'asoc/fix/simple', 'asoc/fix/wm5110' and 'asoc/fix/wm8960' into asoc-linus
'asoc/fix/mxs-saif', 'asoc/fix/qcom' and 'asoc/fix/rt286' into asoc-linus
'asoc/fix/dpcm', 'asoc/fix/dwc', 'asoc/fix/fsl' and 'asoc/fix/fsl-ssi' into asoc-linus
When the FLL is in pseudo-fractional mode there is an additional
limit on fref based on the fratio, to prevent aliasing around the
Nyquist frequency. If fref exceeds this limit the refclk divider
must be increased and the calculation tried again until a suitable
combination of fref and fratio is found or we have to fall back to
integer mode.
This patch also adds some debug log prints around this code.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Forwarding the return value of i2c_master_send, leads to errors
later on, since i2c_master_send returns the number of bytes
transmittet. Check for ret < 0 instead and return 0 otherwise.
Signed-off-by: Pascal Huerst <pascal.huerst@gmail.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
The match module lacked module license and description, so add it
Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
DPCM driver is recommended for BYT, CHT based platforms, so if
CONFIG_SND_SST_IPC_ACPI is selected then don't compile the BYT
Device IDs in common ACPI driver to avoid probe conflicts.
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Acked-by: Jie Yang <yang.jie@intel.com>
The ACPI match module is common to all three drivers, HSW, SKL
and Atom-DPCM driver. But Atom-DPCM driver does not use common
sst code so we cannot include the common SST module in Atom-DPCM
driver.
So the solution is to have a independent sst-match-acpi module
which helps in matching for all the three drivers. Now all driver
can be inbuilt in a single image
This patch really fixes the regression introduced by the
commit 95f098014815 ("ASoC: Intel: Move apci find machine routines")
driver"
This reverts commit dc901a354171 ("ASoC: Intel: fix ACPI probe
regression with Atom DPCM driver") as the fix prevented the probe
on HSW/BDW if Atom-DPCM was selected
The driver used autosuspend delay to delay going to D3. But per
HW recommendation we should go to D3 soon, so remove the delay
from driver
Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com>
DMIC BE can have 2 or 4 channels supported. The DMIC fixup needs
to take this into account.
Signed-off-by: Jeeja KP <jeeja.kp@intel.com>
Some modules may be directly connected to a pipeline without a
mixer module. For these modules, we require PRE_PMU and POST_PMU
handler which will do bind between the pipelines, so add these
missing handlers.
skl_tplg_bind_sinks() takes only the first sink widget. This
breaks in case we have multiple sinks for a module.
So pass source widget to skl_tplg_bind_sinks() and bind for all
sinks by calling this recursively
We should not stop the sink pipe in it's pmd handler for a mixin
module as this module may still be connected to other pipes.
This will be stopped and freed by current implementation on last
connected pipe unbind.
For binding modules we should check if source or destination
module is in UNINT state. We canot bind even if one of them is
in this state.
So update the check from logical AND to logical OR and do not
bind modules for this case
In unbind modules, the skl_get_queue_index() can return error
if the pin is dynamic and module is not bound yet. So instead
of returning error this check should return success as modules
is not yet bound. This will let the module be bound when connected
pipes are enabled and will bind this as well.
So change the return value to 0
We check and allocate pipeline resources in one shot. That causes
leaks if module creation fails later as that is not freed.
So split the resource allocation into two, first check if
resources are available and then add the resources upon
successful creation. So two new functions are added for checking
and current functions are re-purposed to only add the resources
for memory and MCPS.
Signed-off-by: Dharageswari.R <dharageswari.r@intel.com>
While cleaning resources on module pmd event, we check for return
of skl_unbind_modules(). On failure this causes leak as all modules
attached do not have resources freed.
So ignore return value of module unbind and continue freeing
resources. This makes dapm state and resources correct.
Signed-off-by: Guneshwor Singh <guneshwor.o.singh@intel.com>
When delay reported by HW is equal to buffersize, it means the
value is wrapped so we should report as 0. So add the condition
to check this while reporting the delay from LPIB.
TLV buffer can be smaller than the module data, so update the
size of data to be copied before doing the copy.
Also TLV header consists of two unsigned ints, this is also taken
into account here and size modified to reflect this
Suggested-by: Takashi Iwai <tiwai@suse.de>
When a DAPM context has a prefix the autodisable widgets get prefixed
twice, once for the control and once for the widget. To avoid this use
the un-prefixed control name to construct the autodisable widget name.
This change is purely cosmetic.
Commit a106804 ("ASoC: compress: Fix compress device direction check")
added a dependency on the compress-cpu-dai channel_min field
which was removed earlier by commit 77095796
("ASoC: Intel: Atom: clean-up compressed DAI definition")
as part of the baytrail cleanups.
The net result was a regression at probe on all Atom platforms
with no sound card created.
Fix by adding explicit initialization for channel_min to 1
for the compress-cpu-dai.
Reported-by: Tobias Mädel <alsa-devel@tbspace.de>
While performing hw_free, DPCM checks the BE state but leaves out
the suspend state. The suspend state needs to be checked as well,
as we might be suspended and then usermode closes rather than
resuming the audio stream.
This was found by a stress testing of system with playback in
loop and killed after few seconds running in background and second
script running suspend-resume test in loop
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Cc: stable@vger.kernel.org
In the case that the driver is configured from device-tree
i2s_reg_comp1 and i2s_reg_comp2 aren't initialised, breaking the driver.
Fix this by unconditionally setting these values before checking for quirks.
Fixes: a242cac1d3aa ("ASoC: dwc: add quirk to override COMP_PARAM_1 register")
Signed-off-by: Jon Medhurst <tixy@linaro.org>
Commit e22579713ae1 ("ASoC: simple card: set cpu-dai sysclk
with mclk-fs") added sysclk / SND_SOC_CLOCK_OUT setting, that makes
asoc_simple_card_hw_params fail if the operation is not supported,
although the intention clearly was to ignore ENOTSUPP. Fix it.
The patch fixes audio playback on Kirkwood / OpenRD client,
where the following errors are seen:
asoc-simple-card sound: ASoC: machine hw_params failed: -524
alsa-lib: /alsa-lib-1.0.28/src/pcm/pcm_hw.c:327:(snd_pcm_hw_hw_params) SNDRV_PCM_IOCTL_HW_PARAMS failed (-524): Unknown error 524
Fixes: e22579713ae1 ("ASoC: simple card: set cpu-dai sysclk with mclk-fs")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The clk_prepare() call in hw_params() has no matching clk_unprepare(),
leaving the clk with an ever-increasing prepare count. Moreover,
hw_params() can be called multiple times which would again leave us
with a runaway prepare count. Fix this by moving the clk_prepare()
call to the startup() function and adding a shutdown() function with
a matching clk_unprepare() as these operations are already correctly
bracketed by soc-core.
Signed-off-by: Mans Rullgard <mans@mansr.com>
When registering a ASoC card the driver data of the parent device is set to
point to the card. This driver data is used in the
snd_soc_suspend()/resume() callbacks.
The imx-spdif driver overwrites the driver data with custom data which
causes snd_soc_suspend() to crash. Since the custom driver is not used
anywhere simply deleting the line which sets the custom driver data fixes
the issue.
Fixes: 43ac946922b3 ("ASoC: imx-spdif: add snd_soc_pm_ops for spdif machine driver")
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
There is no guarantee that on fsl_ssi module load
SSI registers will have their power-on-reset values.
In fact, if the driver is reloaded the values in
registers will be whatever they were set to previously.
However, the cache needs to be fully populated at probe
time to avoid non-atomic allocations during register
access.
Special case here is imx21-class SSI, since
according to datasheet it don't have SACC{ST,EN,DIS}
regs.
This fixes hard lockup on fsl_ssi module reload,
at least in AC'97 mode.
Fixes: 05cf237972fe ("ASoC: fsl_ssi: Add driver suspend and resume to support MEGA Fast")
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
With the introduction of WM8960_SYSCLK_AUTO mode, WM8960_SYSCLK_PLL mode was
made unusable. Ensure we're not PLL mode before trying to use MCLK.
Fixes: 3176bf2d7ccd ("ASoC: wm8960: update pll and clock setting function")
Signed-off-by: Stuart Henderson <stuart.henderson@cirrus.com>
Reviewed-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
INBMIX1 controls LINPUTs and INBMIX2 controls RINPUTs, so fix the naming
accordingly.
The driver was not unregistering the compressed platform in
wm5110_remove(). If the codec is built as a module, this would
lead to a NULL pointer deref if the module was unloaded and then
re-probed.
If snd_soc_tplg_component_load() fails we just printed an error message
and returned the error code but we missed releasing the firmware.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
The newly added rt5659 codec driver unconditionally defines an
ACPI device match table but then uses ACPI_PTR() to remove the
only reference to it, so we get a harmless build warning:
sound/soc/codecs/rt5659.c:4200:30: warning: 'rt5659_acpi_match' defined but not used [-Wunused-variable]
static struct acpi_device_id rt5659_acpi_match[] = {
This changes both the OF match table and the ACPI match table
to follow the same style, using ACPI_PTR/of_match_ptr to
make the reference conditional, and using an #ifdef to hide
the table. This also adds the missing MODULE_DEVICE_TABLE for
the OF case and adapts the formatting to the same style.
The shift bit of IN1 boost gain control is 12.
Signed-off-by: Bard Liao <bardliao@realtek.com>
RT286_CBJ_CTRL1(0x4f) bit 10 is needed for headset capture. It
will be turned off when "VREF" widget is on and be turned on when
bias level is ON. It is odd. And if "VREF" is turned on in bias
level is ON, RT286_CBJ_CTRL1(0x4f) bit 10 will be turned off.
This patch move the bit control from rt286_set_bias_level and
rt298_vref_event to rt286_jack_detect. So it will be turned on
once a jack is plugged in.
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"Here is the bulk of GPIO changes for v4.5.
Notably there are big refactorings mostly by myself, aimed at getting
the gpio_chip into a shape that makes me believe I can proceed to
preserve state for a proper userspace ABI (character device) that has
already been proposed once, but resulted in the feedback that I need
to go back and restructure stuff. So I've been restructuring stuff.
On the way I ran into brokenness (return code from the get_value()
callback) and had to fix it. Also, refactored generic GPIO to be
simpler.
Some of that is still waiting to trickle down from the subsystems all
over the kernel that provide random gpio_chips, I've touched every
single GPIO driver in the kernel now, oh man I didn't know I was
responsible for so much...
Apart from that we're churning along as usual.
I took some effort to test and retest so it should merge nicely and we
shook out a couple of bugs in -next.
Infrastructural changes:
- In struct gpio_chip, rename the .dev node to .parent to better
reflect the fact that this is not the GPIO struct device
abstraction. We will add that soon so this would be totallt
confusing.
- It was noted that the driver .get_value() callbacks was sometimes
reporting negative -ERR values to the gpiolib core, expecting them
to be propagated to consumer gpiod_get_value() and gpio_get_value()
calls. This was not happening, so as there was a mess of drivers
returning negative errors and some returning "anything else than
zero" to indicate that a line was active. As some would have bit
31 set to indicate "line active" it clashed with negative error
codes. This is fixed by the largeish series clamping values in all
drivers with !!value to [0,1] and then augmenting the code to
propagate error codes to consumers. (Includes some ACKed patches
in other subsystems.)
- Add a void *data pointer to struct gpio_chip. The container_of()
design pattern is indeed very nice, but we want to reform the
struct gpio_chip to be a non-volative, stateless business, and keep
states internal to the gpiolib to be able to hold on to the state
when adding a proper userspace ABI (character device) further down
the road. To achieve this, drivers need a handle at the internal
state that is not dependent on their struct gpio_chip() so we add
gpiochip_add_data() and gpiochip_get_data() following the pattern
of many other subsystems. All the "use gpiochip data pointer"
patches transforms drivers to this scheme.
- The Generic GPIO chip header has been merged into the general
<linux/gpio/driver.h> header, and the custom header for that
removed. Instead of having a separate mm_gpio_chip struct for
these generic drivers, merge that into struct gpio_chip,
simplifying the code and removing the need for separate and
confusing includes.
Misc improvements:
- Stabilize the way GPIOs are looked up from the ACPI legacy
specification.
- Incremental driver features for PXA, PCA953X, Lantiq (patches from
the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48
New drivers:
- Add a GPIO chip to the ALSA SoC AC97 driver.
- Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir,
but the branch is merged here too to account for infrastructural
changes).
- The sx150x driver now supports the sx1502"
* tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits)
gpio: generic: make bgpio_pdata always visible
gpiolib: fix chip order in gpio list
gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs()
gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs()
gpio: brcmstb: Allow building driver for BMIPS_GENERIC
gpio: brcmstb: Set endian flags for big-endian MIPS
gpio: moxart: fix build regression
gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs()
leds: pca9532: use gpiochip data pointer
leds: tca6507: use gpiochip data pointer
hid: cp2112: use gpiochip data pointer
bcma: gpio: use gpiochip data pointer
avr32: gpio: use gpiochip data pointer
video: fbdev: via: use gpiochip data pointer
gpio: pch: Optimize pch_gpio_get()
Revert "pinctrl: lantiq: Implement gpio_chip.to_irq"
pinctrl: nsp-gpio: use gpiochip data pointer
pinctrl: vt8500-wmt: use gpiochip data pointer
pinctrl: exynos5440: use gpiochip data pointer
pinctrl: at91-pio4: use gpiochip data pointer
The newly added mediatek drivers for mt8173 select codes that depend
on I2C, which cuases a build failure if I2C is disabled:
warning: (SND_SOC_ADAU1761_I2C && SND_SOC_ADAU1781_I2C && SND_SOC_ADAU1977_I2C && SND_SOC_RT5677 && EXTCON_MAX14577 && EXTCON_MAX77693 && EXTCON_MAX77843 && BMC150_ACCEL_I2C && BMG160_I2C) selects REGMAP_I2C which has unmet direct dependencies (I2C)
codecs/rt5645.c:3854:1: warning: data definition has no type or storage class
codecs/rt5645.c:3854:1: error: type defaults to 'int' in declaration of 'module_i2c_driver' [-Werror=implicit-int]
codecs/rt5677.c:5270:1: warning: data definition has no type or storage class
77_i2c_driver);
codecs/rt5677.c:5270:1: error: type defaults to 'int' in declaration of 'module_i2c_driver' [-Werror=implicit-int]
This adds an explicit dependency.
Acked-by: Koro Chen <koro.chen@mediatek.com>
Use devm_request_threaded_irq to ensure the irq is freed when unload the
module. The rt5659->i2c is no longer used after this conversion, thus
remove it as well.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Static checkers complain if we don't free "adata" before returning.
Fixes: 7c31335a03b6 ('ASoC: AMD: add AMD ASoC ACP 2.x DMA driver')
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Last updates for v4.5
A bunch more updates for v4.5, mainly driver work:
- More topology API enhancements from Mengdong Lin working towards
making everything more component based and being able to specify PCM
links via topology.
- Large sets driver updates from Cirrus, Intel (mainly more Skylake
support) and Renesas.
- New driver for AMD ACP
- Rename PCM1792a driver to be generic pcm179x
dev pointer in struct snd_soc_pcm_runtime does not have dma_ops set. In
v4.4 kernel dma_ops would end up pointing to dummy_dma_ops in such cases.
So attempting to use such device in allocating coherent memory on aarch64
would fail.
According to commit 1dccb598df549d892b6450c261da54cdd7af44b4 ("arm64:
simplify dma_get_ops") The current behavior of dma_get_ops is to fall
back to the global dma_ops when a device has not set its own dma_ops,
but only for DT based systems.
So, this patch fixes the driver to use correct device pointer while
allocating coherent memory, and also deletes un-necessary dma_mask setup
on soc_runtime->dev.
Without this patch lpass driver would fail with below log:
[ 6.541542] ADV7533: lpass_platform_alloc_buffer: Could not allocate DMA buffer
[ 6.541914] apq8016-lpass-cpu 7708000.lpass-cpu: ASoC: pcm constructor failed: -12
[ 6.548216] qcom-apq8016-sbc 7702000.sound: ASoC: can't create pcm ADV7533 :-12
[ 6.555581] qcom-apq8016-sbc 7702000.sound: ASoC: failed to instantiate card -12
[ 6.566072] qcom-apq8016-sbc: probe of 7702000.sound failed with error -12
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
into asoc-next
'asoc/topic/fsl-ssi' into asoc-next
into asoc-next
