For both UAC1 and UAC2, interrupt endpoint messages are now parsed with
structs rather that with anonymous buffer array accesses.
For UAC2, only CUR interrupt notifications are supported for now.
snd_usb_mixer_status_complete() was renamed to
snd_usb_mixer_interrupt().
Fixed one indentation flaw on the way.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Clemens Ladisch <clemens@ladisch.de>
Commit 23caaf19b ("ALSA: usb-mixer: Add support for Audio Class v2.0")
broke support for Class1 devices due to two faulty changes. This patch
fixes it.
Reported-and-Tested-by: The Source <thesourcehim@gmail.com>
usb-midi causes sometimes Oops at snd_usbmidi_output_drain() after
disconnection. This is due to the access to the endpoints which have
been already released at disconnection while the files are still alive.
This patch fixes the problem by checking disconnection state at
snd_usbmidi_output_drain() and by releasing urbs but keeping the
endpoint instances until really all freed.
Tested-by: Tvrtko Ursulin <tvrtko@ursulin.net>
Cc: <stable@kernel.org>
The original code doesn't take into consideration that the value of
MIXART_BA0_SIZE - pos can be less than zero which would lead to a large
unsigned value for "count".
Also I moved the check that read size is a multiple of 4 bytes below
the code that adjusts "count".
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Use the call to snd_card_free in the error handling code at the end of the
function, as in the other error cases.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression E,E2;
snd_card_free(E)
E = E2
* E
// </smpl>
We actually pass an array of 7 chars not 5.
This silences a smatch warning.
Implicit slab.h inclusion via percpu.h is about to go away. Make sure
gfp.h or slab.h is included as necessary.
BugLink: https://launchpad.net/bugs/481058
The OR has verified that both 'Headphone Jack Sense' and 'Line Jack Sense'
need to be muted for sound to be audible, so just add the machine's SSID
to the ac97 jack sense blacklist.
Reported-by: Richard Gagne
Tested-by: Richard Gagne
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
The commit 4d96eb255c53ab5e39b37fd4d484ea3dc39ab456 broke the interrupt
time xrun functionality (stream stop etc.) if the CONFIG_SND_PCM_XRUN_DEBUG
is not set. This is because the xrun() is null defined without it.
Fix this by letting the function xrun() to be always defined as it was
before.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Cc: Jaroslav Kysela <perex@perex.cz>
BugLink: https://launchpad.net/bugs/303789
This model needs both 'Headphone Jack Sense' and 'Line Jack Sense'
muted for audible audio, so just add its SSID to the blacklist and
don't enumerate the controls.
This adds basic support for M-Audio's Fast Track Ultra series of USB
audio interfaces. It is a refactored version of the patch Clemens
Ladisch posted some time ago. Neither playback nor capturing work
properly at 44100 Hz (don't know why).
The other sampling rates work properly. There's no support for the DSP
mixer, yet.
Signed-off-by: Felix Homann <fexpop@web.de>
When the CMI8738 FRAME2 register is read, the chip sometimes (probably
when wrapping around) returns an invalid value that would be outside the
programmed DMA buffer. This leads to an inconsistent PCM pointer that is
likely to result in an underrun.
To work around this, read the register multiple times until we get a
valid value; the error state seems to be very short-lived.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-and-tested-by: Matija Nalis <mnalis-alsadev@voyager.hr>
Now that the EHCI driver copes with small iso packets without blowing
up, take the snd-ua101 driver out of the alpha-test stage.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Fix build errors when CONFIG_PM is not enabled:
sound/usb/card.c:629: error: 'usb_audio_suspend' undeclared here (not in a function)
sound/usb/card.c:630: error: 'usb_audio_resume' undeclared here (not in a function)
This device does not have audio controllers and backlit buttons only.
Input data is handled over a dedicated USB endpoint.
All functions are supported by the driver now.
Cc: Dmitry Torokhov <dtor@mail.ru>
The constant DMA_ACTIVE is defined with the dma_buffparams structure rather
than with the audio_operations structure. Takashi Iwai suggested that the
dmap_out field of the audio_operations structure should be used instead.
This is not tested.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
sound: sequencer: clean up remove bogus check
ALSA: hda: Use LPIB and 6stack-dig for eMachines T5212
ALSA: hda - Disable MSI for Nvidia controller
ALSA: hda - Add PCI quirks for MSI NetOn AP1900 and Wind Top AE2220
ALSA: hda - Fix secondary ADC of ALC260 basic model
ALSA: hda - Add an error message for invalid mapping NID
ALSA: hda - New Intel HDA controller
A few lines earlier bend is limited to 2399. So semitones is always
less than 24 here.
BugLink: https://bugs.launchpad.net/bugs/538895
The OR has verified that both position_fix=1 and model=6stack-dig are
necessary to have capture function properly. (The existing 3stack-6ch
model quirk seems to be incorrect.)
Reported-by: Reuben Bailey <reuben.e.bailey@gmail.com>
Tested-by: Reuben Bailey <reuben.e.bailey@gmail.com>
Judging from the member of enable_msi white-list, Nvidia controller
seems to cause troubles with MSI enabled, e.g. boot hang up or other
serious issue may come up. It's safer to disable MSI as default for
Nvidia controllers again for now.
This should make the speakers and jack detection work on MSI all-in-one
computers NetOn AP1900 and Wind Top AE2220.
Signed-off-by: Anisse Astier <anisse@astier.eu>
Fix adc_nids[] for ALC260 basic model to match with num_adc_nids.
Otherwise you get an invalid NID in the secondary "Input Source" mixer
element.
Add an error message to snd_hda_add_nid() for invalid mapping NID to make
easier to hunt the buggy code.
Also added a missing space to the error message in snd_hda_build_controls()
Added a PCI controller id on new Dell laptops.
Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com>
ALSA: hda - Sound MSI fallout on a Asus mobo NVIDIA MCP55
sound: fix opti92x-ad1848 build
ALSA: hda - Fix input source elements of secondary ADCs on Realtek
ALSA: hda - Fix wrong model range check for ALC268
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (370 commits)
ARM: S3C2443: Add set_rate and round_rate calls for armdiv clock
ARM: S3C2443: Remove #if 0 for clk_mpll
ARM: S3C2443: Update notes on MPLLREF clock
ARM: S3C2443: Further clksrc-clk conversions
ARM: S3C2443: Change to using plat-samsung clksrc-clk implementation
USB: Fix s3c-hsotg build following Samsung platform header moves
ARM: S3C64XX: Reintroduce unconditional build of audio device
ARM: 5961/1: ux500: fix CLKRST addresses
ARM: 5977/1: arm: Enable backtrace printing on oops when PC is corrupted
ASoC: Fix S3C64xx IIS driver for Samsung header reorg
ARM: S3C2440: Fix plat-s3c24xx move of s3c2440/s3c2442 support
[ARM] pxa: fix typo in mxm8x10.h
[ARM] pxa/raumfeld: set GPIO drive bits for LED pins
[ARM] pxa/zeus: Add support for mcp2515 CAN bus
[ARM] pxa/zeus: Add support for onboard max6369 watchdog
[ARM] pxa/zeus: Add Eurotech as the manufacturer
[ARM] pxa/zeus: Correct the USB host initialisation flags
[ARM] pxa/zeus: Allow usage of 8250-compatible UART in uncompress
[ARM] pxa: refactor uncompress.h for non-PXA uarts
[ARM] mmp2: fix incorrect calling of chip->mask_ack() for 2nd level cascaded IRQs
USB Audio Class v2.0 compliant devices have different descriptors and a
different way of setting/getting min/max/res/cur properties. This patch
adds support for them.
Introduce a number of new structs for mixer, selector, feature and
processing units and some static inline helpers to access fields which
have dynamic offsets. Use them in mixer.c to parse the descriptors. This
is necessary for the upcoming audio v2 parsers.
For clearer namespace, also rename usbmixer_maps.c -> mixer_maps.c
Move all non-standard mixer controls and vendor-specific extensions to a
separate file. Some structs need to be exported now.
No need for the private enum.
- Split the audio.h file in two to clearly denote the differences
between the standards.
- Add many more defines to audio-v2.h. Most of them are not currently
used.
- Replaced a magic value with a proper define
without the following patch audio ssttuutteerrs on
ASUS M2N32-SLI PREMIUM ACPI BIOS Revision 1304
the sound device is:
00:0e.1 Audio device: nVidia Corporation MCP55 High Definition Audio (rev a2)
worked with 2.6.32
Signed-off-by: Ralf Gerbig <rge@quengel.org>
arch/arm/mach-mx2/devices.c
arch/arm/mach-mx2/devices.h
sound/soc/pxa/pxa-ssp.c
Fix 'else' placement in ifdef block so that build succeeds:
sound/isa/opti9xx/opti92x-ad1848.c:221: error: 'else' without a previous 'if'
devel-stable
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ALSA: hdmi - show debug message on changing audio infoframe
ALSA: hdmi - merge common code for intelhdmi and nvhdmi
ALSA: hda - Add ASRock mobo to MSI blacklist
ALSA: hda: uninitialized variable fix
ALSA: hda: Use LPIB for a Biostar Microtech board
ALSA: usb/audio.h: Fix field order
ALSA: fix jazz16 compile (udelay)
ALSA: hda: Use LPIB for Dell Latitude 131L
ALSA: hda - Build hda_eld into snd-hda-codec module
ALSA: hda - Support NVIDIA MCP89 and GT21x hdmi audio
ALSA: hda - Support max codecs to 8 for nvidia hda controller
ALSA: riptide: clean up while loop
ALSA: usbaudio - remove debug "SAMPLE BYTES" printk line
ALSA: timer - pass real event in snd_timer_notify1() to instance callback
ALSA: oxygen: change || to &&
ALSA: opti92x: use PnP data to select Master Control port
ASoC: fix ak4104 register array access
ASoC: soc_pcm_open: Add missing bailout tag
ALSA: usbaudio: Fix wrong bitrate for Creative Creative VF0470 Live Cam
ALSA: ua101: removing debugging code
Since alc_auto_create_input_ctls() doesn't set the elements for the
secondary ADCs, "Input Source" elemtns for these also get empty, resulting
in buggy outputs of alsactl like:
control.14 {
comment.access 'read write'
comment.type ENUMERATED
comment.count 1
iface MIXER
name 'Input Source'
index 1
value 0
This patch fixes alc_mux_enum_*() (and others) to fall back to the
first entry if the secondary input mux is empty.
