path: root/sound/soc/codecs/tlv320dac33.c
2018-11-16ASoC: tlv320dac33: clean up indentation, remove extraneous tabColin Ian King
The goto statement is indented too much by one level, fix this by removing the extraneous tab. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-02-12ASoC: tlv320dac33: replace codec to componentKuninori Morimoto
Now we can replace Codec to Component. Let's do it. Note: xxx_codec_xxx() -> xxx_component_xxx() .idle_bias_off = 1 -> .idle_bias_on = 0 .ignore_pmdown_time = 0 -> .use_pmdown_time = 1 - -> .endianness = 1 - -> .non_legacy_dai_naming = 1 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-01-16ASoC: tlv320dac33: fix regression by adding back .read/.writeKuninori Morimoto
commit c4305af43a8 ("ASoC: use internal reg_cache on tlv320dac33") removed .read/.write from driver, but it might breaks non-regmap driver, because ALSA SoC framework might call it. To fix this regression, this patch back .read/.write Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-11-27ASoC: use internal reg_cache on tlv320dac33Kuninori Morimoto
Codec reg_cache is legacy feature and very few driver only are using it. But, ALSA SoC framework needs to support it. Codec will be merged into Component in the future, so, let's remove legacy and unused feature from framework. This patch implements ALSA SoC reg_cache feature into driver, and don't use ALSA SoC framework's feature. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-11-27ASoC: don't use codec hw_write on tlv320dac33Kuninori Morimoto
uda1380 driver is using codec hw_write/control_data, but it is redundant code. This patch cleanup these Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-08-10ASoC: codecs: add const to snd_soc_codec_driver structuresBhumika Goyal
Declare snd_soc_codec_driver structures as const as they are only passed as an argument to the function snd_soc_register_codec. This argument is of type const, so declare the structures with this property as const. In file codecs/sn95031.c, snd_soc_codec_driver structure is also used in a copy operation along with getting passed to snd_soc_register_codec. So, it can be made const too. Done using Coccinelle: @match disable optional_qualifier@ identifier s; position p; @@ static struct snd_soc_codec_driver s@p={...}; @good1@ identifier match.s; position p; @@ snd_soc_register_codec(...,&s@p,...) @bad@ identifier match.s; position p!={match.p,good1.p}; @@ s@p @depends on !bad disable optional_qualifier@ identifier match.s; @@ static +const struct snd_soc_codec_driver s={...}; Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-29Merge remote-tracking branches 'asoc/topic/tas5086', 'asoc/topic/tegra', ↵Mark Brown
'asoc/topic/tlv320aic31xx', 'asoc/topic/tlv320dac33' and 'asoc/topic/topology' into asoc-next
2016-09-14ASoC: tlv320dac33: Remove deprecated create_singlethread_workqueueBhaktipriya Shridhar
The workqueue "dac33_wq" queues a single work item &dac33->work and hence doesn't require ordering. Also, it is not being used on a memory reclaim path. Hence, it has been converted to use system_wq. System workqueues have been able to handle high level of concurrency for a long time now and hence it's not required to have a singlethreaded workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue created with create_singlethread_workqueue(), system_wq allows multiple work items to overlap executions even on the same CPU; however, a per-cpu workqueue doesn't have any CPU locality or global ordering guarantee unless the target CPU is explicitly specified and thus the increase of local concurrency shouldn't make any difference. The work item has been flushed in dac33_soc_remove to ensure that there are no pending tasks while disconnecting the driver. Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-08-08ASoC: codec duplicated callback function goes to component on tlv320dac33Kuninori Morimoto
codec driver and component driver has duplicated callback functions, and codec side functions are just copied to component side when register timing. This was quick-hack, but no longer needed. This patch moves these functions from codec driver to component driver. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-03-01ASoC: tlv320dac33: Fix enum ctl accesses in a wrong typeTakashi Iwai
"FIFO Mode" ctl in tlv320dac33 codec driver is enum, while the current driver accesses wrongly via value.integer.value[]. They have to be via value.enumerated.item[] instead. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-15ASoC: drivers: Drop owner assignment from i2c_driverKrzysztof Kozlowski
i2c_driver does not need to set an owner because i2c_register_driver() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-05-15ASoC: tlv320dac33: Replace direct snd_soc_codec dapm field accessLars-Peter Clausen
The dapm field of the snd_soc_codec struct is eventually going to be removed, in preparation for this replace all manual access to codec->dapm.bias_level with snd_soc_codec_get_bias_level(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-04-27ASoC: Move bias level update to the coreLars-Peter Clausen
All drivers have the same line at the end of the set_bias_level callback to update the bias_level state. Move this update into snd_soc_dapm_force_bias_level() and remove them from the drivers. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-01-15ASoC: tlv320dac33: Replace w->codec snd_soc_dapm_to_codec(w->dapm)Lars-Peter Clausen
The codec field of the snd_soc_widget struct is eventually going to be removed, use snd_soc_dapm_to_codec(w->dapm) instead. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-27ASoC: tlv320dac33: Cleanup manual bias level transitionsLars-Peter Clausen
Since the ASoC core now takes care of setting the bias level to SND_SOC_BIAS_OFF when removing the CODEC there is no need to do it manually anymore. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-08-04Merge remote-tracking branches 'asoc/topic/tlv320aic3x', 'asoc/topic/width', ↵Mark Brown
'asoc/topic/wm0010', 'asoc/topic/wm8904' and 'asoc/topic/wm8962' into asoc-next
2014-07-31ASoC: tlv320dac33: Convert to params_width()Mark Brown
The CODEC doesn't care how data is laid out in memory. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2014-06-21ASoC: Move name and id from CODEC/platform to componentLars-Peter Clausen
The component struct already has a name and id field which are initialized to the same values as the same fields in the CODEC and platform structs. So remove them from the CODEC and platform structs and used the ones from the component struct instead. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-22Merge remote-tracking branches 'asoc/topic/rt5651', 'asoc/topic/samsung', ↵Mark Brown
'asoc/topic/sgtl5000', 'asoc/topic/sh', 'asoc/topic/simple', 'asoc/topic/sirf', 'asoc/topic/sta350' and 'asoc/topic/tlv320dac33' into asoc-next
2014-04-25ASoC: tlv320dac33: Use devm_regulator_bulk_get()Fabio Estevam
Using devm_regulator_bulk_get() can make the code cleaner and smaller as we do not need to call regulator_bulk_free() in the error and remove paths. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-14ASoC: Add snd_soc_kcontrol_codec() helper functionLars-Peter Clausen
For CODEC controls snd_kcontrol_chip() currently returns a pointer to the CODEC that registered the control. With the upcoming consolidation of platform and CODEC controls this will change. Prepare for this by introducing the snd_soc_kcontrol_codec() helper function that will hide the implementation details of how the CODEC for a control can be obtained. This will allow us to change this easily in the future. The patch also updates all CODEC drivers to use the new helper function. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-13Merge remote-tracking branch 'asoc/topic/io' into asoc-nextMark Brown
2014-03-12Merge remote-tracking branches 'asoc/topic/tlv320aic23', ↵Mark Brown
'asoc/topic/tlv320aic26', 'asoc/topic/tlv320aic32x4', 'asoc/topic/tlv320aic3x', 'asoc/topic/tlv320dac33', 'asoc/topic/twl4030', 'asoc/topic/twl6040', 'asoc/topic/uda1380', 'asoc/topic/wl1273' and 'asoc/topic/wm2200' into asoc-next
2014-03-11ASoC: io: New signature for snd_soc_codec_set_cache_io()Xiubo Li
Now that all users have been converted to regmap and the config.reg_bits and config.val_bits can be setted by each user through regmap core API. So these two params are redundant here. Since the only control type that left is SND_SOC_REGMAP, so remove it. Drop the control params and add struct regmap *regmap to simplify the code. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-06ASoC: Add helper function to check whether a CODEC is activeLars-Peter Clausen
Instead of directly checking the 'active' field of the CODEC struct add a new helper function that will return either true or false depending on whether the CODEC is active. This will make the migration to the component level easier. The patch also updates all CODEC drivers that check the active attribute to use the new helper function. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-23ASoC: tlv320dac33: Use SOC_ENUM_SINGLE_*_DECL()Takashi Iwai
Just replace with the helper macros. No functional change at all. Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-01-13ASoC: tlv320dac33: Remove suspend/resume soc driver operationsPeter Ujfalusi
With idle_bias_off these are no longer needed. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: codecs: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-06ASoC: tlv320dac33: Use module_i2c_driverSachin Kamat
module_i2c_driver makes the code simpler by eliminating module_init and module_exit calls. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-04ASoC: codecs: Remove rtd->codec usage from CODEC driversMark Brown
In order to support CODEC<->CODEC links remove the assumption that there is only a single CODEC on a DAI link by removing the use of the CODEC pointer in the rtd from the CODEC drivers. They are already being passed their DAI whenever they are passed an rtd and can get the CODEC from there. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-04ASoC: core: Add support for DAI and machine kcontrols.Liam Girdwood
Currently ASoC can only add kcontrols using codec and platform component device handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for SoC card machine drivers too. This allows the kcontrol to have a direct handle to the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily get it's private data. This change makes snd_soc_add_controls() static and wraps it in the folowing calls (card and dai are new) :- snd_soc_add_card_controls() snd_soc_add_codec_controls() snd_soc_add_dai_controls() snd_soc_add_platform_controls() This patch also does a lot of small mechanical changes in individual codec drivers to replace snd_soc_add_controls() with snd_soc_add_codec_controls(). It also updates the McBSP DAI driver to use snd_soc_add_dai_controls(). Finally, it updates the existing machine drivers that register controls to either :- 1) Use snd_soc_add_card_controls() where no direct codec control is required. 2) Use snd_soc_add_codec_controls() where there is direct codec control. In the case of 1) above we also update the machine drivers to get the correct component data pointers from the kcontrol (rather than getting the machine pointer via the codec pointer). Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-27ASoC: Set idle_bias_off flag in snd_soc_codec_driverAxel Lin
Since commit 33c5f969 "ASoC: Allow idle_bias_off to be specified in CODEC drivers", now we can set idle_bias_off flag in struct snd_soc_codec_driver for devices can unconditionally support idle_bias_off. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-21ASoC: Fix build of tlv320dac33Mark Brown
The problem was introduced due to the obscure formatting some of the older drivers use. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-20ASoC: tlv320dac33: Use core to set the msbits constraintPeter Ujfalusi
Core can set the msbits constraint in behalf of the dai. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-02ASoC: Convert tlv320dac33 to devm_kzalloc()Axel Lin
2011-12-02ASoC: Drop unused state parameter from CODEC suspend callbackLars-Peter Clausen
The existence of this parameter is purely historical. None of the CODEC drivers uses it and we always pass in the same value anyway, so it should be safe to remove it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-27ASoC: Remove unneeded platform_device.h inclusions from CODECsMark Brown
They've not been needed for a long time if they were ever required. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: Constify snd_soc_dai_ops structsLars-Peter Clausen
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure") introduced the possibility to have constant DAI ops structures, yet this is barley used in both existing drivers and also new drivers being submitted, although none of them modifies its DAI ops structure. The later is not surprising since existing drivers are often used as templates for new drivers. So this patch just constifies all existing snd_soc_dai_ops structs to eliminate the issue altogether. The patch was generated with the following coccinelle semantic patch: // <smpl> @@ identifier ops; @@ -struct snd_soc_dai_ops ops = +const struct snd_soc_dai_ops ops = { ... }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-27Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-10-11ASoC: tlv320dac33: Convert to table based initPeter Ujfalusi
2011-09-29ASoC: tlv320dac33: Add guarding parentheses to macrosAxel Lin
Put parentheses around macro argument uses. This avoids pitfalls for the programmer, where the argument expansion does not give the expected result, for example: SAMPLES_TO_US(substream->runtime->rate, dac33->uthr - DAC33_MODE7_MARGIN + 1); Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-11ASoC: tlv320dac33: Update e-mail addressPeter Ujfalusi
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-10Merge branch 'for-2.6.40' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2011-04-13ASoC: tlv320dac33: Lower the OSC calibration timePeter Ujfalusi
To get correct calibration, we can decrease the time needed for the OSC to calibrate itself. With this change we can save ~15ms in the OSC calibration phase. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-03-28Merge branch 'for-2.6.39' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into fix/asoc
2011-03-26ASoC: tlv320dac33: Move codec power up to DAPMPeter Ujfalusi
Move the codec power on (in reg 0x01, bit 4) from set_bias_level:SND_SOC_BIAS_ON to a DAPM supply. In this way we can be sure, that all the things within the codec is powered before the external amp is going to be enabled. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26ASoC: tlv320dac33: Restore L/R DAC power control registerPeter Ujfalusi
Register 0x40, 0x41 need to be restored after power up, since it contains gain related fields, which affects playback volume. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
