path: root/sound/soc/bcm
2014-10-20ASoC: bcm: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-01-08ASoC: bcm: Remove obsoleted Kconfig dependencyTakashi Iwai
CONFIG_SND_SOC_DMAENGINE_PCM was renamed to CONFIG_SND_DMAENGINE_PCM recently. And yet we don't have to select it since CONFIG_SND_GENERIC_DMAENGINE_PCM selects the dependency by itself, so just rip it off. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Florian Meier <florian.meier@koalo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-02ASoC: bcm2835-i2s: Use devm_snd_dmaengine_pcm_register()Lars-Peter Clausen
Makes the code slightly shorter. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-25ASoC: Add support for BCM2835Florian Meier
This driver adds support for digital audio (I2S) for the BCM2835 SoC that is used by the Raspberry Pi. External audio codecs can be connected to the Raspberry Pi via P5 header. It relies on cyclic DMA engine support for BCM2835. Signed-off-by: Florian Meier <florian.meier@koalo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
