Add SND_SOC_DAIFMT_CBM_CFS support for omap3/omap4. The patch was tested on
a pandaboard-es board connected to the pcm1792a codec. mcbspx_fsx must
configured as output and mcbspx_clkx must be configured as input.
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no
driver is bound) removes the need to set driver data field to
NULL.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Use the common DAI DMA data struct for omap, this allows us to use the common
helper function to configure the DMA slave config based on the DAI DMA data.
For omap-dmic and omap-mcpdm also move the DMA data from a global variable to
the driver state struct.
Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
The omap PCM driver provides a set_threshold callback which gets called by the
PCM driver when either playback or capture is started. The only DAI driver which
sets this callback is the mcbsp driver. This patch removes the callback from the
PCM driver and moves the invocation of the omap_mcbsp_set_threshold() function
to the mcbsp hw_params callback since this is the only place where the threshold
size can change. Doing so allows us to use the default dmaengine PCM trigger
callback in the omap PCM driver.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
We cannot include any plat or mach headers for the multiplatform
support.
Fix the issue by defining local mcbsp_omap1().
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This contains pretty many small commits covering fairly large range of
files in sound/ directory. Partly because of additional API support
and partly because of constantly developed ASoC and ARM stuff.
Some highlights:
- Introduced the helper function and documentation for exposing the
channel map via control API, as discussed in Plumbers; most of PCI
drivers are covered, will follow more drivers later
- Most of drivers have been replaced with the new PM callbacks (if
the bus is supported)
- HD-audio controller got the support of runtime PM and the support
of D3 clock-stop. Also changing the power_save option in sysfs
kicks off immediately to enable / disable the power-save mode.
- Another significant code change in HD-audio is the rewrite of
firmware loading code. Other than that, most of changes in
HD-audio are continued cleanups and standardization for the generic
auto parser and bug fixes (HBR, device-specific fixups), in
addition to the support of channel-map API.
- Addition of ASoC bindings for the compressed API, used by the
mid-x86 drivers.
- Lots of cleanups and API refreshes for ASoC codec drivers and
DaVinci.
- Conversion of OMAP to dmaengine.
- New machine driver for Wolfson Microelectronics Bells.
- New CODEC driver for Wolfson Microelectronics WM0010.
- Enhancements to the ux500 and wm2000 drivers
- A new driver for DA9055 and the support for regulator bypass mode."
Fix up various arm soc header file reorg conflicts.
* tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits)
ALSA: hda - Add new codec ALC283 ALC290 support
ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls
ALSA: hda - fix indices on boost volume on Conexant
ALSA: aloop - add locking to timer access
ALSA: hda - Fix hang caused by race during suspend.
sound: Remove unnecessary semicolon
ALSA: hda/realtek - Fix detection of ALC271X codec
ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310
ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event
ALSA: hda - make a generic unsol event handler
ASoC: codecs: Add DA9055 codec driver
ASoC: eukrea-tlv320: Convert it to platform driver
ALSA: ASoC: add DT bindings for CS4271
ASoC: wm_hubs: Ensure volume updates are handled during class W startup
ASoC: wm5110: Adding missing volume update bits
ASoC: wm5110: Add OUT3R support
ASoC: wm5110: Add AEC loopback support
ASoC: wm5110: Rename EPOUT to HPOUT3
ASoC: arizona: Add more clock rates
ASoC: arizona: Add more DSP options for mixer input muxes
Set the dma_data for the stream (snd_soc_dai_set_dma_data) at dai_startup
time so omap-pcm will have access to the needed information regarding to
the DMA channel earlier.
This is needed for the clean dmaengine support.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
omap-pcm can figure out the correct dma_type based on the stream's format.
In this way we can get rid of the plat/dma.h include from these drivers.
The omap-pcm platform driver no longer needs this parameter to select
between ELEMENT and PACKET mode. The selection is based on the configured
packet_size.
When McBSP is configured in threshold mode we can use sDMA packet mode in
all cases.
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the omap include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Benoît Cousson" <b-cousson@ti.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Jean Pihet <j-pihet@ti.com>
Cc: J Keerthy <j-keerthy@ti.com>
Cc: linux-omap@vger.kernel.org
As the interrupts should only be defined in the platform_data, and
eventually coming from device tree, there's no need to define them
in header files.
Let's remove the hardcoded references to irqs.h and fix up the includes
so we don't rely on headers included in irqs.h. Note that we're
defining OMAP_INTC_START as 0 to the interrupts. This will be needed
when we enable SPARSE_IRQ. For some drivers we need to add
#include <plat/cpu.h> for now until these drivers are fixed to
remove cpu_is_omapxxxx() usage.
While at it, sort som of the includes the standard way, and add
the trailing commas where they are missing in the related data
structures.
Note that for drivers/staging/tidspbridge we just define things
locally.
Cc: Paul Walmsley <paul@pwsan.com>
Since we always need to have set and get callbacks for McBSP sidetone it
makes sense to combine the two macro to create the two callbacks.
To remove duplicated code from the driver.
When asked to add the ST controls warn only if the st_data is missing.
In this way we do not block the otherwise functional card to probe.
In ddevice tree booted kernel all device have unique name and their device
id is set to 0.
Use the mcbsp->id for checking to decide which control set we should add
for McBSP sidetone handling.
Device tree support for McBSP modules on OMAP2+ SoC.
We can use the has_ccr flag to replace the cpu_is_omap* checks.
This provides future proof implementation and we do not need to update the
code if new OMAP revision starts to use the McBSP driver.
Remove the feature to configure the CLKR/FSR mux on McBSP port with 6pin
configuration.
When moving to devicetree these callback can no longer be used in a clean
way anymore.
If a board require to change the 6pin port to work in 4pin setup it needs
to set up the mux in the board file.
For OMAP2/3:
u32 devconf0;
/* McBSP1 CLKR/FSR signal to be connected to CLKX/FSX pin */
devconf0 = omap_ctrl_readl(OMAP2_CONTROL_DEVCONF0);
devconf0 |= OMAP2_MCBSP1_CLKR_MASK | OMAP2_MCBSP1_FSR_MASK;
omap_ctrl_writel(devconf0, OMAP2_CONTROL_DEVCONF0);
For OMAP4:
u32 mcbsp_pad;
/* McBSP4 CLKR/FSR signal to be connected to CLKX/FSX pin */
mcbsp_pad = omap4_ctrl_pad_readl(OMAP2_CONTROL_DEVCONF0);
mcbsp_pad |= ((1 << 31) | (1 << 30));
omap4_ctrl_pad_writel(mcbsp_pad, OMAP2_CONTROL_DEVCONF0);
In case when the kernel is booted with DT blob the pinctrl-single will be
provided as soon as it is enabled on the platform.
This patch add missing modules aliases to get sound working on omap devices.
Tested on Beagleboard xM rev. B.
This patch is against 3.5-rc6 vanilla.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Signed-off-by: Mans Rullgard <mans.rullgard@linaro.org>
From 18b1ba8becc3dd256bdaad2d825f46b551debda3 Mon Sep 17 00:00:00 2001
From: Guillaume GARDET <guillaume.gardet@oliseo.fr>
Date: Tue, 10 Jul 2012 13:47:16 +0200
Subject: [PATCH] Add missing modules aliases to fix audio on omap devices
In capture stream the buffer size does not need to be constrained to be
bigger then the McBSP FIFO.
In capture the FIFO content is taken out in period length burst, this
enusres that the FIFO is not going to overflow.
Signed-off-by: Liam Girdwood <lrg@ti.com>
The frame dma_op_mode has never been used, and it is just creating
confusion for users/developers.
Take the DMA packet mode into use when the McBSP is configured in element
dma_op_mode if the stream is not mono.
In this way we transfer one sample from/to McBSP FIFO upon DMA request.
This change only affects OMAP3+ versions, where the McBSP ports have FIFO.
We are setting SNDRV_PCM_HW_PARAM_BUFFER_SIZE based on
SNDRV_PCM_HW_PARAM_CHANNELS, not vice versa. This bug didn't
have much impact because the rules are evaluated multiple times
by the core, and intended value got set eventually.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Remove the no longer valid check for McBSP1 regarding to signal mux
selection (on OMAP4 McBSP4 has 6 pin setup).
Only clear the srgr2, pcr0 register configuration if the requested clock
configuration will actually going to touch it. In this way we can avoid
issues if the CLKR/FSR mux has been configured after the clock selection.
We are going to check for the valid McBSP port in the
omap_mcbsp_6pin_src_mux() function based on the validity of the mux_signal
callback (which is only valid for ports having 6 pin setup).
Use single function for the CLKR/FSR mux configuration.
OMAP2/3 has 6 pin configuration on McBSP1 instance, while on OMAP4
McBSP4 instance have the 6 pin configuration so the omap2_mcbsp1_mux_* is
not correct name for all support OMAP versions
Configure the DMA request line, port address, and stream name at
probe time instead of every time we start a stream.
These settings are static in the system.
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Since the drivers has been merged, merge the two structures together.
Use devm_* where it is possible to save on cleanup path.
Start merging the two mcbsp file content.
Move pm_runtime_enable/disable calls to ASoC probe, remove from module
probe/remove time.
We no longer need accessor functions for max_tx/rx_threshold, dma_op_mode
or for the FIFO size.
The OMAP McBSP driver stack used to contain two different
drivers. One of them was used as kind low-level access to
the IP, while the other driver was the ASoC DAI driver.
There were global, shared structures, in different places,
the McBSP instances are reffered with id numbers (sometimes
0 based, in other cases 1 based id numbers).
Create one single driver for OMAP McBSP with name: omap-mcbsp.
Convert the old omap-mcbsp driver initially to be a library
for the omap-mcbsp DAI driver. With this change we can get rid
of all global variables, structures.
Further cleanup is coming...
Move most of the content of the plat/mcbsp.h header file under
sound/soc/omap/ to help further cleanups.
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Allow McBSP FIFO configuration from ASoC dai driver
on OMAP4 platform.
Factor out some boilerplate code.
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
Signed-off-by: Michael Opdenacker <michael.opdenacker@linaro.org>
Before commit 75d9ac4 ("ASoC: Allow DAI formats to be specified in the
dai_link") expectation for omap-mcbsp was that snd_soc_dai_set_fmt is to be
called first in machine hw_params callback before other CPU DAI functions.
Thus it was enough that only omap_mcbsp_dai_set_dai_fmt cleared the
mcbsp->regs structure. [Note that this was pure convention, it's always
been OK to set things on init -- broonie]
Now this doesn't hold anymore since machine drivers can set the DAI format
only once on init time and thus mcbsp->regs may get out of sync when other
CPU DAI functions are modifying them dynamically with different values
between the calls. Therefore clear the accessed mcbsp->regs bits and
bitfields in other functions too.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Commit 75d9ac4 ("ASoC: Allow DAI formats to be specified in the dai_link")
changed DAI format flag values and we cannot simply invert anymore e.g.
frame-sync with ^= SND_SOC_DAIFMT_NB_IF (which was anyway misuse) as there
is no anymore fixed bit position for bit-clock or frame-sync inversion.
Fix this by relying only on DAI format flag values passed to us and by not
making any assumption on individual bit positions.
Fixes the following compile time warning:
omap-mcbsp.c:519: warning: suggest explicit braces to avoid ambiguous ‘else’
Attempt to change McBSP CLKS source while another stream is active is not
safe after commit d135865 ("OMAP: McBSP: implement functional clock
switching via clock framework") in 2.6.37.
CLKS parent clock switching using clock framework have to idle the McBSP
before switching and then activate it again. This short break can cause a
DMA transaction error to already running stream which halts and recovers
only by closing and restarting the stream.
This goes more fatal after commit e2fa61d ("OMAP3: l3: Introduce
l3-interconnect error handling driver") in 2.6.39 where l3 driver detects a
severe timeout error and does BUG_ON().
Fix this by not changing any configuration in omap_mcbsp_dai_set_dai_sysclk
if the McBSP is already active. This test should have been here just from
the beginning anyway.
Cc: stable@kernel.org
My gmail account got disabled and I'm not going to reopen it.
Acked-by: Liam Girdwood <lrg@ti.com>
Current checks for cpu type were too restrictive leading
to failures for other silicons in same family.
The problem was found while testing audio playback on
AM37x and AM35x processors. But should exist on OMAP36xx
as well.
Signed-off-by: Sanjeev Premi <premi@ti.com>
cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
cc: Liam Girdwood <lrg@ti.com>
cc: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Removed the use of macros to obtain base address and DMA channel number.
Instead use the McBSP driver API's that passes base address and DMA
channel number to the client driver.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
