We forgot to set the error code on this error path.
Fixes: 4a23fc8cc068 ("ALSA: lx6464es: add error handling for pci_ioremap_bar")
When pci_ioremap_bar fails, the lack of error-handling code may
cause unexpected results.
This patch adds error-handling code after calling pci_ioremap_bar.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
Make this const as it is only used during a copy operation.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Declare snd_kcontrol_new structures as const as they are only passed as
an argument to the function snd_ctl_new1. This argument is of type
const, so snd_kcontrol_new structures having the same property can be
made const too.
Done using Coccinelle:
@r1 disable optional_qualifier @
identifier i;
position p;
static struct snd_kcontrol_new i@p = {...};
@ok1@
identifier r1.i;
position p;
expression e1;
snd_ctl_new1(&i@p,e1)
@bad@
position p!={r1.p,ok1.p};
identifier r1.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r1.i;
+const
struct snd_kcontrol_new i;
Check for snd_pcm_ops structures that are only stored in the ops field of a
snd_soc_platform_driver structure or passed as the third argument to
snd_pcm_set_ops. The corresponding field or parameter is declared const,
so snd_pcm_ops structures that have this property can be declared as const
also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_pcm_ops i@p = { ... };
@ok1@
identifier r.i;
struct snd_soc_platform_driver e;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
snd_pcm_set_ops(e1, e2, &i@p)
@bad@
position p != {r.p,ok1.p,ok2.p};
identifier r.i;
struct snd_pcm_ops e;
e@i@p
identifier r.i;
static
+const
struct snd_pcm_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Use the new snd_pcm_hw_constraint_single() helper function instead of
calling snd_pcm_hw_constraint_minmax() with the same value for min and max
to install a constraint that limits the possible configuration values to a
single value. Using snd_pcm_hw_constraint_single() makes the indented
result clearer.
Spotted by sparse:
sound/pci/lx6464es/lx6464es.c:415:47: warning: Using plain integer as NULL pointer
sound/pci/lx6464es/lx6464es.c:417:48: warning: Using plain integer as NULL pointer
PCI_DEVICE() macro itself defines SSID entries while we override them
after that. Replace with a more appropriate macro, PCI_DEVICE_SUB()
to define all ID values properly.
Spotted by sparse:
sound/pci/lx6464es/lx6464es.c:60:11: warning: Initializer entry defined twice
sound/pci/lx6464es/lx6464es.c:61:12: also defined here
sound/pci/lx6464es/lx6464es.c:64:11: warning: Initializer entry defined twice
sound/pci/lx6464es/lx6464es.c:65:12: also defined here
Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
pci_dma_supported@p ( id, ...)
pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
when != pci_get_drvdata ( id )
when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com>
Like the other previous changes, this patch for lx6464es takes the
same strategy for converting to nonatomic PCM ops: replacing spinlock
with mutex, converting the irq tasklet to the threaded irq, and
merging the trigger tasklets back to the trigger callback.
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Convert with dev_err() and co from snd_printk(), etc.
Also remove superfluous snd_card_set_dev() calls.
The warnings are really harmless but annoying. Since they are only
about debug prints, and it's at most 32bit DMA, let's just cast to
unsigned long.
sound/pci/lx6464es/lx6464es.c:457:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
sound/pci/lx6464es/lx_core.c:1195:21: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
As drvdata is cleared to NULL at probe failure or at removal by the
driver core, we don't have to call pci_set_drvdata(pci, NULL) any
longer in each driver.
The only remaining pci_set_drvdata(NULL) is in azx_firmware_cb() in
hda_intel.c. Since this function itself releases the card instance,
we need to clear drvdata here as well, so that it won't be released
doubly in the remove callback.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44541
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
each device has a unique mac address, which can be used to distinguish
multiple devices in the same machine. we therefore include the full mac
address in the device shortname and the last 6 bytes in the device id.
Signed-off-by: Tim Blechmann <tim@klingt.org>
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
converts a 1 bit signed bitfield to an unsigned.
Reported-by: Dr. David Alan Gilbert <linux@treblig.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
as long as the io channel number is not set by the driver, the card
is not visible from the ethersound network
We're about to make DMA_nnBIT_MASK() emit `deprecated' warnings. Convert the
remaining stragglers which are visible to the x86_64 build.
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Eric Moore <Eric.Moore@lsil.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: Yi Zou <yi.zou@intel.com>
trivial patch to support the alsa module parameters `index', `id'
and `enable'
Use snd_card_create() instead of the obsoleted snd_card_new().
prototype of a driver for the digigram lx6464es 64 channel ethersound
interface.
