Change the legacy DAI naming flag from opting in to the new scheme
(non_legacy_dai_naming), to opting out of it (legacy_dai_naming).
These drivers appear to be on the CPU side of the DAI link and
currently uses the legacy naming, so add the new flag.
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Link: https://lore.kernel.org/r/20220623125250.2355471-29-ckeepax@opensource.cirrus.com
Signed-off-by: Mark Brown <broonie@kernel.org>
Now the core has been migrated across to the new direct clock
specification we can move the drivers back to the normal set_fmt
callback.
Link: https://lore.kernel.org/r/20220519154318.2153729-44-ckeepax@opensource.cirrus.com
As part of updating the core to directly tell drivers if they are clock
provider or consumer update these CPU side drivers to use the new direct
callback.
Link: https://lore.kernel.org/r/20220519154318.2153729-17-ckeepax@opensource.cirrus.com
To avoid dereferencing hardwired constant pointers from a global header
file, change the driver to use devm_platform_ioremap_resource for getting
an __iomem pointer, and then using readl/writel on that.
Each pointer dereference gets changed by a search&replace, which leads
to a few overlong lines, but seems less risky than trying to clean up
the code at the same time.
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: alsa-devel@alsa-project.org
This is a basically a platform_data file, so move it out of
the mach/* header directory.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.com>
Cc: Sergey Lapin <slapin@ossfans.org>
The mach/hardware.h is included in lots of places, and it provides
three different things on pxa:
- the cpu_is_pxa* macros
- an indirect inclusion of mach/addr-map.h
- the __REG() and io_pv2() helper macros
Split it up into separate <linux/soc/pxa/cpu.h> and mach/pxa-regs.h
headers, then change all the files that use mach/hardware.h to
include the exact set of those three headers that they actually
need, allowing for further more targeted cleanup.
linux/soc/pxa/cpu.h can remain permanently exported and is now in
a global location along with similar headers. pxa-regs.h and
addr-map.h are only used in a very small number of drivers now
and can be moved to arch/arm/mach-pxa/ directly when those drivers
are to pass the necessary data as resources.
Cc: Michael Turquette <mturquette@baylibre.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Jacek Anaszewski <jacek.anaszewski@gmail.com>
Cc: Pavel Machek <pavel@ucw.cz>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Cc: linux-clk@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: linux-input@vger.kernel.org
Cc: linux-leds@vger.kernel.org
Cc: linux-mmc@vger.kernel.org
Cc: linux-mtd@lists.infradead.org
Cc: linux-rtc@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: dri-devel@lists.freedesktop.org
Cc: linux-fbdev@vger.kernel.org
Cc: linux-watchdog@vger.kernel.org
Now with the recent addition of WC buffer allocation support, we can
use the standard PCM buffer allocation helpers for pxa2xx drivers.
This allows us to remove lots of superfluous code.
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Link: https://lore.kernel.org/r/20210802072815.13551-6-tiwai@suse.de
This patch syncs naming rule.
- xxx_rates;
+ xxx_rate;
- xxx_samplebits;
+ xxx_sample_bits;
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Link: https://lore.kernel.org/r/87h7niolhf.wl-kuninori.morimoto.gx@renesas.com
Now we can use asoc_substream_to_rtd() macro,
let's use it.
Link: https://lore.kernel.org/r/87k0yz0yua.wl-kuninori.morimoto.gx@renesas.com
We have snd_soc_dai/dai_stream/component_active() macro
This patch uses it.
Reviewed-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
Link: https://lore.kernel.org/r/87o8qq58ia.wl-kuninori.morimoto.gx@renesas.com
Tested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/87k13bir62.wl-kuninori.morimoto.gx@renesas.com
There is no big difference at implementation for .suspend/.resume
between DAI driver and Component driver.
But because some driver is using DAI version, thus ALSA SoC needs
to keep supporting it, hence, framework becoming verbose.
If we can switch all DAI driver .suspend/.resume to Component driver,
we can remove verbose code from ALSA SoC.
Driver is getting its private data via dai->dev.
But dai->dev and component->dev are same dev, thus, we can convert
these. For same reason, we can convert dai->active to
component->active if necessary.
Link: https://lore.kernel.org/r/87sgkbx7ic.wl-kuninori.morimoto.gx@renesas.com
ASoC PCM core deals the empty ioctl field now as default.
Let's kill the redundant lines.
Link: https://lore.kernel.org/r/20191210145406.21419-12-tiwai@suse.de
snd_pcm_ops is no longer needed.
Let's use component driver callback.
Link: https://lore.kernel.org/r/87o8yz90e9.wl-kuninori.morimoto.gx@renesas.com
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
Now that the functions are now available through pxa2xx-lib, hook them up
to pxa-sspi, pxa-ac97 and pxa-i2s. This allows DT platforms to use the DAIs
without a platform driver.
Signed-off-by: Daniel Mack <daniel@zonque.org>
As the pxa architecture switched towards the dmaengine slave map, the
old compatibility mechanism to acquire the dma requestor line number and
priority are not needed anymore.
This patch simplifies the dma resource acquisition, using the more
generic function dma_request_slave_channel().
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
This was reported by checkpatch.pl
Signed-off-by: Codrut Grosu <codrut.cristian.grosu@gmail.com>
This patch removes the old PXA DMA API usage and switches over to
generic functions provided by snd-soc-dmaengine-pcm.
More cleanups may be done on top of this, and some function stubs can
now be removed completetly. However, the intention here was to keep
the transition as small as possible.
This was tested on the mioa701 pxa27x board.
Signed-off-by: Daniel Mack <zonque@gmail.com>
[trivial change from mmp-dma to pxa-dma]
Signed-off-by: Axel Lin <axel.lin@ingics.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Use WARN_ON() and handle the error cases accordingly.
Signed-off-by: Mark Brown <broonie@linaro.org>
Use snd_dmaengine_dai_dma_data for passing the dma parameters from
clients to the pxa pcm lib. This does no functional change, it's just an
intermedia step to migrate the pxa bits over to dmaengine.
The calculation of dcmd is a transition hack which will be removed again
in a later patch. It's just there to make the transition more readable.
Acked-by: Mark Brown <broonie@linaro.org>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Linux 3.4-rc3 contains a bunch of Tegra changes which are conflicting
annoyingly with the new development that's going on for Tegra so merge
it up to resolve those conflicts.
sound/soc/soc-core.c
sound/soc/tegra/tegra_i2s.c
sound/soc/tegra/tegra_spdif.c
* fixes
sound/soc/pxa/pxa2xx-i2s.c:86:2: error: implicit declaration of function 'IOMEM' [-Werror=implicit-function-declaration]
sound/soc/pxa/pxa2xx-i2s.c:86:2: error: initializer element is not constant
after 23019a733bb83c8499f192fb428b7e6e81c95a34 removed IOMEM
definition from arch/arm/mach-pxa/include/mach/hardware.h
Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com>
This patch adds clk_prepare/clk_unprepare calls to the pxa2xx-i2s
driver by using the helper functions clk_prepare_enable and
clk_disable_unprepare.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
anyway.
Removed #include of pxa2xx-pcm.h
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This fixes a memory corruption when ASoC devices are used in
full-duplex mode. Specifically for pxa-ssp code, where this pointer
is dynamically allocated for each direction and destroyed upon each
stream start.
All other platforms are fixed blindly, I couldn't even compile-test
them. Sorry for any breakage I may have caused.
[Note that this is a backported version for 2.6.34.
Upstream commit is fd23b7dee]
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Reported-by: Sven Neumann <s.neumann@raumfeld.com>
Reported-by: Michael Hirsch <m.hirsch@raumfeld.com>
The clock API can't cope with unbalanced enables and disables and
we only enable in hw_params() but try to disable in shutdown.
pxa2xx_i2s_resume is :
- unconditionnaly setting SACR0_ENB
- unsetting SACR0_ENB in saved SACR0 pxa_i2s.sacr0
fix these.
In pxa2xx_i2s_{resume,suspend}, save/restore registers even
when !dai->active.
Signed-off-by: Karl Beldan <karl.beldan@mobile-devices.fr>
i2s_clk is 'put' for no reason in pxa2xx_i2s_shutdown.
Now we 'get' i2s_clk at probe and 'put' it at driver removal or when
probe fails.
- hw_params enables both RPL and REC functions each time : Enable the
appropriate function in pxa2xx_i2s_trigger.
- pxa2xx_i2s_shutdown disables i2s anytime one of RPL or REC function is
off : Turn it off only when both functions are off.
Make sure we are in a know good state at end of probe :
Reset FIFO logic and registers, and make sure REC and RPL functions
along with FIFO service are disabled (SACR0_RST enables REC and RPL).
Resetting loses current settings so remove reset from stream startup.
Now reset occurs only at probe.
There is a single I2S_SYNC pin on the chip.
1. Driver code where pxa_request_dma() is called will most likely
reference DMA registers as well, and it is really unnecessary
to include pxa-regs.h just for this. Move the definitions into
<mach/dma.h> and make relevant drivers include it instead of
<mach/pxa-regs.h>.
2. Introduce DMAC_REGS_VIRT as the virtual address base for these
DMA registers. This allows later processors to re-use the same
IP while registers may start at different I/O address.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Considering the fact that most cpu_dai or codec_dai are using a same
'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better
made a pointer instead, to make sharing easier and code a bit cleaner.
The patch below is rather preliminary since the asoc tree is being
actively developed, and this touches almost every piece of code,
(and possibly many others in development need to be changed as
well). Building of all codecs are OK, yet to every SoC, I didn't test
that.
This removes the calls to pxa_gpio_mode from the pxa2xx-i2s driver.
Pin setup should be done during board init via pxa2xx_mfp_config
instead.
Acked-by: Eric Miao <eric.miao@marvell.com>
Register all platform DAIs with the core. In line with current behaviour
this is done at module probe time rather than when the devices are probed
(since currently that only happens as the entire ASoC card is registered
except for those drivers that currently implement some kind of hotplug).
Since the core currently ignores DAI registration this has no practical
effect.
None of the DAIs use it except s3c2412-i2s which only uses it for
dev_() printouts.
DAI type information is only ever used within ASoC in order to special
case AC97 and for diagnostic purposes. Since modern CPUs and codecs
support multi function DAIs which can be configured for several modes
it is more trouble than it's worth to maintain anything other than a
flag identifying AC97 DAIs so remove the type field and replace it with
an ac97_control flag.
Liam Girdwood's ASoC v2 work avoids having two different ops structures
for DAIs by merging the members of struct snd_soc_ops into struct
snd_soc_dai_ops, allowing per DAI configuration for everything.
Backport this change.
This paves the way for future work allowing any combination of DAIs to
be connected rather than having fixed purpose CODEC and CPU DAIs and
only allowing CODEC<->CPU interconnections.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (33 commits)
ALSA: ASoC codec: remove unused #include <version.h>
ALSA: ASoC: update email address for Liam Girdwood
ALSA: hda: corrected invalid mixer values
ALSA: hda: add mixers for analog mixer on 92hd75xx codecs
ALSA: ASoC: Add destination and source port for DMA on OMAP1
ALSA: ASoC: Drop device registration from GTA01 lm4857 driver
ALSA: ASoC: Fix build of GTA01 audio driver
ALSA: ASoC: Add widgets before setting endpoints on GTA01
ALSA: ASoC: Fix inverted input PGA mute bits in WM8903
ALSA: ASoC: OMAP: Set DMA stream name at runtime in McBSP DAI driver
ALSA: ASoC: OMAP: Add support for OMAP2430 and OMAP34xx in McBSP DAI driver
ALSA: ASoC: OMAP: Add multilink support to McBSP DAI driver
ALSA: ASoC: Make TLV320AIC26 user-visible
ALSA: ASoC - clean up Kconfig for TLV320AIC2
ALSA: ASoC: Make WM8510 microphone input a DAPM mixer
ALSA: ASoC: Implement WM8510 bias level control
ALSA: ASoC: Remove unused AUDIO_NAME define from codec drivers
ALSA: ASoC: tlv320aic3x: Use uniform tlv320aic naming
ALSA: ASoC: Add WM8510 SPI support
ALSA: ASoC: Add WM8753 SPI support
Update the contact information for Liam Girdwood in ASoC core and
drivers as my old email address is no longer valid.
