path: root/sound/usb/proc.c
2012-04-21ALSA: snd-usb: remove refactorization left-oversDaniel Mack
Drop some struct members and definitions that became obsolete during the refactorization of the driver. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: usb: Remove obsoleted fields from struct snd_usb_substreamTakashi Iwai
Many fields have been moved to struct snd_usb_endpoint. Also fix the proc output to correspond to the new structure. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-27ALSA: usb-audio: automatically detect feedback formatClemens Ladisch
There are two USB Audio Class specifications (v1 and v2), but neither of them clearly defines the feedback format for high-speed UAC v1 devices. Add to this whatever the Creative and M-Audio firmware writers have been smoking, and it becomes impossible to predict the exact feedback format used by a particular device. Therefore, automatically detect the feedback format by looking at the magnitude of the first received feedback value. Also, this allows us to get rid of some special cases for E-Mu devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-14ALSA: usb: USB3 SuperSpeed sound supportPaul Zimmerman
This is V2 of the patch, after feedback from Clemens and Daniel. This patch adds SuperSpeed support to the USB drivers under sound/. It adds tests for USB_SPEED_SUPER to the appropriate places that check for the USB speed. This patch has been tested with our SS USB3 device emulating a set of Yamaha speakers and a Logitech microphone, but with the descriptors modified to add USB3 support. It has also been tested with the real speakers and microphone, to make sure that USB2 devices still work. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: use a format bitmask per alternate settingClemens Ladisch
In preparation for USB audio 2.0 support, change the audioformat structure so that it uses a bitmask to specify possible formats. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: rename substream format field to altset_idxClemens Ladisch
The snd_usb_substream::format field actually contains the index of the current alternate setting, so rename it to altset_idx to avoid confusion. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
