Disconnect also the path to AUXL from the HF path during digital_mute to
avoid pop noise leakage to Line-out pads.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
When the codec is in standby we do not need to keep the HPPLL active.
Use to_platform_device() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
'asoc/topic/wm5100', 'asoc/topic/wm8741' and 'asoc/topic/wm8960' into asoc-next
The dapm field of the snd_soc_codec struct is eventually going to be
removed, in preparation for this replace all manual access to
codec->dapm with snd_soc_codec_get_dapm().
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
So pass the IRQF_ONESHOT flag in this case.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/irqf_oneshot.cocci.
All drivers have the same line at the end of the set_bias_level callback to
update the bias_level state. Move this update into
snd_soc_dapm_force_bias_level() and remove them from the drivers.
Use the new snd_soc_codec_force_bias_level() helper function to invoke the
bias_level callback of a driver instead of calling the callback by hand.
Currently the effect of this is the same, but having all bias level updates
go through a central place will allow us to move more of the bias level
management into the DAPM core.
The codec field of the snd_soc_widget struct is eventually going to be
removed, use snd_soc_dapm_to_codec(w->dapm) instead.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Set the CODEC driver's suspend_bias_off flag rather than manually going to
SND_SOC_BIAS_OFF in suspend and SND_SOC_BIAS_STANDBY in resume. This makes
the code a bit shorter and cleaner.
Since the ASoC core now takes care of setting the bias level to
SND_SOC_BIAS_OFF when removing the CODEC there is no need to do it manually
anymore either.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
For CODEC controls snd_kcontrol_chip() currently returns a pointer to the
CODEC that registered the control. With the upcoming consolidation of
platform and CODEC controls this will change. Prepare for this by introducing
the snd_soc_kcontrol_codec() helper function that will hide the implementation
details of how the CODEC for a control can be obtained. This will allow us to
change this easily in the future.
The patch also updates all CODEC drivers to use the new helper function.
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Just replace with the helper macro.
Also, use ARRAY_SIZE() in some ASOC_ENUM_SINGLE() lines.
No functional change at all.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
The rate constraints in this driver are shared between all device instances. It
should not be (and is not) modified at runtime, so make them const.
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
We can rely on mfd driver to manage the register caching via regmap. The
driver still need to cache some registers associated with DL1/2 routes.
The MFD core takes care of the restore via standard regmap API, no need to
do this anymore here.
Introduce a small register cache for registers which needs special caching
to reduce pop noise:
TWL6040_REG_HSLCTL, TWL6040_REG_HSRCTL, TWL6040_REG_EARCTL, TWL6040_REG_HFLCTL
and TWL6040_REG_HFRCTL.
Switch over and use the new small cache for these registers instead of the
main reg_cache.
This is in preparation to remove the local ASoC reg_cache from the driver.
Matches more precisely of the functionality.
By using the new virtual DAPM mixer controls it is possible to remove the
twl6040 specific implementation of virtual controls.
Redundant semicolon removed.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
We use the same 3 lines to get the CODEC for a kcontrol in a quite a few places.
This patch puts them into a common helper function. Having this encapsulated in
a helper function will also make it more easier to eventually change the data
layout of the kcontrol's private data.
The accessory detect debounce work is not performance sensitive so let
the scheduler run it wherever is most efficient rather than in a per CPU
workqueue by using the system power efficient workqueue.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
To reduce pop noise during playback stream start and stop the codec needs
to have the digital_mute callback implemented.
The codec need to be muted before the CPU dai has been stopped (McPDM).
Stopping the McPDM will generate a pop on the codec since no signal on the
PDM bus means full negative amplitude.
By managing the mute/unmute state of the outputs we can decrease the amount
of pop noise when playback starts or stops.
Later we can identify the DAIs by this ID number.
We need to free the irq at twl6040_remove() which is called when the machine
driver has been removed (the card has been removed).
If we fail to do that, next time when the machine driver is loaded the
codec's probe will fail since the irq has been already requested.
The code to do the ramp has been removed a long time ago. Remove the
remaining code as well since this is not needed.
There's no need to create a queue for this anymore
In this way we can clean up the probe and remove paths
No need to set the bias_level twice to _STANDBY - since this is the only
state the device could be at suspend time. The driver do not support
idle_bias_off yet.
Convert headset PLUGINT interrupt to NO_SUSPEND type in order to
allow handling of insertion/removal events while device is suspended.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Fixes commit: 805238b ASoC: twl6040: Convert to use DAI DAPM widgets
where the connection between the stream widgets and the ADC widgets was
reversed and because of this on capture the DAPM is not powering up the
codec.
Use DAPM mapping for stream events and give unique names for the streams.
This change also fixes the following warning:
twl6040-codec twl6040-codec: Failed to create Capture debugfs file
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD bits from Samuel Ortiz:
"We have support for a few new drivers:
- Samsung s2mps11
- Wolfson Microelectronics wm5102 and wm5110
- Marvell 88PM800 and 88PM805
- TI twl6041
We also have our regular driver improvements:
- Device tree and IRQ domain support for STE AB8500
- Regmap and devm_* API conversion for TI tps6586x
- Device tree support for Samsung max77686
- devm_* API conversion for STE AB3100
Besides that, quite a lot of fixing and cleanup for mc13xxx, tps65910,
tps65090, da9052 and twl-core."
Fix up mostly trivial conflicts, with the exception of
drivers/usb/host/ehci-omap.c in particular, which had some
re-organization of the reset sequence (commit 1a49e2ac9651: "EHCI:
centralize controller initialization") that clashed with commit
2761a6394516 ("mfd: USB: Fix the omap-usb EHCI ULPI PHY reset fix
issues").
In particular, commit 2761a6394516 moved the usb_add_hcd() to the
*middle* of the reset sequence, which clashes fairly badly with the
reset sequence re-organization (although it could have been done inside
the new omap_ehci_init() function).
I left that part of commit 2761a6394516 just undone.
* tag 'mfd-3.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (110 commits)
mfd: Ensure AB8500 platform data is passed through db8500-prcmu to MFD Core
mfd: Arizone core should select MFD_CORE
mfd: Fix arizona-irq.c build by selecting REGMAP_IRQ
mfd: Add debug trace on entering and leaving arizone runtime suspend
mfd: Correct tps65090 cell names
mfd: Remove gpio support from tps6586x core driver
ARM: tegra: defconfig: Enable tps6586x gpio
gpio: tps6586x: Add gpio support through platform driver
mfd: Cache tps6586x register through regmap
mfd: Use regmap for tps6586x register access.
mfd: Use devm managed resources for tps6586x
input: Add onkey support for 88PM80X PMIC
mfd: Add support for twl6041
mfd: Fix twl6040 revision information
mfd: Matches should be NULL when populate anatop child devices
input: ab8500-ponkey: Create AB8500 domain IRQ mapping
mfd: Add missing out of memory check for pcf50633
Documentation: Describe the AB8500 Device Tree bindings
mfd: Add tps65910 32-kHz-crystal-input init
mfd: Drop modifying mc13xxx driver's id_table in probe
twl6040 ES1.1 and ES1.2 have the same revid (0x01).
ES1.3 of twl6040 REVID is 0x02.
Fix spelling mistake in "High-Performance" option of twl6040 power mode.
Signed-off-by: Simon Wilson <simonwilson@google.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
Linux 3.4-rc7
Conflicts):
drivers/base/regmap/regmap.c (overlap with bug fixes)
sound/soc/blackfin/bf5xx-ssm2602.c (overlap with bug fixes)
None of the machines uses the gain ramp possibility for HS/HF.
This code path is mostly unused and it does not reduces the pop
noise on the output (it alters it to sound a bit different).
The preferred method to reduce pop noise is to use ABE.
Remove the gain ramp, and related features form the driver.
Complete the separation of the twl6040 from the twl core since
it is a separate chip, not part of the twl6030 PMIC.
Make the needed Kconfig changes for the depending drivers at the
same time to avoid breaking the kernel build (vibra, ASoC components).
Reviewed-by: Mark Brown <broonie@opensource.wolfsonicro.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
In order to support CODEC<->CODEC links remove the assumption that there
is only a single CODEC on a DAI link by removing the use of the CODEC
pointer in the rtd from the CODEC drivers. They are already being passed
their DAI whenever they are passed an rtd and can get the CODEC from
there.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into topic/asoc
This has been a very active release for ASoC, as well as the usual raft
of bugfixes and driver updates there's quite a few framework enhancements.
Most are either small or are laying the groundwork for user visible
features (especially dynamic PCM), the most directly visible change is
the dmaengine library. There's also a bunch of regmap API enhancements
pulled into the tree so that either the framework or drivers can take
advantage of the new features.
Changes include:
- Support for widgets not associated with a CODEC, an important part of
the dynamic PCM framework.
- A library factoring out the common code shared by dmaengine based DMA
drivers contributed by Lars-Peter Clausen. This will save a lot of
code and make it much easier to deploy enhancements to dmaengine.
- Support for binary controls, used for providing runtime configuration
of algorithm coefficients.
- A new DAPM widget type for regulator supplies allowing drivers for
devices that can power down unused supplies while active to do without
any per-driver code.
- DAPM widgets for DAIs, initially giving a speed boost for playback
startup and shutdown and also the basis for CODEC<->CODEC DAI link
support.
- Support for specifying the number of significant bits on audio
interfaces, useful for allowing applications to know how much effort to
put into generating data for a larger sample format.
- Conversion of the FSI driver used on some SH processors to DMAEngine.
- New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200.
It's set unconditionally.
Acked-by: Liam Girdwood <lrg@ti.com>
In order to avoid breakage change the omap-abe-twl6040
machine driver's routing.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Provide a method for mach drivers to query the HS DC offset step size in mV.
The DL1 PDM interface adds a little gain depending on the output device.
Add a method to retrieve the gain value for machine driver usage.
The existence of this parameter is purely historical. None of the CODEC drivers
uses it and we always pass in the same value anyway, so it should be safe to
remove it.
Factors out a bit of boilerplate.
