound module reports incorrect bSubframeSize in its descriptors, additional change is made in format.c to detect it and to override it (which uses the existing code for Edirol SD-90). Tested both when the sound module was in 44100 Hz mode and 48000 Hz mode and both audio input and output. MIDI related part of the driver is not touched. Signed-off-by: Takamichi Horikawa <takamichiho@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-21ALSA: hda - add AZX_DCAPS_I915_POWERWELL to BaytrailMengdong Lin
This patch addes AZX_DCAPS_I915_POWERWELL to BYT (Baytrail). Like Braswell and Skylake, the HDMI codec on Bytrail is also in the shared power well with GPU. This power well must be turned on before we reset link to probe the codec, to avoid communication failure with the codec. The side effect is that this power is always ON in S0 because the BYT HDMI codec does not support EPSS or D3ClkStop and so the controller doesn't enter D3 at runtime, and the HDMI codec and analog codec share a single physical HD-A link and so we cannot reset the HD-A link freely when we re-enable the power to use the HDMI codec. Next step is to test if an AGP reset or double AGP reset on BYT HDMI codec is okay to bring the HDMI codec back to a functional state after restoring the power. If okay, we can bind the power on/off with the HDMI codec PM without interrupting the analog audio. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-20ALSA: hda - only sync BCLK to the display clock for Haswell & BroadwellMengdong Lin
Only Intel Haswell and Broadwell have a separate HD-A controller (PCI device 3) for display audio, which needs to get 24MHz HD-A link BCLK from the variable display core clock through vendor specific registers EM4 & EM5. Other platforms (Baytrail, Braswell and Skylake) don't have this feature. So this patch checks the PCI device ID of the controller in haswell_set_bclk() and only sync BCLK for HSW and BDW. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-20ALSA: hda - Mute headphone pin on suspend on XPS13 9333Gabriele Mazzotta
Muting the headphone output pin right before the codec suspension prevents pop noises when headphones are plugged in (except for a barely audible click noise). This solution allows to truly save some power when headphones are plugged in unlike the previous solution (033b0a7ca9c: "ALSA: hda - Pop noises fix for XPS13 9333") Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-18sound/oss: fix deadlock in sequencer_ioctl(SNDCTL_SEQ_OUTOFBAND)Alexey Khoroshilov
A deadlock can be initiated by userspace via ioctl(SNDCTL_SEQ_OUTOFBAND) on /dev/sequencer with TMR_ECHO midi event. In this case the control flow is: sound_ioctl() -> case SND_DEV_SEQ: case SND_DEV_SEQ2: sequencer_ioctl() -> case SNDCTL_SEQ_OUTOFBAND: spin_lock_irqsave(&lock,flags); play_event(); -> case EV_TIMING: seq_timing_event() -> case TMR_ECHO: seq_copy_to_input() -> spin_lock_irqsave(&lock,flags); It seems that spin_lock_irqsave() around play_event() is not necessary, because the only other call location in seq_startplay() makes the call without acquiring spinlock. So, the patch just removes spinlocks around play_event(). By the way, it removes unreachable code in seq_timing_event(), since (seq_mode == SEQ_2) case is handled in the beginning. Compile tested only. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-17ALSA: hda - potential (but unlikely) uninitialized variableDan Carpenter
This function is a bit unusual because it accepts negative values as "conn_len". It's theoretically possible for both "cache_len" and "conn_len" to be -ENOSPC and in that case we would oops trying to run memcmp() on the uninitialized "list" pointer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17ASoC: pcm512x: use DIV_ROUND_CLOSEST_ULL() from kernel.hJavi Merino
Now that the kernel provides DIV_ROUND_CLOSEST_ULL(), drop the internal implementation and use the kernel one. Signed-off-by: Javi Merino <javi.merino@arm.com> Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Peter Rosin <peda@axentia.se> Acked-by: Mark Brown <broonie@kernel.org> Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-16Merge tag 'powerpc-4.1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - Numerous minor fixes, cleanups etc. - More EEH work from Gavin to remove its dependency on device_nodes. - Memory hotplug implemented entirely in the kernel from Nathan Fontenot. - Removal of redundant CONFIG_PPC_OF by Kevin Hao. - Rewrite of VPHN parsing logic & tests from Greg Kurz. - A fix from Nish Aravamudan to reduce memory usage by clamping nodes_possible_map. - Support for pstore on powernv from Hari Bathini. - Removal of old powerpc specific byte swap routines by David Gibson. - Fix from Vasant Hegde to prevent the flash driver telling you it was flashing your firmware when it wasn't. - Patch from Ben Herrenschmidt to add an OPAL heartbeat driver. - Fix for an oops causing get/put_cpu_var() imbalance in perf by Jan Stancek. - Some fixes for migration from Tyrel Datwyler. - A new syscall to switch the cpu endian by Michael Ellerman. - Large series from Wei Yang to implement SRIOV, reviewed and acked by Bjorn. - A fix for the OPAL sensor driver from Cédric Le Goater. - Fixes to get STRICT_MM_TYPECHECKS building again by Michael Ellerman. - Large series from Daniel Axtens to make our PCI hooks per PHB rather than per machine. - Small patch from Sam Bobroff to explicitly abort non-suspended transactions on syscalls, plus a test to exercise it. - Numerous reworks and fixes for the 24x7 PMU from Sukadev Bhattiprolu. - Small patch to enable the hard lockup detector from Anton Blanchard. - Fix from Dave Olson for missing L2 cache information on some CPUs. - Some fixes from Michael Ellerman to get Cell machines booting again. - Freescale updates from Scott: Highlights include BMan device tree nodes, an MSI erratum workaround, a couple minor performance improvements, config updates, and misc fixes/cleanup. * tag 'powerpc-4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (196 commits) powerpc/powermac: Fix build error seen with powermac smp builds powerpc/pseries: Fix compile of memory hotplug without CONFIG_MEMORY_HOTREMOVE powerpc: Remove PPC32 code from pseries specific find_and_init_phbs() powerpc/cell: Fix iommu breakage caused by controller_ops change powerpc/eeh: Fix crash in eeh_add_device_early() on Cell powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTH powerpc/perf/hv-24x7: Fail 24x7 initcall if create_events_from_catalog() fails powerpc/pseries: Correct memory hotplug locking powerpc: Fix missing L2 cache size in /sys/devices/system/cpu powerpc: Add ppc64 hard lockup detector support oprofile: Disable oprofile NMI timer on ppc64 powerpc/perf/hv-24x7: Add missing put_cpu_var() powerpc/perf/hv-24x7: Break up single_24x7_request powerpc/perf/hv-24x7: Define update_event_count() powerpc/perf/hv-24x7: Whitespace cleanup powerpc/perf/hv-24x7: Define add_event_to_24x7_request() powerpc/perf/hv-24x7: Rename hv_24x7_event_update powerpc/perf/hv-24x7: Move debug prints to separate function powerpc/perf/hv-24x7: Drop event_24x7_request() powerpc/perf/hv-24x7: Use pr_devel() to log message ... Conflicts: tools/testing/selftests/powerpc/Makefile tools/testing/selftests/powerpc/tm/Makefile
2015-04-16ALSA: hda - Fix regression for slave SPDIF setupsTakashi Iwai
The commit [a551d91473e5: ALSA: hda - Use regmap for command verb caches, too] introduced a regression due to a typo in the conversion; the IEC958 status bits of slave digital devices aren't updated correctly. This patch corrects it. Fixes: a551d91473e5 ('ALSA: hda - Use regmap for command verb caches, too') Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-16ALSA: intel8x0: Check pci_iomap() success for DEVICE_ALIScott Wood
DEVICE_ALI previously would jump to port_inited after calling pci_iomap(), bypassing the check for bmaddr being NULL. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-16ALSA: hda - simplify azx_has_pm_runtimeDavid Henningsson
Because AZX_DCAPS_PM_RUNTIME is always defined as non-zero, the initial part of the expression can be skipped. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-15Merge tag 'sound-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "There have been major modernization with the standard bus: in ALSA sequencer core and HD-audio. Also, HD-audio receives the regmap support replacing the in-house cache register cache code. These changes shouldn't impact the existing behavior, but rather refactoring. In addition, HD-audio got the code split to a core library part and the "legacy" driver parts. This is a preliminary work for adapting the upcoming ASoC HD-audio driver, and the whole transition is still work in progress, likely finished in 4.1. Along with them, there are many updates in ASoC area as usual, too: lots of cleanups, Intel code shuffling, etc. Here are some highlights: ALSA core: - PCM: the audio timestamp / wallclock enhancement - PCM: fixes in DPCM management - Fixes / cleanups of user-space control element management - Sequencer: modernization using the standard bus HD-audio: - Modernization using the standard bus - Regmap support - Use standard runtime PM for codec power saving - Widget-path based power-saving for IDT, VIA and Realtek codecs - Reorganized sysfs entries for each codec object - More Dell headset support ASoC: - Move of jack registration to the card level - Lots of ASoC cleanups, mainly moving things from the CODEC level to the card level - Support for DAPM routes specified by both the machine driver and DT - Continuing improvements to rcar - pcm512x enhacements - Intel platforms updates - rt5670 updates / fixes - New platforms / devices: some non-DSP Qualcomm platforms, Google's Storm platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC Misc: - ice1724: Improved ESI W192M support - emu10k1: Emu 1010 fixes/enhancement" * tag 'sound-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits) ALSA: hda - set GET bit when adding a vendor verb to the codec regmap ALSA: hda/realtek - Enable the ALC292 dock fixup on the Thinkpad T450 ALSA: hda - Fix another race in runtime PM refcounting ALSA: hda - Expose codec type sysfs ALSA: ctl: fix to handle several elements added by one operation for userspace element ASoC: Intel: fix array_size.cocci warnings ASoC: n810: Automatically disconnect non-connected pins ASoC: n810: Consistently pass the card DAPM context to n810_ext_control() ASoC: davinci-evm: Use card DAPM context to access widgets ASoC: mop500_ab8500: Use card DAPM context to access widgets ASoC: wm1133-ev1: Use card DAPM context to access widgets ASoC: atmel: Improve machine driver compile test coverage ASoC: atmel: Add dependency to SND_SOC_I2C_AND_SPI where necessary ALSA: control: Fix a typo of SNDRV_CTL_ELEM_ACCESS_TLV_* with SNDRV_CTL_TLV_OP_* ALSA: usb-audio: Don't attempt to get Microsoft Lifecam Cinema sample rate ASoC: rnsd: fix build regression without CONFIG_OF ALSA: emu10k1: add toggles for E-mu 1010 optical ports ALSA: ctl: fill identical information to return value when adding userspace elements ALSA: ctl: fix a bug to return no identical information in info operation for userspace controls ALSA: ctl: confirm to return all identical information in 'activate' event ...
2015-04-15Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs update from Al Viro: "Now that net-next went in... Here's the next big chunk - killing ->aio_read() and ->aio_write(). There'll be one more pile today (direct_IO changes and generic_write_checks() cleanups/fixes), but I'd prefer to keep that one separate" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits) ->aio_read and ->aio_write removed pcm: another weird API abuse infinibad: weird APIs switched to ->write_iter() kill do_sync_read/do_sync_write fuse: use iov_iter_get_pages() for non-splice path fuse: switch to ->read_iter/->write_iter switch drivers/char/mem.c to ->read_iter/->write_iter make new_sync_{read,write}() static coredump: accept any write method switch /dev/loop to vfs_iter_write() serial2002: switch to __vfs_read/__vfs_write ashmem: use __vfs_read() export __vfs_read() autofs: switch to __vfs_write() new helper: __vfs_write() switch hugetlbfs to ->read_iter() coda: switch to ->read_iter/->write_iter ncpfs: switch to ->read_iter/->write_iter net/9p: remove (now-)unused helpers p9_client_attach(): set fid->uid correctly ...
2015-04-14Merge tag 'mfd-for-linus-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - Rename child driver [axp288_battery => axp288_fuel_gauge]; axp20x - Rename child driver [max77693-flash => max77693-led]; max77693 - Error handling fixes; intel_soc_pmic - GPIO tweaking; intel_soc_pmic - Remove non-DT code; vexpress-sysreg, tc3589x - Remove unused/legacy code; ti_am335x_tscadc, rts5249, rtsx_gops, rtsx_pcr, rtc-s5m, sec-core, max77693, menelaus, wm5102-tables - Trivial fixups; rtsx_pci, da9150-core, sec-core, max7769, max77693, mc13xxx-core, dln2, hi6421-pmic-core, rk808, twl4030-power, lpc_ich, menelaus, twl6040 - Update register/address values; rts5227, rts5249 - DT and/or binding document fixups; arizona, da9150, mt6397, axp20x, qcom-rpm, qcom-spmi-pmic - Couple of trivial core Kconfig fixups - Remove use of seq_printf return value; ab8500-debugfs - Remove __exit markups; menelaus, tps65010 - Fix platform-device name collisions; mfd-core New drivers/supported devices: - Add support for wm8280/wm8281 into arizona - Add support for COMe-cBL6 into kempld-core - Add support for rts524a and rts525a into rts5249 - Add support for ipq8064 into qcom_rpm - Add support for extcon into axp20x - New MediaTek MT6397 PMIC driver - New Maxim MAX77843 PMIC dirver - New Intel Quark X1000 I2C-GPIO driver - New Skyworks SKY81452 driver" * tag 'mfd-for-linus-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (76 commits) mfd: sec: Fix RTC alarm interrupt number on S2MPS11 mfd: wm5102: Remove registers for output 3R from readable list mfd: tps65010: Remove incorrect __exit markups mfd: devicetree: bindings: Add Qualcomm RPM regulator subnodes mfd: axp20x: Add support for extcon cell mfd: lpc_ich: Sort IDs mfd: twl6040: Remove wrong and unneeded "platform:twl6040" modalias mfd: qcom-spmi-pmic: Add specific compatible strings for Qualcomm's SPMI PMIC's mfd: axp20x: Fix duplicate const for model names mfd: menelaus: Use macro for magic number mfd: menelaus: Drop support for SW controller VCORE mfd: menelaus: Delete omap_has_menelaus mfd: arizona: Correct type of gpio_defaults mfd: lpc_ich: Sort IDs mfd: Fix a typo in Kconfig mfd: qcom_rpm: Add support for IPQ8064 mfd: devicetree: qcom_rpm: Document IPQ8064 resources mfd: core: Fix platform-device name collisions mfd: intel_quark_i2c_gpio: Don't crash if !DMI dt-bindings: Add vendor-prefix for X-Powers ...
2015-04-14Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: "Part one: - struct filename-related cleanups - saner iov_iter_init() replacements (and switching the syscalls to use of those) - ntfs switch to ->write_iter() (Anton) - aio cleanups and splitting iocb into common and async parts (Christoph) - assorted fixes (me, bfields, Andrew Elble) There's a lot more, including the completion of switchover to ->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags race fixes, etc, but that goes after #for-davem merge. David has pulled it, and once it's in I'll send the next vfs pull request" * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits) sg_start_req(): use import_iovec() sg_start_req(): make sure that there's not too many elements in iovec blk_rq_map_user(): use import_single_range() sg_io(): use import_iovec() process_vm_access: switch to {compat_,}import_iovec() switch keyctl_instantiate_key_common() to iov_iter switch {compat_,}do_readv_writev() to {compat_,}import_iovec() aio_setup_vectored_rw(): switch to {compat_,}import_iovec() vmsplice_to_user(): switch to import_iovec() kill aio_setup_single_vector() aio: simplify arguments of aio_setup_..._rw() aio: lift iov_iter_init() into aio_setup_..._rw() lift iov_iter into {compat_,}do_readv_writev() NFS: fix BUG() crash in notify_change() with patch to chown_common() dcache: return -ESTALE not -EBUSY on distributed fs race NTFS: Version 2.1.32 - Update file write from aio_write to write_iter. VFS: Add iov_iter_fault_in_multipages_readable() drop bogus check in file_open_root() switch security_inode_getattr() to struct path * constify tomoyo_realpath_from_path() ...
2015-04-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Usual trivial tree updates. Nothing outstanding -- mostly printk() and comment fixes and unused identifier removals" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: goldfish: goldfish_tty_probe() is not using 'i' any more powerpc: Fix comment in smu.h qla2xxx: Fix printks in ql_log message lib: correct link to the original source for div64_u64 si2168, tda10071, m88ds3103: Fix firmware wording usb: storage: Fix printk in isd200_log_config() qla2xxx: Fix printk in qla25xx_setup_mode init/main: fix reset_device comment ipwireless: missing assignment goldfish: remove unreachable line of code coredump: Fix do_coredump() comment stacktrace.h: remove duplicate declaration task_struct smpboot.h: Remove unused function prototype treewide: Fix typo in printk messages treewide: Fix typo in printk messages mod_devicetable: fix comment for match_flags
2015-04-14ALSA: hda - set GET bit when adding a vendor verb to the codec regmapMengdong Lin
Some HD-A codecs may add their own vendor 'set' verb to the regmap, thru func snd_hdac_add_vendor_verb(). This patch sets the GET bit (bit 11) when adding the verb so that its peer vendor 'get' verb is actually added. This can avoid I/O error when writing the 'set' verb thru remap, since HD-A regmap internally looks up a writable vendor verb with GET bit set at first. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-13Merge tag 'asoc-v4.1-2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v4.1 More updates for v4.1, pretty much all drivers: - Lots of cleanups from Lars, mainly moving things from the CODEC level to the card level. - Continuing improvements to rcar from Morimoto-san, pcm512x from Howard and Peter, the Intel platforms from Vinod, Jie, Jin and Han, and to rt5670 from Bard. - Support for some non-DSP Qualcomm platforms, Google's Storm platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC.
2015-04-13ALSA: hda/realtek - Enable the ALC292 dock fixup on the Thinkpad T450Jo-Philipp Wich
The Lenovo Thinkpad T450 requires the ALC292_FIXUP_TPT440_DOCK as well in order to get working sound output on the docking stations headphone jack. Patch tested on a Thinkpad T450 (20BVCTO1WW) using kernel 4.0-rc7 in conjunction with a ThinkPad Ultradock. Signed-off-by: Jo-Philipp Wich <jow@openwrt.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-13ALSA: hda - Fix another race in runtime PM refcountingTakashi Iwai
Although some races in runtime PM refcount was fixed by the commit [664c715573c2: ALSA: hda - Work around races of power up/down with runtime PM], there is still a race in the following case: CPU0: CPU1 : runtime suspend: codec->in_pm = 1 snd_hdac_power_up_pm(): pm_runtime_get_sync() skipped suspend finished: codec->in_pm = 0 snd_hdac_power_down_pm(): pm_runtime_put_*() is called! For avoiding this situation, increment in_pm flag atomically when it's non-zero, and decrement accordingly, to ensure that in_pm is set consistently for the whole concurrent operations. Also, since atomic_inc_not_zero() and atomic_dec_if_positive() are lengthy inline functions, move snd_hdac_power_up_pm() and _down_pm() to sound/hda/hdac_device.c as no inline functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-13ALSA: hda - Expose codec type sysfsTakashi Iwai
The type field of HD-audio codec object should be exposed to user-space so that it can identify which driver type to bind (legacy / asoc). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-13ALSA: ctl: fix to handle several elements added by one operation for ↵Takashi Sakamoto
userspace element An element instance can have several elements with the same feature. Some userspace applications can add such an element instance by add operation with the number of elements. Then, the element instance gets a memory object to keep states of these elements. But the element instance has just one memory object for the elements. This causes the same result to each read/write operations to the different elements. This commit fixes this bug by allocating enough memory objects to the element instance for each of elements. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-04-13Merge branch 'for-next' into for-linusTakashi Iwai
2015-04-12Merge remote-tracking branches 'asoc/topic/wm2200', 'asoc/topic/wm5100', ↵Mark Brown
'asoc/topic/wm8731', 'asoc/topic/wm8804' and 'asoc/topic/wm8996' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/tegra', 'asoc/topic/tlv320aic23' ↵Mark Brown
and 'asoc/topic/ux500' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/rt5641', 'asoc/topic/rt5677' and ↵Mark Brown
'asoc/topic/sh-cleanup' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/omap', 'asoc/topic/qcom', ↵Mark Brown
'asoc/topic/rcar' and 'asoc/topic/rt286' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/link-param', ↵Mark Brown
'asoc/topic/max98090', 'asoc/topic/max98925' and 'asoc/topic/nuc900' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/jack', 'asoc/topic/jz4740' and ↵Mark Brown
'asoc/topic/kirkwood' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/dmaengine', 'asoc/topic/fsi', ↵Mark Brown
'asoc/topic/fsl' and 'asoc/topic/fsl-ssi' into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/cx20442' and 'asoc/topic/davinci' ↵Mark Brown
into asoc-next
2015-04-12Merge remote-tracking branches 'asoc/topic/4554', 'asoc/topic/ab8500', ↵Mark Brown
'asoc/topic/ak4642', 'asoc/topic/arizona' and 'asoc/topic/atmel' into asoc-next
2015-04-12Merge remote-tracking branch 'asoc/topic/rt5645' into asoc-nextMark Brown
2015-04-12Merge remote-tracking branch 'asoc/topic/intel' into asoc-nextMark Brown
2015-04-12Merge remote-tracking branch 'asoc/topic/dapm' into asoc-nextMark Brown
2015-04-12Merge remote-tracking branch 'asoc/topic/core' into asoc-nextMark Brown
2015-04-12Merge tag 'asoc-v4.1' into asoc-nextMark Brown
ASoC: Changes for v4.1 A selection of changes for v4.1 so far. The main things are: - Move of jack registration to the card where it belongs. - Support for DAPM routes specified by both the machine driver and DT. # gpg: Signature made Thu 05 Mar 2015 01:10:27 GMT using RSA key ID 5D5487D0 # gpg: WARNING: digest algorithm MD5 is deprecated # gpg: please see https://gnupg.org/faq/weak-digest-algos.html for more information # gpg: Oops: keyid_from_fingerprint: no pubkey # gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" # gpg: aka "Mark Brown <broonie@debian.org>" # gpg: aka "Mark Brown <broonie@kernel.org>" # gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" # gpg: aka "Mark Brown <broonie@linaro.org>" # gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
2015-04-12Merge remote-tracking branch 'asoc/fix/wm8741' into asoc-linusMark Brown
2015-04-12Merge remote-tracking branches 'asoc/fix/ak4642', 'asoc/fix/atmel', ↵Mark Brown
'asoc/fix/cs4271', 'asoc/fix/davinci' and 'asoc/fix/rcar' into asoc-linus
2015-04-12Merge remote-tracking branch 'asoc/fix/pcm512x' into asoc-linusMark Brown
2015-04-12Merge remote-tracking branch 'asoc/fix/intel' into asoc-linusMark Brown
2015-04-12Merge tag 'asoc-fix-v4.0-rc7' into asoc-linusMark Brown
ASoC: Last minute fix for v4.0 This patch backs out a change that came in during the merge window which selects a configuration for GPIO4 on pcm512x CODECs that may not be suitable for all systems using the device. Changes for v4.1 will make this properly configurable but for now it's safest to revert to the v3.19 behaviour and leave the pin configuration alone. Sorry for sending this direct at the last minute but due to the GPIO misuse it'd be really good to get it in the release and I'd not realised it hadn't been sent yet - between some travel, a job change and other non-urgent fixes coming in I'd lost track of the urgency. It's been in -next for several weeks now, is isolated to the driver and fairly clear to inspection. # gpg: Signature made Sat 11 Apr 2015 22:14:17 BST using RSA key ID 5D5487D0 # gpg: WARNING: digest algorithm MD5 is deprecated # gpg: please see https://gnupg.org/faq/weak-digest-algos.html for more information # gpg: Oops: keyid_from_fingerprint: no pubkey # gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" # gpg: aka "Mark Brown <broonie@debian.org>" # gpg: aka "Mark Brown <broonie@kernel.org>" # gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" # gpg: aka "Mark Brown <broonie@linaro.org>" # gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
2015-04-12ASoC: Intel: fix array_size.cocci warningskbuild test robot
sound/soc/intel/haswell/sst-haswell-ipc.c:646:28-29: WARNING: Use ARRAY_SIZE Use ARRAY_SIZE instead of dividing sizeof array with sizeof an element Semantic patch information: This makes an effort to find cases where ARRAY_SIZE can be used such as where there is a division of sizeof the array by the sizeof its first element or by any indexed element or the element type. It replaces the division of the two sizeofs by ARRAY_SIZE. Generated by: scripts/coccinelle/misc/array_size.cocci CC: Jie Yang <yang.jie@intel.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
