Kernel 2.6.18 broke the MotU Fastlane, which uses duplicate endpoint
numbers in a manner that is not only illegal but also confuses the
kernel's endpoint descriptor caching mechanism. To work around this, we
have to add a separate usb_set_interface() call to guide the USB core to
the correct descriptors.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-and-tested-by: David Fries <david@fries.net>
Cc: <stable@kernel.org>
Renamed the old quirk function for ua-700/ua-25 to become more
generic, moving the MIDI interfaces to the quirk data header.
Added a new quirk for the Edirol UA-4FX.
Signed-off-by: Pedro Lopez-Cabanillas <pedro.lopez.cabanillas@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Added the ignore_ctl_error parameter to enable/disable the control-error
handling for mixer interfaces. It was a hard-coded ifdef, and now you
can change it more easily.
Added a new US122L usb-audio driver. This driver works together with a
dedicated alsa-lib plugin.
This patch implements suspend/resume support for USB audio devices.
It works with the microphone in my camera.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Added support for the Edirol UA-101 (only in high-speed mode) by taking
the quirks for the UA-1000 and change them accordingly. Changes were
made in 'usbaudio.c', 'usbaudio.h', and 'usbquirks.h'
MIDI and recording seem to work perfectly (with JACK), but playback
gives some few glitches. I think that's the mentioned
synchronizing-problem in the UA-1000 quirk ('FIXME: playback must be
synchronized to capture'), so I didn't change that.
ToDo: Adding Mixer-Support for the built-in
control-panel/patch-bay/router.
Signed-off-by: Bjoern Fay <mail@bfay.de>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Removed the CS_AUDIO_* #defines, which were duplicates of the
class-specific USB_DT_CS_* #defines in <linux/usb_ch9.h>.
Signed-off-by: Ben Williamson <ben.williamson@greyinnovation.com>
Modules: USB generic driver
Rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CME because Miditech keyboards
are built by CME and use the same protocol, and don't force a Miditech
product name for the USB ID used by both Miditech and CME UF-x
keyboards.
Remove xxx_t typedefs from the USB-Audio driver.
Move the usb_complete_callback() compatibility wrapper out of the
kernel tree.
Move the usb_pipe_needs_resubmit() compatibility wrapper out of the
kernel tree.
USB generic driver
Make the quirk type an enum instead of a #defined integer, and use a
table for the quirk constructor functions instead of a big switch
statement.
USB generic driver
Add support for Miditech Midistart and MidiStudio keyboards (another
case of devices using the standard protocol but having no descriptors).
USB generic driver
Rename the protocol used by the MOTU FastLane to 'raw' because it might
be useful with other devices, and there are other MOTU interfaces that
do not use this protocol.
USB generic driver
Cache the decoded values of idVendor/idProduct to get rid of most of
those ugly le16_to_cpu() calls.
USB generic driver
Move all data related to audio control interfaces into a separate struct
local to usbmixer.c.
USB generic driver,USB USX2Y
This patch removes the superfluous driver parameter from the
disconnect functions.
infrastructure for it.
Let it rip!
