path: root/sound/pcmcia
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Add missing dB scale information to vxpocket driverTakashi Iwai
Added the missing dB scale information for Mic volume to vxpocket driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add dB scale information to vxpocket and vx222 driversTakashi Iwai
Added the dB scale information to vxpocket and vx222 drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Deprecate snd_card_free_in_thread()Takashi Iwai
Deprecated snd_card_free_in_thread(), replaced with snd_card_free_when_closed(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Memory leak in sound/pcmcia/pdaudiocf/pdaudiocf.cEric Sesterhenn
if one of the first three CS_CHECKS fails, we goto cs_failed: In this case parse we donr kfree() parse. Since the the last three CS_CHECKS might also fail, i moved the kfree() below all the CS_CHECKs and added one in the error path. This fixes coverity bug id #1099 Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] sound/vxpocket: fix printk warningRandy Dunlap
Fix printk format warning: sound/pcmcia/vx/vxp_ops.c:205: warning: format '%x' expects type 'unsigned int', but argument 5 has type 'size_t' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] vxpocket - Fix a typoTakashi Iwai
Fix a typo of return value from vxpocket_config(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] PCMCIA sound devices shouldn't depend on ISAErik Mouw
The ALSA drivers for PCMCIA devices depend on ISA, but modern laptops can have PCMCIA support without ISA. This patch removes the dependency. Signed-off-by: Erik Mouw <erik@harddisk-recovery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[PATCH] pcmcia: convert DEV_OK to pcmcia_dev_presentDominik Brodowski
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present(). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irqDominik Brodowski
Convert the remaining drivers which use pcmcia_release_io or pcmcia_release_irq, and remove the EXPORT of these symbols. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-22[ALSA] Don't NULL check vfree argument in pdaudiocf_pcm.cJesper Juhl
Modules: PDAudioCF driver Don't check pointers passed to vfree for null in pdaudiocf_pcm.c Signed-off-by: Jesper Juhl <Jesper.Juhl@Gmail.Com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (Archs, misc buses)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-10spelling: s/trough/through/Adrian Bunk
Additionally, one comment was reformulated by Joe Perches <joe@perches.com>. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-06[PATCH] pcmcia: fix sound driversDominik Brodowski
Update the PCMCIA sound drivers to handle the recent changes to the PCMCIA core. A part of this merge was done by Takashi Iwai <tiwai@suse.de>. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-03[ALSA] pdaudiocf - Fix PM supportTakashi Iwai
Modules: PDAudioCF driver Fix the PM support on pdaudiocf driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] vx-driver - Fix PM supportTakashi Iwai
Fix PM support on VX drivers (vxpocket and vx222). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCMCIA PDaudioCFTakashi Iwai
Modules: PDAudioCF driver Remove xxx_t typedefs from the PCMCIA PDaudioCF driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: VXdriverTakashi Iwai
Remove xxx_t typedefs from the VXdriver codes (vx_core support, vx222 and vxpocket). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove snd_vx_delay() functionTakashi Iwai
Replace snd_vx_delay() with appropriate delay/sleep functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] vxpocket - Register device pointerTakashi Iwai
Digigram VX Pocket driver Add snd_card_set_dev() to register the device pointer. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] vxpocket - Fix wrong index assignmentTakashi Iwai
Digigram VX Pocket driver Fixed the wrong index number assignment. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] vxpocket - Add missing event callbackTakashi Iwai
Digigram VX Pocket driver Added the missing event callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-28[ALSA] vxpocket - Remove unused codeTakashi Iwai
Digigram VX Pocket driver Removed unused files (dropped by the last change). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-28[ALSA] Fix and clean-up of vxpocket driverTakashi Iwai
Documentation,PCMCIA Kconfig,Digigram VX Pocket driver - Fixed Oops with request_firmware() - Detect the card type in runtime (vxpoocket v2 or 440) - snd-vxp440 driver is merged to snd-vxpocket - Clean up the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pcmcia: remove references to pcmcia/version.hDominik Brodowski
As a follow-up, remove the inclusion of pcmcia/version.h in many files. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pcmcia: move event handlerDominik Brodowski
Move the "event handler" to struct pcmcia_driver -- the unified event handler will disappear really soon, but switching it to struct pcmcia_driver in the meantime allows for better "step-by-step" patches. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] pcmcia: id_table for pdaudiocf.cDominik Brodowski
Add pcmcia_device_id table. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] pcmcia: id_table for vxpocket.cDominik Brodowski
2005-06-22[ALSA] Remove redundant NULL checks before kfreeJesper Juhl
Timer Midlevel,ALSA sequencer,ALSA<-OSS sequencer,Digigram VX core I2C tea6330t,GUS Library,VIA82xx driver,VIA82xx-modem driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,YMFPCI driver Digigram VX Pocket driver,Common EMU synth,USB generic driver,USB USX2Y Checking a pointer for NULL before calling kfree() on it is redundant, kfree() deals with NULL pointers just fine. This patch removes such checks from sound/ This patch also makes another, but closely related, change. It avoids casting pointers about to be kfree()'ed. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
