[ Upstream commit 2dab09be49a1e7a4dd13cb47d3a1441a2ef33a87 ]
This driver misses calls to pm_runtime_disable and regulator_bulk_disable
in remove and a call to free_irq in probe failure.
Add the calls to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
Link: https://lore.kernel.org/r/20191118073633.28237-1-hslester96@gmail.com
Signed-off-by: Mark Brown <broonie@kernel.org>
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
To allow for more flexibility in naming of DSP-type cores
move the creation of the firmware controls to the codec
drivers instead of having a hardcoded list in wm_adsp.
Signed-off-by: Richard Fitzgerald <rf@opensource.cirrus.com>
Trivial fix to spelling mistakes in SND_SOC_BYTES literal strings
Now we can replace Codec to Component. Let's do it.
Note:
xxx_codec_xxx() -> xxx_component_xxx()
.idle_bias_off = 1 -> .idle_bias_on = 0
.ignore_pmdown_time = 1 -> .use_pmdown_time = 0
- -> .endianness = 1
- -> .non_legacy_dai_naming = 1
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
wm2200 is the only user of snd_soc_dai::symmetric_rates.
Now, wm2200 is using single DAI on Component.
Thus, wm2200_priv : snd_soc_dai : snd_soc_component are 1 : 1 : 1.
We can replace snd_soc_dai::symmetric_rates on wm2200_priv.
snd_soc_codec_get_drvdata() is common function to get
private data. Let's use it.
The core expects "const char * const" and "unsigned int" for enum
controls, the mixer control definitions in wm2200 use "const char *"
and "int". This patch corrects the type of these arrays.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Check for snd_soc_codec_driver structures that are only passed to
snd_soc_register_codec or memcpy (2nd arg), for which the corresponding
parameters are declared const. Declare as const snd_soc_codec_driver
structures that have these properties.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_soc_codec_driver i@p = { ... };
@ok@
identifier r.i;
expression e1,e2,e3;
position p;
snd_soc_register_codec(e1,&i@p,e2,e3)
memcpy(e1,&i@p,e2)
@bad@
position p != {r.p,ok.p};
identifier r.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct snd_soc_codec_driver i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
codec driver and component driver has duplicated callback functions,
and codec side functions are just copied to component side when
register timing. This was quick-hack, but no longer needed.
This patch moves these functions from codec driver to component driver.
'asoc/topic/ux500' and 'asoc/topic/width' into asoc-next
'asoc/topic/rl6231', 'asoc/topic/rockchip' and 'asoc/topic/rt286' into asoc-next
'asoc/topic/qcom' into asoc-next
Signed-off-by: Axel Lin <axel.lin@ingics.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap into asoc-reg-default
regmap: Create a new struct reg_sequence for register sequences
In order to allow us to start adding extra annotations for sequences
without bloating register default tables duplicate the structure under
the new name reg_sequence and update the APIs to use that instead of
reg_default.
sound/soc/codecs/da7210.c
sound/soc/codecs/rt5651.c
sound/soc/codecs/wm8993.c
The dev_pm_ops variables are not modified after initialization in these
drivers, so make them const.
Separate the functionality using sequences of register writes from the
functions that take register defaults. This change renames the arguments
in order to support the extension of reg_sequence to take an optional
delay to be applied after any given register in a sequence is written.
This avoids adding an int to all register defaults, which could
substantially increase memory usage for regmaps with large default tables.
This also updates all the clients of multi_reg_write/register_patch.
Signed-off-by: Nariman Poushin <nariman@opensource.wolfsonmicro.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-max9877
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Peter Rosin <peda@axentia.se>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
The rate controls are codec-specific, it's not possible to
generically say what the range or the meaning of each control
is (or even if they exist at all) - that depends on the
particular codec.
This is currently being handled for Arizona codecs by putting
an Arizona-specific table of controls inside the wm_adsp driver.
This creates a dependency between wm_adsp and arizona.c, and is an
awkward solution if the ADSP is used in another family of codecs
Fix this by moving the Arizona-specific rate controls into the
Arizona codec drivers.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
The default value for the bias_level is SND_SOC_BIAS_OFF when probe is being
called, there is no need to initialize it explicitly.
return type of wait_for_completion_timeout is unsigned long not int. An
appropriately named unsigned long is added and the assignment fixed up.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under sound/.
Acked-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
Acked-by: Brian Austin <brian.austin@cirrus.com>
Acked-by: Mark Brown <broonie@kernel.org>
SND_SOC_DAPM_VALUE_MUX and SOC_DAPM_VALUE_ENUM are deprecated and merely an
alias for SND_SOC_DAPM_MUX and SOC_DAPM_ENUM. Replace the deprecated macros so
we can eventually remove their definition.
Signed-off-by: Mark Brown <broonie@linaro.org>
For some CODEC drivers like who act as the MFDs children are ignored
by this patch.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Just replace with the helper macro. No functional change at all.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Now that we have regular register mapped controls we should be splitting
the control sets for ADSP1 and ADSP2 as the register maps are not
identical. Do that.
Signed-off-by: Chris Rattray <crattray@opensource.wolfsonmicro.com>
Cc: stable@vger.kernel.org
Allows ADSP control code to set the dsp clock rate to match the
sys clock rate.
These are not supported.
According to the defines in wm2200.h:
* R1284 (0x504) - Audio IF 1_5
We should not left shift 1 bit for fmt_val when setting dai format.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Removed unnecessary labels probably left out of some previous cleanup.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Fix wm2200.c printk format warnings (seen on x86_64):
sound/soc/codecs/wm2200.c:1027:4: warning: format '%d' expects type 'int', but argument 4 has type 'size_t'
sound/soc/codecs/wm2200.c:1139:5: warning: format '%d' expects type 'int', but argument 5 has type 'long unsigned int'
sound/soc/codecs/wm2200.c:1181:2: warning: format '%d' expects type 'int', but argument 7 has type 'size_t'
sound/soc/codecs/wm2200.c:1201:5: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'long unsigned int'
sound/soc/codecs/wm2200.c:1264:4: warning: format '%d' expects type 'int', but argument 4 has type 'size_t'
sound/soc/codecs/wm2200.c:1328:5: warning: format '%d' expects type 'int', but argument 5 has type 'long unsigned int'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Allow a coefficient set provided using the Wolfson callibration tools to
be provided along with the firmware files. Currently only coefficient
files which configure absolute register addresses are supported.
Support download and execution of firmwares to the DSPs on the WM2200.
Use the regmap ranges support to add the WM2200 DSP core memory pages
into the "register map" beyond the end of the real register map. We
don't extend beyond 16 bits since the regmap API will iterate over
every register doing diagnostics.
