One of the laptops has the codec ALC256 on it, applying the
ALC255_FIXUP_DELL1_MIC_NO_PRESENCE can fix the problem, the rest
of laptops have the codec ALC295 on them, they are similar to machines
with ALC225, applying the ALC269_FIXUP_DELL1_MIC_NO_PRESENCE can fix
the problem.
Cc: <stable@vger.kernel.org>
Signed-off-by: Hui Wang <hui.wang@canonical.com>
Realtek codec driver expects an implicit rule where either the codec
SSID or the pincfg NID 0x1d contains the some information encoded in
some bits. One of the expected information is there is the
availability of PC beep, and the driver doesn't build up the PC beep
control if this is *supposed* to be disabled there.
Meanwhile, Lenovo doesn't seem to follow this requirement (yes it's
non-standard after all), and the BIOS sets just the normal SSID and
the pincfg values. This resulted in the lack of PC beep on a few
machines, purely with a lucky or unlucky number. It didn't bother
most people, but some people still demand the PC beep, as found in bug
reports.
This patch just adds the fixup chain to Lenovo machines to skip the
SKU checks. Then the beep control will show up in the mixer, and user
can still decide to enable / disable it via the standard mixer
interface.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=156311
Remove unneeded variables and assignments.
Check for snd_pcm_ops structures that are only stored in the ops field of a
snd_soc_platform_driver structure or passed as the third argument to
snd_pcm_set_ops. The corresponding field or parameter is declared const,
so snd_pcm_ops structures that have this property can be declared as const
also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_pcm_ops i@p = { ... };
@ok1@
identifier r.i;
struct snd_soc_platform_driver e;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
snd_pcm_set_ops(e1, e2, &i@p)
@bad@
position p != {r.p,ok1.p,ok2.p};
identifier r.i;
struct snd_pcm_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct snd_pcm_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
Trivial fix to typos dev_dbg messages and comment.
The subwoofer on Inspiron 7559 was disabled originally.
Applying a pin fixup to node 0x1b can enable it and make it work.
Old pin: 0x411111f0
New pin: 0x90170151
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
This patch enables headset microphone on some variants of
Dell Inspiron 5468. (Dell SSID 0x07ad)
BugLink: https://bugs.launchpad.net/bugs/1617900
Signed-off-by: Shrirang Bagul <shrirang.bagul@canonical.com>
MSI Cubi MS-B120 needs the same fixup as the Gigabyte BXBT-2807 for its
mic to work.
They both use a single 3-way jack for both mic and headset with an
ALC283 codec, with the same pins used.
Cc: Daniel Drake <drake@endlessm.com>
Signed-off-by: Anisse Astier <anisse@astier.eu>
Trivial fix to spelling mistake in dev_warn message.
For SKL and later Intel chips, we control the power well per codec
basis via link_power callback since the commit [03b135cebc47: ALSA:
hda - remove dependency on i915 power well for SKL].
However, there are a few exceptional cases where the gfx registers are
accessed from the audio driver: namely the wakeup override bit
toggling at (both system and runtime) resume. This seems causing a
kernel warning when accessed during the power well down (and likely
resulting in the bogus register accesses).
This patch puts the proper power up / down sequence around the resume
code so that the wakeup bit is fiddled properly while the power is
up. (The other callback, sync_audio_rate, is used only in the PCM
callback, so it's guaranteed in the power-on.)
Also, by this proper power up/down, the instantaneous flip of wakeup
bit in the resume callback that was introduced by the commit
[033ea349a7cd: ALSA: hda - Fix Skylake codec timeout] becomes
superfluous, as snd_hdac_display_power() already does it. So we can
clean it up together.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96214
Fixes: 03b135cebc47 ('ALSA: hda - remove dependency on i915 power well for SKL')
Cc: <stable@vger.kernel.org> # v4.2+
Tested-by: Hans de Goede <hdegoede@redhat.com>
The HDA controller from SKL onwards support additional timestamp
reporting of the link time. The link time is read from HW
registers and converted to audio values.
Signed-off-by: Guneshwor Singh <guneshwor.o.singh@intel.com>
Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com>
Skylake onwards HDA controller supports new capabilities like
Global Time Stamping (GTS) capability. So add support to parse
these new capabilities.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
One of the machines has ALC255 on it, another one has ALC298 on it.
On the machine with the codec ALC298, it also has the speaker volume
problem, so we add the fixup chained to ALC298_FIXUP_SPK_VOLUME rather
than adding a group of pin definition in the pin quirk table, since
the speak volume problem does not happen on other machines yet.
This commit fixes garbled audio on Bonaire HDMI
Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
On Acer Veriton machines, codec with subsystem-id 0x1b0a01b8 the port at
0x15 is configured by default as an Internal Speaker (0x90170120).
However, no physical is speaker installed on-board. This patch adds a quirk
which disables the physical connection on this pin.
BugLink: https://bugs.launchpad.net/bugs/1607647
We have a Dell AIO on which we can't adjust its speaker's volume.
The problem is it is connected to a Audio Output node without Amp-out
capability. To fix it, we change it to be connnected to a node with
Amp-out capability.
Merged 4.8 changes.
total number of members
Currently, sound device drivers for PCI cards produced by Echo Audio
support dimension parameter of element information. But the information
has contradictions to the number of members of each element. I guess that
this comes from the assumption that these sound cards are used only by
'echomixer' in userspace. But ideally, they should be used with usual ALSA
control applications.
This commit removes the contradiction. As a result, 'Monitor Mixer Volume'
and 'VMixer Volume' elements are shown in usual ALSA control applications
such as 'amixer' and 'alsamixer' in series.
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
My static checker complains that "resp" could be unitialized on error
when we print its value.
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
This allows the device to correctly show up as ATI HDMI
rather than a generic one and allows the driver to use
the available caps.
Signed-off-by: Awais Belal <awais_belal@mentor.com>
register_vga_switcheroo() sets the PM ops from the hda structure which
is freed later in azx_free. Make sure that these ops are cleared.
Caught by KASAN, initially noticed due to a general protection fault.
Fixes: 246efa4a072f ("snd/hda: add runtime suspend/resume on optimus support (v4)")
Signed-off-by: Peter Wu <peter@lekensteyn.nl>
We have some Dell laptops which can't detect headset mic, the machines
use the codec ALC225, they have some new pin configuration values,
after adding them in the alc225 pin quirk table, they work well.
This solves the issue that a headphone is not working on the docking
unit.
Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
The kernel.h macro DIV_ROUND_UP performs the computation
(((n) + (d) - 1) /(d)) but is perhaps more readable.
The Coccinelle script used to make this change is as follows:
@haskernel@
#include <linux/kernel.h>
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
vortex_wtdma_bufshift() function does calculate the page index
wrongly, first masking then shift, which always results in zero.
The proper computation is to first shift, then mask.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Kabylake-H shows up as PCI ID 0xa2f0. We missed adding this
earlier with other KBL IDs.
'commpage_bak' is allocated with 'sizeof(struct echoaudio)' bytes.
We then copy 'sizeof(struct comm_page)' bytes in it.
On my system, smatch complains because one is 2960 and the other is 3072.
This would result in memory corruption or a oops.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
UBSAN reports the following warning from accessing path->path[-1]
in set_path_power():
[ 16.078040] ================================================================================
[ 16.078124] UBSAN: Undefined behaviour in sound/pci/hda/hda_generic.c:3981:17
[ 16.078198] index -1 is out of range for type 'hda_nid_t [10]'
[ 16.078270] CPU: 2 PID: 1738 Comm: modprobe Not tainted 4.7.0-rc1-wt+ #47
[ 16.078274] Hardware name: LENOVO 3443CTO/3443CTO, BIOS G6ET23WW (1.02 ) 08/14/2012
[ 16.078278] ffff8800cb246000 ffff8800cb3638b8 ffffffff815c4fe3 0000000000000032
[ 16.078286] ffff8800cb3638e0 ffffffffffffffff ffff8800cb3638d0 ffffffff8162443d
[ 16.078294] ffffffffa0894200 ffff8800cb363920 ffffffff81624af7 0000000000000292
[ 16.078302] Call Trace:
[ 16.078311] [<ffffffff815c4fe3>] dump_stack+0x86/0xd3
[ 16.078317] [<ffffffff8162443d>] ubsan_epilogue+0xd/0x40
[ 16.078324] [<ffffffff81624af7>] __ubsan_handle_out_of_bounds+0x67/0x70
[ 16.078335] [<ffffffffa087665f>] set_path_power+0x1bf/0x230 [snd_hda_codec_generic]
[ 16.078344] [<ffffffffa087880d>] add_pin_power_ctls+0x8d/0xc0 [snd_hda_codec_generic]
[ 16.078352] [<ffffffffa087f190>] ? pin_power_down_callback+0x20/0x20 [snd_hda_codec_generic]
[ 16.078360] [<ffffffffa0878947>] add_all_pin_power_ctls+0x107/0x150 [snd_hda_codec_generic]
[ 16.078370] [<ffffffffa08842b3>] snd_hda_gen_parse_auto_config+0x2d73/0x49e0 [snd_hda_codec_generic]
[ 16.078376] [<ffffffff81173360>] ? trace_hardirqs_on_caller+0x1b0/0x2c0
[ 16.078390] [<ffffffffa089df27>] alc_parse_auto_config+0x147/0x310 [snd_hda_codec_realtek]
[ 16.078402] [<ffffffffa08a332a>] patch_alc269+0x23a/0x560 [snd_hda_codec_realtek]
[ 16.078417] [<ffffffffa0838644>] hda_codec_driver_probe+0xa4/0x1a0 [snd_hda_codec]
[ 16.078424] [<ffffffff817bbac1>] driver_probe_device+0x101/0x380
[ 16.078430] [<ffffffff817bbdf9>] __driver_attach+0xb9/0x100
[ 16.078438] [<ffffffff817bbd40>] ? driver_probe_device+0x380/0x380
[ 16.078444] [<ffffffff817b8d20>] bus_for_each_dev+0x70/0xc0
[ 16.078449] [<ffffffff817bb087>] driver_attach+0x27/0x50
[ 16.078454] [<ffffffff817ba956>] bus_add_driver+0x166/0x2c0
[ 16.078460] [<ffffffffa0369000>] ? 0xffffffffa0369000
[ 16.078465] [<ffffffff817bd13d>] driver_register+0x7d/0x130
[ 16.078477] [<ffffffffa083816f>] __hda_codec_driver_register+0x6f/0x90 [snd_hda_codec]
[ 16.078488] [<ffffffffa036901e>] realtek_driver_init+0x1e/0x1000 [snd_hda_codec_realtek]
[ 16.078493] [<ffffffff8100215e>] do_one_initcall+0x4e/0x1d0
[ 16.078499] [<ffffffff8119f54d>] ? rcu_read_lock_sched_held+0x6d/0x80
[ 16.078504] [<ffffffff813701b1>] ? kmem_cache_alloc_trace+0x391/0x560
[ 16.078510] [<ffffffff812bb314>] ? do_init_module+0x28/0x273
[ 16.078515] [<ffffffff812bb387>] do_init_module+0x9b/0x273
[ 16.078522] [<ffffffff811e3782>] load_module+0x20b2/0x3410
[ 16.078527] [<ffffffff811df140>] ? m_show+0x210/0x210
[ 16.078533] [<ffffffff813b2b26>] ? kernel_read+0x66/0xe0
[ 16.078541] [<ffffffff811e4cfa>] SYSC_finit_module+0xba/0xc0
[ 16.078547] [<ffffffff811e4d1e>] SyS_finit_module+0xe/0x10
[ 16.078552] [<ffffffff81a860fc>] entry_SYSCALL_64_fastpath+0x1f/0xbd
[ 16.078556] ================================================================================
Fix by checking path->depth before use.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
See: https://bugzilla.redhat.com/show_bug.cgi?id=1349539
See: https://bugzilla.kernel.org/show_bug.cgi?id=120961
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
The new Dell laptop with codec 3246 can't detect headset mic when
headset was inserted on the machine. So adding pin configurations
into quirk table makes headset mic work correctly.
Codec: Realtek ALC3246
Vendor Id: 0x10ec0256
Subsystem Id: 0x10280781
Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com>
The readl/writel are not being passed __iomem annotated
variables, so fix the following sparse warnings by adding
__iomem in:
sound/pci/hda/hda_tegra.c:120:9: warning: incorrect type in argument 2 (different address spaces)
sound/pci/hda/hda_tegra.c:120:9: expected void volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:120:9: got unsigned int [usertype] *addr
sound/pci/hda/hda_tegra.c:125:16: warning: incorrect type in argument 1 (different address spaces)
sound/pci/hda/hda_tegra.c:125:16: expected void const volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:125:16: got unsigned int [usertype] *addr
sound/pci/hda/hda_tegra.c:134:13: warning: incorrect type in argument 1 (different address spaces)
sound/pci/hda/hda_tegra.c:134:13: expected void const volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:134:13: got void *dword_addr
sound/pci/hda/hda_tegra.c:137:9: warning: incorrect type in argument 2 (different address spaces)
sound/pci/hda/hda_tegra.c:137:9: expected void volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:137:9: got void *dword_addr
sound/pci/hda/hda_tegra.c:146:13: warning: incorrect type in argument 1 (different address spaces)
sound/pci/hda/hda_tegra.c:146:13: expected void const volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:146:13: got void *dword_addr
sound/pci/hda/hda_tegra.c:156:13: warning: incorrect type in argument 1 (different address spaces)
sound/pci/hda/hda_tegra.c:156:13: expected void const volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:156:13: got void *dword_addr
sound/pci/hda/hda_tegra.c:159:9: warning: incorrect type in argument 2 (different address spaces)
sound/pci/hda/hda_tegra.c:159:9: expected void volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:159:9: got void *dword_addr
sound/pci/hda/hda_tegra.c:168:13: warning: incorrect type in argument 1 (different address spaces)
sound/pci/hda/hda_tegra.c:168:13: expected void const volatile [noderef] <asn:2>*addr
sound/pci/hda/hda_tegra.c:168:13: got void *dword_addr
sound/pci/hda/hda_tegra.c:173:23: warning: incorrect type in initializer (incompatible argument 2 (different address spaces))
sound/pci/hda/hda_tegra.c:173:23: expected void ( *reg_writel )( ... )
sound/pci/hda/hda_tegra.c:173:23: got void ( static [toplevel] *<noident> )( ... )
sound/pci/hda/hda_tegra.c:174:22: warning: incorrect type in initializer (incompatible argument 1 (different address spaces))
sound/pci/hda/hda_tegra.c:174:22: expected unsigned int ( *reg_readl )( ... )
sound/pci/hda/hda_tegra.c:174:22: got unsigned int ( static [toplevel] *<noident> )( ... )
sound/pci/hda/hda_tegra.c:175:23: warning: incorrect type in initializer (incompatible argument 2 (different address spaces))
sound/pci/hda/hda_tegra.c:175:23: expected void ( *reg_writew )( ... )
sound/pci/hda/hda_tegra.c:175:23: got void ( static [toplevel] *<noident> )( ... )
sound/pci/hda/hda_tegra.c:176:22: warning: incorrect type in initializer (incompatible argument 1 (different address spaces))
sound/pci/hda/hda_tegra.c:176:22: expected unsigned short ( *reg_readw )( ... )
sound/pci/hda/hda_tegra.c:176:22: got unsigned short ( static [toplevel] *<noident> )( ... )
sound/pci/hda/hda_tegra.c:177:23: warning: incorrect type in initializer (incompatible argument 2 (different address spaces))
sound/pci/hda/hda_tegra.c:177:23: expected void ( *reg_writeb )( ... )
sound/pci/hda/hda_tegra.c:177:23: got void ( static [toplevel] *<noident> )( ... )
sound/pci/hda/hda_tegra.c:178:22: warning: incorrect type in initializer (incompatible argument 1 (different address spaces))
sound/pci/hda/hda_tegra.c:178:22: expected unsigned char ( *reg_readb )( ... )
sound/pci/hda/hda_tegra.c:178:22: got unsigned char ( static [toplevel] *<noident> )( ... )
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Acked-by: Thierry Reding <treding@nvidia.com>
For readability and to allow for structure randomisation, replace the
in order struct initialisation style with explicit field style.
The Coccinelle semantic patch used to make this change is as follows:
@decl@
identifier i1,fld;
type T;
field list[n] fs;
struct i1 {
fs
T fld;
identifier decl.i1,i2,decl.fld;
expression e;
position bad.p, bad.fix;
struct i1 i2@p = { ...,
+ .fld = e
- e@fix
This patch fixes some warnings from klockwork.
These warnings are not the real issues. The patch
adds the sanity check.
Signed-off-by: Libin Yang <libin.yang@linux.intel.com>
New headset mode of ALC891 for Dell.
This patch is supported Dell headset mode for ALC891.
It is only support I-phone type headset.
I think this function is only support for DELL.
This patch is test passed by Ubuntu team.
Signed-off-by: Kailang Yang <kailang@realtek.com>
Kabylake shows up as PCI ID 0xa171. And Kabylake-LP as 0x9d71.
Since these are similar to Skylake add these to SKL_PLUS macro
Tested with Lenovo Ultradock. Fixes the non-working headphone jack on
the docking unit.
Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Add the pin configuration value of this machine into the pin_quirk
table to make DELL1_MIC_NO_PRESENCE apply to this machine.
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
So far, we enabled the loopback mixing control as default, as this
behavior made somewhat compatible with the earlier HD-audio drivers
for Realtek & co. However, it's getting annoying as we've got more
and more bug reports about the noise coming from the loopback route.
Since the loopback mixing is used fairly rarely and often harmful
(e.g. using PA), let's get rid of the default turn-on lines.
Support new codecs for ALC700/ALC701/ALC703.
That is some different register for ALC255 and ALC256.
ALC256 can't fit with some ALC255 register.
This issue is cause from LDO output voltage control.
This patch is updated the right LDO register value.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull more sound updates from Takashi Iwai:
"This is the second update round for 4.7-rc1. Most of changes are
about the pending ASoC updates and fixes, including a few new drivers.
Below are some highlights:
ASoC:
- New drivers for MAX98371 and TAS5720
- SPI support for TLV320AIC32x4, along with the module split
- TDM support for STI Uniperf IPs
- Remaining topology API fixes / updates
HDA:
- A couple of Dell quirks and new Realtek codec support"
* tag 'sound-4.7-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (63 commits)
ALSA: hda - Fix headset mic detection problem for one Dell machine
spi: spi-ep93xx: Fix the PTR_ERR() argument
ALSA: hda/realtek - Add support for ALC295/ALC3254
ASoC: kirkwood: fix build failure
ALSA: hda - Fix headphone noise on Dell XPS 13 9360
ASoC: ak4642: Enable cache usage to fix crashes on resume
ASoC: twl6040: Disconnect AUX output pads on digital mute
ASoC: tlv320aic32x4: Properly implement the positive and negative pins into the mixers
rcar: src: skip disabled-SRC nodes
ASoC: max98371 Remove duplicate entry in max98371_reg
ASoC: twl6040: Select LPPLL during standby
ASoC: rsnd: don't use prohibited number to PDMACHCRn.SRS
ASoC: simple-card: Add pm callbacks to platform driver
ASoC: pxa: Fix module autoload for platform drivers
ASoC: topology: Fix memory leak in widget creation
ASoC: Add max98371 codec driver
ASoC: rsnd: count .probe/.remove for rsnd_mod_call()
ASoC: topology: Check size mismatch of ABI objects before parsing
ASoC: topology: Check failure to create a widget
ASoC: add support for TAS5720 digital amplifier
Add support for ALC295/ALC3254.
They are simply compatible with ALC225 chip.
The headphone has noise when playing sound or switching microphone sources.
It uses the same codec on XPS 13 9350, but with different subsystem ID.
Applying the fixup can solve the issue.
Also, changing the model name to better differentiate models.
v2: Reorder by device ID.
Pull sound updates from Takashi Iwai:
"This time was again a relatively calm development cycle; most of
updates are about drivers, and no radical changes are seen in any core
code. Here are some highlights:
ALSA core:
- Continued hardening of ALSA hrtimer
- A few leak fixes in timer interface
- Fix poll error handling in PCM and compress
- Add error propagation in compress API
- Removal of dead rtctimer driver
HD-audio:
- Native ELD notify support for i915 HDMI
- Realtek ALC234 & co support
- Code refactoring to standardize chmap support
- Continued development for SKL HDMI core support
Firewire:
- Apply delayed card registration to all drivers
- Improved / stabilized the handling of PCM stream start / stop
- Add tracepoints to dump a part of isochronous packet data
- Fixed incoming/outgoing packet parameter usages
- Add support for M-Audio profire series
USB-audio:
- Fixes for UAC2 clock source
- SS+ support
- Workaround for oft-seen repeated sample rate read errors
ASoC:
- Further slow progress on the topology code
- Substantial updates and improvements for the da7219, es8328,
fsl-ssi, Intel and rcar drivers.
- Compress error handling in WM ADSP driver"
* tag 'sound-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (177 commits)
ALSA: firewire-lib: change a member of event structure to suppress sparse wanings to bool type
sound: oss: Use setup_timer and mod_timer.
ASoC: hdac_hdmi: Remove the unused 'timeout' variable
ASoC: fsl_ssi: Fix channel slipping on capture (or playback) restart in full duplex.
ASoC: fsl_ssi: Fix channel slipping in Playback at startup
ASoC: fsl_ssi: Fix samples being dropped at Playback startup
ASoC: fsl_ssi: Save a dev reference for dev_err() purpose.
ASoC: fsl_ssi: The IPG/5 limitation concerns the bitclk, not the sysclk.
ASoC: fsl_ssi: Real hardware channels max number is 32
ASoC: pcm5102a: Add support for PCM5102A codec
ASoC: hdac_hdmi: add link management
ASoC: Intel: Skylake: add link management
ALSA: hdac: add link pm and ref counting
ALSA: au88x0: Fix zero clear of stream->resources
ASoC: rt298: Add DMI match for Broxton-P reference platform
ASoC: rt298: fix null deref on acpi driver data
ASoC: dapm: deprecate MICBIAS widget type
ALSA: firewire-lib: drop skip argument from helper functions to queue a packet
ALSA: firewire-lib: add context information to tracepoints
ALSA: firewire-lib: permit to flush queued packets only in process context for better PCM period granularity
