path: root/sound/pci/rme9652
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2010-12-01ALSA: hdsp - Add support for RPM io boxFlorian Faber
Add support for the RME HDSP RPM IO box. Changes have been made in the identification of the IO box and the neccessary controls have been added. Signed-off-by: Florian Faber <faberman@linuxproaudio.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-25ALSA: sound/pci/rme9652: prevent reading uninitialized stack memoryDan Rosenberg
The SNDRV_HDSP_IOCTL_GET_CONFIG_INFO and SNDRV_HDSP_IOCTL_GET_CONFIG_INFO ioctls in hdspm.c and hdsp.c allow unprivileged users to read uninitialized kernel stack memory, because several fields of the hdsp{m}_config_info structs declared on the stack are not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-08-12ALSA: hdsp - allow proc reporting with disconnected io boxTim Blechmann
the hdsp driver refuses to report any information via the proc interface, if the io box is not connected. with this patch, the content of the control and status registers is printed before the iobox check. Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10Merge branch 'topic/hdsp' into for-linusTakashi Iwai
* topic/hdsp: ALSA: hdsp - Add a comment about external firmwares for hdsp ALSA: hdsp: allow firmware loading from inside the kernel
2009-06-05ALSA: Clean up 64bit division functionsTakashi Iwai
Replace the house-made div64_32() with the standard div_u64*() functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-12ALSA: hdsp: allow firmware loading from inside the kernelRaphael Doursenaud
Allow the use of the FIRMWARE_IN_KERNEL option with hdsp cards and in-kernel driver. Also corrected a typo in the comment. Signed-off-by: Raphael Doursenaud <rdoursenaud@free.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-05ALSA: hdsp - Ignore MIDI and PCM events in interrupts until initializedTakashi Iwai
Ignore MIDI and PCM events in the interrupt handler until the device gets initialized properly. Otherwise you may get kernel panic by the access to uninitialized devices via hotplugging. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23ALSA: hdsp - whitespace cleanupTim Blechmann
Impact: remove trailing spaces Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23ALSA: hdsp - poll for ioboxTim Blechmann
sleeping for 2 seconds before checking for the iobox is not enough on some systems. this patch increases the timeout, but polls the card during that time. it thus speeds up the module loading when the card has already been initialized, while being more robust on systems, which require a higher timeout than the predefined 2 seconds. Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23Merge branch 'topic/hwdep-cleanup' into topic/hdspTakashi Iwai
2009-02-05ALSA: Remove superfluous hwdep opsTakashi Iwai
Remove NOP hwdep ops in sound drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-25Merge branch 'topic/udev-id-rename' into to-pushTakashi Iwai
2008-12-18ALSA: hda - Convert from takslet_hi_schedule() to tasklet_schedule()Takashi Iwai
Replace all tasklet_hi_schedule() callers with the normal tasklet_schedule(). The former often causes troubles with RT-kernels, and has actually no merit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-12ALSA: hdsp/hdspm: remove card->id from rawmidi device nameJaroslav Kysela
The card->id (card text identification) can be changed at runtime. It might be confusing to have old text identification in device name. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-09ALSA: hdsp: check for iobox and upload firmware during ioctlTim Blechmann
currently, the error message when trying to run hdspmixer or hdspconf if the breakout box is not connected is somehow misleading, since it asks the user to upload the firmware. this patch adds a test, whether the breakout box is connected and tries to upload the firmware in the case, that it is not present, e.g. because of power failures of the breakout box. [Minor coding-style fixes by tiwai] Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-09ALSA: HDSP: check for io box before uploading firmwareTim Blechmann
currently the hdsp driver tries to upload the firmware, even if the io box is not connected. this patch adds a check for the io box before trying to upload the firmware. thus instead of messages complaining about the fifo status and firmware loading failure, the driver gives a message that no multiface or digiface is connected. [A minor coding-style fix by tiwai] Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-25ALSA: Clean up SG-buffer helper functions and macrosTakashi Iwai
Clean up SG-buffer helper functions and macros. Helpers take substream as arguments now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: Kill snd_assert() in sound/pci/*Takashi Iwai
Kill snd_assert() in sound/pci/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] sound/pci/rme9652/hdspm.c: stop inlining largish static functionsDenys Vlasenko
sound/pci/rme9652/hdspm.c has unusually large number of static inline functions - 22. I looked through them and some of them seem to be too big to warrant inlining. This patch removes "inline" from these static functions (regardless of number of callsites - gcc nowadays auto-inlines statics with one callsite). Size difference on 32bit x86: text data bss dec hex filename 20437 2160 516 23113 5a49 linux-2.6-ALLYES/sound/pci/rme9652/hdspm.o 18036 2160 516 20712 50e8 linux-2.6.inline-ALLYES/sound/pci/rme9652/hdspm.o [coding fix by Takashi Iwai <tiwai@suse.de>] Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: hdspm.c fix returning void expression warningsHarvey Harrison
Just drop the returns. sound/pci/rme9652/hdspm.c:1031:3: warning: returning void-valued expression sound/pci/rme9652/hdspm.c:1033:3: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hdsp - RME 9632 fix at 192kHzRemy Bruno
The bits indicating SPDIF frequency in the status register are not the same for the 9632 than for the other cards, because it also supports 192kHz. A specific bitmask has thus been added (used in hdsp_spdif_sample_rate()). The 9632 does not seem to report external sample rates greater than 96kHz. In this case, the best seems to report spdif rate when autosync reference is spdif. This also required to move function hdsp_spdif_sample_rate(). Signed-off-by: Remy Bruno <remy.bruno@trinnov.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-22[ALSA] hdsp - Fix section mismatchTakashi Iwai
Removed invalid __devinit from hdsp_request_fw_loader() and snd_hwdep_create_hwdep() that aren't always init functions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] hdsp: make Multiface II work againAndreas Degert
This device has io_type == 1 (Multiface) and firmware_rev > 0xa (fixes regression from changeset 5326) Signed-off-by: Andreas Degert <ad@papyrus-gmbh.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound: fix rme9652 section mismatchRandy Dunlap
Fix section mismatch in hdsp: snd_hdsp_proc_init() can be called from an ioctl at any time. WARNING: vmlinux.o(.text+0x1089bc2): Section mismatch: reference to .init.text: (between 'snd_hdsp_create_alsa_devices' and 'snd_hdsp_free') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] pci - check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in the rest of PCI drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/pci: remove duplicated definesNicolas Kaiser
Remove duplicated defines. (From their use it looks like 'midiDataOutx are written to rather than read from.) Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hdsp - Fix zero divisionTakashi Iwai
Fix zero-division bug in the calculation dds offset. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] hdsp - Add support for latset RME9632 revisionsRemy Bruno
added support for the latest revision of the 9632 (and hopefully a few following ones). The DSP matrix was not working because of wrong identification of the card in this part of the code. Signed-off-by: Remy Bruno <remy.bruno@trinnov.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hdspm - Fix autosync bugRemy Bruno
* better report of speed mode change failures * autosync_ref control bugfix (was reporting pref_sync_ref instead) (changed HDSPM_AES32_AUTOSYNC_FROM_NONE value to comply with array indexing in snd_hdspm_info_autosync_ref()) * added support for master modes up to 192kHz (clock source control value was restricted up to 96kHz) Signed-off-by: Remy Bruno <remy.bruno@trinnov.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hdspm - Coding style fixesTakashi Iwai
Fix codes to follow more to the standard kernel coding style. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] rme9652 - Fix the hw_pointer checkTakashi Iwai
The negative check in hw_pointer callback doesn't work because the value is unsigned. Cast to int in the comparison to fix this. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] add MODULE_FIRMWARE entriesClemens Ladisch
Add MODULE_FIRMWARE() entries, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] hdsp - Add support for fine tuning of sample rate support to HDSP 9632Julian Cable
Add 'DDS Sample Rate Offset' control. Allows values in Hz from -5000 to +5000. The value is added to the nominal sample rate and written to the DDS register. Signed-off-by: Julian Cable <julian_cable@yahoo.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] hdspm - Support for Master mode of AES32 and recent MADIRemy Bruno
The current MADI driver was found not to completely work, at least on recent MADI cards (rev 204), in particular at 96kHz. This patch solves this: * Add support of DDS feature * Channel map fixed * Channel/rate rules fixed * DMA allocation fixed (need to alloc for all channels and not only for the used ones) Full support for AES32 master mode was added: * Add support of DDS feature * Channel map fixed * Channel/rate rules fixed Signed-off-by: Remy Bruno <remy.bruno@trinnov.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-03-06[ALSA] Add missing sysfs device assignment for ALSA PCI driversTakashi Iwai
Added the missing sysfs device assignment for ALSA PCI drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
