This helps move us towards being able to remove the ASoC level I/O code.
Signed-off-by: Mark Brown <broonie@linaro.org>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
module_i2c_driver makes the code simpler by eliminating module_init
and module_exit calls.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
In order to support CODEC<->CODEC links remove the assumption that there
is only a single CODEC on a DAI link by removing the use of the CODEC
pointer in the rtd from the CODEC drivers. They are already being passed
their DAI whenever they are passed an rtd and can get the CODEC from
there.
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Signed-off-by: Liam Girdwood <lrg@ti.com>
Devices that aren't MFDs don't need to distinguish this.
The existence of this parameter is purely historical. None of the CODEC drivers
uses it and we always pass in the same value anyway, so it should be safe to
remove it.
Acked-by: Liam Girdwood <lrg@ti.com>
They've not been needed for a long time if they were ever required.
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
sound/soc/codecs/wm8940.c
According to the datasheet:
BCLK is controlled by BIT[4:2] of WM8940_CLOCK(06h) register.
Signed-off-by: Chris Paulson-Ellis <chris@edesix.com>
Reported-by: Chris Paulson-Ellis <chris@edesix.com>
Cc: stable@vger.kernel.org
The registers are 16 bits, thus remove an extra F for the mask.
The PLL Output clock division ratio is controlled by BIT[5:4] of
WM8940_GPIO register(08h).
Current code read/write the WM8940_ADDCNTRL(07h) register which is wrong.
Convert to snd_soc_cache_sync for sync reg_cache with the hardware.
The control_data field is used to initialize the codec's control_data field,
but since this is also done by the snd-soc-cache core, the redundant
assignment can be removed and the field can be dropped.
removing unnecessary if(ret) checks
This updated patch corrects a minor spelling problem in the commit message
and resolves two other (similar) issues found in wm8940.c by Jonathan Cameron.
Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but there are quite a few drivers left which now have an unused reg_cache field in
their private device struct.
This patch removes these unused fields.
Some codec drivers do not initialize the control_type field in their private
device struct, but still use it when calling snd_soc_codec_set_cache_io.
This patch fixes the issue by properly initializing it in the drivers probe
functions.
Cc: stable@kernel.org (for 2.6.37 only)
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
The reg_cache_size is the number of elements in the register cache,
not the size of the cache itself. This is not a problem if the size
of each element of the cache is 1 byte but it matters in any other
case.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch adds checking for wm8940_register return value,
and does kfree(wm8940) if wm8940_register() fail.
sound/soc/codecs/ad1938.c
The core will ensure that the device is in either STANDBY or OFF bias
before suspending, restoring the bias in the driver is unneeded. Some
drivers doing slightly more roundabout things have been left alone
for now.
Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
One of the features of the multi CODEC work is that it embeds a struct
device in the CODEC to provide diagnostics via a sysfs class rather than
via the device tree, at which point it's much better to use the struct
device private data rather than having two places to store it. Provide
an accessor function to allow this change to be made more easily, and
update all the CODEC drivers are updated.
To ensure use of the accessor the private data structure member is
renamed, meaning that if code developed with older an older core that
still uses private_data is merged it will fail to build.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Sevelar ASoC codec drivers wrongly assume, that the params_rate() macro
returns one of SNDRV_PCM_RATE_* defines instead of the actual numerical
sampling rate. Fix them.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
The DAPM widgets are now insntantiated by the core when creating the card
so there is no need for the individual CODEC drivers to do so.
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
The PM core will grow pm_link infrastructure in 2.6.33 which can be
used to implement the intended functionality of the ASoC-specific
device suspend and resume callbacks so drop them.
Fix for typo in commit 8d50e447d19fec64adebeef55f2b60d695435412
ASoC: Factor out I/O for Wolfson 8 bit data 16 bit register CODECs
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
More and more devices feature PLLs and FLLs with the ability to select
between multiple input clocks. In order to better support these devices
a new argument, source, has been added to the set_pll() configuration
API. Using set_clkdiv() is often difficult due to the need to stop the
PLL/FLL before any reconfiguration can be done.
