path: root/sound/pci
2008-06-23ALSA: aw2 - Fix Oops at initializationTakashi Iwai
The irq handler may be called before the proper initialization of hardware. Call snd_aw2_saa7146_setup() before the irq handler registration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-06-16sound: oxygen: fix NULL pointer dereference when loading snd-oxygenClemens Ladisch
Check that model->control_filter is set before trying to call it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-06-09[ALSA] hda - Fix "alc262_sony_unsol[]" hda_verb arrayAkio Idehara
I think that hda_verb array must have "terminator (empty array)". But alc262_sony_unsol[] does not have it. And it causes gcc-4.3's buggy behavior with snd_hda_sequence_write(). Signed-off-by: Akio Idehara <zbe64533@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-06-06sound: emu10k1 - fix system hang with Audigy2 ZS Notebook PCMCIA cardJaroslav Franek
When the Linux kernel is compiled with CONFIG_DEBUG_SHIRQ=y, the Soundblaster Audigy2 ZS Notebook PCMCIA card causes the system hang during boot (udev stage) or when the card is hot-plug. The CONFIG_DEBUG_SHIRQ flag is by default 'y' with all Fedora kernels since 2.6.23. The problem was reported as https://bugzilla.redhat.com/show_bug.cgi?id=326411 The issue was hunted down to the snd_emu10k1_create() routine: /* pseudo-code */ snd_emu10k1_create(...) { ... request_irq(... IRQF_SHARED ...) { register the irq handler #ifdef CONFIG_DEBUG_SHIRQ call the irq handler: snd_emu10k1_interrupt() { poll I/O port // <---- !! system hangs ... } #endif } ... snd_emu10k1_cardbus_init(...) { initialize I/O ports } ... } The early access to I/O port in the interrupt handler causes the freeze. Obviously it is necessary to init the I/O ports before accessing them. This patch moves the registration of the irq handler after the initialization of the I/O ports. Signed-off-by: Jaroslav Franek <jarin.franek@post.cz> Acked-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-06-04[ALSA] hda - COMPAL IFL90/JFL-92 laptop quirkTony Vroon
Use quirk table to assign ALC268_TOSHIBA to COMPAL IFL90/JFL-92 laptops. No analog output on autoprobe. Signed-off-by: Tony Vroon <tony@linx.net> Tested-by: Guri <gurashka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-06-03[ALSA] hda - Fix resume of auto-config mode with Realtek codecsTakashi Iwai
The auto-config mode of Realtek ALC codecs has a bug since 2.6.25 that it cannot resume properly. The problem was the wrong assignment of init_hook that overrides the whole initialization. Relevant bug reports: http://bugzilla.kernel.org/show_bug.cgi?id=10662 https://bugzilla.novell.com/show_bug.cgi?id=385473 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-30[ALSA] hda - Fix model for LG LS75 laptopTakashi Iwai
Set the proper model for LG LS75 with CM9880 codec. See ALSA bug#2105: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=2105 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-30[ALSA] hda - Fix mic input on HP2133Takashi Iwai
The mic pins are wrongly assigned on AD1884A mobile model. The mic handling is fixed for the automatic mic selection, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-30[ALSA] ac97 - Fix ASUS A9T laptop outputTakashi Iwai
ASUS A9T laptop uses line-out pin as the real front-output while other devices use it as the surround. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-25[ALSA] hda - Fix capture mute Widget for stac9250/9251Mauro Carvalho Chehab
Fix capture mute widget for STAC9250/9251 codecs. The widget 0x09 has no mute but 0x14 does actually. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-24[ALSA] hda - Added support for Foxconn P35AX-S mainboardTravis Place
Added IDs for the Foxconn P35AX-S mainboard to patch_realtek.c, so that ALC883_6ST_DIG is used by default. Signed-off-by: Travis Place <wishie@wishie.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-24[ALSA] hda - Fix COEF and EAPD in ALC889 auto-configuration modeTakashi Iwai
Fix the missing COEF and EAPD initialization in ALC889 auto-configuration mode. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-24[ALSA] hda - Fix noise on VT1708 codecTakashi Iwai
We get quite noisy output on the right channel on VT1708 codec when 24bit samples are used. Suppress the 24bit support until any real fix is found. https://bugzilla.novell.com/show_bug.cgi?id=390473 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-24[ALSA] hda - Add model for ASUS P5K-E/WIFI-APTravis Place
Added a config table entry for the ASUS P5K-E/WIFI-AP mainboard (ID 1043:8227) to use AD1988_6STACK_DIG Signed-off-by: Travis Place <wishie@wishie.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-20[ALSA] hda - Fix ASUS P5GD1 modelTravis Place
Corrected the model assignment for the ASUS P5GD1 w/SPDIF after reports of surround sound not being possible. Signed-off-by: Travis Place <wishie@wishie.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-20[ALSA] hda - Fix ALC262 fujitsu modelTakashi Iwai
Fixed the speaker auto-mute with two laptop and docking headphones. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Tony Vroon <tony@linx.net>
2008-05-05[ALSA] ac97 - Add a workaround for broken quirk for VT1617A codecTakashi Iwai
On boards with VT1617A codec, the sound disappears suddenly. This looks like a problem with HPE-bit control that is supposed to be set in patch_vt1617a(). However, on such problematic hardwares, the bit is actually reset mysteriously. The patch adds a workaround for the wrong quirk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05[ALSA] Revert migration to alc_set_pin_output() in ↵Jacek Luczak
alc861_auto_set_output_and_unmute() Change done by: commit f6c7e5461e9046445d50c5c7a9a4587824239623 [ALSA] hda-codec - Fix auto-configuration of Realtek codecs broke sound on ALC861 Analog. Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05[ALSA] fm801 - Fix kconfig dependency mess of fm801-tea575xTakashi Iwai
FM801-tea575x tuner has a reverse selection to V4L1 and this causes nasty dependency problems. The patch simplifies the dependency with a normal "depends on VIDEO_V4L1". This decreases the usability but fixes bugs, yeah. If any better feature like "requires" is introduced to kbuild in future, we'll be able to switch it... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05[ALSA] hda - Support IDT 92HD206 codecTakashi Iwai
Added the support for IDT 92HD206 codec chip. It's compatible with STAC927x. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-29[ALSA] hda - Add support of Medion RIM 2150Takashi Iwai
Added the support of Medion RIM 2150 laptop with ALC880 codec. ALSA bug#3708: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3708 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-29[ALSA] ice1724 - Enable watermarksTakashi Iwai
Enable watermarks settings (previously commented out) for MPU RX/TX. Otherwise irqs aren't issued properly. Tested-by: Pavel Hofman <pavel.hofman@insite.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-29[ALSA] Add MPU401_INFO_NO_ACK bitflagTakashi Iwai
Added MPU401_INFO_NO_ACK bitflag to ignore the ACK check for UART commands. VT172x doesn't handle ACK commands, for example. Tested-by: Pavel Hofman <pavel.hofman@insite.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ice1724 - Fix IRQ lock-up with MPU accessTakashi Iwai
The sound boards with VT1724 and compatible chips may lock up when MPU401 is accessed together with the PCM streaming. This patch fixes the problem. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Fix Thinkpad X300 digital micTakashi Iwai
TP X300 digital mic requires additional init verbs with magic COEFs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Fix model for Acer Aspire 5720zTakashi Iwai
Set the proper model=acer for Acer Aspire 5720z with ALC268 codec. ALSA bug#3550: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3550 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Fix possible races at free_irq in PCI driversTakashi Iwai
The irq handler of PCI drivers must be released before releasing other resources since the handler for a shared irq can be still called and may access the freed resource again. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ice1712 - Add Terrasoniq TS88 supportPeter Lienig
Added the support of Terrasonq TS88. Signed-off-by: Peter Lienig <lienig@rheinmetall-de.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Fix synchronize_irq() bugs, redundanciesJeff Garzik
free_irq() calls synchronize_irq() for you, so there is no need for drivers to manually do the same thing (again). Thus, calls where sync-irq immediately precedes free-irq can be simplified. However, during this audit several bugs were noticed, where free-irq is preceded by a "irq >= 0" check... but the sync-irq call is not covered by the same check. So, where sync-irq could not be eliminated completely, the missing check was added. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Audiophile 192: Fix ad converter initializationKarsten Wiese
Correct some arguments in calls to snd_ice1712_gpio_write_bits() from ap192_set_rate_val(). Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Don't set gpio mask register in snd_ice1712_gpio_write_bits()Karsten Wiese
Some calls to snd_ice1712_gpio_write() go wrong, if snd_ice1712_gpio_write_bits() ran before and changed the gpio mask register. Read the actual gpio value and combine it with the to be set bits in the cpu instead. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ice1724.c: toggle "chip reset" and "eeprom based setup" sequenceKarsten Wiese
Let "chip reset" become first. Increasement of the "chip reset" related timeout leads to correctly read eeprom's contents here. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Avoid unexpected breakage with ALC889A hackTakashi Iwai
The last ALC889A hack may break on some devices with certain model presets since patch_alc*() have different model tables. So, now it's handled in the original patch_alc882() but fly to patch_alc883() in model=auto appropriately. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Fix ALC889A codec supportTakashi Iwai
ALC889A is recognized ALC885/ALC882 but it's actually closer to ALC888/ALC883. Cc: Kasper Sandberg <lkml@metanurb.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda: Add 5.1 support for second headphone jackMatthew Ranostay
Several 92hd7xxx and STAC9228 laptops have multiple headphone jacks, the second headphone jack should be used for the 5.1 surround sound. Add support for 'Headphone as Line Out' switch, which allows it be used in 5.1 surround sound. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] oxygen: generalize DAC volume TLV handlingClemens Ladisch
Add a pointer for DAC volume TLV data to the model structure so that the model driver do not need to manually assign it in their control filter. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] oxygen: mute by defaultClemens Ladisch
Initialize the playback volume controls as being muted and having minimal volume. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] oxygen: generalize handling of DAC volume limitsClemens Ladisch
Add fields for the DAC volume limits to the module structure so that model drivers do not need to install their own control info handlers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hifier: remove empty hifier_mixer_init()Clemens Ladisch
The empty hifier_mixer_init() function is useless; remove it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Add support of AD1989A/AD1989BTakashi Iwai
Added the support of AD1989A and AD1989B codecs. These codecs can have multiple SPDIF devices, but currently we handle only one SPDIF. If any real devices with two SPDIF interfaces (likely one for SPDIF and one for HDMI), we'll fix this rightly. Otherwise, these codecs are pretty similar with AD1988. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] virtuoso: fix DX front panel I/OClemens Ladisch
Fix the GPIO 1 mixer control to enable I/O through the front panel connector of the Xonar DX. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-intel: Add Quanta IL1 ALC267 modelHerton Ronaldo Krzesinski
This adds support for Quanta IL1 mini-notebook to alsa, defining a new model for it. It comes with an ALC267 codec chip. Some notes about this model: * In headphone automute, I use AC_VERB_SET_PIN_WIDGET_CONTROL instead of common amp mute, to avoid conflict with mixer switch (mixer and automute use the same nid). * The only connected capture sources in the hardware are the internal mic and external mic jack. So instead of using an input source selector like on other ALC268 models, the mic automute automatically switch between captures. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda: EAPD power managementMatthew Ranostay
Power management support for EAPD enabled laptops, when headphones are sensed it pulls the EAPD GPIO line low to power it down. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda: Correct SPDIF out default configMatthew Ranostay
Several laptops have have the SPDIF out defined as 'Digital other out' when it should be 'SPDIF out' in the default config. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Fujitsu Lifebook PC speaker signalTony Vroon
The legacy PC speaker signal was not routed to outputs. The codec is not prevented from powering down in this patch, although I suppose one could argue that perhaps it should be. Let me know if anyone feels strongly one way or the other. Signed-off-by: Tony Vroon <tony@linx.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - PCI quirk for laptop LG which use CMI9880Jiang zhe
Please refer to [0003874] on the alsa mantis. This patch added the pci quirk. Signed-off-by: Jiang zhe <zhe.jiang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda - Should use HDA_OUTPUT instead of HDA_INPUT to mute pin 15 of ALC880Jiang zhe
To mute the output of Pin widget 15 in ALC880, we should use the HDA_OUTPUT. However, current code looks like : snd_hda_codec_amp_stereo(codec, 0x15, HDA_INPUT, 0, HDA_AMP_MUTE, bits); It may be a misspelling. Signed-off-by: Jiang zhe <zhe.jiang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Fix unbalanced mutexFrederik Deweerdt
On Wed, Apr 02, 2008 at 08:19:29AM -0400, Miles Lane wrote: > [ 48.765906] [ BUG: bad unlock balance detected! ] > [ 48.765912] ------------------------------------- > [ 48.765918] pulseaudio/4277 is trying to release lock > (&codec->spdif_mutex) at: > [ 48.765930] [<c03031b7>] mutex_unlock+0x8/0xa > [ 48.765945] but there are no more locks to release! > [ 48.765950] > [ 48.765952] other info that might help us debug this: > [ 48.765959] 2 locks held by pulseaudio/4277: > [ 48.765965] #0: (&pcm->open_mutex){--..}, at: [<f89f134b>] > snd_pcm_open+0xc1/0x1ba [snd_pcm] > [ 48.766003] #1: (&chip->open_mutex){--..}, at: [<f8b4f13d>] > azx_pcm_open+0x36/0x184 [snd_hda_intel] > [ 48.766057] > [ 48.766059] stack backtrace: > [ 48.766066] Pid: 4277, comm: pulseaudio Not tainted 2.6.25-rc8-mm1 #12 > [ 48.766086] [<c013afc6>] print_unlock_inbalance_bug+0xce/0xd8 > [ 48.766107] [<c0109e1c>] ? save_stack_trace+0x1d/0x3b > [ 48.766130] [<c012f54e>] ? __kernel_text_address+0x1b/0x27 > [ 48.766146] [<c0104533>] ? dump_trace+0xcd/0xd9 > [ 48.766160] [<c0109d9e>] ? save_stack_address+0x0/0x2c > [ 48.766176] [<c013b80a>] ? find_usage_backwards+0xa4/0xc3 > [ 48.766193] [<c013cfb5>] lock_release_non_nested+0x84/0x120 > [ 48.766209] [<c03031b7>] ? mutex_unlock+0x8/0xa > [ 48.766222] [<c013d1bb>] lock_release+0x16a/0x199 > [ 48.766238] [<c0303137>] __mutex_unlock_slowpath+0xa9/0x121 > [ 48.766252] [<c03031b7>] mutex_unlock+0x8/0xa > [ 48.766263] [<f8b4ffd8>] snd_hda_multi_out_analog_open+0xd3/0xef > [snd_hda_intel] The following patch should fix it. Cc: "Miles Lane" <miles.lane@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] es1968 - fix coding style in the last patchAndrew Morton
WARNING: braces {} are not necessary for single statement blocks #40: FILE: sound/pci/es1968.c:1831: + if (diff > 1) { + __maestro_write(chip, IDR0_DATA_PORT, cp1); + } total: 0 errors, 1 warnings, 35 lines checked ./patches/es1968-fix-jitter-on-some-maestro-cards.patch has style problems, please review. If any of these errors are false positives report them to the maintainer, see CHECKPATCH in MAINTAINERS. Please run checkpatch prior to sending patches Cc: Andreas Mueller <andreas@stapelspeicher.org> Tested-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] es1968: fix jitter on some maestro cardsAndreas Mueller
This patch suppresses jitter on several Maestro cards in stereo mode (ALSA of course). The patch is also incorporated in the *BSD drivers where I "ported" it from. Without this patch most of the stereo audio gets out of sync and really distorted (oss-emulation with mplayer at 48000khz worked somehow). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
