path: root/sound/soc/fsl/pcm030-audio-fabric.c
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2009-08-07ASoC: Add missing DRV_NAME definitions for fsl/* driversTakashi Iwai
Module builds are broken due to missing DRV_NAME for efika-audio-fabric and pcm030-audio-fabric. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-26ASoC: Support for AC97 on Phytec pmc030 base board.Jon Smirl
A wm9712 AC97 codec is used. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
