path: root/sound/soc/omap
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-10ASoC: sdp3430: Let core to deal with the DAPM widgetsPeter Ujfalusi
Pass the DAPM widgets/routes via the snd_soc_card struct to core. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-10ASoC: osk5912: Let core to deal with the DAPM widgetsPeter Ujfalusi
Pass the DAPM widgets/routes via the snd_soc_card struct to core. With this change we do not need the init function since the remaining snd_soc_dapm_enable_pin calls are not needed. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-10ASoC: n810: Let the core to register DAPM widgets/routes and controlsPeter Ujfalusi
Pass the DAPM widgets/routes and static controls via the snd_soc_card struct to core. In this way the machine driver does not need to handle the DAPM widgets/routes. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-10ASoC: am3517evm: Let core to deal with the DAPM widgetsPeter Ujfalusi
Pass the DAPM widgets/routes via the snd_soc_card struct to core. With this change we do not need the init function since the remaining snd_soc_dapm_enable_pin calls are not needed. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Anuj Aggarwal <anuj.aggarwal@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-10ASoC: sdp4430: No need to call dapm_pin_enable at init timePeter Ujfalusi
Widgets are connected by default. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-10ASoC: sdp4430: Let core to deal with the DAPM widgetsPeter Ujfalusi
2011-10-10ASoC: zoom2: No need to call dapm_pin_enable at init timePeter Ujfalusi
2011-10-10ASoC: zoom2: Let core to deal with the DAPM widgetsPeter Ujfalusi
2011-10-10ASoC: OMAP machines: Remove soc_dapm_sync() call from initPeter Ujfalusi
No need to call soc_dapm_sync at init time. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Anuj Aggarwal <anuj.aggarwal@ti.com> Cc: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Gražvydas Ignotas <notasas@gmail.com> Cc: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-10ASoC: fix checkpatch.pl error in omap-mcbspMichael Opdenacker
Signed-off-by: Michael Opdenacker <michael.opdenacker@linaro.org> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-04ASoC: omap-pcm: Fix the no period wakeup implementationPeter Ujfalusi
After omap_request_dma the BLOCK_IRQ is enabled as default configuration for the channel. If we are requested for no period wakeup, we need to disable the BLOCK_IRQ in order to not receive any interrupts. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-02ASoC: omap: Use single hw_params callback in sdp3430 and zoom2Jarkko Nikula
There is no need to use two hw_params callbacks in sdp3430 and zoom2 as thet are now identical. Use instead the same snd_soc_ops structure and hw_params callback for both DAI links. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-02ASoC: omap: Convert bunch of machine drivers to use init time DAI formatJarkko Nikula
2011-10-02ASoC: omap-mcbsp: Prepare for init time DAI format settingJarkko Nikula
Before commit 75d9ac4 ("ASoC: Allow DAI formats to be specified in the dai_link") expectation for omap-mcbsp was that snd_soc_dai_set_fmt is to be called first in machine hw_params callback before other CPU DAI functions. Thus it was enough that only omap_mcbsp_dai_set_dai_fmt cleared the mcbsp->regs structure. [Note that this was pure convention, it's always been OK to set things on init -- broonie] Now this doesn't hold anymore since machine drivers can set the DAI format only once on init time and thus mcbsp->regs may get out of sync when other CPU DAI functions are modifying them dynamically with different values between the calls. Therefore clear the accessed mcbsp->regs bits and bitfields in other functions too. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-30ASoC: omap-mcbsp: Fix FS polarity for LEFT_J, DSP_A and DSP_B formatsJarkko Nikula
Commit 75d9ac4 ("ASoC: Allow DAI formats to be specified in the dai_link") changed DAI format flag values and we cannot simply invert anymore e.g. frame-sync with ^= SND_SOC_DAIFMT_NB_IF (which was anyway misuse) as there is no anymore fixed bit position for bit-clock or frame-sync inversion. Fix this by relying only on DAI format flag values passed to us and by not making any assumption on individual bit positions. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-30ASoC: sdp4430: Fix string for FM input nameUjfalusi, Peter
The name contains invalid valid character (/), which causes problems when trying to create the debugfs directory structure: ASoC: Failed to create Aux/FM Stereo In debugfs file Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-26ASoC: sdp4430: Configure McPDM offset cancellationPeter Ujfalusi
Based on the values from twl6040 codec (HSOTRIM L/R) we can configure the McPDM offset cancellation. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-26ASoC: omap-mcpdm: API to configure offset cancellationPeter Ujfalusi
The offset cancellation values can be different from board to board, even on the same HW platform. Provide a way for the machine drivers to configure the McPDM offset cancellation. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-26ASoC: omap-mcbsp: Fix compile time warning about ambiguous ‘else’Peter Ujfalusi
Fixes the following compile time warning: omap-mcbsp.c:519: warning: suggest explicit braces to avoid ambiguous ‘else’ Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-23ASoC: omap-mcpdm: Correct the supported number of channelsPeter Ujfalusi
OMAP4 McPDM supports 5 downlink (playback), and 3 uplink (capture) channels. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-23Merge branch 'for-3.1' into for-3.2Mark Brown
2011-09-23ASoC: omap-mcbsp: Do not attempt to change DAI sysclk if stream is activeJarkko Nikula
Attempt to change McBSP CLKS source while another stream is active is not safe after commit d135865 ("OMAP: McBSP: implement functional clock switching via clock framework") in 2.6.37. CLKS parent clock switching using clock framework have to idle the McBSP before switching and then activate it again. This short break can cause a DMA transaction error to already running stream which halts and recovers only by closing and restarting the stream. This goes more fatal after commit e2fa61d ("OMAP3: l3: Introduce l3-interconnect error handling driver") in 2.6.39 where l3 driver detects a severe timeout error and does BUG_ON(). Fix this by not changing any configuration in omap_mcbsp_dai_set_dai_sysclk if the McBSP is already active. This test should have been here just from the beginning anyway. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-09-22ASoC: twl6040/sdp4430: Change legacy DAI namePeter Ujfalusi
Change the legacy DAI name from "twl6040-hifi" to "twl6040-legacy" to be more intuitive. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-22ASoC: omap-mcpdm: Replace legacy driverMisael Lopez Cruz
Reasons for the replacement: The current driver for McPDM was developed to support the legacy mode only. In preparation for the ABE support the current driver stack need the be replaced. The new driver is much simpler, easier to extend, and it also fixes some of the issues with the old stack. Main changes: - single file for omap-mcpdm (mcpdm.c/h removed) - Define names for registers, bits cleaned up, prefixed - Full-duplex audio operation (arecord | aplay) has been fixed - Less code McPDM need to be turned off after all streams has been stopped. This might cause pop noise on the output, if the codec's DAC is still powered at this time. Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Sebastien Guiriec <s-guiriec@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-22ASoC: OMAP4: McPDM: Convert to hwmod/omap_devicePeter Ujfalusi
In order to probe, and operate correctly, the OMAP McPDM driver needs to be converted to use hwmod. The device name has been changed to probe the driver. Replace the clk_* with pm_runtime_* calls to manage the clocks correctly. Missing request_mem_region/release_mem_region added. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-09-22ASoC: omap-mcpdm: Fix threshold and dma configurationPeter Ujfalusi
DMA packet_size must be configured based on the McPDM FIFO threshold value, number of channels. Due to the FIFO operation the DMA muse be configured differently for playback, and capture. At the same time fix the McPDM threshold values used for playback, and capture to avoid broken code. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-19ASoC: omap: Fix build errors in ams-deltaJarkko Nikula
Fix "error: too few arguments to function 'ams_delta_set_bias_level'" build errors in ams-delta.c that were introduced after commit d4c6005 ("ASoC: Add context parameter to card DAPM callbacks") by adding dapm context to ams_delta_set_bias_level calls. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-26Merge branch 'next/devel2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits) OMAP: Add debugfs node to show the summary of all clocks OMAP2+: hwmod: Follow the recommended PRCM module enable sequence OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming OMAP2+: PM: idle clkdms only if already in idle OMAP2+: clockdomain: add clkdm_in_hwsup() OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition() OMAP4: hwmod: Introduce the module control in hwmod control OMAP4: cm: Add two new APIs for modulemode control OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure OMAP4: hwmod data: Add PRM context register offset OMAP4: prm: Remove deprecated functions OMAP4: prm: Replace warm reset API with the offset based version OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros OMAP: hwmod: Wait the idle status to be disabled OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros OMAP2+: hwmod: Init clkdm field at boot time OMAP4: hwmod data: Add clock domain attribute OMAP4: clock data: Add missing divider selection for auxclks ...
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-07ASoC: twl6040: Move PLL selection to codec driverPeter Ujfalusi
It is better if the selection between the Low power, and High performance PLL is handled within the codec driver, not in machine driver(s) to avoid duplicated code, and also to have consistent tracking of the selected PLL, and the resulting differences in supported sample rates. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-05Merge branch 'for-3.1' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2011-07-04ASoC: twl6040: Convert into TWL6040 MFD childMisael Lopez Cruz
Convert TWL6040 CODEC driver into a TWL6040 MFD child, it implies that MFD-level operations like register accesses, clock setting and power management are done through MFD APIs, not directly by CODEC driver anymore. To avoid conflicts with the other MFD child, vibrator registers are skipped in CODEC driver. Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-04MFD: twl4030-codec -> twl4030-audio: Rename the driverPeter Ujfalusi
Rename the driver, and header file from twl4030-codec to twl4030-audio. To avoid breakage change depending drivers at the same time. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> CC: Misael Lopez Cruz <misael.lopez@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com>
2011-06-24treewide: Fix recieve/receive typosJoe Perches
Just spelling fixes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-07ASoC: core - Optimise and refactor pcm_new() to pass only rtdLiam Girdwood
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI. Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains card, pcm and DAI along with other members too that are useful too. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-06ASoC: Add context parameter to card DAPM callbacksMark Brown
The card callback will get called for each DAPM context in the card so it can be useful for it to know which device is currently undergoing a transition. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-06-03ASoC: OMAP: Update Makefile and Kconfig for HDMI audioRicardo Neri
Update Makefile and Kconfig to build HDMI audio support for OMAP4 SDP and Panda boards. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-06-03ASoC: OMAP4: Add HDMI Audio machine driver for OMAP4 boardsRicardo Neri
Add machine driver for HDMI audio on OMAP4 boards. This driver is in charge of putting together the HDMI audio codec and the CPU DAI and register the HDMI sound card with ALSA. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-06-03ASoC: OMAP: Add CPU DAI driver for HDMIRicardo Neri
Addition of the HDMI CPU DAI driver for OMAP4. This driver is in charge of configuring DMA settings for HDMI. Also, it finds the HDMI video device and determines if audio playback can proceed. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-26Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits) OMAP3: PM: Boot message is not an error, and not helpful, remove it OMAP3: cpuidle: change the power domains modes determination logic OMAP3: cpuidle: code rework for improved readability OMAP3: cpuidle: re-organize the C-states data OMAP3: clean-up mach specific cpuidle data structures OMAP3 cpuidle: remove useless SDP specific timings usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled usb: otg: OMAP4430: Fixing the omap4430_phy_init function usb: musb: am35x: fix compile error when building am35x usb: musb: OMAP4430: Power down the PHY during board init omap: drop board-igep0030.c omap: igep0020: add support for IGEP3 omap: igep0020: minor refactoring omap: igep0020: name refactoring for future merge with IGEP3 omap: Remove support for omap2evm arm: omap2plus: GPIO cleanup omap: musb: introduce default board config omap: move detection of NAND CS to common-board-devices omap: use common initialization for PMIC i2c bus omap: consolidate touch screen initialization among different boards ...
2011-05-13omap: Remove support for omap2evmTony Lindgren
The board support has never been merged for it as noticed by Russell King <linux@arm.linux.org.uk>. So let's remove the related dead code. Cc: linux-fbdev@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-13ASoC: omap-mcbsp: Remove restrictive checks for cpu typeSanjeev Premi
Current checks for cpu type were too restrictive leading to failures for other silicons in same family. The problem was found while testing audio playback on AM37x and AM35x processors. But should exist on OMAP36xx as well. Signed-off-by: Sanjeev Premi <premi@ti.com> cc: Mark Brown <broonie@opensource.wolfsonmicro.com> cc: Liam Girdwood <lrg@ti.com> cc: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-13ASoC: omap-pcm: Period wakeup disabling on OMAP2+Peter Ujfalusi
Allow disabling ALSA period wakeup interrupts. This can only be done on OMAP2+ (2/3/4), since there we can chain the DMA. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-11ASoC: RX51: Update e-mail addressPeter Ujfalusi
2011-05-11ASoC: omap-pcm: Update e-mail addressPeter Ujfalusi
2011-05-11ASoC: omap-mcbsp: Update e-mail addressPeter Ujfalusi
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
