This moves us towards being able to remove the duplicated register I/O
code in ASoC.
The datasheet and the driver document the device as having a register map
divided into pages but since the paging is actually done by sending the
page address and the register address with each transaction this is no
different to having a simple register address. The datasheet does also
document the low five bits of the 16 bit "command" as unused which we could
represent as padding but it seems simpler and less confusing to things
that use block transfers or autoincrement to represent these as part of
the register address.
Signed-off-by: Mark Brown <broonie@linaro.org>
Use snd_soc_update_bits() rather than open coding. Since the register cache
is currently only used where update_bits() is used this means the current
register cache can be removed entirely.
Provide external widgets for the CODEC to ensure the device continues to
function with DAPM mandatory and to make it easier to hook the device up
to other components.
Use the core to do I/O rather than directly calling the driver operations
in order to support further refactoring.
The tlv320aic26 contains a embedded snd_soc_codec struct which is referenced in
the keyclick code. That struct is never initialized though, replace the embedded
struct with a pointer and use that in the keyclick code.
module_spi_driver makes the code simpler by eliminating
module_init and module_exit calls.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
In order to support CODEC<->CODEC links remove the assumption that there
is only a single CODEC on a DAI link by removing the use of the CODEC
pointer in the rtd from the CODEC drivers. They are already being passed
their DAI whenever they are passed an rtd and can get the CODEC from
there.
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Signed-off-by: Liam Girdwood <lrg@ti.com>
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
The current PLL configuration code for the tlc320aic26 codec appears to assume a
hardcoded system clock of 12 MHz. Use the clock value provided by the DAI_OPS
API for the calculation.
Tested using a MityDSP-L138 platform providing a 24.576 MHz clock.
Signed-off-by: Michael Williamson <michael.williamson@criticallink.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but there are quite a few drivers left which now have an unused reg_cache field in
their private device struct.
This patch removes these unused fields.
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
sound/soc/codecs/ad1938.c
Conversions to snd_soc_codec_{get|set}_drvdata() were missing in some files
in the previous commit.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
The drivers are basically duplicating the same code over and over.
As snd_soc_cnew is going to be made static some time after the next
merge window, we might as well convert them now.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Considering the fact that most cpu_dai or codec_dai are using a same
'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better
made a pointer instead, to make sharing easier and code a bit cleaner.
The patch below is rather preliminary since the asoc tree is being
actively developed, and this touches almost every piece of code,
(and possibly many others in development need to be changed as
well). Building of all codecs are OK, yet to every SoC, I didn't test
that.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
This is a further stage on the road to refactoring away the ASoC
platform device.
Currently this is done at module probe time since ASoC ties in codec
device probe to the instantiation of the entire ASoC device. Subsequent
patches will refactor the codec drivers to handle probing separately.
Note that the core does not yet use this information.
AC97 is special since the codec is controlled over the AC97 link but
we want to give the machine driver a chance to set up the system before
trying to instantiate since it may need to do configuration before the
AC97 link will operate
Currently ASoC card initialisation is completed by a function called
snd_soc_register_card(). As part of the work to allow independant
registration of cards, codecs and machines in ASoC v2 a new function of
the same name has been added so rename the existing function to
facilitate the merge of v2.
Liam Girdwood's ASoC v2 work avoids having two different ops structures
for DAIs by merging the members of struct snd_soc_ops into struct
snd_soc_dai_ops, allowing per DAI configuration for everything.
Backport this change.
This paves the way for future work allowing any combination of DAIs to
be connected rather than having fixed purpose CODEC and CPU DAIs and
only allowing CODEC<->CPU interconnections.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This fixes sparse warnings and allows non-OpenFirmware systems to attempt
to bind to the device.
ASoC Codec driver for the TLV320AIC26 device. As it stands, this driver
doesn't support all the modes and clocking options of the AIC16, but it
is a start.
