path: root/sound
2010-02-12Merge branch 'fix/hda' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - use WARN_ON_ONCE() for zero-division detection
2010-02-12ALSA: hda - use WARN_ON_ONCE() for zero-division detectionTakashi Iwai
Replace the zero-division warning message with WARN_ON_ONCE() per the advice by Linus. This shouldn't happen, but if it happens, it's possible that the bug happens often due to buggy IRQs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda-intel: Avoid divide by zero crash
2010-02-09ALSA: hda-intel: Avoid divide by zero crashJody Bruchon
On my AMD780V chipset, hda_intel.c can crash the kernel with a divide by zero for as-yet unknown reasons. A simple check for zero prevents it, though the problem that causes it remains. Since the workaround is harmless and won't affect anyone except victims of this bug, it should be safe; moreover, because this crash can be triggered by a user-mode application, there are denial of service implications on the systems affected by the bug without the patch. Signed-off-by: Jody Bruchon <jody@nctritech.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-05Merge remote branch 'alsa/fixes' into for-linusTakashi Iwai
2010-02-05Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-02-05Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-02-05ASoC: pandora: Add APLL supply to fix audio outputGrazvydas Ignotas
Pandora's external DAC is using 256*Fs output from the TWL4030 codec, and TWL4030 needs to have APLL enabled for it's 256*Fs output to function. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-05ALSA: ice1724 - aureon - fix wm8770 volume offsetJaroslav Kysela
The volume register is from 0..0x7f and 0..0x1a range is mute. Also, fix mute combining in wm_vol_put(). The wrong behaviour was noticed by Peter Christensen. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-05ALSA: cosmetic: make hda intel interrupt name consistent with othersMaxim Levitsky
This renames the interrupt name in /proc/interrupt. HDA Intel -> hda_intel This also eliminates space from the name, probably helping some parsers. Don't think anybody depends on this name in userspace Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-05ALSA: hda - Delay switching to polling mode if an interrupt was missingMaxim Levitsky
My sound codec seems sometimes (very rarely) to omit interrupts (ALC268) However, interrupt mode still works. Thus if we get timeout, poll the codec once. If we get 3 such polls in a row, then switch to polling mode. This patch is maybe an bandaid, but this might be a workaround for hardware bug. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-04ALSA: ctxfi - fix PTP address initializationJaroslav Kysela
After hours of debugging, I finally found the reason why some source and runtime combination does not work. The PTP (page table pages) address must be aligned. I am not sure how much, but alignment to PAGE_SIZE is sufficient. Also, use ALSA's page allocation routines to ensure proper virtual -> physical address translation. Cc: <stable@kernel.org> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-31Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-01-31Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-01-29ASoC: AM3517: ASoC driver not getting compiledAnuj Aggarwal
Commit 761c9d45 (ASoC: Fix build of OMAP sound drivers) changes CONFIG_MACH_OMAP3517EVM -> CONFIG_SND_OMAP_SOC_OMAP3517EVM in the Makefile. Whereas the config option defined in Kconfig is SND_OMAP_SOC_AM3517EVM. Because of this, ASoC driver for AM3517 was not getting compiled. Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-01-29ASoC: AIC23: Fixing writes to non-existing registers in resume functionAnuj Aggarwal
Commit e9ff5eb2 (Fixing infinite loop in resume path) uses wrong AIC23 register in resume function because of which register writes happen on some non-existing registers. Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-01-27ALSA: hda - Add an ASUS mobo to MSI blacklistTakashi Iwai
Sid Boyce reported that his machine locks up without enable_msi=0 option. This looks like another ASUS mobo with Nvidia combo. Reported-by: Sid Boyce <sboyce@blueyonder.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-25Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-01-25ASoC: fix a memory-leak in wm8903Guennadi Liakhovetski
Remember to free the temporary register-cache. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-01-25ALSA: hda - add possibility to choose speakers configuration for 4930gŁukasz Wojniłowicz
Now one can choose speaker configuration in e.g. PulseAudio mixer Signed-off-by: Łukasz Wojniłowicz <lukasz.wojnilowicz@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-20ALSA: hda - Fix HP T5735 automuteTakashi Iwai
This patch fixes the aut-mute setup on HP T5735 with ALC262 codec. Instead of wrong amp, use pin control toggling for muting the speaker now. Tested-by: Lee Trager <lee.trager@hp.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-19ALSA: hda - Turn on EAPD only if available for Realtek codecsTakashi Iwai
Some codecs disable widgets used for output pins and reserve as vendor- spec widgets. Thus we need to check the widget type and pin cap before actually sending SET_EAPD verbs in the auto-configuration mode. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-19ALSA: hda - Fix parsing pin node 0x21 on ALC259Takashi Iwai
ALC259 has a widget NID 0x21 for the output pin, but it wasn't handled properly in alc268_new_analog_output(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-18Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-01-18ALSA: Remove warning message for invalid OSS minor rangesTakashi Iwai
When a card instance with a higher card number is registered, warning messages are spewed eventually with stack traces due to the invalid minor number for OSS device registration. For example, thinkpad-acpi registers the card number 29 as default, and you'll see always these messages. This is rather confusing (and worries users), thus better to return simply the error code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-17ALSA: hda - Fix capture on Sony VAIO with single inputTakashi Iwai
Sony VAIO VGN-P11G with ALC262 codec has only one input pin, and the recording doesn't work with model=auto because ALC262 parser sets the wrong cap NIDs to choose the route and the default route for the sole input pin wasn't initialized properly. This patch solves these issues. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-15ALSA: hda - Fix mute led GPIO on HP dv-series notebooksKunal Gangakhedkar
On my laptop (HP dv6-1110ax), there are no OEM strings in SMBIOS of type "HP_Mute_LED*". Hence, the GPIO for the mute button LED doesn't get set properly. I didn't find the strings in my cousin's laptop (HP dv9500t CTO) either. As per the documentation of find_mute_led_gpio(), these strings occur in HP B-series systems - so, before scanning the SMBIOS strings, we need to check if we're dealing with a B-series system. Need to get confirmation from HP if this logic takes care of all the systems. I'm trying to poke a friend there. Signed-off-by: Kunal Gangakhedkar <kunal.gangakhedkar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-14ALSA: use subsys_initcall for sound core instead of module_initThadeu Lima de Souza Cascardo
This is needed for built-in drivers which are built before the sound directory, like thinkpad_acpi. Otherwise, registering a card fails. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-14ALSA: hda - Fix missing capture mixer for ALC861/660 codecsTakashi Iwai
The capture-related mixer elements are missing with ALC861/ALC660 codecs when quirks are present, due to missing call of set_capture_mixer(). Reference: Novell bnc#567340 http://bugzilla.novell.com/show_bug.cgi?id=567340 Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2010-01-13ALSA: hda - Improved MacBook (Pro) 5,1 / 5,2 supportAlex Murray
This patch adds support for automatically muting the speakers when headphones are inserted, as well as relabelling the headphone widgets from the non-standard "HP" to the standard "Headphone" for the mb5 model. Signed-off-by: Alex Murray <murray.alex@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-13ALSA: hda - Fix Toshiba NB20x quirk entryTakashi Iwai
The alc664-mode4 model doesn't seem to fit with Toshiba NB205 correctly. NB205 uses the pin 0x17 connected with the mixer 0x0f for the speaker output, which isn't controlled by mode4 model at all. Rather model=auto works fine as is on the latest driver, so let it back again. Tested-by: Nickolas Lloyd <ultrageek.lloyd@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-12Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-01-12Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-01-12ALSA: hda - Fix ALC861-VD capture source mixerTakashi Iwai
The capture source or input source mixer element wasn't created properly for ALC861-VD codec due to the wrong NID passed to alc_auto_create_input_ctls(). References: Novell bnc#568305 http://bugzilla.novell.com/show_bug.cgi?id=568305 Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2010-01-12Merge remote branch 'alsa/fixes' into fix/miscTakashi Iwai
2010-01-10ALSA: ac97: add AC97 STMicroelectronics' codecsKrzysztof Helt
Add the STMicroelectronics ST7597 codec and an unknown codec from the same manufacturer found on the Creative SB 128 card (CT4810). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-10ALSA: ac97: Add Dell Dimension 2400 to Headphone/Line Jack Sense blacklistDaniel T Chen
This model needs both 'Headphone Jack Sense' and 'Line Jack Sense' muted for audible playback, so just add it to the ad1981 jack sense blacklist. Cc: stable@kernel.org Tested-by: Pete <x41215201@gmail.com> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-08ASoC: Fix WM8350 DSP mode B configurationMark Brown
We need to set the LRCLK inversion bit to select DSP mode. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Cc: stable@kernel.org
2010-01-08sbawe: fix memory detection part 2Krzysztof Helt
The patch "sbawe: fix memory detection" fixed detection for memoryless SB32 cards but broke detection of memory above 512KB. This patch fixes the regression. The patch has been tested on the SB32 card (CT3670) with 0MB, 2MB and 8MB memory installed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-08Merge branch 'master' of ↵Jaroslav Kysela
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into fixes
2010-01-08sound: oss: off by one bugDan Carpenter
The problem is that in the original code sound_nblocks could go up to 1024 which would be an array overflow. This was found with a static checker and has been compile tested only. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-05Merge branch 'for-2.6.33' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 * 'for-2.6.33' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6: ASoC: fixup oops in generic AC97 codec glue ASoC: fix params_rate() macro use in several codecs ASoC: fsi-ak4642: Remove ak4642_add_i2c_device
2010-01-04ASoC: fixup oops in generic AC97 codec glueManuel Lauss
Initialize the glue by calling snd_soc_new_ac97_codec() as is done in other ASoC AC97 codecs. Fixes an oops caused by dereferencing uninitialized members in snd_soc_new_pcms(). Run-tested on Au1250. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-28ALSA: usb-audio - Avoid Oops after disconnectTakashi Iwai
As the release of substreams may be done asynchronously from the disconnection, close callback needs to check the shutdown flag before actually accessing the usb interface. Reference: Novell bnc#505027 http://bugzilla.novell.com/show_bug.cgi?id=565027 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: test off by one in setsamplerate()Roel Kluin
With `while (i++ < MAX_WRITE_RETRY)' i reaches MAX_WRITE_RETRY + 1 after the loop Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: atiixp: Specify codec for Foxconn RC4107MA-RS2Daniel T Chen
BugLink: https://bugs.launchpad.net/ubuntu/+bug/498863 This mainboard needs ac97_codec=0. Cc: stable@kernel.org Tested-by: Apoorv Parle <apparle@yahoo.co.in> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-27Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-12-27ALSA: hda - Fix Oops at reloading beep devicesTakashi Iwai
The recent change for supporting dynamic beep device allocation caused a problem resulting in Oops at reloading the driver. Also, it ignores the error from input device registration. This patch fixes the wrong check in snd_hda_detach_beep_device(), and returns an error when the input device registration fails properly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-27ALSA: hda - Don't cache beep controlsTakashi Iwai
The beep control verbs don't need to be cached for resume. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-26Merge commit 'v2.6.33-rc2' into for-2.6.33Mark Brown
