path: root/sound/pci
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-03-18ALSA: sound/pci/asihpi: check adapter index in hpi_ioctlDan Rosenberg
The user-supplied index into the adapters array needs to be checked, or an out-of-bounds kernel pointer could be accessed and used, leading to potentially exploitable memory corruption. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-16Merge branch 'topic/hda' into for-linusTakashi Iwai
2011-03-16ALSA: ctxfi - use list_move() instead of list_del()/list_add() combinationKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - Remove an unused variable in patch_realtek.cTakashi Iwai
2011-03-14ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecsVitaliy Kulikov
This patch replaces use of the harcoded arrays of pins, muxes, digital mics and adcs with the auto-generated ones using codec parsing and auto-discovers all actually connected digital mic pins on 92HD8X-like codecs This patch also adds the support for d-mic on pin 0x20. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - fix digital mic selection in mixer on 92HD8X codecsVitaliy Kulikov
When the mux for digital mic is different from the mux for other mics, the current auto-parser doesn't handle them in a right way but provides only one mic. This patch fixes the issue. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - Move default input-src selection to init partTakashi Iwai
Move the default input-src selection code for alc268/269 to the init part instead of the parser. The input-src selection might be overwritten by init verbs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - Initialize special cases for input src in init phaseTakashi Iwai
Currently some special handling for the unusual case like dual-ADCs or a single-input-src is done in the tree-parse time in set_capture_mixer(). But this setup could be overwritten by static init verbs. This patch moves the initialization into the init phase so that such input-src setup won't be lost. Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Clear input settings before initializationPrzemyslaw Bruski
Clear input settings before initialization. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Fix SPDIF status retrievalPrzemyslaw Bruski
SDPIF status retrieval always returned the default settings instead of the actual ones. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Fix incorrect SPDIF status bit maskPrzemyslaw Bruski
SPDIF status mask creation was incorrect. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Fix microphone boost codes/commentsPrzemyslaw Bruski
microphone boost was set at +12dB, not +20dB (like in Windows driver and in adc_conf structure declaration), some comments added. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: atiixp - Fix wrong time-out checks during ac-link resetTakashi Iwai
The time-out in snd_atiixp_aclink_reset() is wrongly checked, and it resulted in exiting from the loop at the first iteration. Reported-by: Amir Shamsuddin <AmirS2+alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: intel8x0m: append 'm' to "r_intel8x0"Paul Bolle
Appending an 'm' will distinguish it from a similar struct in intel8x0.c Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: intel8x0m: add 'm' as "suffix" to static functionsPaul Bolle
Adding an 'm' will distinguish them from identical names in intel8x0.c. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: intel8x0m: wait a bit before warm reset checkPaul Bolle
At every resume a laptop I use prints this message (at KERN_ERR level): ALSA sound/pci/intel8x0m.c:904: AC'97 warm reset still in progress? [0x2] The thing to note here is that 0x2 corresponds to ICH_AC97COLD. Ie, what seems to be happening is that the register involved indicated a warm reset for some time (as the ICH_AC97WARM bit was set) but by the time the warning is printed, and that same register is checked again, that bit is already cleared and only the ICH_AC97COLD bit is still set. It turns out a warm reset needs some time to settle, but it is currently checked right away. The test therefore fails the first time it is done and schedule_timeout_uninterruptible() will be called. Once we return from that jiffies is already (far) past end_time on this laptop, so we exit the loop, print a warning, and exit the function while the warm reset actually succeeded. A way to fix this is to call usleep_range() after writing to the register involved. A handful of tests suggest 500 usecs is a safe value. (This might punish the "finish cold reset" case, but on this laptop such a cold reset apparently never happens, so I can't say for sure.) While we're at it drop the extra single tick from end_time, as it looks rather silly. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2011-03-10ALSA: hda: Prevent writing ICH6_PCIREG_TCSEL on AMD systemsAdam Lackorzynski
azx_init_pci() always writes PCI config register ICH6_PCIREG_TCSEL although this looks to be only defined on Intel systems and has a different meaning on AMD systems. On AMD systems the PCI interrupt pin control register is modified instead. Since the meaning of offset 0x44 in device specific configuration space is unknown for devices by other vendors, we only exclude AMD systems to retain the current behaviour. Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-10ALSA: HDA: Realtek ALC88x: Do not over-initialize speakers and hp that are ↵David Henningsson
primary outputs Do not initialize again the what has already been initialized as multi outs, as this breaks surround speakers. Tested-by: Bartłomiej Żogała <nusch88@gmail.com> Cc: <stable@kernel.org> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-10ALSA: HDA: Fixup unnecessary volume control index on Realtek ALC88xDavid Henningsson
Without this change, a volume control named "Surround" or "Side" would get an unnecessary index, causing it to be ignored by the vmaster and PulseAudio. Tested-by: Bartłomiej Żogała <nusch88@gmail.com> Cc: <stable@kernel.org> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-10ALSA: HDA: Fix volume control naming for surround speakers on Realtek ↵David Henningsson
auto-parser When more than one pair of internal speakers is present, allow names according to their channels. Tested-by: Bartłomiej Żogała <nusch88@gmail.com> Cc: <stable@kernel.org> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-10ALSA: HDA: Enable surround and subwoofer on Lenovo Ideapad Y530David Henningsson
The pin config values would change the association instead of the sequence, this commit fixes that up. Tested-by: Bartłomiej Żogała <nusch88@gmail.com> Cc: <stable@kernel.org> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-08ALSA: asihpi - Use %zd for size_t argument in error messageTakashi Iwai
2011-03-08ALSA: hdspm - Add firmware ID for older AES32 cards.Adrian Knoth
The current AES32 firmware revision ID is 234, however, a user confirmed that everything works fine with the previous revision, too. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-03ALSA: hda - Don't set to D3 in Cirrus errata init verbsTakashi Iwai
The errata init verbs for CS42xx codecs contain the verbs to set the power-state of SPDIF nodes to D3, which seem to break the SPDIF output on some MacBooks. Since this is executed during the power-up initialization, we shouldn't turn them down there. Reported-by: Arun Raghavan <arun.raghavan@collabora.co.uk> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-03ALSA: hda - Make common input-jack helper functionsTakashi Iwai
Since multiple codec drivers already use the input-jack stuff, let's make common helper functions to reduce the duplicated codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-03Merge branch 'fix/hda' into topic/hdaTakashi Iwai
2011-03-03ALSA: hda - add new Fermi 5xx codec IDs to snd-hdaRichard Samson
Added the missing HDMI codec IDs for new Nvidia stuff. Note that ID 0x17 isn't assigned to anything so far, as suggested by Stephen. [Modified to get rid of 0x17 by tiwai] Signed-off-by: Richard Samson <samson.richard@gmail.com> Acked-by: Acked-By: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-01ALSA: hda - Fix unable to record issue on ASUS N82JVChih-Wei Huang
The codec of N82JV is ALC269VB. Signed-off-by: Chih-Wei Huang <cwhuang@linux.org.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: HDA: Realtek: Fixup jack detection to input subsystemDavid Henningsson
This patch fixes an error in the jack detection reporting, causing the jack detection sometimes not to be reported correctly to the input subsystem. It should apply to several Realtek codecs. Cc: stable@kernel.org Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - Fix midi port initializationAdrian Knoth
Depending on the model and the presence of a TCO module, the number of midi ports varies. Some have 1 port (MADIface), some have 2 (default), with TCO, there are 3. Don't hardcode the number of midi ports to initialize. This patch also fixes a boot lockup on MADIface. [Coding-style fixes by tiwai] Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - Abort on unknown firmware revisionAdrian Knoth
Don't continue if we cannot detect the real card type, otherwise, all subsequent functions, especially strcpy(), would fail, leaving the whole driver in an unusable state. Without such a protection, dmesg would look like this: Pid: 1525, comm: modprobe Not tainted 2.6.38-rc6 #1 MSI MS-7250/MS-7250 EIP: 0060:[<c114e700>] EFLAGS: 00010296 CPU: 1 EIP is at strcpy+0x10/0x30 EAX: f4d33e58 EBX: f5990800 ECX: f4d33e58 EDX: 00000000 ESI: 00000000 EDI: f4d33e58 EBP: f5990930 ESP: f3dd3e0c DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 f53d4204 00000000 f90bfc03 00000001 00000001 f3dd3e64 c10fedff f3dd3e7c f3d854e4 f53d4000 c10307b8 00000001 c10307b8 f5990860 c10307b8 00000001 c10332e5 f59908bc c12f4339 f59908bc f5990860 c11ef207 f4d33e00 f53d4000 [<f90bfc03>] ? snd_hdspm_probe+0x7e7/0x1166 [snd_hdspm] [<c10fedff>] ? __sysfs_add_one+0x1f/0xf0 [<c10307b8>] ? get_parent_ip+0x8/0x20 [<c10307b8>] ? get_parent_ip+0x8/0x20 [<c10307b8>] ? get_parent_ip+0x8/0x20 [<c10332e5>] ? add_preempt_count+0xa5/0xd0 [<c12f4339>] ? _raw_spin_lock_irqsave+0x19/0x40 [<c11ef207>] ? pm_runtime_enable+0x17/0x80 [<c1160172>] ? local_pci_probe+0x42/0xb0 [<c1161091>] ? pci_device_probe+0x61/0x80 [<c11e9587>] ? driver_probe_device+0x77/0x180 [<c11600f0>] ? pci_match_device+0xa0/0xc0 [<c11e9709>] ? __driver_attach+0x79/0x80 [<c11e9690>] ? __driver_attach+0x0/0x80 [<c11e8e32>] ? bus_for_each_dev+0x52/0x80 [<c11e9416>] ? driver_attach+0x16/0x20 [<c11e9690>] ? __driver_attach+0x0/0x80 [<c11e8771>] ? bus_add_driver+0xa1/0x220 [<c1160f20>] ? pci_device_remove+0x0/0xf0 [<c11e99a3>] ? driver_register+0x63/0x120 [<c11612bd>] ? __pci_register_driver+0x3d/0xb0 [<c1001132>] ? do_one_initcall+0x32/0x160 [<f90d6000>] ? alsa_card_hdspm_init+0x0/0x14 [snd_hdspm] [<c10676a9>] ? sys_init_module+0x99/0x1e0 [<c10ade3d>] ? sys_close+0x6d/0xc0 [<c1002c90>] ? sysenter_do_call+0x12/0x26 ---[ end trace 239f0661c558378b ]--- Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - Add updated firmware revision for AES32Adrian Knoth
In contrast to the PCIe version (RME AES), the PCI version (RME AES32) has a different firmware revision. This patch adds the missing PCI revision. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - AES32: Use define instead of hardcoded channel countAdrian Knoth
2011-02-25ALSA: emu10k1 - emu10k1_main.c remove one to many l's in the word.Justin P. Mattock
The patch below removes an extra "l" in the word. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-25ALSA: hda - patch_realtek.c remove one to many l's in the word.Justin P. Mattock
2011-02-24ALSA: hda - Add support for new IDT 92HD98 and 92HD99 codecsVitaliy Kulikov
Also fix number of 92HD87 pins to exclude invalid pins. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-24Merge branch 'fix/hda' into topic/hdaTakashi Iwai
2011-02-24ALSA: hda - 4930g add internal lfe sliderŁukasz Wojniłowicz
Lately I sent patch that switched lfe with side in mixer for acer-aspire-4930g. Then I connected 5.1 speaker system and noticed that lfe slider wasn't working and that old lfe slider worked. What I'm doing now is: - reverting old patch - adding internal lfe slider - removing side as it is superfluous (ALC888S-VC is 7.1 but in fact laptop can only do 5.1 and it is so in drivers for MS Windows) Signed-off-by: Łukasz Wojniłowicz <lukasz.wojnilowicz@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: HDA: Add ideapad quirk for two Dell machinesDavid Henningsson
These two Dell machines have been reported working well with the ideapad model. BugLink: http://bugs.launchpad.net/bugs/723676 Cc: stable@kernel.org Tested-by: David Chen <david.chen@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: HDA: Add a new Conexant codec 506e (20590)David Henningsson
Conexant 506e/20590 has the same graph as the rest of the 5066 family. BugLink: http://bugs.launchpad.net/bugs/723672 Cc: stable@kernel.org Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Fix lock/sync reporting on MADI and AES32Adrian Knoth
2011-02-23ALSA: hdspm - prevent reading unitialized stack memoryAdrian Knoth
Original patch by Dan Rosenberg <drosenberg@vsecurity.com> under commit e68d3b316ab7b02a074edc4f770e6a746390cb7d. I'm copying his text here: The SNDRV_HDSPM_IOCTL_GET_CONFIG_INFO ioctl in hdspm.c allow unprivileged users to read uninitialized kernel stack memory, because several fields of the hdspm_config struct declared on the stack are not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - fix sync check on AES32Adrian Knoth
Fredrik Lingvall <fredrik.lingvall@gmail.com> has discovered wrong frequency and sync detection on AES32. According to him, the provided patch fixes these issues. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Remove input selector on MADIfaceAdrian Knoth
In contrast to the RME MADI card, coax/optical selection on the MADIface is done via a physical switch located at the breakout box. Obviously, the driver cannot switch ports in software. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Fix DS/QS output channel mappings on RME MADI/MADIfaceAdrian Knoth
Caused by two typos, no output channel mappings were assigned for MADI/MADIface at double/quad speed. The channel mapping is indeed identical to the single speed mapping, the cards will simply use the first N channels. Signed-off-by: Florian Faber <faber@faberman.de> Signed-off-by: Fredrik Lingvall <fredrik.lingvall@gmail.com> Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Restrict channel count on RME AES/AES32Adrian Knoth
Without calling an appropriate rule, AES/AES32 cards would announce a theoretical channel count of 64 (HDSPM_MAX_CHANNELS), leading to the already known bug: [37422.640481] ------------[ cut here ]------------ [37422.640487] WARNING: at sound/pci/rme9652/hdspm.c:5449 snd_hdspm_ioctl+0x18f/0x202 [snd_hdspm]() [37422.640489] Hardware name: PRIMERGY RX100 S6 [37422.640490] BUG? (info->channel >= hdspm->max_channels_in) [37422.640492] Modules linked in: snd_hdspm snd_seq_midi ipmi_watchdog ipmi_poweroff ipmi_si ipmi_devintf ipmi_msghandler i2c_i801 e1000e snd_rawmidi power_meter [last unloaded: snd_hdspm] [37422.640501] Pid: 22231, comm: jackd Tainted: G D W 2.6.36-gentoo-r5 #5 [37422.640502] Call Trace: [37422.640508] [<ffffffff8103db3a>] warn_slowpath_common+0x80/0x98 [37422.640511] [<ffffffff8103dbe6>] warn_slowpath_fmt+0x41/0x43 [37422.640514] [<ffffffff81034306>] ? get_parent_ip+0x11/0x42 [37422.640518] [<ffffffffa0055763>] snd_hdspm_ioctl+0x18f/0x202 [snd_hdspm] [37422.640522] [<ffffffff813fd626>] snd_pcm_channel_info+0x73/0x7c [37422.640525] [<ffffffff814001e9>] snd_pcm_common_ioctl1+0x326/0xb01 [37422.640527] [<ffffffff81034306>] ? get_parent_ip+0x11/0x42 [37422.640531] [<ffffffff8105be6c>] ? __srcu_read_unlock+0x3b/0x59 [37422.640533] [<ffffffff81400bce>] snd_pcm_capture_ioctl1+0x20a/0x227 [37422.640537] [<ffffffff811e599c>] ? file_has_perm+0x90/0x9e [37422.640540] [<ffffffff81400c15>] snd_pcm_capture_ioctl+0x2a/0x2e [37422.640543] [<ffffffff810f2c69>] do_vfs_ioctl+0x404/0x453 [37422.640546] [<ffffffff810f2d09>] sys_ioctl+0x51/0x74 [37422.640549] [<ffffffff81002aab>] system_call_fastpath+0x16/0x1b [37422.640552] ---[ end trace 0cd919cd68118082 ]--- We already have all the right values in place, we simply have to inform the upper layers about this restriction. Note that snd_hdspm_hw_rule_rate_out_channels and snd_hdspm_hw_rule_rate_in_channels must not be called on AES32, because the channel count is always 16, no matter of the samplerate in use. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
