Currently we can only have a single platform built in with AC'97 support
due to the use of a global variable to provide the bus operations. Fix
this by making that variable a pointer and having the bus drivers set the
operations prior to registering.
This is not a particularly good or nice approach but it avoids blocking
multiplatform and a real fix involves fixing the fairly deep problems
with AC'97 support - we should be converting it to a real bus.
Signed-off-by: Mark Brown <broonie@linaro.org>
There is no need to have versioning beyond that for the kernel, especially
when the version number never gets updated.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Since commit 98d3088e5 (SoC: core: Fix check before defaulting to regmap)
, it is not necessary to provide codec->control_data anymore.
Since commit 38cbf9598feba97de9f9b43efa9153fd7c1a2ec9
("ASoC: core: Try to use regmap if the driver doesn't set up any I/O")
any ASoC codec which doesn't set codec::control_data is assumed
to use regmap. That doesn't work with AC97 so this workaround
sets the codec::control_data member to a random value to restore
proper behaviour.
Tested with WM9712.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Signed-off-by: Liam Girdwood <lrg@ti.com>
reg_cache_size is supposed to be the number of elements in the register cache,
not the size in bytes.
The existence of this parameter is purely historical. None of the CODEC drivers
uses it and we always pass in the same value anyway, so it should be safe to
remove it.
Acked-by: Liam Girdwood <lrg@ti.com>
Factors out a bit of boilerplate.
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Looks like this is missing during multi-component conversion.
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
sound/soc/codecs/ad1938.c
The core will ensure that the device is in either STANDBY or OFF bias
before suspending, restoring the bias in the driver is unneeded. Some
drivers doing slightly more roundabout things have been left alone
for now.
Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
One of the features of the multi CODEC work is that it embeds a struct
device in the CODEC to provide diagnostics via a sysfs class rather than
via the device tree, at which point it's much better to use the struct
device private data rather than having two places to store it. Provide
an accessor function to allow this change to be made more easily, and
update all the CODEC drivers are updated.
To ensure use of the accessor the private data structure member is
renamed, meaning that if code developed with older an older core that
still uses private_data is merged it will fail to build.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Change code so that switching to playing music through the analog output
disables SPDIF out instead of disabling it when stream ends.
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
Keep index within stac9766_reg[]
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Fairly minor issues:
- Don't register the DAIs, it's not required for AC97 devices.
- Make unexported functions static.
- Wrap some excessively long lines.
- Undo tab/space breakage.
Datasheet: http://www.idt.com/products/getDoc.cfm?docID=13134007
