path: root/sound
2006-12-07[PATCH] make 1-bit bitfields unsignedMariusz Kozlowski
Keeps sparse happy. Signed-of-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] The scheduled removal of some OSS optionsAdrian Bunk
The scheduled removal of the OSS drivers depending on OSS_OBSOLETE_DRIVER. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] sound/oss/emu10k1: handle userspace copy errorsJeff Garzik
Propagate copy_to/from_user() errors back through callers. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] sound/oss/btaudio.c: ioremap balanced with iounmapAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: incorrect VM_FAULT_OOM returns from driversNick Piggin
Some drivers are returning OOM when it is not in response to a memory shortage. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Airlie <airlied@linux.ie> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] pcmcia: IDs for Elan serial PCMCIA devciesTony Olech
Add IDs for Elan serial PCMCIA devices. In addition, move the pdaudio_cf driver from matching based on manf_id and card_id to the more specific prod_id1 and prod_id2 to avoid false positives. Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] severing poll.h -> mm.hAl Viro
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (103 commits) usbcore: remove unused argument in autosuspend USB: keep count of unsuspended children USB hub: simplify remote-wakeup handling USB: struct usb_device: change flag to bitflag OHCI: make autostop conditional on CONFIG_PM USB: Add autosuspend support to the hub driver EHCI: Fix root-hub and port suspend/resume problems USB: create a new thread for every USB device found during the probe sequence USB: add driver for the USB debug devices USB: added dynamic major number for USB endpoints USB: pegasus error path not resetting task's state USB: endianness fix for asix.c USB: build the appledisplay driver USB serial: replace kmalloc+memset with kzalloc USB: hid-core: canonical defines for Apple USB device IDs USB: idmouse cleanup USB: make drivers/usb/core/driver.c:usb_device_match() static USB: lh7a40x_udc remove double declaration USB: pxa2xx_udc recognizes ixp425 rev b0 chip usbtouchscreen: add support for DMC TSC-10/25 devices ...
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) Driver core: show drivers in /sys/module/ Documentation/driver-model/platform.txt update/rewrite Driver core: platform_driver_probe(), can save codespace driver core: Use klist_remove() in device_move() driver core: Introduce device_move(): move a device to a new parent. Driver core: make drivers/base/core.c:setup_parent() static driver core: Introduce device_find_child(). sysfs: sysfs_write_file() writes zero terminated data cpu topology: consider sysfs_create_group return value Driver core: Call platform_notify_remove later ACPI: Change ACPI to use dev_archdata instead of firmware_data Driver core: add dev_archdata to struct device Driver core: convert sound core to use struct device Driver core: change mem class_devices to be real devices Driver core: convert fb code to use struct device Driver core: convert firmware code to use struct device Driver core: convert mmc code to use struct device Driver core: convert ppdev code to use struct device Driver core: convert PPP code to use struct device Driver core: convert cpuid code to use struct device ...
2006-12-01Driver core: convert sound core to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. It also makes the struct sound_card to show up as a "real" device where all the different sound class devices are placed as childs and different card attribute files can hang off of. /sys/class/sound is still a flat directory, but the symlink targets of all devices belonging to the same card, point the the /sys/devices tree below the new card device object. Thanks to Kay for the updates to this patch. Signed-off-by: Kay Sievers <kay.sievers@novell.com> Acked-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01usb: usbmixer free kill urb cleanupMariusz Kozlowski
- usb_free_urb() cleanup - usb_kill_urb() cleanup Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01usb: usbmidi kill urb cleanupMariusz Kozlowski
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix misc Kconfig typosMatt LaPlante
Fix various Kconfig typos. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-28[ALSA] snd-emu10k1: Fix capture for one variant.James Courtier-Dutton
Fixes ALSA bug#324 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-28[ALSA] Fix hang-up at disconnection of usb-audioTakashi Iwai
Fix hang-up at disconnection of usb-audio devices while accessing PCM. Don't handle PCM operations any more after shutdown flag is set. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-28[ALSA] hda: fix typo for xw4400 PCI sub-IDJohn W. Linville
The PCI sub-device ID for the HP xw4400 is actually 0x280c. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-28[ALSA] hda: fix sigmatel dell system detectionMatt Porter
Fixes Dell system detection on 9200 codecs. The support to detect certain Dell machines was merged in the 9205 table where it will be unused on the various Dell 9200-based codec systems. This moves the subsystem IDs to the correct 9200 table. Signed-off-by: Matt Porter <mporter@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-28[ALSA] Enable stereo line input for TAS codecPaul Mackerras
Despite what the data sheet says in one place, to get stereo input from input A (line in), we have to clear the 'input B monaural' bit in the ACR. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-28[ALSA] rtctimer: handle RTC interrupts with a taskletClemens Ladisch
The calls to rtc_control() from inside the interrupt handler can upset the RTC code, so move our interrupt handling code to a tasklet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-14[PATCH] ALSA: hda-intel - Disable MSI support by defaultTakashi Iwai
Disable MSI support on HD-audio driver as default since there are too many broken devices. The module option is changed from disable_msi to enable_msi, too. For turning MSI support on, pass enable_msi=1, instead. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-24[PATCH] Merge headphone and speaker volume controls for Panasonic R4 laptopKeith Packard
Signed-off-by: Keith Packard <keithp@neko.keithp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-23Merge branch 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsa: [ALSA] hda-intel - Add check of MSI availabity [ALSA] version 1.0.13 [ALSA] Fix addition of user-defined boolean controls [ALSA] Fix AC97 power-saving mode [ALSA] Fix re-use of va_list [ALSA] hda_intel: add ATI RS690 HDMI audio support [ALSA] hda-codec - Add model entry for ASUS U5F laptop [ALSA] Fix dependency of snd-adlib driver in Kconfig [ALSA] Various fixes for suspend/resume of ALSA PCI drivers [ALSA] hda-codec - Fix assignment of PCM devices for Realtek codecs [ALSA] sound/isa/opti9xx/opti92x-ad1848.c: check kmalloc() return value [ALSA] sound/isa/ad1816a/ad1816a.c: check kmalloc() return value [ALSA] sound/isa/cmi8330.c: check kmalloc() return value [ALSA] sound/isa/gus/interwave.c: check kmalloc() return value
2006-10-23[ALSA] hda-intel - Add check of MSI availabityTakashi Iwai
Check the availability of MSI and turn off MSI automatically when it's not available on the hardware. MSI seems broken on some hardwares but the kernel doesn't know exactly, thus we have to turn the MSI feature off on the sound driver manually. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Fix addition of user-defined boolean controlsTakashi Iwai
Fixed the addition of user-defined boolean controls, the private data size is corrected to be handled properly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Fix AC97 power-saving modeTakashi Iwai
Fix the bug in AC97 power-saving mode that the power isn't turned on when power_save is set to 1 via sysfs during the power off state. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Fix re-use of va_listTakashi Iwai
The va_list is designed to be used only once. The current code may pass va_list arguments multiple times and may cause Oops. Copy/release the arguments temporarily to avoid this problem. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] hda_intel: add ATI RS690 HDMI audio supportFelix Kuehling
This patch adds support for the HDMI codec of the ATI RS690 IGP northbridge. Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] hda-codec - Add model entry for ASUS U5F laptopTakashi Iwai
Added a model entry for ASUS U5F laptop with AD1986A codec. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Fix dependency of snd-adlib driver in KconfigTakashi Iwai
Added the missing dependency on CONFIG_SND for snd-adlib driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Various fixes for suspend/resume of ALSA PCI driversTakashi Iwai
- Check the return value of pci_enable_device() and request_irq() in the suspend. If any error occurs there, disable the device using snd_card_disconnect(). - Call pci_set_power_state() properly with pci_choose_state(). - Fix the order to call pci_set_power_state(). - Removed obsolete house-made PM codes in some drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] hda-codec - Fix assignment of PCM devices for Realtek codecsTakashi Iwai
Fixed the assignment of PCM devices for Realtek codecs. The secondary analog capture should be statically asigned to the third device regardless whether SPDIF exists or not. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/opti9xx/opti92x-ad1848.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_card_opti9xx_pnp(), in file sound/isa/opti9xx/opti92x-ad1848.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/ad1816a/ad1816a.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_card_ad1816a_pnp(), in file sound/isa/ad1816a/ad1816a.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/cmi8330.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_cmi8330_pnp(), in file sound/isa/cmi8330.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/gus/interwave.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_interwave_pnp(), in file sound/isa/gus/interwave.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-19sh: Cleanup board header directories.Paul Mundt
Now with the ide.h mess sorted out, most of these boards don't need their own directory. Move the headers out, and update the driver paths. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-10-10[PATCH] hwdep_compat missed __user annotationsAl Viro
2006-10-09Merge branch 'irqclean-submit1' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'irqclean-submit1' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6: drivers/isdn/act2000: kill irq2card_map drivers/net/eepro: kill dead code Various drivers' irq handlers: kill dead code, needless casts drivers/net: eliminate irq handler impossible checks, needless casts arch/i386/kernel/time: don't shadow 'irq' function arg
2006-10-08[PATCH] missing include in pdaudiocf_irqAl Viro
2006-10-08[PATCH] misc arm pt_regs fixesAl Viro
2006-10-06Merge branch 'submit1' of viper:/spare/repo/irq-remove-2.6 into irqcleanupsJeff Garzik
2006-10-06Various drivers' irq handlers: kill dead code, needless castsJeff Garzik
- Eliminate casts to/from void* - Eliminate checks for conditions that never occur. These typically fall into two classes: 1) Checking for 'dev_id == NULL', then it is never called with NULL as an argument. 2) Checking for invalid irq number, when the only caller (the system) guarantees the irq handler is called with the proper 'irq' number argument. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-06[ALSA] sound/pci/au88x0/au88x0.c: ioremap balanced with iounmapAmol Lad
Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-06[ALSA] Handle file operations during snd_card disconnects using static ↵Karsten Wiese
file->f_op Alsa used to kmalloc one file->f_op per file per disconnecting snd_card. This led to oopses sometimes when file->f_op was freed before __fput() finished. Patch adds a virtual device for disconnect: VDD. VDD consists of: LIST_HEAD(shutdown_files) protected by DEFINE_SPINLOCK(shutdown_mutex) static struct file_operations snd_shutdown_f_ops and functions assigned to it Additions to struct snd_monitor_file to specify if instance is hidden by VDD or not. A VDD's instance is created in snd_card_disconnect() under the card->files_lock. cleaned up in snd_card_file_remove() under the card->files_lock. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
