This macro is useful to avoid link error on 32-bit systems.
We have the same definition in two drivers, so move it to
include/linux/kernel.h
While we are here, refactor DIV_ROUND_UP_ULL() by using
DIV_ROUND_DOWN_ULL().
Link: http://lkml.kernel.org/r/1500945156-12907-1-git-send-email-yamada.masahiro@socionext.com
Acked-by: Mark Brown <broonie@kernel.org>
Cc: Cyrille Pitchen <cyrille.pitchen@wedev4u.fr>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.com>
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Drivers
- RK805 Power Management IC (PMIC)
- ROHM BD9571MWV-M MFD Power Management IC (PMIC)
- Texas Instruments TPS68470 Power Management IC (PMIC) & LEDs
New Device Support:
- Add support for HiSilicon Hi6421v530 to hi6421-pmic-core
- Add support for X-Powers AXP806 to axp20x
- Add support for X-Powers AXP813 to axp20x
- Add support for Intel Sunrise Point LPSS to intel-lpss-pci
New Functionality:
- Amend API to provide register layout; atmel-smc
Fix-ups:
- DT re-work; omap, nokia
- Header file location change {I2C => MFD}; dm355evm_msp, tps65010
- Fix chip ID formatting issue(s); rk808
- Optionally register touchscreen devices; da9052-core
- Documentation improvements; twl-core
- Constification; rtsx_pcr, ab8500-core, da9055-i2c, da9052-spi
- Drop unnecessary static declaration; max8925-i2c
- Kconfig changes (missing deps and remove module support)
- Slim down oversized licence statement; hi6421-pmic-core
- Use managed resources (devm_*); lp87565
- Supply proper error checking/handling; t7l66xb
Bug Fixes:
- Fix counter duplication issue; da9052-core
- Fix potential NULL deference issue; max8998
- Leave SPI-NOR write-protection bit alone; lpc_ich
- Ensure device is put into reset during suspend; intel-lpss
- Correct register offset variable size; omap-usb-tll"
* tag 'mfd-next-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (61 commits)
mfd: intel_soc_pmic: Differentiate between Bay and Cherry Trail CRC variants
mfd: intel_soc_pmic: Export separate mfd-cell configs for BYT and CHT
dt-bindings: mfd: Add bindings for ZII RAVE devices
mfd: omap-usb-tll: Fix register offsets
mfd: da9052: Constify spi_device_id
mfd: intel-lpss: Put I2C and SPI controllers into reset state on suspend
mfd: da9055: Constify i2c_device_id
mfd: intel-lpss: Add missing PCI ID for Intel Sunrise Point LPSS devices
mfd: t7l66xb: Handle return value of clk_prepare_enable
mfd: Add ROHM BD9571MWV-M PMIC DT bindings
mfd: intel_soc_pmic_chtwc: Turn Kconfig option into a bool
mfd: lp87565: Convert to use devm_mfd_add_devices()
mfd: Add support for TPS68470 device
mfd: lpc_ich: Do not touch SPI-NOR write protection bit on Haswell/Broadwell
mfd: syscon: atmel-smc: Add helper to retrieve register layout
mfd: axp20x: Use correct platform device ID for many PEK
dt-bindings: mfd: axp20x: Introduce bindings for AXP813
mfd: axp20x: Add support for AXP813 PMIC
dt-bindings: mfd: axp20x: Add AXP806 to supported list of chips
mfd: Add ROHM BD9571MWV-M MFD PMIC driver
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"We have touched quite a lot of files but with fewer changes at this
cycle; as you can see, most of changes are trivial fixes, especially
constification patches.
Among the massive attacks by constification gangs, we had a few core
changes (mostly for ASoC core), as well the fixes and the updates by
major vendors.
Some highlights:
ALSA core:
- Fix possible races in control API user-TLV codes
- Small cleanup of PCM core
ASoC:
- Continued work for componentization; still half-baked, but we're
certainly progressing
- Use of devres for jack detection GPIOs, rather as a cleanup
- Jack detection support for Qualcomm MSM8916
- Support for Allwinner H3, Cirrus Logic CS43130, Intel Kabylake
systems with RT5663, Realtek RT274, TI TLV320AIC32x6 and Wolfson
WM8523"
* tag 'sound-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (512 commits)
ALSA: hda/ca0132 - Fix memory leak at error path
ALSA: hda: Fix forget to free resource in error handling code path in hda_codec_driver_probe
ASoC: cs43130: Fix unused compiler warnings for PM runtime
ASoC: cs43130: Fix possible Oops with invalid dev_id
ASoC: cs43130: fix spelling mistake: "irq_occurrance" -> "irq_occurrence"
ALSA: atmel: Remove leftovers of AVR32 removal
ALSA: atmel: convert AC97c driver to GPIO descriptor API
ALSA: hda/realtek - Enable jack detection function for Intel ALC700
ALSA: hda: Fix regression of hdmi eld control created based on invalid pcm
ASoC: Intel: Skylake: Add IPC to configure the copier secondary pins
ASoC: add missing compile rule for max98371
ASoC: add missing compile rule for sirf-audio-codec
ASoC: cs43130: Add devicetree bindings for CS43130
ASoC: cs43130: Add support for CS43130 codec
ASoC: make clock direction configurable in asoc-simple
ALSA: ctxfi: Remove null check before kfree
ASoC: max98927: Changed device property read function
ASoC: max98927: Modified DAPM widget and map to enable/disable VI sense path
ASoC: max98927: Added PM suspend and resume function
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for the CS43130 driver
A couple of warning fixes for the newly added CS43130 driver.
Add __maybe_unused prefix for addressing the following warnings:
sound/soc/codecs/cs43130.c:2615:12: warning: ‘cs43130_runtime_resume’ defined but not used [-Wunused-function]
sound/soc/codecs/cs43130.c:2596:12: warning: ‘cs43130_runtime_suspend’ defined but not used [-Wunused-function]
Fixes: 8f1e5bf9b440 ("ASoC: cs43130: Add support for CS43130 codec")
Signed-off-by: Mark Brown <broonie@kernel.org>
As compiler spotted out, there is the potential NULL-dereference in
the code when dc-measure OF is given for other than 43130/43131:
sound/soc/codecs/cs43130.c:2089:18: warning: ‘hpload_seq’ may be used uninitialized in this function [-Wmaybe-uninitialized]
Warn it and return before triggering Oops.
include/linux/i2c is not for client devices. Move the header file to a
more appropriate location.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
ASoC: Updates for v4.14
This is quite a large release by volume of patches and diff, a lot of
that is mechanical cleanup patches but it's great to also see a range of
vendors actively working on adding new features and fixing issues in
their drivers. Intel and Realtek have been especially active here.
- Continued work towards moving everything to the component model from
Morimoto-san.
- Use of devres for jack detection GPIOs, eliminating some potential
resource leaks.
- Jack detection support for Qualcomm MSM8916.
WM8523.
Trivial fix to spelling mistake in variable name
Pull drm updates from Dave Airlie:
"This is the main drm pull request for 4.14 merge window.
I'm sending this early, as my continuing journey into fatherhood is
occurring really soon now, I'm going to be mostly useless for the next
couple of weeks, though I may be able to read email, I doubt I'll be
doing much patch applications or git sending. If anything urgent pops
up I've asked Daniel/Jani/Alex/Sean to try and direct stuff towards
you.
Outside drm changes:
Some rcar-du updates that touch the V4L tree, all acks should be in
place. It adds one export to the radix tree code for new i915 use
case. There are some minor AGP cleanups (don't see that too often).
Changes to the vbox driver in staging to avoid breaking compilation.
Summary:
core:
- Atomic helper fixes
- Atomic UAPI fixes
- Add YCBCR 4:2:0 support
- Drop set_busid hook
- Refactor fb_helper locking
- Remove a bunch of internal APIs
- Add a bunch of better default handlers
- Format modifier/blob plane property added
- More internal header refactoring
- Make more internal API names consistent
- Enhanced syncobj APIs (wait/signal/reset/create signalled)
bridge:
- Add Synopsys Designware MIPI DSI host bridge driver
tiny:
- Add Pervasive Displays RePaper displays
- Add support for LEGO MINDSTORMS EV3 LCD
i915:
- Lots of GEN10/CNL support patches
- drm syncobj support
- Skylake+ watermark refactoring
- GVT vGPU 48-bit ppgtt support
- GVT performance improvements
- NOA change ioctl
- CCS (color compression) scanout support
- GPU reset improvements
amdgpu:
- Initial hugepage support
- BO migration logic rework
- Vega10 improvements
- Powerplay fixes
- Stop reprogramming the MC
- Fixes for ACP audio on stoney
- SR-IOV fixes/improvements
- Command submission overhead improvements
amdkfd:
- Non-dGPU upstreaming patches
- Scratch VA ioctl
- Image tiling modes
- Update PM4 headers for new firmware
- Drop all BUG_ONs.
nouveau:
- GP108 modesetting support.
- Disable MSI on big endian.
vmwgfx:
- Add fence fd support.
msm:
- Runtime PM improvements
exynos:
- NV12MT support
- Refactor KMS drivers
imx-drm:
- Lock scanout channel to improve memory bw
- Cleanups
etnaviv:
- GEM object population fixes
tegra:
- Prep work for Tegra186 support
- PRIME mmap support
sunxi:
- HDMI support improvements
- HDMI CEC support
omapdrm:
- HDMI hotplug IRQ support
- Big driver cleanup
- OMAP5 DSI support
rcar-du:
- vblank fixes
- VSP1 updates
arcgpu:
- Minor fixes
stm:
- Add STM32 DSI controller driver
dw_hdmi:
- Add support for Rockchip RK3399
- HDMI CEC support
atmel-hlcdc:
- Add 8-bit color support
vc4:
- Atomic fixes
- New ioctl to attach a label to a buffer object
- HDMI CEC support
- Allow userspace to dictate rendering order on submit ioctl"
* tag 'drm-for-v4.14' of git://people.freedesktop.org/~airlied/linux: (1074 commits)
drm/syncobj: Add a signal ioctl (v3)
drm/syncobj: Add a reset ioctl (v3)
drm/syncobj: Add a syncobj_array_find helper
drm/syncobj: Allow wait for submit and signal behavior (v5)
drm/syncobj: Add a CREATE_SIGNALED flag
drm/syncobj: Add a callback mechanism for replace_fence (v3)
drm/syncobj: add sync obj wait interface. (v8)
i915: Use drm_syncobj_fence_get
drm/syncobj: Add a race-free drm_syncobj_fence_get helper (v2)
drm/syncobj: Rename fence_get to find_fence
drm: kirin: Add mode_valid logic to avoid mode clocks we can't generate
drm/vmwgfx: Bump the version for fence FD support
drm/vmwgfx: Add export fence to file descriptor support
drm/vmwgfx: Add support for imported Fence File Descriptor
drm/vmwgfx: Prepare to support fence fd
drm/vmwgfx: Fix incorrect command header offset at restart
drm/vmwgfx: Support the NOP_ERROR command
drm/vmwgfx: Restart command buffers after errors
drm/vmwgfx: Move irq bottom half processing to threads
drm/vmwgfx: Don't use drm_irq_[un]install
'asoc/topic/zte' into asoc-next
'asoc/topic/utils', 'asoc/topic/ux500' and 'asoc/topic/wm8523' into asoc-next
'asoc/topic/tegra', 'asoc/topic/tlv320aic32x4' and 'asoc/topic/tlv320aic3x' into asoc-next
'asoc/topic/sta32x', 'asoc/topic/stm32' and 'asoc/topic/sunxi' into asoc-next
'asoc/topic/rt5677' and 'asoc/topic/samsung' into asoc-next
'asoc/topic/rt5645', 'asoc/topic/rt5659' and 'asoc/topic/rt5663' into asoc-next
'asoc/topic/rt274' and 'asoc/topic/rt5514' into asoc-next
'asoc/topic/pxa' into asoc-next
'asoc/topic/nau8825', 'asoc/topic/nuc900' and 'asoc/topic/of-graph' into asoc-next
'asoc/topic/max98926' and 'asoc/topic/max98927' into asoc-next
'asoc/topic/jack' and 'asoc/topic/jz4740' into asoc-next
'asoc/topic/fsi', 'asoc/topic/fsl' and 'asoc/topic/hdmi' into asoc-next
'asoc/topic/cygnus' and 'asoc/topic/davinci' into asoc-next
and 'asoc/topic/cs42l42' into asoc-next
'asoc/topic/cirrus' and 'asoc/topic/compress' into asoc-next
'asoc/topic/atmel', 'asoc/topic/au1x' and 'asoc/topic/bcm' into asoc-next
asoc-linus
ASoC: Fixes for v4.13
A couple of fixes, one for a regression in simple-card introduced during
the merge window that was only reported this week and another for a
regression in registration of ACPI GPIOs.
# gpg: Signature made Thu 31 Aug 2017 12:50:29 BST
# gpg: using RSA key ADE668AA675718B59FE29FEA24D68B725D5487D0
# gpg: issuer "broonie@kernel.org"
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" [unknown]
# gpg: aka "Mark Brown <broonie@debian.org>" [unknown]
# gpg: aka "Mark Brown <broonie@kernel.org>" [unknown]
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" [unknown]
# gpg: aka "Mark Brown <broonie@linaro.org>" [unknown]
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>" [unknown]
# gpg: WARNING: This key is not certified with a trusted signature!
# gpg: There is no indication that the signature belongs to the owner.
# Primary key fingerprint: 3F25 68AA C269 98F9 E813 A1C5 C3F4 36CA 30F5 D8EB
# Subkey fingerprint: ADE6 68AA 6757 18B5 9FE2 9FEA 24D6 8B72 5D54 87D0
Copier can support upto 4 output pins. However, only pin 0 is configured
as a part of copier initialization. Configuring rest of pins require the
separate IPC to be sent to fw.
Signed-off-by: Pradeep Tewani <pradeep.d.tewani@intel.com>
Acked-By: Vinod Koul <vinod.koul@intel.com>
It is still using old driver style, this patch also
fixup it.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
fixup it.
fixup it.
Add support for Cirrus Logic CS43130 codec.
Support:
I2S/DSP PCM playback.
DoP/DSD playback.
HP detection and DC/AC impedance measurement.
Signed-off-by: Li Xu <li.xu@cirrus.com>
Acked-by: Brian Austin <brian.austin@cirrus.com>
Some CPU drivers (e. g. davinci-mcasp) may require the system clock to
be configured as OUT, while there's no good way currently to set
SND_SOC_CLK_OUT in simple-soc driver if the clock is fixed-rate.
This patch makes asoc_simple_card_init_dai() initialize clock to
SND_SOCK_CLK_OUT if explicitly stated in the relevant dts file. This
change is transparent and doesn't change the default behavior.
Signed-off-by: Vitaly Wool <vitaly.wool@konsulko.com>
Signed-off-by: Ryan Lee <ryans.lee@maximintegrated.com>
