path: root/sound/pci/pcxhr
2009-03-24Merge branch 'topic/pcxhr' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/hwdep-cleanup' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-02-20ALSA: pcxhr.h replace signed one-bit bitfieldsHarvey Harrison
The usage and comments make it clear values of 1/0 were intended rather than -1/0 Noticed by sparse: sound/pci/pcxhr/pcxhr.h:100:20: error: dubious one-bit signed bitfield sound/pci/pcxhr/pcxhr.h:101:22: error: dubious one-bit signed bitfield sound/pci/pcxhr/pcxhr.h:102:24: error: dubious one-bit signed bitfield sound/pci/pcxhr/pcxhr.h:103:21: error: dubious one-bit signed bitfield sound/pci/pcxhr/pcxhr.h:104:25: error: dubious one-bit signed bitfield sound/pci/pcxhr/pcxhr.h:105:20: error: dubious one-bit signed bitfield Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Remove superfluous hwdep opsTakashi Iwai
Remove NOP hwdep ops in sound drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-31ALSA: pcxhr: fix trivial typoTim Blechmann
Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-23ALSA: pcxhr - add support for gpio ports and minor bug fixMarkus Bollinger
- add support for gpio ports (2 GPI, 2 GPO) of pcxhr stereo cards - minor bugfixes : allow setting clock to internal by the mixer even if there is no stream (but monitoring) Signed-off-by: Markus Bollinger <bollinger@digigram.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-25Merge branch 'topic/pcxhr-update' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/convert-tasklet' into to-pushTakashi Iwai
2008-12-20Merge branch 'topic/pcsp-fix' into topic/miscTakashi Iwai
2008-12-18ALSA: hda - Convert from takslet_hi_schedule() to tasklet_schedule()Takashi Iwai
Replace all tasklet_hi_schedule() callers with the normal tasklet_schedule(). The former often causes troubles with RT-kernels, and has actually no merit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-01ALSA: pcxhr - change firmware filenamesMarkus Bollinger
- compatibility issue : change firmware filenames the pcxhr driver version <= 1.0.18a does not work with new firmware > 1.0.17. Keep the old firmware files and add new firmware files with different names Signed-off-by: Markus Bollinger <bollinger@digigram.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-27ALSA: sound/pci/mixart/mixart.c: Add missing snd_card_freeJulia Lawall
The function snd_mixart_create creates a link between mgr and card that allows snd_mixart_free to free card as well. But if snd_mixart_create fails, then the link has not been created and card has to be freed explicitly. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S,S1; position p1,p2,p3; expression E,E1; type T,T1; expression *ptr != NULL; @@ ( if ((x@p1 = snd_card_new(...)) == NULL) S | x@p1 = snd_card_new(...); ) ... when != snd_card_free(...,(T)x,...) when != if (...) { <+... snd_card_free(...,(T)x,...) ...+> } when != true x == NULL || ... when != x = E when != E = (T)x when any ( if (x == NULL || ...) S1 | if@p2 (...) { ... when != snd_card_free(...,(T1)x,...) when != if (...) { <+... snd_card_free(...,(T1)x,...) ...+> } when != x = E1 when != E1 = (T1)x ( return \(0\|<+...x...+>\|ptr\); | return@p3 ...; ) } ) @ script:python @ p1 << r.p1; p3 << r.p3; @@ print "* file: %s snd_card_new: %s return: %s" % (p1[0].file,p1[0].line,p3[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-25ALSA: pcxhr - add support for pcxhr stereo sound cards (mixer part)Markus Bollinger
- add support for pcxhr stereo cards mixer controls - adjust tlv db scales to real dBu values - fix bug with monitoring volume control pcxhr_monitor_vol_put - do some cleanup Signed-off-by: Markus Bollinger <bollinger@digigram.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-25ALSA: pcxhr - add support for pcxhr stereo sound cards (firmware support)Markus Bollinger
- Add support for pcxhr stereo cards and their firmware - autorize sound cards without analog IO - do some cleanup Signed-off-by: Markus Bollinger <bollinger@digigram.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-25ALSA: pcxhr - add support for pcxhr stereo sound cards (core change)Markus Bollinger
- Add support for pcxhr stereo cards - minor bugfixes : period and buffer size consraints - fix PLL register values - do some clean up Signed-off-by: Markus Bollinger <bollinger@digigram.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-25ALSA: pcxhr - add support for pcxhr stereo sound cardsMarkus Bollinger
- Add support for pcxhr stereo cards - do some clean up Signed-off-by: Markus Bollinger <bollinger@digigram.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-15ALSA: sound/pci/pcxhr/pcxhr.c: introduce missing kfree and pci_disable_deviceJulia Lawall
Error handling code following a kzalloc should free the allocated data. The error handling code is adjusted to call pci_disable_device(pci); as well, as done later in the function The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,l; position p1,p2; expression *ptr != NULL; @@ ( if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S | x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S ) <... when != x when != if (...) { <+...x...+> } x->f = E ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/pci/*Takashi Iwai
Kill snd_assert() in sound/pci/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-10Fix a const pointer usage warning in the Digigram pcxhr soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram pcxhr compatible soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier is part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10pcxhr: treat firmware data as constDavid Woodhouse
2008-05-27[ALSA] Replace CONFIG_SND_DEBUG_DETECT with CONFIG_SND_DEBUG_VERBOSETakashi Iwai
Replace CONFIG_SND_DEBUG_DETECT with CONFIG_SND_DEBUG_VERBOSE to represent its meaning more better. This config isn't provided only for the detection but for more verbose debug prints in general. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/pci/pcxhr/pcxhr.c: fix warningsAndrew Morton
sparc64: sound/pci/pcxhr/pcxhr.c: In function `pcxhr_update_r_buffer': sound/pci/pcxhr/pcxhr.c:459: warning: cast to pointer from integer of different size sound/pci/pcxhr/pcxhr.c: In function `pcxhr_trigger_tasklet': sound/pci/pcxhr/pcxhr.c:628: warning: long int format, different type arg (arg 4) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/pci/pcxhr/pcxhr_core.c: fix printk warningAndrew Morton
sound/pci/pcxhr/pcxhr_core.c: In function `pcxhr_set_pipe_state': sound/pci/pcxhr/pcxhr_core.c:899: warning: long int format, different type arg (arg 4) suseconds_t is int on sparc64. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/pci: remove unused variableJulia Lawall
The variable is_capture is initialized but never used otherwise. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; identifier i; constant C; @@ ( extern T i; | - T i; <+... when != i - i = C; ...+> ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: pcxhr_core.c fix shadowed variable warningHarvey Harrison
Inner loop redeclares err with u32 rather than int, stupid fix here is to change the inner err to err2. sound/pci/pcxhr/pcxhr_core.c:1008:8: warning: symbol 'err' shadows an earlier one sound/pci/pcxhr/pcxhr_core.c:983:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] pci - check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in the rest of PCI drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] pcxhr - Fix dB level informationTakashi Iwai
Some dB level information is wrong in pcxhr driver according to the datasheet. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] pcxhr - Fix trigger start with non-linked streamsTakashi Iwai
The non-linked streams couldn't be started properly due to missing setting of stream->status. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] remove incorrect usage of SNDRV_PCM_INFO_SYNC_START and ↵Clemens Ladisch
snd_pcm_set_sync() Set the SNDRV_PCM_INFO_SYNC_START flag and the substream's sync ID (only) if the substream actually can be linked to another one. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] check for linked substreams of different cardsClemens Ladisch
It is possible to have linked substreams that belong to different cards and/or different drivers. This patch changes some drivers to make sure that they do not incorrectly try to handle substreams of a different card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] add MODULE_FIRMWARE entriesClemens Ladisch
Add MODULE_FIRMWARE() entries, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] pcxhr - Minor optimization in trigger callbackTakashi Iwai
Minor optimization in trigger start callback. This fixes a nasty compile warning, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Add dB scale information to pcxhr driverTakashi Iwai
Added the dB scale information to pcxhr driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] pcxhr - Fix a compiler warning on 64bit architecturesHenrik Kretzschmar
The patch fixes a conpile warning on 64bit architectures, caused by different sizes of size_t . Since size_t is unsigned I permited myself to cange the format, too. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] sound/pci/: remove duplicate #include'sAdrian Bunk
There's no reason for #include'ing linux/dma-mapping.h more than once. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] pcxhr - Fix the crash with REV01 boardMarkus Bollinger
On a new board revision for pcxhr boards, the PCXHR_CHIPSC_GPI_USERI bit is no more supported. The cards concerned have a REV01 in their PCI ID. As the current driver tests this bit and does not load the first Xilinx binary when it's 1, the card will crash on Xilinx access over PCI. (the PCI will freeze ....) The fix (fix to version 1.0.11rc4) works for both REV00 and REV01 cards. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
