Modules: ALSA Core,ALSA<-OSS emulation
Remove a global function snd_task_name(), and move it local
to snd-pcm-oss module.
Modules: Documentation,PCM Midlevel,Timer Midlevel,ALSA Core
Use the standard getnstimeofday() function instead of ALSA's own one.
Remove snd_runtime_check() macro.
This macro worsens the readability of codes. They should be either
normal if() or removable asserts.
Also, the assert displays stack-dump, instead of only the last caller
pointer.
Modules: Intel8x0-modem driver,VIA82xx-modem driver,HDA Codec driver
Signed-off-by: Sasha Khapyorsky <sashakh@alsa-project.org>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Modules: Intel8x0 driver
On my Acer Aspire 3003LCi laptop, the speaker volume is not controlled
by the master control, but by the headphone control. Enabling the
'hp_only' quirk corrects this. The patch below adds this device to the
list of known quirks.
Signed-off-by: Dick Streefland <dick@streefland.net>
Modules: ICE1724 driver
Remove the restcition of sample rates on Revolution 7.1 board.
This enables the low 8-44kHz sample rates.
Added dummay obsoleted module options for backward compatibility
(to reduce possible bugzilla entries :)
Suppress the codec warnings during probing of codecs.
Remove the code for supporting eight cards from the integrated
controller drivers because There Can Be Only One controller of
each type per mainboard.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Modules: Sound Core,PCI drivers
AC97 Kconfig entries broke the ALSA device drivers menu,
so move them to a location where that won't happen,
enabling all device sub-menus to be presented together.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This patch cleans last ac97 audio/modem codec interception in
initialization procedures (ac97_mixer_new()) and removes obsolete
SHARED_TYPE 'locking' which prevents from AMC codecs to function
correctly.
Signed-off-by: Sasha Khapyorsky <sashak@smlink.com>
dev_class=SNDRV_PCM_CLASS_MODEM for all supported softmodem PCMs
Modules: YMFPCI driver
This patch adds a new mixer control called 'IEC958 Loop' which makes
it possible to loop digital signals from S/PDIF-in to S/PDIF-out.
Signed-off-by: Glen Masgai <mimosius@gmx.de>
Modules: ALSA sequencer
Remove the last parameter of snd_seq_timer_set_tick_resolution()
because it is always one.
Modules: RTC timer driver
The check whether rtctimer_freq is a power of two can be done easier
with a simple bit operation.
The rtc_inc variable is never used outside the interrupt handler, and
is always one where it matters, so we can just remove it.
Modules: USB generic driver
Move the usb_complete_callback() compatibility wrapper out of the
kernel tree.
Move the usb_pipe_needs_resubmit() compatibility wrapper out of the
kernel tree.
Add more comments about other device modes and unsupported devices to
the Roland part of the quirks table.
Modules: au88x0 driver
This patch extends au88x0 AC97 codec access procedures to handle multiple
codecs properly.
Modules: HDA Codec driver
Added a new model 'fujitsu' to ALC260 config for Fujitsu S7020.
Add a quirk entry for the Hercules DJ Console to ignore timeouts on
some mixer control transfers.
Simplify the handling of MIDI quirks by treating an interface without
quirks as a QUIRK_MIDI_STANDARD_INTERFACE.
This also fixes the bug where a MIDI_STANDARD quirk would not be
recognized.
Modules: CMIPCI driver
If possible, use ports in the card's PCI port address range instead of
the legacy ports.
Modules: HDA Intel driver
This patch is to make the Intel HDA code work for NVIDIA azalia controller.
Modified by Takashi Iwai <tiwai@suse.de>
Signed-off-by: Vinod G. <vinodg@nvidia.com>
Modules: AC97 Codec
Fix a typo in the last patch.
Modules: AC97 Codec
- Fixed surround controls of CMI9761 (model 83) in update_jacks callback.
- Clean up ad1888 and ad1985 update_jacks callbacks.
Modules: EMU10K1/EMU10K2 driver
Adds left and right front channel outputs using fxbus 8 and 9 and 'Front'
playback and capture volume controls.
Signed-off-by: Mikael Magnusson <mikma@users.sourceforge.net>
This adds the magic IO wakeup code for the CardBus version of the
Creative Labs Audigy 2 to the snd-emu10k1 driver.
Without the magic IO enable sequence, reading from the IO region of the
card will fail spectacularly, and the machine will hang.
My next task will be getting the driver to actually play sound without
distortion.
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
[ This is a work-in-progress, but since it avoids a total lockup
if the emu10k module is loaded on a machine with the cardbus
card inserted, we're better off with it than without it, even
if sound quality is bad right now ]
Manual #include fixups for clashes - there may be some unnecessary
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Typo fix: dots appearing after a newline in printk strings.
Removed some more references to check_region().
I checked these changes into the 'checkreg' branch of
rsync://rsync.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6.git
The only valid references remaining are in:
drivers/scsi/advansys.c
drivers/scsi/BusLogic.c
drivers/cdrom/sbpcd.c
sound/oss/pss.c
Remove last vestiges of ide_check_region()
drivers/char/specialix: trim trailing whitespace
drivers/char/specialix: eliminate use of check_region()
Remove outdated and unused references to check_region()
[sound oss] remove check_region() usage from cs4232, wavfront
[netdrvr eepro] trim trailing whitespace
[netdrvr eepro] remove check_region() usage
Remove PageReserved() calls from core code by tightening VM_RESERVED
handling in mm/ to cover PageReserved functionality.
PageReserved special casing is removed from get_page and put_page.
All setting and clearing of PageReserved is retained, and it is now flagged
in the page_alloc checks to help ensure we don't introduce any refcount
based freeing of Reserved pages.
MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being
deprecated. We never completely handled it correctly anyway, and is be
reintroduced in future if required (Hugh has a proof of concept).
Once PageReserved() calls are removed from kernel/power/swsusp.c, and all
arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can
be trivially removed.
Last real user of PageReserved is swsusp, which uses PageReserved to
determine whether a struct page points to valid memory or not. This still
needs to be addressed (a generic page_is_ram() should work).
A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and
thus mapcounted and count towards shared rss). These writes to the struct
page could cause excessive cacheline bouncing on big systems. There are a
number of ways this could be addressed if it is an issue.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Refcount bug fix for filemap_xip.c
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
pci_ids cleanup: replace symbols built by macros with whole symbols to
aid grep searches.
Signed-off-by: Grant Coady <gcoady@gmail.com>
drivers/video/cirrusfb.c | 24 ++++++++++++------------
sound/oss/ymfpci.c | 17 +++++++++--------
sound/pci/bt87x.c | 11 +++++++----
3 files changed, 28 insertions(+), 24 deletions(-)
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Input: convert sound/ppc/beep to dynamic input_dev allocation
This is required for input_dev sysfs integration
The previous patch adding the ability to nest struct class_device
changed the paramaters to the call class_device_create(). This patch
fixes up all in-kernel users of the function.
Minor manual fixups for gfp_t clashes.
The patch fixes Oops from sound drivers using generic platform device
but have no suspend/resume callbacks.
